View Full Version : Redcat Racing Support
- big block in a 10th scale redcat racing tornado buggy.
- New Vehicles Coming Soon
- Redcat ever plan on offering Heli's
- Redcat Hurricane XTR Spur/Pinion Gears
- Nitro Carb Help
- How to refill Sumo alu shocks? (#24600)
- Need help with REDCATS Earthquake 3.5 Parts
- help with volcano epx pro
- Caldera 3.0 questions?
- Tornado s30 emgine problem
- Battery charging error,,,HELP
- Diff upgrades for Hurricane XTR
- volcano s30 carb adjustment
- Thinking about an Avalanche XTE
- Aluminun steering hubs worth it on my Tornado S30?
- Volcano EPX Pro suspension settings...
- radio system chargers
- need help with ESC on earthquake
- HELP! Volcano EXP Pro GONE WILD.....
- spun the teeth off my gear
- Redcat racing avalance xte steering problem
- need help with redcat s30 valcano.
- Life expectancy
- Caldera 10E servo saver unit
- EPX PRO upgrades
- Question about Earthquake 8e
- Recast Tornado S30 No Longer Starts
- ground pounder body measurements
- Front Axle Repair - 1/16 Tremor Truggy/Monster Truck
- Tornado S30 glo plug wont thread
- Caldera10E front outer hub bearing
- blonde beginner
- Caldrea 10E steering servo
- Volcano S30 radio bind help
- Earthquake 8E Exploded View Help
- You've got to be kidding me!!!
- S30 volcano nitro rc truck will not stay running.
- Caldera 3.0 - Flywheel Loose - Recurring Problem
- Newb needs help with tornado s30
- Cooling Volcano between tanks of gas
- Redcat Tornado s30 radio/ reciver problem
- Avalanche XTE Calibrating ESC with remote
- Question regarding Triton Junior charger to charge Tornado battery
- redcat volcano epx slow to stop
- EPX Slow on charged battery
- Will these clutch shoes work on a Caldera 3.0?
- Caldera 3.0 - Better Clutch Shoes
- twister xb with truck body
- Redcat Racing avalanche XTE avalanche batteries
- Monsoon vs. Earthquake.
- upgrade for vortex ss
- Caldera: Cheap/Alternate BS903-019 Driveshaft?
- Volcano epx pro Running problem
- PLEASE HELP! Redcat Racing F-18C
- good deal
- chasis compatibility??
- sweet, I own a 8e again
- Volcano Epx Pro lipo battery problem
- Couple Easy Avalanche Questions
- twister xb dont run. make beep sound when press fwd
- rampage XT. i think i killed it
- volcano epx battery not lasting
- wheel hexes
- tornado wheels...
- Problem with Tornado S30 Motor.
- Tremor - 2s Lipo - ?
- Redcat Sandstorm Baja Buggy?
- compatible parts for vortex ss?
- Why Use A Fail Safe.... See Photos!
- Redcat rampage mt motor questions
- Shockwave Nitro Engine Help
- Seized Up Engine?
- tremor 1/16 review
- Tornado EPX pro wheels/tires combo. (brushless version)
- Tornado EPX PRO 1/10 Buggy 8.4v NiMH Battery issue
- redcat sumo
- New Receiver BAD on arrival
- Servo sugestions please.
- Which Part Broke in this Picture?
- play in rear wheels on volcano epx pro
- need aftershock body measurements.
- Clutch keeps sticking
- Caldera 3.0
- Why Banana Plugs?
- Who knew?
- volcano epx pro gears stripped?
- Ihobby images of .....
- did I just put a vxl and 3s into a tornado?
- Volcano EXP Pro - electric - full throttle at startup
- twister owners, what breaks most?
- Electric Redcat Volcano S30 Video
- Volcano EPX motors
- Bodies that fit the twister XTG Pro?
- NitroRCX Sale Until Oct 3 2012 - Cheap Caldera/Shredder/Earthquake/Backdraft/Aftershock parts
- carb????
- Suggestions.
- Vortes SS Engine Troubles
- Monsoon XTR Needs new shoes!
- volcano epx pro vs. avalanche xte ????
- xtra parts must buy????
- good cheap lipo charger/balancer????
- Redcat Shredder XT electric
- Monsoon XTR
- Redcat Volcano S30 Converted to Electric
- 1/24 SUMO - brushless with ground FPV
- Rampage XT,
- Hurricane XP, what would be the equal to this product.
- Throttle linkage stuck?
- starter box for redcats?
- BS903-109 vs BS903-110
- Carb
- Tornado EPX shock removal
- Vortex SS no second gear
- Gearbox unit
- Gas spitting from glowplug/heatsink
- Redcat Racing Monsoon XTR Main Spur
- Help!! With Avalanche XTE
- Help!!
- Shockwave Not Starting!
- Vortex SS Desert Truck 4X4
- 1/8 rockslide issues
- Earthquake 8E new combo
- Earthquake 8e servo upgrade
- Setting end points on tornado epx pro?
- lightning str
- Mamba Monster upgrade RC Avalanche XTE
- Caldera SC10E Spur gear
- Huge problem! Help me out.
- Stock needle settings for Tornado Engine
- Volcano EXP Pro vs. Caldera 10E
- Does Redcat make any boats?
- Volcano esc program?
- tornado rpx tires and axles
- Help Identifying a Volcano S30 Part
- Multi gear transmisson?
- New parts dont fit old Tornado.
- help with Hurricane XTE
- Volcano EPX bumpers
- EQ8e part number
- Shockwave Question
- Cat 5 Tornado!
- RS-10xt issues
- Volcano EPX tires for pavement.
- Caldera 3.0 issues.....
- Shredder XB spur and pinion?
- tornado S30 weird issue
- Replacement wheels
- Installation of new C-carriers, Drive cups
- Win a Redcat Sumo in Canada
- Sumo 1/24 brushless motors
- Volcano EPX... battery...
- SH .18, in the Nitro STR On-road car??
- This is odd...
- monsoon xtr
- Exhaust Bolts on the Volcano S30?
- Shocks upgrade for Earthquake 8e and Volcano EPX Pro?
- steering wont work on redcat hurricane XTR PLZ HELP!
- Tornado EPx loses power and/or stops
- Caldera SC-10E conversion
- Volcano EPX?
- XTE brushless motor in Earthquake 8e
- Dune Runner Powerless
- .28 tunning help
- redcat hurricane xte *** problems
- je$us....now main spur gear gone - Caldera 10E
- Velineon 3-s Esc
- avalanche xtr diffentral question
- Bullet Connectors stuck together.
- Grounder Pounder
- quick fix?
- Worn out motor?
- 1/8 Super Crawler
- MOVED: 1/5 Scale Rampage model differences
- Lost reverse on my Tornado EPX Pro
- hurricane xte impressions
- Caldera 10E - Help w/Installation of new Frnt dogbones, Frnt Cups and Servo
- Earthquake 3.5 differntial
- landslide compatible
- Sumo RC issues
- redcat shockwave help no steering or throttle control
- FRnt Differential broke...???
- esc programming
- Lipo Batteries. Need help fast!!
- Sumo RC Truck
- Want a 1/5th or 1/8th RedCat? How does $200 sound?
- New redcat cars coming?
- Spur And Pinion Gears
- Any hobbyshops around city of industry that will fix redcat 1/5 slace
- volcano parts truck wanted
- differential
- New Backdraft 8E Problems
- Monsoon XTR Help
- new backdraft 3.5 problems
- Compatible Aluminum Hubs, Redcat Earthquake 3.5
- Help with Redcat Hop Up Part # 06048 or 106017
- Motor starts, then quickly dies
- Arrgh - Why are lipos out of stock everywhere
- Twister XTG PRO ESC...HELP ME!!!
- Batteries for Lightning EPX standard
- Does Redcat/HSP have an Electric 1/8th Truggy? Can it handle 6S?
- Backdraft 8e or hurricane xte
- Backdraft 8E noob
- RC controlled 1/10Th scale buggy's, truggys trucks and everything in between
- Carburetor yes, fuel line no
- Where to buy Redcat Racing decal stickers?
- Where can I buy Redcat Racing Truck Bodies???
- Earthquake 3.5 help!
- epx pro
- Caldera SC10e stuttering at take off?
- Can't tighten nuts
- Redcat Avalanche XTE?
- caldera 3.0 - wheels don't turn on the ground
- Volcano Sandrail
- carrying case for starter kit?
- ESC Light Stays Red/
- Sumo help
- Sumo vs pickup truck
- Bushing in servo save Earthquake 8e
- Redcat any good for light bashers?
- SH 3.0 redcat
- Just received my new Redcat SC 10E
- Traxxas motors. Need help fast!!!
- best quality tools to work on vehicles?
- Engine Quits when I squeeze throttle
- How Long Nitro Engines last ?
- Replacing Tornado S30 tires
- Lost binding to my Tornado S30?
- Avalanche xte
- getting really mad!
- Traxxas Shocks on Volcano S30
- Shockwave Wheels
- Pull Start Conversion?
- just got my first truck. RC question
- Volcano EXP PRO
- 20% More Red, 10% More Cat: Shredder SC pics!
- Racing my tornado epx pro
- Aluminum upper plate help?
- Shockwave Shocks
- Tools of the trade
- Tornado s30 new wheels
- Caldrea 10E short radio range
- Which Redcat?
- Tornado S30 Transmission/Differential Broken?
- Backdraft 8E strange deal???? HELP!
- Driving me crazy!!...It's about to go in the trash can!
- Shockwave will not run
- Monsoon wheels
- Volcano Epx Pro Wheel/Tire Options?
- Steering knuckle.. broken D/S. Noob needs help
