- thanks redcat, rufaster
- 0.18 engine problems
- Rasied from the grave!! My Volcano Sv with pics!!
- Calling all Volcano Owners
- Shiping parts outside the states
- Volcano SV Upgrades
- Tornado S-30
- Running temp on monsoon
- Check this damage....Hurricane
- throttle arm
- Recall on FM radios
- spur gears anything better??
- Volcano SV question
- Pull Starter Is Stuck Out
- Need help
- Sh. 18 and other mods
- FAULTY CARB???? PLEASE HELP
- volcano epx pro brushless
- Big newbie here and need some help!
- break problems
- Redcat service center
- help when I put the brake on full my tsunami dies
- trick/tip to installing rear driveshaft - Tornado BB?
- newbie
- 2 shoe to 3 shoe clutch coversion?
- BREAK IN TEMP
- please help
- fuel filter
- ?? clutch ?? Avalanche
- BDC
- newbie
- one way bearing
- BURNING up glow plugs? why?
- Volcano sv parts?
- dynamite tuned pipe
- Wheels and Rims
- S30 Break IN
- pull start problem
- how do i remove owb from SH28
- Avalanche SH28 engine issue?
- Volcano EPX (brushless) motor gear
- slight cut out on top end tornado BB
- redcat tornado bb question
- What is the size of the OWB in the SH .07 engine?
- the new lanslide 1/8 scale
- faster engine for my tornado???
- Which Gear should I use
- Down time
- wheel problem -HELP!!
- Differences between Redcat tornado S30 and tornado bb
- SH parts
- is this a good on-roader?
- Aluminum hop up kits
- New rims!
- question will this fit on my lightning?
- volcano sv idle problem
- Servos
- VX 18 Specs
- help me get going
- redcat tornado vs. losi 8ight lolJ
- tornado BB trans
- Stupid Newb Question
- Stub axles pins
- volcano sv break-in question
- need help in wisconsin
- exhaust manifold?
- Near nitro engine death experience
- volcano sv factory carb settings
- New Brushless Electrics
- Blank Body Shell For Tornado BB
- Installing #08023 in a TsunamiUW, your thoughts!!!
- i wonder if this should have been posted by a mod?
- tornado BB rear shocks
- Volcano sv diff. gear
- Broken clutch bell
- First day Running the Volcano SV Pro
- oneway bearing
- gall bladder
- Volcano SV Pro 6V Battery Pack
- shockwave?
- Tremor clutch problem?
- low speed needle
- tornado epx
- help
- Volcano EPX radio system compatibility?
- front wheels smaller than back....reason?
- what size bogdones
- Anyone know the factory settings for a Tornado BB, anyone have the manual?
- Problem with a Redcat replacement part?!?
- Who ran what this week?
- tuned pipes
- When's the next Redcat video contest?
- help
- my switch tore itself apart
- Better Wheels and tires for volcano sv?
- Stock electric engine question
- Minnesota Hobby Shops
- Breakin the law??
- can't get this part - exhaust gasket for volcano sv
- getting a volcano sv soon!!
- wheels turn during idle after warming up
- Another broken part
- more take off
- Tsunami Ultrawide front end problems?
- BRAKES FOR VOLCANO
- Broken Hurricane XP Pro Wheels...HELP!!!
- Can a Tsunami be made ROAR legal?
- alot of fuel coming from exhaust. (NOOB)
- Big crash
- RedCat Tsunami EPX general Qs
- Traxxas shocks
- just got my redcat tornado bb today
- Where can you get receiver switches?
- Some redcat drifters
- What do I need?
- VOLCANO SV PRO
- hot engine
- When will the 1/5th and Ultralites come out?
- Heres one for the books
- tsunami epx foam inserts were can i find them online????
- how to remove fuel tank on tornado bb?
- Is there an aluminum chassis available for the Electric Tsunami?
- Tank problem
- Tsunami dogbone
- Tornado Dogbone Keeps Popping Out!!
- not a bad day racing my monsoon
- issue
- alu. shock rebuild and oil fill up
- Lightning EPX
- Shockwave Suspension Spring Options?
- Curious to know if a 18/23 pinion gear will work
- Please help with my Tornado BB
- I just upgraded to my TSUNAMI EPX to BRUSHLESS.
- Good deal on SV PRO?
- servos
- I'd like to apogize
- lol bashing
- steering servo
- 1/10 buggy racing
- RTM models
- Replacement motor for Tornado BB
- How do I know when the batteries are dying in my remote?
- 27 mhz am crystal
- REDCAT Brushless system questions
- rmonsoon
- help
- Center diff vs slipper
- 1/5 Scale Rampage Pricing has been set
- 18/25 tooth clutch bell for more speed!!!
- Tsunami won't start!
- Racing in Vancouver
- REDCAT RACING
- Fuel.
- short clips testing out my new ramp and doing backflips
- Good Deed
- avalanche motor saver
- Need some major help with my lighting HELP!!
- What is the stock Lighting epx motor rating?
- Radio problems - range / glitching
- Speed Controller, Postive wire, hets HOT??Melt
- fed up
- Estart
- clutch bell question - monsoon
- STEERING HUB
- Clutch Bell?
- need parts for monsoon
- Pull start
- $40 and 8 hours later...
- Anyone know where to get the bushing that fits inside the 47 gear see pic
- CANT FIND RIMS FOR TRUCK
- Servo
- Very sloppy steering in Lightning VX!! Help!!
- Brushless sys
- 1/8 roll cages for buggy ?
- low profile air filter?
- SH Settings (Volcano)
- Anyone know of a wheelie bar that fits the Tsunami?
- what were the prizes for the name the redcat contest?
- New 1/8 scale Ultralites
- Go vote for Redcat
- cool rims for volcano
- Need a good muffler for LRP Z.28 SPEC 3
- upgrades for volcano
- Electric Starter
- How do yu clean SH28 one way bearing?
- ?Roto Start ? Engine?? NOOBIE here
- Longer Volcano Pro axles and hexes DONT WORK on Tsunami... Please Help.
- glueing tires
- Tsunami.........Day 1
- replacement gear
- Only survivor.
- Stuck in 2nd gear??
- Whats the stock glowplug in tornado BB?
- Contest ideas...
- Why do you need after run oil?
- AM Transmitter
- Jeep Cherokee Body?
- Loosing throttle
- REDCAT lighting Electric, Want to DRFIT help
- After an intense run.
- monsoon
- Will These wheels and tires go on my lightning??help
- How fast is Redcat Volcano with Brushless?
- Why does it............
- getting a tornado BB soon!!!
- new clutchbell & carb for tornado???
- redcat tornado / os 21 tm
- 1/5 Scale Body Styles including Buggy
- Gears on my New Tsunami will only spin together manually
- Soon to be released TYPHOON
- Nitro Lightning bogging after shifting to 2nd
- Determine Engine Sizes
- Opinions on page layout
- Need help lubing a Lightining Bearing!!!
- 14 tooth clutch bell
- How?
- universal drive-shafts on 1/10th
- New to this, buying a SV Pro
- drift tires and rims on lightning?
- cool bumpers
- FINNED ALUMINIUM parts
- Wanna Scramble eggs on my volcano?
- Lightning VX Uncontrollable!!
- Arizona bashers May 3rd 1/5 scale running
- needed upgrades for more speed or more performance
- Increasing Lighting speed w/o upgrading the engine?????
- WHAT DID I JUST DO TO MY CLUTCH!!! SEE PICS
- Savage X or Avalache? Help
- Batteries
- Redcat Tremor Truggy Video
- Wheels and tires
- tsunami clutch problem
- Tornado Sway bars?
- Tornado Engine block separated from Muffler aluminum connection plate?
- Byron fuel...
- High idle, stalls when braking
- help cleaning my car??
- ugrade ???? 's
- Locktite
- Stoupid Spur gear
- project "MUTT"
- Maybe be broke idk someone awnser ma question please
- need to replace/upgrade fuel tank
- what do you break the most on your tornado bb???
- Flywheel
- Forza / Tornado Axial Beadlocks?
- NEW BODY FOR TORNADO BB????
- monsoon body mount
- Found the Grinding sound in the rear of the tornado bb
- TO RICH HELP PLEASE FAST
