PDA
View Full Version : Composites Fabrication And Repair
Pages : 1 2 3 4 5 6 7 [8] 9 10 11
  1. PVA clean up
  2. solaris acro arf
  3. Composite ARF - Sandwich Core Material
  4. CNC Foam Cutting Machine
  5. buying hydrocal
  6. Cheap Vacuum Pump Poll
  7. liquid weight versus cured weight
  8. hot wire help
  9. carbon fibering a foam core wing
  10. Skin hinging ala Composite ARF
  11. composite molding made easy dvd
  12. Building molds for CF props?
  13. Help me build a CARBON FIBER wing spar
  14. COMPOSITE TECHS NEEDED
  15. Starting to hate my composite fuse
  16. Epoxy recommendations
  17. FOAM COWL PLUG QUESTION
  18. What is Depron?
  19. Nomex.......were can i get it int he UK
  20. replacement for 3m77
  21. Glass work
  22. PVA trick
  23. How do I make foam cutting equipment?
  24. Hot Box? Any one use one?
  25. How do you patch gelcoat
  26. Phenolic tubing
  27. What type of foam is this?
  28. Cowl For goldgerg cub
  29. Avoiding are voids in corners
  30. priming in the mold (dupont primer)
  31. Question with composite
  32. Sources of PVC foam !! help please !!
  33. Transparent filler or something?!
  34. Composite wing repair
  35. release subsitute
  36. Flimsy fiberglass
  37. Fiberglass Molder Wanted
  38. CF Spinners - Use Vacuum?
  39. How many layers of CF for landing gear
  40. Prepreg CF
  41. Hornet II Quesiton
  42. Newbie fiberglass help
  43. Plastic filler?
  44. Mold cleanup...
  45. Repainting an old fiberglass cowl
  46. filler material
  47. Vac Bag to fill weave?
  48. Need help making a mold of an old kit I have
  49. Where is the PVA supposed to end up?
  50. Help! Look for a Company to do Lost Wax Aluminum castings of landing gear
  51. BONDO
  52. i want to make a 'glass canopy
  53. Sandable Foam?
  54. From foam block to a new jet
  55. Need plan to build composite tailwheel assembly for my 28% Extra
  56. Wax only?
  57. vaccum bagging systems?
  58. who would make a mold for me..
  59. CRASH Crease reduction
  60. Sheet foam for ribs?
  61. Painting in the mold
  62. Laminating C/F to liteply? (Firewall Reinforcement)
  63. What is Peel Ply and how is it used
  64. A LAY UP QUESTION
  65. What type of foam for mold?
  66. COMPOSITE FUSELAGE FOR 1/2A
  67. Gear needed 1/4 Edge Hanger 9
  68. Great Projects to learn from
  69. fiberglas cowl needed
  70. Scratch building a Cowl
  71. Anyone Know how to Paint in mold?
  72. divinycell sandwich core
  73. Rohacell
  74. MOLDMAKERS,got a question
  75. Any body Know about TAVS(Total Area Vacuum Sandwich) Technology
  76. Wax vs PVA or both
  77. Need some carbon fiber advice
  78. PVA
  79. Clay making for Plug
  80. For dessolving polyurithane foam?
  81. Aeroglass website?
  82. Scared Me!
  83. reinforcing a foam wing (combat) with CF
  84. Mold Wax
  85. How to do everything magnificently...
  86. Are special tools required to cut/drill Carbon Fibre sheet/plate/tube?
  87. repair to carbon fiber landing gear
  88. Cutting Carbon Fiber Push Rods
  89. Carbon shortage!!!
  90. fusalage plug
  91. Edges of molds
  92. Foam wing spars and Dihedral braces??
  93. Good Prices on Carbon Fabric
  94. Cheap CF tubes ?
  95. Why do molds stick??
  96. Kevlar Hinges
  97. Idiots guide to making a vacuum pump?
  98. Slick finish repair on carbon fiber gear? Help guys...
  99. MOVED: Spitfire "The World Model" 63" wing span
  100. How to fix balsa wings
  101. Plywood former replacement....
  102. Composite Hazards
  103. Lost Mold fuselage
  104. Carbon fiber tube, how strong is this tube for my CAP232?
  105. extra 260 35 % from romanbuiltmodels.com
  106. new to fiberglass
  107. Anodizing
  108. Vacuum pump
  109. Enlarging spinneer openings
  110. buying carbonfiber
  111. Source for honeycomb sheets
  112. How to remove CA stains on clear plastics.
  113. Wing Mold
  114. buildin with foam
  115. Composite tail wheel bracket
  116. fiberglass fuses
  117. Which material to use for plug
  118. Local supplier of CF tube in Southern Michingan
  119. Help Required for Vacum Bagging Fuselages!!!
  120. what material for large open spaces in foam
  121. Need tricks on sanding down carbon fiber wing tube.
  122. MOLD MAKERS
  123. Pinholes & Airbubbles
  124. Canadian Carbon Fiber Source?
  125. Why is my fiberglass mold flimsy
  126. Kevlar fuel tanks
  127. Custom Foam Cutting
  128. How to Add Retracts to Cloud Dancer
  129. how to make composite gear
  130. cutting wing tube socket in foam
  131. K&B resin - where do ya get it
  132. Carbon Fiber Stress Signs
  133. Cutting wheel pants and cowls...
  134. Strength of Foam for Wing Cores?
  135. Contacting CST???????
  136. ELAPOR Foam
  137. Conversion to a Trike configuration
  138. Releasing FG from a vac formed mold?
  139. Project GTO: Molds
  140. Help, molding jet intakes
  141. Painting in the mold with prepreg?
  142. Sandwich material?
  143. Bolting sandwich material
  144. EPOXY
  145. Anyone using VARTM?
  146. composite landing gear
  147. Pic of Colorful Kevlar /Carbon composite
  148. Fiberglassing Pu foam
  149. where can I order carbon fiber?
  150. Plans for 33% Edge 540T
  151. reinforcing foam core wing
  152. Getting started with fiberglass and carbon fiber!
  153. Which Gloves are Best When Working with Resin?
  154. What over dope
  155. which epoxy
  156. Really need help for buliding plug
  157. repairing painted covering
  158. Glassing balsa sheeting...Is it worth it?
  159. Problem wetting out fabric
  160. The cost of composites
  161. Carbon fiber structure
  162. Where do you get your cloth?
  163. Monokote, patch or replace?
  164. Painting and Glassing a foam wing...
  165. How to Apply Covering on Fiberglass or Carbon?
  166. How to keep larger amounts of mixed epoxy from heating up?
  167. Carbon Fiber Tube's threaded pushrod Ends
  168. Fiberglass Repair
  169. Questions with composite wing ...
  170. Vacuum forming plug, how to make
  171. Repairing a new glass fuselage
  172. carbon undercarriage
  173. Joining carbon fibre tubes - dihedral !?
  174. Painting carbon gear
  175. Front windshield
  176. My home made carbon scale blade
  177. PayPal & Composites
  178. Making A Plug From Scratch
  179. 1 carbon tube
  180. Joining two halves of a float
  181. Getting Started with composite EDF
  182. Cutting carbon fiber?
  183. How to paint a model in a mold?
  184. Multiple layers of fglass
  185. A MATTER OF CONCERN
  186. Seeking CF material info (like IFO planes) to make 20-40” dia arcs
  187. Mylar and ds
  188. Carbon Fiber I-struts?
  189. cf rotor blade repair?
  190. Epoxy remover.
  191. Flying Wing-Glass ship
  192. My first glassing project... Need help!
  193. carbon propeller
  194. Anyone using carbon rods, tubes rectangles etc,..
  195. Carbon ribbon (tow) and polyurethane glue
  196. Can carbon rods be threaded?
  197. Trying to build a fiberglass cowl - need advise
  198. Bondo problem...
  199. Glass wings
  200. Info required re EPP
  201. Should I get this pump?
  202. repairing molded fusealage
  203. HELP! Repairing a hollow molded wing w/ missing tips...
  204. Fiberglass Fuse to Plug help
  205. Mold Considerations
  206. Is it heavy or not ?
  207. Mold stuck to plug -- any suggestions as to why
  208. help with sandwich construction
  209. Carbon Fiber spinner and gear
  210. Hollow moulded wings...anyone tried to make?
  211. Tank leaked oil soaked wood
  212. Small wheel pant problems
  213. Sanding/Filler question
  214. HOW DO I MAKE BALSA FILLER HARDER?
  215. Vinyl Ester Resins
  216. Composite Wing Repair
  217. resin won't cure
  218. Baking Composite Parts?
  219. Aftermarket fiberglass cowels?
  220. New How to: Repair Landing Gear
  221. Help finding materials Please......
  222. Fiberglass weave filler
  223. IF YOU MIX 5 MIN EPOXY WITH 30 MIN EPOXY WILL YOU COME OUT WITH 17 MINUTE EPOXY?
  224. Paint stripping
  225. fiberglass molds
  226. Health Risk with Carbon Fiber!!
  227. Epoxy vs polyester resins
  228. Composite videos
  229. How to make CF plates ?
  230. Carbon Fiber Booms
  231. foam wing cutting
  232. Job Opportunity
  233. vinyl spackle vs. lightweight spackle... HELP
  234. Painting fiberglass
  235. Stupid question--cutting fiberglass cloth
  236. fuel tank
  237. Looking to outsource glasswork or sell moulds & MFG rights
  238. Review: Composite Molding Made Easy DVD
  239. Polycrylic vs Deft polyeurothane vs cheap epoxy resin
  240. EXAUST PIPE INSIDE THE FUSELAGE
  241. carbon undercarriage question
  242. Polyester Resin on Pink Foam, Sealing?
  243. How to build an accurate model of small part without using formers
  244. Fabrication
  245. Carbon fiber spinner
  246. kangke cap 232 .60
  247. Help with kevlar
  248. respirators and other protection
  249. Composite servo tray, best materials?
  250. Resin melting pink foam?
