View Full Version : Redcat Racing Support
- car wont start.rope very easy to pull.HELP!
- Hello
- clear bodies
- just a question
- motor parts for redcat needed
- Brakes are not engaging!
- fuel tank
- Air intake
- Pushing to the limit
- 08033 in stock
- Rear wheels do not spin on Volcano!
- location of redcat racers
- so where are the hurricane xp and pro
- pull start
- Exhaust header gasket for tornado .18
- Great Aftermarket Parts Found!
- Replacing Shocks/Gas Tank
- screws
- pics
- Never had this before!
- PLEASE PLEASE HELP ME
- glow plug
- Tornado XP Parts on Ebay
- one way bearing
- need help with clutch placement
- Need a Carb for my Buggy
- Big crash
- still having problem with tornado xp
- Throttle Trim adjustment
- New Aluminum - Work in progress @ TST
- Stalling
- Larger Wheels for Volcano
- wont shift to second
- Volcano STX clutch
- Extending the Tuned pipe
- 1st spur gear gone bad
- Play the Game & You Can WIN a Buggy
- RC Expo in SoCal
- aluminum rims for tornado xp
- low end needle on volcano stx
- Starter Box for Redcats
- Volcano STX
- tornado xp....please help
- MOTOR SWAP 2
- Still waiting on Clutch gear......
- Transmission Shafts (Dogbones)
- Back from vacation whooo hooo
- need 1(35T)
- convert pull start to non pull start
- Question for the Redcat Dealers
- tuned header
- Motor swap
- Engine temp help
- where the truck thread go??
- metal gear sets
- will this work with
- tires
- Loose Carb
- help..no compresion!
- Volcano Springs...
- Almost Absolutely Perfect!
- Clutch Gear Housing Explostion
- upper plate
- HPI MT2 hop up parts are combatable with redcat 10th scale!
- mt2 parts?
- I have a idea
- just a question
- exhaust gasket problem
- Volcano STX REDCAT
- question on tires
- volcano engine
- e clips-- Differential Box
- When is REDCAT making 1/8 on road and moster truck?
- Redcat vehicle repair/tune FAQ
- Need A Spur Gear!!!
- traxxas shoes
- Clutch Slice- Quick Question
- Top Speed Toys
- no shifting...
- two speed or one?
- infinity engine
- Clutch bell warped teeth
- got a problem
- tires spin at idle
- lock(too)tight
- Traxxas Clutch Spring
- shopping for glow plug
- volcano stx piston
- Volcano Stx Clutch question
- newbie help - buggie keeps stalling
- Volcano , Eldorado Diffgear set question
- Quick Question
- HEEEEELLLLPPPPP
- Free Hp out of the XL
- Help with Lighting!
- Aluminum door mounts pic on my truck.
- need Volcano STX faster!
- Just alittle note
- spun a dogbone
- some one pleaze helpp
- Jato or MT2?
- Ok, I now own a Traxxas Jato... But I need help to start it...
- DHL SUCKS!!!!!!!
- help starting tornado xp for the first time
- question about 2021 2022
- Redcat!!! Your kidding me, right???
- helpp!!
- Shooting a Redcat out of a canon !!
- a good thing about redcat
- monsters wheels
- guestion about after run oil
- Hidden costs with your Redcat
- I'LL be back
- Wanted, Aluminum steering arms Tornado
- How do you feel ??
- Any1 got any vids?
- Tornado XP Lives !?
- CLEARANCE TIPS FOR BUGGIES
- Part # 81010 steering wheel set?
- anyone here know about k&b outboard engines??
- yahoo messenger
- anyone have a link for this????
- brakes don't mix with the engine
- whats best TRAXXAS vehicle?? plz answer
- "something" motorsports.com???
- PULL STARTER screws
- Where can I get a bigger air filter for q .18?
- BIGGER ENGINE
- PLZ ANSWER THIS IMPORT. QUESTION
- answer this ASAP
- 3 IMPORTANT QUESTIONS
- 3 import. questions
- sad day I kill the engine
- Gears question???
- question about parts
- Grinding Noise
- Volcano STX truck
- Exhaust Connector Screw needed
- Other Makes....Compatible Parts
- Fixer Up Er, Is there any parts i can use besides volcano
- just keeps breaking... Now I hit the gas and nothing... wheels won't spin
- fuel line
- REDCAT WHY DO THE GEARS STRIP OUT?? BIG NEWS ADDED PAGE 5!!!
- shock oil
- idle screw?
- Transmitter/ servos problems
- alunimum gear box what th F^&^
- Is this a redcat dealer forum??
- throttle question
- Electric start for Redcats
- can shift to 2nd gear!!! getting PO!
- Tornado XP SLICKS FOR SALE
- please help!
- where to buy cheap glow plugs
- what rims will fit on my tornado xp???
- After Run Oil
- engine compression
- 2 SPEED TRANNY FOR VOLCANO
- I'm MAD AS Hell
- tornado xp gear help
- Redcat Volcano STX 1/10 Truck
- Throttle Pull Rod
- just a question
- Engine stalls, won't idle...
- got the car running
- more stripped gears
- where
- my last thread got the boot
- help!!!!!!!!!
- Tornado XP problem
- ALUMINUM PARTS ARE HERE
- tornado xp, gear stripping, shifting problems
- FAIL SAFE
- flash light driving
- New Accessories
- im hot
- saggy shock fix
- Clutch spring
- Maintenance
- Parts Order -> Anyone have these in stock?
- Volcano's First Day Out!!! --> CRASH!
- want alumminum parts for my tornado xp!!!!
- how do i lower idle speed??
- METAL Gears 47T ans 42T
- Cant Figure it out
- Join the Redcat Affiliate Program and Make Cashola
- Glow Plug Question
- sooo mad
- Check your shocks !!
- Florida racers lets get together.
- carb cleaner
- tires for xp
- Volcano Fuel - Which Type?
- my car is slow?
- bigger tires for my tornado xp
- REDCAT RACING SHIPPING DEPT!!!
- I NEED HELP !!!
- Volcano or Tornado XP?
- clutch springs
- newbie question
- Sunday AM and the Tornado sits ...
- i need to fine tune my car what should i do??
- Wont hit second gear!!!
- broken pullstart
- engine cool down?
- How Good Is Redcat
- Remote/Servo Issues Tornado XP please help!
- I NEED HELP!!!!!!!!!!
- Tiger Drive---Question
- cluch spring
- Pull starter
- tornado xp
- The Tornado XP sits ....
- Andt the Hurricane sits
- Aluminum Truck parts
- Just Getting Started, STX
- Newbie Volcano help
- New day Lets try again
- baught a tornado XP anything i need to know?
- engine temp?
- volcano goes in reverse
- diff oil subs
- Darin , I want my radio to work !!
- Engine temp/tuning questions...
- Bad Servo?
- Tornado XP problems
- Radio spazzed ...
- Second Gear
- Where did you buy your Redcat?
- Tornado XP Engine Sieze
- lift kit
- lift kit
- Day Of Bashing
- One more month wait for aluminum parts
- deffernt between himoto and redcatracing
- TRUE RADAR SPEEDS
- just a question
- Toe in or out???
- glow plug igniter
- Most wanted parts for Volcano
- RADAR GUN
- Breaking In Your Engine
- Help with taking apart my engine
- Stadium truck lower arms that would fit volcano?
- Any idea's
- a little bent
- redcatracing(darin)
- Tornado xp/xl motor compatability?
