PDA
View Full Version : Car Nitro & Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. need to buy .28 picco eng
  2. New Video, modified Sirio CL7B
  3. Engine Rebuild O.S. 30
  4. NEED SOME CLARIFICATION
  5. Looking for all the used OS RG 21 parts motors!
  6. I need some help picking a engine
  7. Spark plugs for trx 3.3!!
  8. Clutch Bearings
  9. Axial 32
  10. will it ever work????
  11. OS 18 Over Heating
  12. Rebuilding Kyosho GS11
  13. Glow Plug length
  14. RB S3 or S5 combo
  15. Needle adjustment on Infinity Samurai 528
  16. Pre-detonation ????
  17. STS .30 over heating
  18. How long to bearings generally last for?
  19. 5 year old Trx. 15
  20. axial turbo button for .32
  21. need help with the engine plz
  22. Good pipe?
  23. 2nd Generation Byrons
  24. think my go is quicker
  25. GRP 28 promo pack or no promo pack?
  26. LRP .28 and dirt is badtimes!
  27. Nova Plus 28 7 T
  28. MOVED: Where are these Schumacher .28 Picco cars??
  29. Lrp 28 truggy VS Dynamite Platinum 28 non Pull
  30. picco p3 ps v truggy
  31. Factory setting for a Ninja .12 on road engine please
  32. hpi t 3.0 and g3.0 rebuild kit??
  33. Factory settings for picco p3
  34. Question about Engine Mods
  35. Quick rotostart Question
  36. go 5port turbo dyno
  37. What does a carby washer do?
  38. OFNA Hyper .21 Question.....
  39. picco p3+losi 8t
  40. Engine shutting off
  41. TOP engine T528XSP settings
  42. Megatech Q16 series engine help
  43. Need Help wit Nitro Car
  44. Let's talk temps.....
  45. 1/8th Buggy Motor Questions
  46. Sealing an engine
  47. Question on ceramic TKO front crank bearing
  48. Selecting a tuned pipe
  49. kings at all as to the BrandMystery engine
  50. help picking out a motor for my rc8
  51. clutch for a 28zx
  52. 4-Tec 2.5 Keeps Dying
  53. OS 18TM problem
  54. Mugen now going with OS
  55. OS 11L Rotary Carb on OS .21TM?
  56. turning axe rossi cobra into mamba
  57. Engine Help!!!
  58. Nitro %'s
  59. picco rebuild
  60. ? ? ?-Loose carb Force .28? ? ?
  61. OS .18tm and tz
  62. RB engine Recommendations
  63. GAS engine temps
  64. looking for an Ofna part
  65. Mamba Axe Rossi 0.21 Off Road engine....
  66. Picco .28 question????
  67. Sirio .21 CL7B (Photos)
  68. Os .18 tuning trouble
  69. any one ported t3.0??
  70. Go .21 R-spec (Photos)
  71. RB Crankshafts
  72. Team Orion CRF Rev. 21 - What Pipe?
  73. Starter help!
  74. Picco P3 Turbo head to shim or not to shim?
  75. What engine?
  76. os 18 tm Leak (I guess)
  77. what is the difference on engines made in italy like novarrossi and the ones in the usa like axial
  78. HPI G3.0 engine
  79. Walbro carb 813
  80. Crank bearing size for Picco .28 P3?
  81. never owned a nitro car help!!!!!
  82. OS 18 TZ Question!!
  83. OS .21 sleeve......
  84. STS .30 specs
  85. Mach 427 Tuning/Break in Issues
  86. TRX 3.3 glow plug's what do you run?
  87. IGT engine Question
  88. LRP Z.28r Spec 3 non pull-start
  89. Nothing
  90. Trinity " Draked" .12
  91. ninja mr21-r01a
  92. vspec 21 problem
  93. This is why I seal every motor
  94. gas engine carb help
  95. How do you remove bearings
  96. Kyosho GXR18 engine
  97. OS 18TZ EB Mod Worth it??
  98. what should i get
  99. OS 18tz
  100. axe rossi cobra x1 evo with broken conrod
  101. Buku pipe on a .28jpx?
  102. fuel not being fed in carb
  103. Picco P3 drag motor or the Jammin motor
  104. What mod to get
  105. replacement engine for MMGT 3.0
  106. Ceramic Bearings??
  107. trx engine questions
  108. HP Chart
  109. Picco Plug Difference
  110. New Engine in Stampede
  111. Confused about getting a big or small block engine?
  112. Tuning Assistance Needed
  113. replacement cooling head
  114. What Pipe
  115. yet another fuel question
  116. Electric Starter or Pullstart?
  117. Difference betwwen clutch bells?
  118. Piston cuts
  119. Question for RB owners
  120. Idle problems
  121. problems with hpi out law
  122. Front bearing leaking?
  123. trx pro.15
  124. sts .12 eco
  125. [HELP] Rip cords
  126. maxpower xrs .21
  127. SH engine?
  128. Sirio CL7B STI video !!
  129. Burbling at low rpm, too rich?
  130. lrp z18s
  131. Bump Box Break In......
  132. Ninja 28 Stock HSN LSN settings?
  133. VENOM Electronics?????
  134. Trying to break in. Not Working out
  135. traxxas .15 low end hesitation
  136. so have we decided on the best break in method yet?
  137. How much oil should an engine leak?
  138. whitch engine is right for me???
  139. engine dissasembly
  140. When will my TRX 3.3 Die?!
  141. When to rebuild?
  142. axe cobra,long stroke?
  143. OPS SFV21B
  144. Losi Stock tune pipe
  145. O.S VG 21 stalls at half tank
  146. Exhaust Modifying Question.
  147. Boggy engine after oiling air filter?
  148. old model t maxx dies after fuel tank is less then half
  149. big blocks for tmaxx 3.3
  150. below $200 .21??
  151. GoTech .21R 3+2 Port
  152. The Beastly OS 28 Thread !!!
  153. OS .18 TM rebuild
  154. where to buy an engine???
  155. Picco .28 Turbo Engine Question??????????
  156. OS18 CVR
  157. Tuning Help needed
  158. OS 15 CV-R Rebuild
  159. Diablo .18 Parts?
  160. Trinity Picco .15 XP
  161. Engine Imitation?
  162. [ask] engine setting
  163. os 21
  164. Picco .26 Parts
  165. How to heat up engine in the field?
  166. AE 15 manifold
  167. Glow plug recommendations
  168. Kyosho Sandmaster Upgrade
  169. Axial turbo button head??
  170. hyper 21?
  171. Help me out quick!!!
  172. want to replace in engine in duratrax warhead.
  173. P3 lockup at TDC? Hey Supertib!
  174. OFNA Picco .21B 3-Port Nitro Engine
  175. Nooby Help
  176. Kyosho Sandmaster
  177. 053 pipe on a Jammin .28?
  178. Best place to check engine temps??
  179. swap to roto on os 21
  180. boggieness at the start?
  181. Custom Exhaust Question
  182. Flywheel Help
  183. Axial Engines
  184. metal cone inside exhaust?
  185. RB C6BB
  186. Picco P-7r evo II or MR Ninja MR21 B01A
  187. Replace leaking Ninja Front Bearing with Ninja bearing or other brand?
  188. Noob engine consistancy
  189. 4.6HO issue
  190. Picco P9R EVO 2 X-Dyno results
  191. .28 engine advice?
  192. Converting to Pneumatic (Air Powered)
  193. Thinking of sending my Ninja .28 off to ABMods to get modded?
  194. trx .15 pro last chance
  195. Hey Supertib
  196. Beginners Bad luck, engine popping.....
  197. High Speed Needle Help
  198. ??? Novarossi 528x factory settings???
  199. picco p3 .28shims
  200. sirio 15 tup af engine any good
  201. pro.15 getting hot
  202. Os .18 cv-r
  203. engine help
  204. OPS Y2K6 BUGGY MOTOR
  205. GRP .28 Issue
  206. Nova Rossi 528x help
  207. Leaking head gasket
  208. trx .15 pro
  209. engin keeps dying after full throttle
  210. Engine timing profiles.
  211. nitro country store?
  212. axe rossi cobra
  213. engine break-in
  214. car stops quickly
  215. STS S21T
  216. Axial .28 1S pull starter slipping
  217. how hot is to hot
  218. Ninja 21 BO1A
  219. How do I find glow plugs that fit, the one I used is discontinued.
  220. TRX 3.3 vs. OS 18 CVR
  221. Broken Rod
  222. NOVA 6/B "2000"
  223. Quick Fuel Question.
  224. Engine Break-in like the pros
  225. FR .27 with XTM carb won't stay running/hard to start
  226. Picco P3 .28 which one did I get?
  227. WHAT IS THE BEST RB MOTOR TO GET?
  228. modded my 3.3 *** broke the rod
  229. os 21tm on a redcat tornado
  230. base carb setting for os 21tm???
  231. Dynamite 086 for Ninja .28?
  232. BAD GO TECH ENGINE EXPERIENCES??????
  233. found the air leak on carb slide!!!
  234. HELP!!!!! motor rebuild
  235. OPS CAR MOTORS ARE BACK IN THE USA
  236. Nitro Engine tuning Dials
  237. tuned pipe for any .28 engine
  238. Dynamite 086 vs TTR 2039 vs ?? for Modded V-SPEC
  239. Differences between a 5CXP engine and a 7CXP engine?
  240. Go .21 3 port R-spec
  241. Factory Needle Settings For O.S. 28xz
  242. how long do engines last?
  243. LRP .28 Spec 3 fuel consumption?
  244. CAN YOU DRILL START A 24.7
  245. need help head sims for a os .21vg
  246. plz help me experts
  247. Engine Seize!! Please help
  248. STARTING A MAMMOTH
  249. Tuning Sportwerks .26
  250. Hey I dont know alot about cooling heads but I need another.
