PDA
View Full Version : Car Nitro & Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. I need tuning help!
  2. Axial .28 spec1
  3. How are these??
  4. new LRP spec 3
  5. BlueThunder in gallons
  6. O.S .21 vs. Picco .26
  7. need opinions on engines
  8. help with first time OS engine
  9. TRX head compatibility question
  10. Just one engine question. I always wondered why.
  11. XTM/SH .28 vs Fantom FR .27
  12. STS D21B x STS D21T MKII
  13. Engine runs but when I just tap the throttle it shuts down?...Help!
  14. new engine tuning
  15. which pipe will be work good with the VSPEC
  16. IS the STS .30 really worth this???
  17. lrp .28r vs. axial .28rr
  18. Long trip
  19. engine temp
  20. Stripped plug on head, now what...
  21. kanaii throttle response
  22. Engine troubleshooting help
  23. engine break in
  24. .18 and .21 questions??
  25. How Many Seconds For Low Side? STS .30
  26. Glow Igniter Question
  27. O.S. .21 VZB
  28. Revo STS .30 questions
  29. trouble starting
  30. braking problems + more plz help
  31. twin engins
  32. I Want To Know How To Sand/Water Proof A RC Car
  33. os v-spec, 2006 or 2007
  34. Need Help With Making My Own RC Fuel
  35. Break In fuel nitro content
  36. rb concepts engines
  37. help with thunder tiger pro28 pullstart!!
  38. Altering timing
  39. Pro Twister Mods
  40. starting issue....sort of
  41. Which jp-? exhaust to fit v-spec?
  42. the best big block on the market.
  43. G3.0 MT2 engine
  44. trx2.5r questions
  45. new pipe
  46. mario rossi tuned ninja 5 port
  47. os.18 cvrx can i use rotostart
  48. AB Mods X-Dyno graphs and vid inside
  49. Blue Thunder Fuel
  50. O.S. .21 VZ-B engine question....???
  51. Im looking for a one way bearing for a Hyper.21
  52. Not geting enuff fuel
  53. OS .18tm question
  54. Shuts off when braking
  55. Difference between marine and car engines?
  56. Engine Trouble
  57. looking for a reasonable priced reliable engine for hyper 7
  58. engine troubles
  59. Axial .28 RR question.
  60. is my enine shot....?
  61. big block glow plug question
  62. can i exchange......
  63. Question about the Radical 628
  64. How do you remove the front and rear BEARING?
  65. tuning question
  66. OS V-Spec. Who's running them?
  67. Problems running in os 18tm.
  68. leaky bearing
  69. max power engines
  70. hpi carburator on a gxr28 engine?
  71. QUESTION ABOUT TRINITY ADAM DRAKE 21 ENGINE
  72. pipe for axial rr.28
  73. Which glow plug for RB Concept S5 MSC 5-port?
  74. trinity platinum .28 draked
  75. os crank in a trx
  76. GO RACING engines
  77. Glow plug storage case
  78. after-run oil ........ how often???
  79. .12 fuel consumption?
  80. You can make you own fuel?
  81. Break in Question
  82. flywheel nut...can i just use a regular lock nut?
  83. Kyosho GS-21
  84. best break-in for P7R-evo2
  85. my rc truck is geting no gas
  86. STS D30m
  87. Who Really Makes the Engines?
  88. 457 lock up!!!
  89. problem with new bearings
  90. 2-shoe clutches vs 3-shoe clutches
  91. heip!!!! asap
  92. hyper .21 carb part #
  93. Nitro scent
  94. OS max .15 CV-R, with fuel, 20-25%
  95. Werks B3 Factory Settings
  96. what is this part called that i broke
  97. Smallest gas engine
  98. Mt 12
  99. TRX 2.5 issue. PLEASE HELP!!!
  100. Flywheel Removal
  101. Motor Seal
  102. Car idles but would shutdown after high reving
  103. Is there a .12-.15 three needle carb?
  104. new lrp .28 spec 3
  105. What pipes should I buy???????
  106. Sirio .12 turbo Q.
  107. Wrist Pin Clip
  108. CAN ANYONE ANSWER THIS??????
  109. STSd30m HELP
  110. Broken "ear" for mount bracket
  111. Axial .28 head shims
  112. OS 18 Tm Problems
  113. Problem with my OS MAX VZB V-spec
  114. please help!!!!!!
  115. walbro wt285
  116. 30vg roto start to bump start
  117. Picco .21 XP On-Road?
  118. tuning trouble
  119. New engine or rebuild?
  120. Info on engine
  121. Boost Port Timing
  122. Hard start
  123. kyosho gx21 ABC OR ABN ?
  124. Jammin .28 engine parts
  125. HPI .28 won't idle
  126. Replacing Crankshaft
  127. rc10gt2 engine
  128. upgraded from TRX2.5 to Ofna Force .26
  129. temp question
  130. .21 Delta FORCE Engine
  131. Engine won't idle/difficult to restart
  132. STS D30M revo mount
  133. axe rossi mamba
  134. HELP pls, taking out the sleeve
  135. Low End Tuning Problem
  136. y wont it start?
  137. help starting new motor
  138. Need a fast engine, but not a 3.3
  139. Poor Fuel Mileage on Novarossi P5X
  140. settings for os .12 cv-r
  141. Doubled my fuel economy!
  142. Picco P3 HELP please!
  143. opinions please
  144. savage splutters
  145. front bearing
  146. break in driving
  147. How do the pro's break in their engines?
  148. linkage help
  149. 15 T clutch bell
  150. engine help
  151. 21, 3port nova
  152. STS D21T MKII
  153. time for a new motor :)
  154. Sleeve
  155. clutch screw and loctite?
  156. new to RC plz help me!!
  157. draked .28 vs picco .28 turbo.Whats differen't?
  158. Ofna Force .26
  159. TRX 2.5R Sleeve is Stuck!
  160. Tiger Drive w/18cvr-x
  161. OS VSpec, Running JP3 now, how about JP1?
  162. revo 2.5 motor
  163. new engine
  164. break-in hpi rs4 evo engine
  165. Most powerful .28 engine?
  166. 15 size header question
  167. Does this happen??
  168. Any '06 Fantom .21 owners out there?
  169. Opps?!?!?!?!?
  170. compession test?
  171. which engine
  172. rb questions
  173. switching carbs
  174. Break-in in hot weather
  175. Afterrun oil question.
  176. Refrigerating fuel
  177. pollished muffler pipes
  178. Peak Performance Help
  179. hpi .25 rebuild
  180. Peak Performance Diablo
  181. xtm trick parts
  182. mugen ninja or rb928?
  183. Colder plug = cooler engine???
  184. Muffler vs No muffler
  185. pipe
  186. Guide Ports On Liner
  187. blown hpi
  188. rpm way high
  189. Pulse Jet
  190. Carb problems
  191. STS D30M break-in woes!
  192. hpi 4.6 in a hellfire
  193. O.S. .30 VG or Axial .32?
  194. please help me
  195. Need Advice!!! noob at porting here**BLINK BLINK**
  196. OS Max .15 CV-R car engine
  197. flushing
  198. Another Engine Question
  199. post pictures of your motors here!!!
  200. Axial .28 spec 1 HELP!
  201. Need HELP with Axial .28 spec 1
  202. Really Need help with my engine.
  203. I HATE PULLSTARTERS!!!!!!
  204. Axial or Racer's Edge?
  205. Phew, I did it.
  206. where to learn about
  207. os30 vg
  208. 2.5 problems
  209. help!!!
  210. New engine breakin questions
  211. os max .15cv temp
  212. some engine ?'s
  213. new to nitro enigine shuts off
  214. Porting a .12 force
  215. High speed needle valve and low speed needle valve?
  216. ryobi 31cc
  217. my trx 2.5 stalls when i hit the brake
  218. abmods did you get that dyno yet?
  219. Nitro Fuel..Oil %%%
  220. Picco .27?
  221. Pipe for Werks B7?
  222. Hpi Nitro star T15,Colt .15, and flywheel
  223. WD-40 for cleaning engine?
  224. salvageable?
  225. STS D30M is it a good buy?
  226. New Engine for LX Comp (Deleted)
  227. What ever happened to C-VEC?
  228. fuel????
  229. Anaconda Tires
  230. High Speed needle sticky?
  231. picco .26 break in problems please help!
  232. hpi rs4 t-15engine help!
  233. Mugen Bogging up High.
  234. NEM: NX-76 Engine
  235. Engine dies at WOT
  236. Car moves at idle
  237. tc3 os .12cv-r
  238. plz help os .18 cv-r to firestorm
  239. ofna 8 port engine
  240. low operating temp
  241. need help
  242. CARB STICKING?
  243. os .18cvrx
  244. Novarrosi 353 sleeve
  245. TIRED OF FLAME-OUTS!
  246. buggy engine
  247. buggy engine
  248. truggy engine
  249. firestorm 10t swaping motos to an os .18cvrx
  250. Sportwerks .26 V2 Breakin..
