- Slimline Pitts muffler for ST G-61 question?
- ST 2500 specs
- MOVED: SuperTiger 90 Muffler Issues
- recommened size fuel tank for a ST G-61
- ST 90 Idle problem
- MOVED: Zenoah 20 cc ei in a sig four star 60?
- parts for a.29
- SuperTigre Engine Problem
- S90 Parts Needed
- Super Tigre laminar flow engines
- WHAT GLOW PLUG FOR SUPER TIGRE 3000
- Starting G-4500
- crank thread size on super tigre 3000
- Supertigre 61 wont run in high speed
- Super Tigre G90 won't idle.
- MOVED: ST .11
- ST2300 High-Speed Needle Valve Assembly
- G-27 CX Warranty Work
- Idle too high on .75
- ST 45 won't hold needle setting
- G90 problem
- Super Tigre 25 question
- ST GS-40 No Compression
- Super Tigre 90 propeller advice
- Another 2300 question
- Muffler system, how deep?
- G 61 RPM's ?
- ST 90 fuel consumption
- G 51
- 2300 Carb Issue
- SUPER TIGRE G-27 ENGINE
- ST3000 to 3250
- RPM's for ST 2300
- super tiger 46 quits abruptly
- ST G2300 Exhaust Manifold
- Jett Carb For G2300
- ST Pistons
- Italian 45 Ring
- ST-2300
- MOVED: Super Tigres Made in China
- tightening head bolts?
- s 3000 prop
- st g3250 no compression??
- ST 90 Problem
- Need Super Tigre g. 21/46 cubic in. muffler
- Wanted. New piston for Supertigre 2000, 25cc
- Pardon my ignorance but....
- muffler 4500
- G51 Compression problem
- St61 surging
- St2300 with pump
- Super Tigre G27 CX getting hot
- Which prop on ST G-90
- G-2300 with bisson pitss mufler
- Inverted GS45
- Hey Bax, need help to sort out a G90 power loss
- trouble with a ST G61 ABC
- trouble with new super tigre
- G-27cx Duratrax Raze
- How does the ST 75 work in
- SORRY BAX..... G 51
- need help for set up 40s/t
- G-90 opinions
- G51 DRIVE WASHER STUCK AGAINST ENGINE
- G 51 the "ENGINE" most dificult to carburate.
- High speed needle ST3250
- ST 4500
- X40 and X45 parts?
- Cool Power heli fuel in ST engines
- Am I on the right track?
- marine 4-strokes?
- Inverted ST 2300
- Prop reversed on test stand
- G-51 idle screw adjustment
- ST 2000 25cc Questions
- What to purchase for a new engine
- G27CX In Warhead EVO Problem
- What is different about the 2300
- GS-45 Cylinder Liner
- MOVED: X11 PB RC
- proper I.D of this engine
- GS-45 Throttle Stop Screw
- ST V60 parts
- Fitting Air Filter
- ST2500
- Crankcase pressure fitting on 2300
- ST 2000 or ST 2300
- Crankshaft Clearance
- super tiger 2300 inverted
- ST3250 Setup
- .61 Super Tigre SERIE X manual/help needed
- Super Paw or Tigre Paw muffler
- St 3250
- Stripped Screw holes in G-90
- Super tiger 45 abc carb problems
- ST GS .40
- Where to find older Super Tigre .45 cylinder?
- ST2500 Muffler
- 2000, 2500, 3000 parts
- Super Tigre G90 exhaust stack
- Supertigre torque
- ST 2300 needle not responding
- ST2300 inverted
- ST LS Needle
- New (to me) G2300
- Carb Retaining Nut Size and Source
- Leaky? ST51 carb
- New st fan
- What engine
- .51 Engine Performance
- For Bax: the in-betweens
- G2300 Break-in prop
- ST 3250 "backfire" problems
- G-2300 Muffler Extension
- G90 Cooling in Cowl
- G90 Carb Position
- summary of the setup of G20/23
- ST 2000
- Tank Size for a ST 90
- Supertigre 45 abc losing power
- Help with tuning ST G90
- Help on super Tigre Muffler !!!!!
- Best plug for an ST .45?
- 4500 gas conversion
- 3750???
- ST 51 idle
- ST 2500-3250 Fuel
- st2300 idle stop screw
- Rich Running
- Problems with ST G-90
- Ready to give up on my ST engines...almost.
- Big Supertigre Carb Problems
- fab ST2300 gone Bad?
- Request about G90
- Theres something strange in my G90 Muffler!
- Super Tigre G51 exhaust is dark grey now
- ST 2300
- Old Italian G49
- G-90 and perry pump
- New G 90 - 3D Prop
- S T G2300 scorched combustion chamber
- GS-45 ABC leakage
- G-34 Settings
- ST 2300
- G 90 - Perry Pump
- muffler conversion
- Position of spraty bar
- G 51 SLEEVE REMOVAL
- Super Tigre s-45
- WEAK G90 COMPRESSION
- S-2500 problems
- X-60 Question
- Need Help With a Super Tigre V .60
- thread size on Italian 90
- ST 3250 and bisson muffler
- Super Tigre .61
- Idle Creeping Up
- G90 engine problems
- G-49 Italian w/wire hi needle
- G90 Break-in period
- Did run It in wrong
- G4500 and G90 questions
- idle needle setting
- What gives?
- G-51 mid-range
- SUPER TIGER 90 QUESTION
- ST 51 not running high RPM
- Help with WAY too lean G90
- 4500 carb dimensions
- 5% vs. 15% nitro
- ST 15 muffler needed.
- Super Tiger G-90 Vibrating
- G51 does not pull fuel...
- prop washer torque
- Italian ST90 cutting out after 6 minutes
- G2300 MK II
- Leak? Eek!
- Carb for S3000
- Glow-Plug Q's
- chances of getting a good 2300
- g-90 cant tune it help
- what's the limit on prop size?
- G51 break in questions, help for a newbie
- DuraTrax/Supertiger G-27CX Racing w/Pull Start
- ST 2300 tight fit
- Fuel tank size for G3250
- .61 pitts muffler
- G3250 Backplate Mount
- Exhaust deflector for ST .45
- ST G61 ABC stalls at half throttle
- Are new and old ST .45 sleeves the same?
- G 90 BAX ?
- muffler for a 2300
- Optimum RPM ranges for 3250?
- 2500 carbs
- ST G90 OS F glow plug
- what year G -90
- G-2300, 12 or 18 percents of oil?
- ST 2300 fuel delivery problem
- factory default: idle stop screw
- G-90, SLOTin spraybar
- SUP TIGRE 2500
- G90
- OS and ST
- ST G-51 REBUILD
- G51 Spitting Carb
- Nitro Percentage for GS-40 & G90
- St G51 vs perry pump
- super tiger 90
- front bearing
- Soot like Black Spatter fromNeedle Valve Assembly
- s .29
- ST2300 fuel inlet too small!
- st-2300 neddle valve fuel leak
- ST 2300 Bearings
- SuperTigre 15 Muffler
- st s45-k
- 2300 Throttle Barrel Sticking
- Supertigre .45 assy help
- installing g51 rings
- g 2300 prop and carb issues
- sup tigre 2500
- New case for ST1
- Is both my ST 40's the same?
- ST2300 Needle extension - How?
- st 51 ring bracking proceess
- G-90 confusion?
- giant jug with 3250
- need carb. and muffler for ST GS 45abc helppp
- Super tigre Purchased
- ST .51 is hard to start
- Super Tigre G-3250 (carb or on board glow???)
- Is there a rotostart backplate for the Super Tiger 44 in my new Warhead
- Bearings for G 20/23
- ST 90 exhaust bolts sheared off
- ST2300 and Muffler advise
- Cleaning a Tigre?
- ring installation
- G90 and Pitts Muffler Manifold Extension
- Spinner Backplate for ST3000
- ST90 Won't die with throttle off
- ST Compression
- ST 51 Parts
- G-27CX (warhead)
- Old ST X45 F.I.R.E.
- ST 2300 needle needed
- Size and Operating Questions
- G90 crankcase tap location
- Super Tigre 3000 Spinner back plate
- st 2300 questions
