PDA
View Full Version : Car Nitro & Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. HYPER .21 MODS
  2. 21 vs. 26 vs. 28 in a Truggy...
  3. carbon, rulon, or what other material
  4. Picco .26 vs. Picco .28 for my Revo
  5. XTM 24.7 rebuilt, but no go :(
  6. dynamite engines good or bad?
  7. Motor to put in my Savage X SS?
  8. OS 18 Exhaust Timing and Head Shims
  9. Picco Engine
  10. wheelies
  11. TRAXXAS 3.3 CARB QUESTIONS
  12. EXHAUST QUESTION!!!!!!!!!!
  13. jammin.21
  14. LSN and HSN settings on ????????
  15. engine.........
  16. What engine is this exactly????
  17. whbw
  18. need help
  19. .12 engines
  20. tamiya fs-18
  21. Picco .26 piston/sleeve
  22. is there any good .32 motors.
  23. plane engine in truck
  24. Yay! or Nay! engine
  25. Go tech .25 and .28
  26. OS 12 CV-X, is a good engine?
  27. Engine Smoke
  28. WHAT TO USE TO FIX A LEAKY BACKPLATE?
  29. Pass the pipe
  30. i stripped my starting shaft on my axial.. (i think) plz help
  31. Brand new OS .15 CV-X, having trouble breaking it in...
  32. Extraction cilynder and bearing of engine ofna?
  33. Problem wiht engine Ofna Force .32 !!!
  34. Cheapest Place for STS D30M?
  35. STS ENGINES?
  36. how mant tanks should i run rich?
  37. Roto start for picco 26 max
  38. can it be saved.
  39. RTV High temp seal
  40. Problem with OSmax .15cv clutch
  41. What engine?????
  42. Whats the Difference
  43. leak from carb around lsn?
  44. Alcohol engine?
  45. os max vzb vspec carb restriction?
  46. os 30 vg for lst2
  47. Ninja .28 Glow Plug Question
  48. Engine tuning help, please!
  49. LRP 28 Vs Picco P3 28 best bang for buck...(look inside)
  50. Os 18cv-r wih silver head??
  51. HOW CAN I POWER PORT THE SAVAGE ENGINE?
  52. which engine is this?
  53. drill instead of roto
  54. Changing from an old Traxxas Pro .15 to a new Pro .15 have a few Q's w/ pics
  55. i should have listened
  56. engines
  57. Beat a dead horse one more time.
  58. Go Tech Engine question
  59. Mach 26 vs Picco P3 26
  60. Can anyone identify this engine ??
  61. leo engines?
  62. O.S. V-Spec EB Mod GOOD OR BAD?
  63. Picco p3 .26 cutting off issue
  64. axial 32 front bearing leak
  65. How can you tell if a car is broken in just by it idling?
  66. Engine
  67. Nitro motor propblems (2.5r) Help!
  68. NEW Ninja .28 Leaking!!
  69. Engine Question?
  70. pipe for osmax vzb v-spec .21???
  71. Sportwerks V2 carb?
  72. nitro evader won't start???
  73. where to buy picco owb
  74. Best .18 engines
  75. STS .30 bites the dust, what next.
  76. standard mixture settings for a X15 in a Schumacher Riot
  77. Piston/Con-rod removal, need help!
  78. power output of abmods stage 2 sts 30.
  79. length of sts 30 con rod
  80. sts 30 OWB
  81. fuel issue
  82. Savage X Engine Upgrade Specs
  83. Brand new Picco red dot binding
  84. Proper Nitro Engine Break-In
  85. find hp of your engine w/o dyno
  86. Air bubbles coming in my fuel line from Carb.
  87. picco .26 outlap bumpstart backplate?
  88. nitro engine help
  89. Looking for a really good $150 .21 buggy motor!
  90. New Truggy.. What motor to get?
  91. AB Mods rocks it !!! X-Dyno results
  92. If you ruin an engine do you have to buy a whole new one?
  93. Maxx mods Picco 28 dyno testing
  94. glow plugs go out halfway through each run?
  95. 15cxp 2speed problem
  96. ninja .28 info
  97. engine for LX Comp
  98. sirio .23
  99. Best pipe to go w/ a Savage, Axial 28, and a lot of bashing
  100. Sportwerks v2 .26 opinions
  101. 3.3 Engine Problems.
  102. wanna know??????????
  103. How to shorten a crankshaft
  104. OS 12TR question????
  105. Superchargers
  106. can a 3+1 port become a 6+1 port?
  107. Can't get my VZB V-SPEC engine dialed in....
  108. OS 28 vs. Ninja 28
  109. CHEAPEST BB MOTOR?
  110. Mach 427 opinions
  111. this is serious....?
  112. 4s basher
  113. HPI Nitro Star K5.9 - Now With Pics!
  114. Please help me identify this engine!
  115. unknown engine size
  116. glow plug question about humidity
  117. Got a OS xz28 truggy engine
  118. New engine help
  119. Rebuilding an engine
  120. flywheel?
  121. Engine?
  122. car filter
  123. BEST RC TRUGGY ENGINE UNDER $200 dollors
  124. will it fit
  125. Weston 5.8 (Webra .36 )
  126. OS CZ JUNK?
  127. Motor need what is a good one .21!
  128. Best Glow Plug ?
  129. kyosho .28 stock
  130. Picco .21 tuning help
  131. rb ws711 stock needle settings
  132. noverossi
  133. T-2050 O.S. pipe will be good w/ C6BB?
  134. extender
  135. 3.3 trx help
  136. RB C6BB,RBTM 928: Much difference?
  137. Axial.28 spec or STS .28
  138. engine suggestion for team magic g4
  139. running temp
  140. Nitro engine basics
  141. Can't get the tune right, help
  142. Engine idle speed revs out to full throttle after starting. Help please!!
  143. is there a longer con. rod you can get for the sts30?
  144. XR80 Mid-range adjustment
  145. Want a bit more "Umph" from your engine?
  146. Help identifying motor
  147. needle settingins for sts 30 and best break in method.
  148. oil in fuel ?
  149. Pipe for Picco 28??
  150. highest quality 20% nitro fuel?
  151. Super Tigre Help!
  152. OS CZ quandry
  153. replacing carberator on the traxxas 2.5
  154. oil weights for losi 8-b
  155. Force .26 engine one way bearing
  156. HELP DISSION ON NEW ENGINE FOR MY TEAM MAGIC G4
  157. Need alittle engine education
  158. OS CZ starter spring
  159. Pullstart Vs. Non-pullstart
  160. is my rb 9886 tuned pipe ok on an axial .28rr
  161. the LRP spec 3 will still not idle
  162. CEN SH .28 motor
  163. Different kind of "gas" engine!
  164. Updated AB Mods modified JLR .12 dyno results
  165. when I remove the glow igniter engine dies
  166. no fuel to carburator
  167. low end pipe for modded sts 30.
  168. temp issues
  169. help on my 2.5r eangine
  170. Variable top speed problem
  171. xtm 24.7 in revo
  172. LRP 28 Spec 3 or OS 28XZ
  173. I WANT TO FLY!!!!!!!!!!
  174. Help for a newbe.
  175. .28 vs .32 shopping around
  176. new truggy engine
  177. fuel stabilizers?
  178. help
  179. Crankshaft for lrp z.28r spec3 pullstart
  180. Associated LRP32802 Z.28R Spec 3 w/PS
  181. OS 28X2 Truggy, Opinions/Experience
  182. used to think byrons fuel was the best,
  183. NEW* D28M 5-PORT COMPETITION TRUGGY ENGINE
  184. best motor for traxxas revo 2.5
  185. Gen I STS .30 Versus The Newer Gen !! Questions
  186. converting a OS cv-r to a cv-rx, whats needed?
  187. vspec popping noises
  188. clutch shoe spacers
  189. first gasser
  190. Please Help Me
  191. Is there a difference between the axial green and gray
  192. What kind of engine is that!! PLS HELP!!
  193. ninja troubles
  194. new engine recomendations
  195. LRP 28R right pipe help?!
  196. lrp z.28 spec 3 or picco .28 p3 for aftershock
  197. LRP 28 Spec 3 Truggy Version Pipe
  198. cleaning bearings
  199. Is this piston toast?
  200. 20% or 30% fuel
  201. How much priming question?
  202. Cooling heads
  203. JAMMIN' JPX .28 ENGINE BREAK-IN.... ANYONE??
  204. Wasp .28
  205. Thunder tiger .28 pro ajustments tuning ???
  206. Advice setting up my axial carb on STS .30
  207. help with Sirio .27
  208. Tuning Questions
  209. Losi 427 wont start.
  210. ofna macstar .28 break in/fuel question
  211. sportwerks carb on a sts .30
  212. Best performance engine for your buggy regardless of price
  213. CEN Magnum
  214. glow plugs for an LRP z.28 spec 3
  215. nitro engine run too cool??
  216. rossi cobra,vspec or p7r
  217. is this a decent deal?
  218. Sportwerks .26 V2 PS SG
  219. New picco .28 truggy engine
  220. LRP CARB ON MACH 427
  221. friggin awesome
  222. Engine bogs after down / dies after wide open run
  223. broken conrods common?
  224. ABC or Ringed
  225. vspec "runs on" off throttle
  226. Hot Start Problems
  227. GXR28 problems
  228. picco .12 jlr
  229. Problem with Ninja .21 BO1A
  230. USING A DEGREE WHEEL?
  231. Sirio Evo 3 STI
  232. Port questions
  233. Acme Condor Engine
  234. ninja MR 21 C7 plug cold medium hot ????
  235. LRP Z.28 Spec 3, which clutch?
  236. Drill plate or electric starter for 7 CXP engine
  237. looking for rd logics dual stinger pipe.
  238. engine help
  239. os .12cv
  240. Novarossi P5X dyno graph
  241. trx 3.3 engine
  242. Best "Budget" engine?
  243. High Engine Temps
  244. Sportwerks MayhemST engine problems
  245. JAPAN RTR .05 / JAPAN 5 CXP / JAPAN 7 CXP ENGINES. What are the differences?
  246. AB Mods Picco EVO2 with TKO rear ceramic Vs Stock Picco EVO 2 X-Dyno graph
  247. Nitro Star 4.6K High Output v LRP 28 V Axial 28
  248. .18 cxp nitro by exceed
  249. Raised Exhaust Timing
  250. Difference between shafts ????????
