- no radio power
- Volcano S30 controller problem
- volcano ugraded diffs??
- Batteries
- Different motors??
- lost screw on my 3.5 earthquake
- Brushless motors
- Shockwave Engine Question
- Several issues with brand new Volcano S30
- Vortex SS Dogbones
- My Caldera 10e family
- Fuel pushing out of carb
- Redcat LIGHTNING STR (2spd clutch help)
- Volcano s30 pullstart
- Batteries and battery charger
- volcano with trx3.3 upgrade
- Troubleshooting steps if nitro won't start?
- Volcano s30 help!
- Use Marvel's Mystery Oil as After Run Oil for Tornado S30?
- **OFFICIAL** VORTEX SS Parts, Discussion, Pics, Videos
- vortex ss steering configuration HELP!!!
- Long Body Posts for Caldera's
- What happened??? s30 opposite direction
- problem starting caldera
- Twister XTG Pro don't turn to the right
- Racing Redcats in Canada, eh?
- Body question
- backdraft 3.5 tires
- twister xb/xtg and xb/xtg pro thread
- Truggy won't reverse
- caldera reverse problem
- volcano epx pro 8.4v?
- DESTROYED FRONT GEAR HOUSING
- Vortex SS gears
- Earthquake 3.5 motor
- lansu radio from twister xb pro ?????
- Need help with a Tornado s30!
- Tornado S30 VS Shockwave
- Getting back in the hobby after 4 years
- Just bought a rampage mt
- Cadera 10e upgrade question
- Tornado s30 front wheels wont "spin"
- bodies
- clutch shoes,
- screw came lose from shockwave not sure where it goes
- Painting New Shell
- Volcano epx brushless motor
- Earthquake 3.5 clutch bell?
- shredder bad experience
- earthquake 3.5 gear mesh
- help please with my tornado
- Earthquake 3.5 Wheelie bar?
- New Tornado owner
- Volcano S30 Transmission
- Redcat volcano with SH REAR exhaust
- Caldera 10E XB bodies...
- REDCAT LARGE SCALE Rampage OR XT?
- Battery dying ?
- Problems with the Redcat racing rampage XT
- engine cuts out at half a tank
- Redcat Backdraft 3.5 shuts when applying gas (trying to move)
- What are your HSN/LSN settings for Shockwave?
- redcat 1\8 super crawler problem
- Shredder SCB Bolt Replacement
- rezzi's rampage + inertia racing fast fuel + dual shocks
- just a quick question
- Lightning epx pro on 3s lipo
- Tornado s30 problems keeping it running
- Redcat=WindHobby?
- tornado S30 Help?
- Tornado s30 new tires
- Clutch Spring 30cc Dune Runner 4x4 Use HPI part?
- Glow Plug Recommendations? Cold vs. Hot?
- tornado S30 help...I broke something?
- Sumo steel axle nut size
- Rotary carb for .18 SH engine
- Volcano/bug crusher uk engine.
- volcano s30 throttle/receiver problem
- RedCat Spur Gear? Steel Spur Gear vs. Plastic Spur Gear? Pic Inside?
- Returning to hobby and undecided
- Shockwave upgrade questions
- Lipo and RS10XT
- Redcat monssoon+HSP Sea-Rover PICS!!
- Sumo Rear Drive Shaft issue?
- 2.4 ghz receiver
- avalanche trx needles
- NEED HELP-TORNADO S30-BRAKE PAD BURNED
- noob having problem with backdraft 8e
- glow plug included with shockwave?
- How fast is the Shockwave (MPH?)
- Backdraft 8e shocks Update
- tornado s30 upgrade
- Colored Wheels
- Stronger drive cups for tornado s30
- Ticked off!! Redcat parts problem!!!! HELP!!!!
- Redcat Monsoon/HSP Searover Body Shell
- Making your own nitro fuel?
- Redcat Makes some boats
- caldera 3.0 servo
- shock lenghts.
- Monsoon xtr
- nitro fuel lines in dogbone cups-volcano epx pro
- pull starter broke please help
- NEW epx pro-wheels nut keeps coming loose????
- RedCat Availability
- Lansu radio steering wheel broken...
- Cant bind standard 2.4g radio
- Tornado s30 dish wheels?
- Nascar anyone?
- need help with my tornadoBB
- Who actually races their Redcat at the local track?
- Problem With Lightning EPX Pro, FLashing ESC?
- Sumo RC clicking rear axle
- Sumo micro crawler question
- How to remove the steering/servo from volcano chassis?
- Whats the biggest one?
- Valcano S30 problem.
- tornado steering problem
- Anyone racing 8E Aftershock in 4X4 SC???
- Tornado s30 burn hole
- Aftershock 3.5 Body
- servo
- servo
- Removing Tires on Tornado S30?
- Caldera 10 e
- Broke Volano epx pro chassis, where to get new one??? PICS INSIDE!!!
- redcat may be a mistake
- My New Himoto Mega E
- (Pic) It's alive! The new version of my Brushless Tornado Pro.
- Redcat and Houston hobby shops
- 20c 30c 40c 50c?????
- oops
- Looking to purchase Redcat RC
- Can't get to program my esc properly
- Changing gear ratios in Caldera 10e?
- caldera 10e bodies
- no front drive shaft
- caldera 10e tires
- Volcano S30 idle set screw
- Aftershock 8E Bearings
- Drove the wheels off it! Need new wheels!
- Model support...exploded views
- problem with steering linkage
- Twister XB Pro
- HOLY CRAP
- RedCat/Exceed Parts
- RedCat Caldera 3.0 Not Staying On When Started?
- pull start
- metal spur gear
- Getting back in to RC's... Redcat options?
- Found a real bolt on Front Bumper for The Tornado
- value of this?
- ground pounder wheels
- looking for tire options and more
- New Tornado S30 Owner Needs Help
- advice needed
- aftershock body size
- I must be twisted!
- made mistake not buyin BL
- Hex Fly Servo
- Lansu 3Ch 2.4Ghz
- caldera 10e esc
- rs10 Radio help pic of truck
- volcano out of control electric brushe
- How Many turns on my brushless?
- electric volcano epx pro takes off
- Electric conversion Volcano SV
- redcat racing support failed need help
- What is the name of the connector they put on the new Redcats
- still testing caldera 10e
- Honest opinion on Tornado S30
- Pull start on Caldera
- Futaba 3PM MX and Aftershock 8E
- Tornado Pro Electric - rarely hits top speed? How to set the ESC.
- Help me buy a Redcat 1/5. Info PLZ
- A little about me before I post
- Redcat Caldera 3.0
- Volcano S30 will not start (Brand New)
- Tornado S30 running way to fast!
- tornado s30 enigine swap
- ever here of crystals going bad?
- Install exhaust to manifold
- Convert Shockwave to 2speed tranny
- my new RS10
- Sumo help please! Horrible high pitch
- Aluminum Parts for Volcano S30!
- caldera 10e up grade motor
- caldera 10e
- what parts are hard to find for you?
- volcano epx will not move
- Monsoon XTR
- RedCat Lighting STR , RTR Will not Move
- red cat charger
- redcat 1/8 scale crawler
- Newbie getting started
- low spped setting
- New Avalanche XTR - Such a lemon...
- Upgrade Volcano S30 Engine
- Just Cant Win
- My custom Vortex SS 3.0 my fav redcat ever! PICS INSIDE!
- Finally impressed with Caldera 10E! please read
- Steering problems
- HEX FLY HX-3CP SERVO
- bannana plugs
- Aftershock 8E Shocks
- high idle.....reving without throttle
- I am new to Hobbie Caldera 3.0 need help plz!
- How many Aftershock 8E's needed for a good bash?
- Lack of aftermarket parts for Caldera?
- HELP! Complete newb on nitro motors
- Single vs. 2 Speed? Anyone plz help??
- Tornado EPX Pro run times
- new body on volcano pics!
- volcano and backdraft, new parts/pics
- tornado s30
- brushless motor for my Redcat Caldera sc 10e
- following the manual
- New tires for Caldera 10e?
- Tornado BB spur gear issues
- On-Board battery pack broke...
- Backdraft vs Hurricane?
- bogging/dieing under load
- Avalanche xte or hurricane xte or backdraft 8e?
- Tricks and Tips to keep your Redcats running!
- caldera 10e
- Easy Connector For Dual Lipo's?
- Alignment on Caldera 10e
- So I ordered my wife a Volcano EPX Pro
- redcats not starting
- Best place to buy parts/upgrades
- my backdraft 8e!
- VOLCANO EPX PRO 1/10 BRUSHLESS
- What size of screw or part number do I need?
- Bent screws on Calders 10e steering arms keep occuring????
- new redcat volcano epx
- avalanche xte
- rampage body messurments
- Earthquake 3.5 Steering issue
- What lipo are you running with caldera 10e and or Hurricane or Avalanch?
- New Volcano S30
- On / Off Switch
- Sumo Truck issue
- Vortex ss wheel/rim replacement or upgrade
- hardened diff gears for aftershock8e
- Engines that'll fit the Tornado S30?
