- Aftershock part upgrades???
- Redcat Volcano Epx Pro
- Caldera 10e w/Parma grave digger shell
- Need Help with my RS10 Crawler Controller
- Spur gear trouble???
- Did the aluminum upgrades on my tornado by myself!!!
- Tornado BB wont start with tuned pipe
- steering servo for my Backdraft 8e/Earthquake 8e
- Rx/Tx/Servo problems
- Vid on Earthquake/Backdraft diff Shimming
- Help Tornado S30 Wont move!!
- Earthquake 3.0 air time
- Avalanch XP Takes Second Place In Fall Series
- Redcat Earthquake 3.5 is Trash
- Tornado EPX Discussion and Picture Thread
- flywheel???
- Is this a Monsoon body?
- Happy Thanksgiving
- can any1 recommend
- Throttle Servo Messing up
- Earthquake 3.0 1/8 Scale Nitro Monster Truck
- Help??
- Redcat 8e Shocks???????
- Cracking, Crunching Servo???
- O Donnell Glow Plugs
- Loss of radio contact
- Need help identifying parts
- My Tornado S30 kick AZz
- New RCs
- 2.4ghz remote??
- redcat Sumo! lipo?
- Amsoil Shock Therapy & Cult Energy Replica MT Bodies!
- Tornado S30
- Spur Gear Caldera 10E????
- Will Redcat every make some cool boat????
- Volcano S30 no tension on pull start
- volcano epx upgrade help
- *Official* Caldera 10E Video, Picture And Discussion Thread
- Redcat Racing Tornando S30 problem...
- Caldera 10E lipo and charger??????
- Bashing in yard... Wheel going flying!!
- Threadlock safe to use with plastic?
- Is it possible to use a 2 speed tranny and/or a sh .28 in a Volcano S30?
- ground pounder problems!
- Rear Driveshaft dog bone
- redcat support
- PIcs of Team Intergy fuel filter and primer pump installed
- Needle Valve for Volcano S30
- Flight Simulator
- Why do people recommend 87mm dogbones for the Tornado s30??
- Just bought earthquake 8e...now what??
- Volcano s30 transmission
- Priming Engine - "Blocking Exhaust Method"
- Rockslide
- Dont you hate little brothers!!!
- Earthquake 3.0 front Differential failed
- looking to buy Lightning EPX PRO but need some advice..
- Earthquake 3.5
- Thxs Redcat!!!!
- redcat problems
- LIGHTNING gear ratios. Spur gear adaptors?
- Drifter Conversion
- Spektrum DSM -Redcat DSM
- neutral
- RedCat Volcano SV
- glow plug idle bar
- compatible fail safe
- oh reactor where are you?
- Volcano S30 No power to rear wheels
- Redcat Planes = AWESOME
- Where to buy Redcat in SO-Cal
- How you battle sand and dirt?
- Whats the word bird?
- HSN fuel line banjo fitting air leak Earthquake 3.0
- Ground Pounder wins World Championship!
- Nitro Fuel brands, so many and no all the same! but what do you think?
- Wheels and tires, how to know if I can use it on my shockwave
- New to RC nitro... with a sore hand
- Redcat Earthquake 3.0 engine high RPM die out
- Clutch bell tight
- Run away RedCat Afftershock 8E...?
- factory settings
- idle screw high low needle
- volcano S30 Toe-in
- backdraft wing mount
- Air filter up grade Earthquake 3.0
- 43 tooth spur, switched to 39 tooth metal or plastic
- Newbie, Stl MO
- RedCat "What is warranty for the Avalanche XP centter diff?"
- What is the typical radio range?
- 2 speed swap
- Cheapest Body clips RC
- help with vortex exp pro
- Lovin My Avalanche XP like a fat kid loves Cake!
- red cat lipos
- very frustrated
- Aftershock 8E steering servo movement
- Volcano S30 Drive Cup
- Need Serious help tornado s30 Red Cat Help!!
- earthquake 3.5
- Adj idle screw for carb
- Volcano redcat racing RC - VX-18
- Sh Engines?
- My brand new Tornado S30 is DEAD
- Switch broken??
- Redcat Black foam in tires.
- Used Savage or New Hurricane?
- Quick question on compatable rims for my Redcat racing tornado BB
- I hate UPS
- Earthquake Servo Saver Problem
- SH .18 Factory Needle Settings?
- Rampage MT breakin issues
- Throttle picture
- AAAAAAAAAAAAARRRRRRRRGGGHHHHH!!!!!!!....Receiver caught on FIRE!!!
- Question about breakin process
- Redcat Racing Tornado BB wont drive
- Monsoon XTR shock/accesory options
- my 1st redcat, good and bad
- Volcano S30 Rear Wheel Drive Broken ?
- Trouble starting brand new Tornado s30
- Avalanche XP is the Touphest truck ever Built
- NITRO TREMOR PARTS
- redcat option parts
- Shock Fluids - help!
- New to th e forum and Redcat
- backdraft 3.5-to-backdraft 8e
- Radio crystals?
- Redcat RS10 crawler ESC blinking red. Help ASAP
- Aftershock 8e
- volcano aluminum parts?
- Tornado BBS30 trouble with Dogbones
- ROLL CAGE?? AFTERSHOCK 8E
- Earthquake wheelie bar
- Need some help. Tornado s30
- 2.4 ghz or FM, HELP
- need throttle stop screw for team infinity .18 slide carb.
- Lipo/ Volcano EPX Pro
- Tornado EPX Pro
- Redcat Starter Switch Melted - Here's My Fix!
- RED CAT STAINLESS SCREW KIT ! ! !
- AFTERSHOCK 8E STAINLESS SCREW SET....
- The Good Times and.... The Bad..... AFTERSHOCK 8E
- Aftershock 8E Needs Upgrades
- Can't Start my Lightning
- No Control
- What are these parts called?
- how to adjust 2-speed tranny
- Sumo Batteries
- Devils Advocate Redcat Thread
- Where to get rockslide and also body?
- Diff Grease
- Electronics protection
- wont accelerate/shockwave clutch ?
- gearing help
- Hurricane XTR and Backdraft 3.5
- Wow what a truck this Avalanche XP
- Why are glow plugs still from the 1800's
- Custom bodies
- Remote control no car signal HELP
- Spur gear
- What is the Best glow plug for Avalanche XP
- Volcano s30 tuning
- Need a new or used Avalanche XP
- AFTERSHOCK 8E ~ Newbie ~ New out of box help!!
- redcat website
- Charger questions
- New Backdraft 8e
- Did redcat kill the reactor?
- Shockwave and Tornado
- Volcano S30 Engine
- Price difference
- aftershock 3.5
- 8E Endbell Maintenance
- Aftershock 8E tire issues
- Wheelies with a Volcano S30
- Lipo batt problem in my Earthquake 8e???
- Tip For redcat diffs.
- My aftershock 3.5 experience!!
- JUNK!!!!!!!!
- Aftershock 3.5 Street Setup
- Backdraft 8E front differentials
- Redcat Shockwave help!!
- could someone please help me with factory settings on sh1.8 carb nitro please
- mamba monster in an aftershock 8e?
- volcano sv carb problem
- New Monsoon XTR owner
- WILL AN OS.21VG (P) ENGINE FIT IN A AVALANCHE
- AfterShock 3.5 Aftermarket list?
- Looking for a new RC who do you suggest?
- tsunami ultra wide
- WHEELY BAR FOR EATHQUAKE 8E ???????
- Looking for another Redcat!!
- Rampage MT issue and reccomendation
- 11.1v 500Mah x2 in an 8E
- Making an 8E rear wheel drive instead of all wheel
- ((( STEERING SERVO SAVERS )))
- ((REDCAT FUEL RECOMMENDATIONS))
- spur gear trouble
- Earthquake w/sh .18. Roto start backplate??
- Program Cards
- 100 degree weather and nitro
- RedCat Racing Planes??????
- Adjusting diffs
- Earthquake 8e ESC Smokes on turn-on
- Selling MY RedCat tomorrow Bummer
- ??(((WD-40)))?? AS A CLEANER LUBERICANT ???
- back draft 8e
- ???(REDCAT Website)??? NO STOCK ON EVERYTHING!!!!
- My New Backdraft 8e (Earthquake 8e Convert)
- Caldera 10E Battery Size (Dimensions)
- ??(AIR FILTER OIL)?? is 20wt non detergent 15-40Wt with color
- ??RC Nitro?? "Shake and Break" FUEL TANKS??
- Starter box for Monsoon.
- Tremor 18E pro tires
- Hurricane xp Question/Problem
- Aftershock 8e Battery Upgrade. help
- Reactor 3.3 tuned
- Fuel Recommendations?
- Hurricane Bodies?
- Whoa!!
- Clutch for Aftershock 3.5
- "REDCAT" 3.0 Clutch Upgrade.
- Does anyone still use the XP series?
- News Flash 3.0 Redcat Clutch Lasts (6 gallons of fuel) ( )
- ! NEW ! BS903-020 Diff Upgrade Redcat Trucks and Buggies
- Lightning EPX PRO esc problem
- (Cheapest) RC nitro Cleanup
- SH .18 in Volcano S30
- Is it possible to upgrade Caldera to a SH21
- Can't keep Tornado running or idle
- help with repair on my volcano
- Racing a Backdraft 8E?
- Converting and Earthquake 8e to Backdraft8e.
- Shake and Break(PLASTIC) Front Chassi Upgrade Redcat
- FREE Mechanical help Nitro RC
- NEW!! REDCAT Big bore shock to Avalanche Shock upgrade
- CLUTCH spring 2 piece install
- Tornado BB : Car Not responding to acceleration
- !!THE BEST!! (alu) Clutch Spring life help.
- Caldera suspension upgrade
- Tornado S30
- Brakes on a Volcano S30
- sway bars
- earthquake 8e lipos ?
- Earthquake 3.0 Advice
- Earthquake 3.5 pullstart stuck ???
- Volcano S30 Driveline Question
