Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 DLE 20cc Gasser! (Data & Links 1st Post) >
Old 08-20-2011 | 09:59 AM
  #4376
My Feedback: (117)
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
I been running an APC 16X8 on both of my DLE 20 sand have been very pleased. But I just assembled and started flying a Pulse 125. Not a lot of prop ground clearence. I switched to a 15X8 APC and am now turning 9300. Is that too much for my DLE 20s??. The manual/paper work does say 15X8 props but it also says 9000. Am I going to damge these little rascals? Thanks Brian Smith
ORIGINAL: ameyam
Is the 16x8 too small for this engine? I figure if the 17x6 is ideal, the 16x8 should also be ok
Ameyam
Old 08-21-2011 | 01:18 PM
  #4377
raptureboy's Avatar
I'm using a Truturn prop hub and as it turns at idle you can see it turning out of round. I thought it was my imagination at first but my friend noticed it too. When I put on just the hub and rotate it with just the hub you can feel the hub go up and then down. You can also see it in the prop rotation. Very strange indeed I admit. I'm perplexed. I may have to get a dial indicator to confirm it though.
Old 08-21-2011 | 01:57 PM
  #4378
raptureboy's Avatar
I just checked it again with out the plug in and only the prop nuts and it is definitely bent[>:] I will order a new one today, and hopefully I won't have any more problems. What is the best way to pull off the hub? Thanks guys.
Old 08-21-2011 | 04:09 PM
  #4379
w8ye's Avatar
My Feedback: (16)
The hub is keyed on a straight shaft but you may need to nudge it with a puller?
Old 08-21-2011 | 07:31 PM
  #4380
Question 4 anyone. What is the minimum distance off (away from) the fire wall the carb can be without obstructing airflow into it?
Old 08-21-2011 | 08:23 PM
  #4381
w8ye's Avatar
My Feedback: (16)
If the carb is not more than 1/4" away from the firewall, I put a hole in the firewall.
Old 08-22-2011 | 04:36 AM
  #4382
raptureboy's Avatar
I thought so, thanks. I have a email out to Jody for a new crank.
Old 08-22-2011 | 11:42 AM
  #4383
My Feedback: (57)
I have a mid-range burble on my H9 Corsair. The low idle and high end are great but I see others have had this issue also and they say that I have to richen up the HS needle, is this the current conclusion from everyone that has had this?
Joe
Old 08-22-2011 | 12:23 PM
  #4384
a1pcfixer's Avatar
My Feedback: (7)
IF the low end & high end and transition are all fine, nothing to worry about if you have a little mid range burbling.
No need to beat yourself up trying to get all such out, some is ok. Go fly & enjoy it!
Old 08-22-2011 | 12:41 PM
  #4385
My Feedback: (57)
Ok cool that's what I have been doing so fly I will! LOL
Old 08-22-2011 | 12:51 PM
  #4386
MetallicaJunkie's Avatar
ORIGINAL: raptureboy
O.K back again, I dumped the old gas out and mixed up a new batch with 4 oz's of oil this time for sure and now my baby is humming along sweet only now I've discovered that the crank on my Stearmans engine is bent ,...Any thought on a bent crank from starter use?
Not on gassers.
... its only common on easily flooded glow engines, especially those mounted inverted
Old 08-22-2011 | 01:47 PM
  #4387
ORIGINAL: w8ye
If the firewall is fairly thick...you could just dish out about were the carb center (throat) is close. This give more strength and also if you can do it keep the behind the firewall more air tight. You may need to run a line to a dead air space from pump cover.
Capt,n
Old 08-23-2011 | 02:07 AM
  #4388
Wolflord's Avatar
Is a 16x8 3 blade prop too much for this engine?
Old 08-23-2011 | 05:57 AM
  #4389
spitfire66's Avatar
Wolflord:
I tested the master airscrew 3 blades and had the 14x7 and 15x7. They are both too small and have me over revving (10,500 and 9300 rpm). A couple pages back in the thread a master airscrew 16x8 had a static rpm of 8200, which in the air should unload to 8800-9000 which is about perfect. That is what I am going to use.
Old 08-23-2011 | 06:04 AM
  #4390
My Feedback: (57)
I am using a 16x8 on my Corsair and I get 8450 rpm and it flys awesome!
Old 08-23-2011 | 08:26 PM
  #4391
vertical grimmace's Avatar
Here are some pics for Mr Wad. Let us know how it all turns out,Ive been thinking of redoing the other one I have also. Feel free to PM me if you need any more pics, this engine was made for this plane.
Great idea painting the needle screw heads. I am going to do this but in white. I have a hard time seeing mine inside the cowl. Way too dark. The white will reflect the light better.
Old 08-24-2011 | 05:31 AM
  #4392
raptureboy's Avatar
Yes, I painted them over white also, after I took the picture I put the cowl on and realized it did not show up very well. I was thinking about glow in the dark paint also.
Old 08-24-2011 | 06:06 AM
  #4393
My Feedback: (47)
Great idea about the paint. Count me in.
Old 08-24-2011 | 06:37 AM
  #4394
My Feedback: (156)
UUHHH, thanks man, best idea ever, need shoewhite or whiteout in my tinker drawer from now on.
Old 08-24-2011 | 06:53 AM
  #4395
I have glow in the dark paint, used to paint my model rockets with it for those dusk launches. Made it easier to find the rocket in the dark.
Anyway the only problem is that you have to shine a light on the paint for a few minutes before it will "glow". Might be tough to do with the cowl on. I be interested if it works though.
Old 08-24-2011 | 08:31 AM
  #4396
My Feedback: (117)
+1 to that idea. Thanks- it "really" makes a difference for me!! Brian
ORIGINAL: vertical grimmace
Old 08-24-2011 | 01:18 PM
  #4397
Here a a few pics and results from tuned pipe testing with a new DLE 20. The header and pipe were originally used with an OS 120 AX. I had to make an adapter plate for the header to fit the DLE. The 120 AX has much wider bolt spacing. As a result the port matching is way off but seems to work fine. The props are more APC pattern type props as I don't have much selection of wood props. In addition to the ES 120AX pipe I also tried the ES 26G pipe which gives very similar result but I can't make the wrap around header short enough for this pipe on the smaller size props. A standard side exhaust header would work fine. The pipe was adjusted trombone style for each prop. I forgot to bring a tape measure so I can't give header lengths. Forgot the camera too so running pics are low res cell phone. I did not try the stock muffler.
I was very happy with the DLE. It's generally 300-500 behind the OS 120AX depending on how much nitro you give the OS. If the DLE were modified to run on glow I expect it would just as strong as the OS. I don't know how the two engines would compare on stock mufflers. A two stroke without a tuned exhaust is only half an engine. Of course running on gas has it's advantages and the DLE runs perfect.
I may put this in an older pattern plane, replacing an old YS. The APC 16x10 looks perfect for this at 8600.
All figures given are with a fully hot engine and the needle set to flying mixture, not squeezed for every last rpm. Hot restarts are one flip, no choke. I used a standard RCEXCL ignition not the stock one. Works great.
Mobil synthetic 2 stoke @ 32:1
8 month old premium pump gas
RCEXCL standard ignition
ES 120 AX pipe
Mueller header
NGK CM6 plug- included by Valley View
temp. low 90's
Xoar 16x8 8750 - free from Valley View
APC 16x8 9400
APC 17x6 9250
APC 16x10 8600
APC 16x11 8100
APC 17x10 7450
ID:	1653076   Click image for larger version
ID:	1653077   Click image for larger version
ID:	1653078   Click image for larger version
ID:	1653079   Click image for larger version
ID:	1653080   Click image for larger version
Old 08-26-2011 | 08:50 PM
  #4398
Ernie Misner's Avatar
A gurgle is almost always slightly rich but if in the midrange only, not to worry, it is getting lubricated well.
Ernie Misner
Old 08-26-2011 | 10:16 PM
  #4399
Thanks for the numbers, very encouraging
Old 08-26-2011 | 10:17 PM
  #4400
