PDA
View Full Version : Car Nitro & Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34
  1. 10% to 20%
  2. 2 trucks 2 fuels argh I want 1 fuel
  3. SMARTECH .27 CXP....HELP PLEASE
  4. Needle settings on Collari?
  5. Glow Plug Question
  6. Any Body? Custom Ideas?
  7. Engine Porting, Force .26
  8. Which needle is this?
  9. .21 BB engine
  10. magnum fuel
  11. Slide carb or rotary carb ???
  12. Tuned pipe selection
  13. New Engine and Problems
  14. fantom 12 help now!
  15. PulseJet powered RC car?
  16. glow plug
  17. Engine Mods?
  18. SMT engine - clutch bell (gear ratio)
  19. whats the best pipe that will fit this engine?
  20. .18 CV-R questions
  21. new engine
  22. Traxxas Revo Engine
  23. .70tt engine
  24. *NEW* O.S. MAX .30 VG (P) BIG BLOCK
  25. Power
  26. tungsten carbide engine parts
  27. HPI 15 carb trouble
  28. Nitrous for cars
  29. HPI T-15 into an RS4
  30. O.S. .18 CVR trouble
  31. RB TM 323 starting options
  32. Clutch spring
  33. Questions on rebuilding
  34. Opinions on the new Thunder Tiger Pro 12/15x engine.
  35. Any Novarossi experts in the house I need advice
  36. SH .28 run in advice?
  37. when removing shims...
  38. Does anyone elses o.s18`s not hold a tune very well?
  39. sirio .23 backplate
  40. what size tank?
  41. Best Fuel for OS 18 TM?
  42. Glow plug heat ranges?
  43. Prime fuel lines??
  44. Cant get my motor to keep running
  45. SMT temp? (Smartech)
  46. compression checks?
  47. stalling out on bumpy ground
  48. Do anyone have the manual to the Kyosho GS-21 engine
  49. need help w/FR.18 clutch assembly
  50. HPI .15 Engine ???
  51. My engine just shut down
  52. Motors?
  53. Sucked sand
  54. motor dies on the ground
  55. .21 P5
  56. Changing a head button? How?
  57. Adding some pep to my OS .15CV-R, converting to turbo plug!
  58. what is the biggest and best for hpi savage 25
  59. Tuned PiPe HeLP> BuYing
  60. BIGGER COOLING HEAD FOR A SIRIO .27
  61. Is It ME?? PICCO'S .26
  62. Opinion's please
  63. acociated engine!
  64. collari 30
  65. Max temp!!
  66. Revo Engine
  67. Opinions on Mach 26 vs. XTM 247 Pro
  68. xtm 24.7
  69. Team Orion Wasp .18 Any Good?
  70. Breaking in an OS 18
  71. how dis clutch work
  72. tuned pipe and exhaust header
  73. What I learned today...
  74. pull start help
  75. Horizon Hobby Mach .26
  76. buggy enngine
  77. clutch
  78. Team Orion Wasp .18
  79. TRX 2.5-R BREAK IN
  80. nitro fuel
  81. carb adaptor to fit o.s carb on a picco
  82. SH .21 (#PT2004XB) vs OS V-SPEC
  83. Will this engine fit on my Hpi rs4 evo??
  84. Clutch Springs for OS VZB V-SPEC
  85. Gotta replace ball bearings
  86. How to Brake in a hpi MT2
  87. cvec .15 or .21 pipe on a sirio 18 engine
  88. getting my old engine to work
  89. clutch
  90. starting a pull start motor with a box
  91. nitro evader st air leak
  92. carb settings for a duratrax Velocity .15 engine
  93. Blue Thunder. What's up?
  94. how to break in engine?
  95. engine keeps shutting down
  96. sealing engines
  97. wasp 28
  98. revo engine
  99. converting pull start to roto start
  100. Thunder Tiger 21 Need Help
  101. help w/cvr 18 mount plz
  102. engine stalling problem
  103. WASP in trouble
  104. Parts for Hyper 8 port race
  105. savage S25 help
  106. .26 or .27
  107. Piston and sleeve for .18 sirio?
  108. RB.12 stalls at midrange
  109. motor problem
  110. Anyone knows how to fix a cracked Crankcase?
  111. is the o.s. cv .15 good?
  112. Whitch pipe?
  113. SH .12 Engine?
  114. Runing out of gas?
  115. cylender head
  116. Picco .27
  117. Need Help With DIABLO.28 MOTOR
  118. .12 for XTM X-Cell Kit version?
  119. engine breakin/tuning quetions.
  120. hpi starting problems
  121. XTM MAMMOTH QUESTION
  122. Convert to nonpullstart???
  123. trx .15 modification
  124. 18ss high speed needle issue
  125. Connecting Rod broke
  126. fuel not constant in carb?
  127. Favorite Brand of Nitro?
  128. V SPEC TROUBLES
  129. break in
  130. SIRIO.27 RACER shim question
  131. carb question
  132. engine problem/solution URGENT
  133. hi neeeed engine help nOw
  134. A Good Pipe
  135. fastest/cheapest
  136. new nova rossi engine where to buy
  137. Where to buy RB concept .12 parts
  138. os engines
  139. Drop in Engine for Rusty
  140. MOST POWERFULL ENGINE ON THE WORLD
  141. engine horror , please help
  142. best drop in engine for the t-maxx 2.5
  143. best drop in engine for the t-maxx 2.5
  144. Best pipe for OS .21 RG
  145. best engine for t maxx?
  146. Bergonzoni piston rings 23cc Boss wher do i get them
  147. i want a new motor 4 my rush evo
  148. is this a good nitro for $110
  149. engine running very loud
  150. Crono RS5 base settings?
  151. .15 traxxass engine porting tips and tune
  152. RB Concept Engine
  153. best engine 4 nitro rustler
  154. Carbon fiber pipe
  155. T-Maxx Problems
  156. Air Leak???
  157. Ofna motors
  158. glowplug life?
  159. New engine for the yokomo?
  160. Drive Hub from OS 18 cvr
  161. hot bodies 26?? 6 port
  162. drooping in a new engine
  163. Truckzilla
  164. My Collari .30 RotoStart Mod
  165. Help with the SCREWS!!
  166. need help with a GS21R engine
  167. O.S. 18 leaking bearing
  168. collari 32
  169. Can someone help me find a Picco .27 w/o pullstart. pn 51231
  170. TMAXX W/.21 WASP
  171. O.S 18 tm crankshaft+compared to trx2.5
  172. New engine for XTM Baja outlaw
  173. Tuning thunger tiger engine
  174. 12ss piston
  175. High Rev Crackling?
  176. Holly! savage!
  177. Five questions about the O.S. .18 CV-RX, Please help!
  178. Glow plug list
  179. sh .28 for $119.54
  180. Pipe for Wasp .18
  181. Heat cycling?
  182. Problems with delta 15 engine
  183. flywheel
  184. Death of the mighty trx 2.5
  185. looking for JP Fx b8t
  186. Nitro full in Israel
  187. TRINITY SIRIO .18 ON AN RS4 OR TC3
  188. big block for my TMAXX
  189. engine rebuild signs?
  190. SH .28 engine?
  191. clutches and starting problems
  192. need new carb
  193. TNX Nitro won't start -- Piston??
  194. Crono rs5
  195. Nitro WIll not start
  196. Roto/Shaft start backplates
  197. Nito Star S-25 tuning issues.
  198. throttle linkage
  199. SH .21 pro buggy engine
  200. Picco 26 piston and sleeve or 27 piston and sleeve
  201. New Zenoah 260RC cannot start!
  202. Need a one-way for my Collari .30 Rotostart
  203. Deleting the one way bearing. Good or bad?
  204. Sand in my carb
  205. a little glow plug cleaning question
  206. engine stalling
  207. Ofna Ultra LX Comp Engine Tuning
  208. GX-15.. Want A Better Engine
  209. Help with new OS .18 on CEN MT2
  210. .15, side exit, rotary carb, pullstart, threaded crank
  211. Engine comparisons
  212. Help with CEN engine that wont run without glow heater attached!
  213. .21os v-spec bearing size?
  214. hyper 21
  215. OFNA Picco .26 MAX
  216. HELP!! another smartech engine problem
  217. SH .28 Shattered piston and shaft? Why?
  218. cryo an engine to reduce wear?
  219. Kyosho GS11 info needed
  220. XTM .15 Head gasket
  221. what do you guys use to clean your r/c engine?
  222. engine tuning...
  223. sirio s30
  224. OS VZB V-Spec
  225. Budget Engine Upgrade for bashing RC10GT.
  226. Nitro truck tuning? am i gonna blow the engine?
  227. engine break in please help
  228. weird acting motor
  229. rev limiter on nitro engines?
  230. New engine help needed
  231. Dyno Testing !!
  232. OS 26FS
  233. Top 421B Which Plug for30% Cant keep it running
  234. mach .15 eratic idleing
  235. help needed with new engine
  236. TORQ 12 Engine
  237. engine pinching?
  238. Warm engine won't re-start?
  239. Where to buy black pixi
  240. New engine suggestions?
  241. picco 27 pipe
  242. O.S MAX RZ online manual ?
  243. Cant get my smartech .15 to Idle
  244. Engine mounts which ones?
  245. HPI Engine Cutting Out
  246. 2nd day using new nitro tc3: blown engine
  247. Any guide for troubleshooting engine?
  248. New engine trouble
  249. OS 4 strokes for sale
  250. OS .15 CV-RX has gotten hard to start
