PDA
View Full Version : Car Nitro & Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. Tuned Pipe ?
  2. which is a better engine for Savage X
  3. sts .21t mkII
  4. tuning problems
  5. parts for peak?
  6. SportWerks .21 V2--What temp/glow plug?
  7. Rpm raising and bogging
  8. Bogging
  9. Sirio or Werks? need input
  10. Starter for Axial .28
  11. boring out an rc engine?
  12. help getting sleeve out
  13. Unknown Engine - HELP!
  14. wheelies
  15. Axial .32 or STS .30 for a truggy
  16. Odd picco .28 temps
  17. Glow plugs for a RB Concept S5 MSC 5-Port
  18. crank shaft porting/cutting...please post pictures
  19. vx18 Crankshaft removal problem
  20. I Would Consider the OS.18TZ
  21. force.32 connecting rod bearing??
  22. HPI R40question about ENGINE???
  23. axial.28 vs cen nx26
  24. selecting the right tuned pipe.
  25. mugen Seiki / Novarossi ??
  26. OS TZ .18 CASES WHERE TO BUY
  27. STS D30M break-in help
  28. werks picco .27 settings
  29. Need your help on this one please pipe for new engine..
  30. TRX 2.5R & Nitro Star 3.0
  31. cen nx 76 engine ISSUES
  32. low-high compression ?
  33. Force .32!!!!!
  34. ofna .26 force
  35. REVO 3.3 engine noise
  36. STS D30M Info!
  37. Fuel
  38. what to do when an engine dies?
  39. Custom exhaust???
  40. exceed rc infinity?
  41. Toki engines, any good?
  42. porting and??
  43. revo 3.3 new engine
  44. picco max .26
  45. If i port do i break in again?
  46. MGT 46 SE engine-trying to understand correctly
  47. novarossi .21 after pinching
  48. Need help with break in and tuning
  49. Help with Force .26 on my Ofna Comp LX Ultra
  50. Axial .28 wont idle
  51. engine questions
  52. Removing clutch shoes
  53. Idles, but More throttle quits
  54. jato 3.3
  55. questions about an engine
  56. 15 CXP engine factory setting ??
  57. Best pipe for Axial .28rr?????
  58. new engine to mayhem st
  59. Ok, what snaps a con rod!
  60. Picco P3 .28 -- LRP .28 spec 3 -- Axial .32 1s (comparison, help for choice making needed!)
  61. short/long plugs
  62. smt cxp .15 and melted exhaust pipe!!!
  63. TRX 3.3 (Jato)
  64. Kyosho GX12 Engine
  65. XTM 24.7 Parts
  66. pipe for novarossi .21B
  67. !!!!!!!!!!!!!!please help me!!!!!!!!!!!!
  68. break in
  69. newbie question.....
  70. How come turbo engines are always bump start?
  71. Factory Carb Settings for a Ninja .12
  72. jato 3.3
  73. engine life
  74. Sirio .21 .23 confusion
  75. Novarossi 528XR
  76. fuelman
  77. 28RR
  78. Megatech M16 Tuning
  79. STS D30m from RBmods
  80. MAx you can port a OS .18 cv-r?
  81. Engine front bearing replacement
  82. 3.3 jato
  83. break in
  84. trinity monster 20%
  85. Reading Glowplug
  86. Cooling head sizes
  87. O.S. .12 CV-R
  88. RB S5
  89. Slightly dark marks on piston head (nitro t-maxx 2.5)
  90. Traxxas 2.5 front engine bearing gone...
  91. RB928 compared to the modified RB928?
  92. picco trinity parts
  93. new member team infinity 15s problem...
  94. novarossi .21 bf
  95. it doesn't work
  96. break in process
  97. Risks
  98. Induction Timing
  99. What Motor Should I Run In My RS4-2? Please Help!
  100. Red Cat Motor In A HPI RS4-2? Please Reply!!!
  101. dissasemble of nitro motor
  102. old COX 049 Engine Question?
  103. CH jumpstart for Zenoah 45cc
  104. Shim question
  105. Rich condition mid to WOT
  106. Please Help: Sportwerks .26 Problems
  107. Converting a bump start to rotostart?
  108. Piston and sleeve
  109. Help Running in.....
  110. jato tuning
  111. STS D30M temperature help!
  112. .18TM eb mods
  113. engine front bearing
  114. Are Colt .15 motors and parts still around?
  115. 27 engine
  116. .247 engine problems
  117. Getting a starter box, what to do with engines?
  118. help with OS 21 RG starting shaft size to fit smaller one way bearing.
  119. How to install bearings?
  120. Where can i get a pull start for this??
  121. help starting my new 18tm revo engine
  122. Pull start issue
  123. Who is knowlegable about Ninja engine
  124. Nova Rossi .28 truggy engines
  125. Mach 28 starting box problem
  126. engine mods that are affortable
  127. OS .18 TZ Head Temperature
  128. nitro star .15 fe? has a chrome sleeve?
  129. O.S. 21TM Pipe?
  130. HELP!!!!!!
  131. trx 3.3 problem.
  132. Best Motor/Pipe setup for truggy
  133. Noob question about my new nitro
  134. engine bearings
  135. HOw are the os .12tg engines?
  136. Break in after nitro % change?
  137. OS18TZ T in RC10GT
  138. sts d30m
  139. Removing Bearings
  140. How to seal airleaks in new .28RR?
  141. mach 427
  142. TRX 2.5 rebuild
  143. mann big blocks are hard to......
  144. piston and cylinder/sleave resizing
  145. Any advise on this..........?
  146. axial .28rr or lrp .28
  147. Clutch Assy
  148. hpi s25 nitro breakin problem
  149. LC COLLARI 32 WONT START!
  150. Nitro Cleaner Replacement
  151. 28rr TDC
  152. jato 2.5
  153. force 28 break in
  154. replacement motor fot the cen .46 nx-76
  155. RB Concept TM523 Vs. Ofna Picco 26 Max
  156. Fastest 1/5 scale motor for FG
  157. ofna comp 2 running problems
  158. where to get engine mods
  159. Cooling heads
  160. help xtm 457 motor
  161. review of propinch mod services
  162. AXE ROSSI COBRA
  163. After Run Oil
  164. Whoa! 374 degrees on SH 21 ???
  165. Nitro TC3 engine
  166. Picco P3 .28
  167. OFNA Force .28 Needle Settings???
  168. crank bearing pitting races?
  169. troubles with my engine...=[
  170. the right piston/sleeve for my novarossi
  171. AE .12 modding
  172. LRP Z.28R SPEC 3 on MGT
  173. Rascal .18 Engine . . . HELP!
  174. Peak Performance Racing Diablo .18
  175. Wasp .28
  176. Anyone ever try this idea?
  177. new GO TECH engine, piston broke
  178. Glow Plug for LRP Z.28 Spec 3
  179. Typical temps for Sure Fire .32
  180. Engine Picking??
  181. New engine rebuild??
  182. OFNA Force .28 problem
  183. .28 sts backplate on .30
  184. Rich and Lean setting problems
  185. Need your tips/tricks on how to safely remove front and rear bearing of the engine.
  186. Truggy .28 engine choices
  187. o.s v-spec engine better then os speed v-spec
  188. Tainted fuel WARNING
  189. New engine trying to turn over. Please Help
  190. OFNA Force 0.25 Needle Settings
  191. OS MAX RG?
  192. Rossi pixy R12 or Orion wasp drone .12
  193. O.S. .12tz turbo problem!!!!! please help...
  194. Which engine should I get?
  195. thoughts on O.S RG
  196. .18 cxp nitro engine
  197. Picco P3 & Orion Wasp .28 Pro
  198. Techwell 5-port needles
  199. Removing Cooling Head
  200. Engine Overheating?
  201. ofna part 52297 (force 32 crankshaft)
  202. Novarossi .21 Race - Stock needle settings im LOST!
  203. Peak performance engine or axail .28RR
  204. new need help on glow engines for rc cars 1/8 scale
  205. engine problem (STS)
  206. TOTAL nOOB with a couple quickies... :)
  207. Boost Bottle.. questions..
  208. STS .21 engines?
  209. available engines for REVO 3.3 ?
  210. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
  211. RC Nitro Engine Tuning Tips
  212. Axial 28RR
  213. PICCO P3.28 VS. LRP SPEC 3 .28
  214. Glow plug issue during break in and now engine has siezed
  215. D4 Diablo engine 'starter' problem
  216. "Go" Engines??
  217. ofna mac 28 engine factory defaults and a problem
  218. Picco .26 MAX dyno results????
  219. Engine air leak
  220. Help
  221. break in and tuning ,how, ''help'''''pics'''
  222. orion engine
  223. duratrax o.s .18 dtx lsn tuning
  224. ENGINE TUNNING
  225. Does AE .15 engine idles hot?
  226. hpi 18ss
  227. Major tuning problem .28 Ofna Force
  228. Anyone dealt with an STS engine issue?
  229. trx 2.5r or trx 3.3 in rustler
  230. Axial .28RR where to buy?
  231. engine screws
  232. Engine Mod'ing Guide?
  233. Cant start my engine. pls help
  234. OS 18 TM In Revo Break In?
  235. rc10gt fuel question
  236. pipe clogging up with fuel?
  237. Erm cant start the thing, Help?
  238. best engine for hurricane xp
  239. replacment engine for old .15 t maxx
  240. ...
  241. PLEASE TELL ME???????
  242. Shaft or Torque Starter for SUT?
  243. Piston Color
  244. worn out piston/sleeve have it pinched regain life
  245. OPS .12
  246. Picco .28
  247. O.S. V-Spec
  248. New Engine
  249. new RB C6 BB 7T
  250. regaining my compression
