- Raptor 30 V.1
- My engine seized up upon starting
- Pinion Dont Fit
- Raptor 30v2 Washout question
- What Pipe/Muffler
- Raptor .30 V2
- setup questions
- Bravo 60 Grafix on R60
- Buy V2 or repair V1 - Raptor 30
- Raptor 30 V2 Being Phased Out??
- Engine dies mid-air
- Raptor 50 Blade holders / new head
- Raptor 30 v2 rotor head upgrade
- Good price for a Raptor 60?
- sliding sideways during flips???
- Just starting out.....
- heli jerking left and right and engine acting funny???
- Raptor V2 Drops out of hover
- raptor 30 tail maxed???
- Ist Boomstrike/Crash/Auto
- R30 V1 Clutch bell wobble
- V1 and V2 parts
- Raptor tt39 carb settings???
- 30 V2 pitch guage
- Weston 1-pc pipe for TT .50?
- Raptor 30V2 Question
- 30v2 control direction
- Raptor V1 Clutch versus V2
- Complete Bearing Listing For 30 V1?
- OS 3 needle 60 size for sale
- Paddles work best with the Raptor 50 V2
- GV-1 installed. Which exhaust?
- Help Installing Stock Decals
- head speed
- Raptor30 V2 Fuel tank???
- fuel oversea's
- rap30 upgrade
- raptor 50 tracking problem
- Thunder Tiger stops the production of Raptor 60...
- Will this equipment work....
- tt39 or Pro39H
- Futaba 9CAP or 9CHP
- Raptor 30 w/GY501
- How tight should the blades be on raptor 30
- Raptor 60 setup
- Overspeeding problem R50
- R 30 v1 owners - need advice and help!
- which helicopter simulator ?
- tt50 into stock 30
- Cant get rap to fly backwards
- 8103 radio 30 V2 settings
- Raptor 50 part numbers?
- Muffler for my Raptor30v2-OS32SXH
- Secure KSJ paddles?
- Jr 550t
- KSJ Paddles on a Raptor 50 V2
- R 30 collective help
- Metal blade grip for Raptor 50 V 2 (Problem)
- Delete
- need advice
- How many Helo pilots are using PCM?
- 97mm tail blades?
- 1st flight R60 at Fire Station
- Raptor 50v2 from ricks the same as heliproz?
- Raptor 30 V2 Clutch Bell
- Very nasty chatter sound when comming out of hover ?
- Rear servo mount?
- Delta Angle ??
- Working range of Hatori 970 tune pipe...
- My Raptor 70
- Rappy 60 body on a 50
- servo selection
- rap 30 2 50
- Tail Rotor Slipping
- Piston Lock alternative
- Raptor 60 V2 Paddles help!!
- uni- flow setup
- R 50 V1 or R 30 V2?
- Carbon blades for my Raptor 30 V2 ?
- Raptor 50 CF Blades
- Nimh charge time
- Lost TT39 Manual
- Os 91 Problem!!!
- Raptor 60 v1 to v2 kit where to get in UK.!
- final setup help
- TT70 wont start
- Rappy clutch
- how to be a TT field rep ??
- Gyro Problems
- V2 pipe broke
- Best Place For Raptor v2 Upgrades?
- H.H servo?
- Cheap Glass Blades
- Gyro issue
- Raptor 30 v2 Pitchynes
- 50V2 manual now available!
- Decals
- Newbie Blade Tracking?
- Ball links?
- Why use a governer
- GY502 for Raptor 50
- Raptor 60 v2 with the wobbles
- Servo Mounting Plates? Raptor 50 V2
- New Raptor90 when is it coming out?
- tail boom rattling noise....help?
- ? about reversing gyro direction
- TT .39 question
- setting up csm560 on T9zhp
- 60 V2 ARF or kit?
- what governor?
- Scale Fuselage's
- Suddun Loss of Altitude
- Raptor 50 V1 & V2 Manual's
- First auto
- "Raptor-Mad"? Buying a raptor mail order in the UK
- pipe HATORI or CY MP or ? for a rap50
- Raptor 30- Strange engine sounds....
- Raptor 90 OS91SXH best ratio?
- Its not pink its magenta !
- V2 60 clutch engagement
- Oily Helicopter(Normal?)
- Fiberglass body for Rappy 30?
- Ys 91 st
- R60 questions
- OS61 Raptor 60 V2
- tt .39 proper temp. range
- R30 v2 with RD8000.... help
- High-Lift Blades for Raptor .30
- 50 v2 servos
- Color Me Impressed
- Rap 60 & TT.70?
- V2 60 question , does this look right
- Engine dies in idle up at 100%
- Raptor 30 V1 gear ratio
- UPS Shipped my Raptor 50 to wrong address!!!
- I need your help about gyro for my Rap50.
- Futaba 9CHP setp for Raptor 30
- ? raptor 30 & 50
- plug and carb seting?
- FMA PS500MBB servos on a Raptor 50 V2 Heli.
- Help building V2 60
- Raptor 30 V2 difference in Stock Vs Pro?
- Help with the TT36 I cant tune
- Carb.
- TT 50 on a V2 50 Raptor
- Which Fuel for TT39
- crank broken
- 46FX-H Carb Modification
- OS 50 throttle barrel sticking?
- R 60 assembly questions
- Just got a Raptor 30 V2 !!!
- TT carbon blades
- Raptor V2 TT.39 upgrades while building
- understanding raptor 30 part numbers???
- Blades Going Out Of Track
- Noisy starter shaft?
- Best deal on Rappy 50v2
- Is this a clutch problem???
- Question about Rap 30 and Cal 30
- lets see some raptor 60 pics
- Raptor 60
- V2 50 0r V2 60 ?
- raptor 50 n electronics advise
- best heli in 30 class
- Check out my new Raptor 70
- R50 Fueling Problems
- TT .39 like it or prefer OS .32?
- couple of questions
- airtronics 94322 and RAP 50 V2
- Where can I find a Raptor 50?
- Raptor V2 & Futaba 9c
- I have just bought Raptor 50 V2.And need your help.
- Blade Articulation
- Raptor 30-v2 pro/sport
- R 60 and fuselage
- Wacky TT39 Engine Tuning
- Rappie on Floats
- FMA Co Pilot & Raptor V2
- Raptor 30
- pitch range?
- Help With Pirouette Rate
- Are TT carbon fiber blades any good?
- After about a 2 full tanks of hovering on a 50, i went 60
- Autorotation unit ?
- First Maintenance Incidents - R30 V2
- Raptor fan coming loose
- My Raptor 30 V2 Pic
- Throttle servo setup
- Raptor 30 V2 wanted!!!!!!
- Raptor 50 is AWESOME!
- Operating temp of a TT.39 and...
- lots of ?'s
- Raptor v1,v2
- Huey 60
- Raptor 50
- 50v1 or 30v2?
- Converting a 30 to a 50
- OS 91 won;t run
- Help With Learning to Auto!!
- Raptor 50 or 60?
- 120 Degree CCPM vs. Original Design?
- Raptor 60
- 4500mah pack on R30 ???
- Good Choice??
- Futaba FF9 Set Up
- raptor 50 with a 32 os engine?
- Raptor 50v2 Servo Installation
- Is the V2 50 tail heavy also?
- Raptor 30 V2 Vibration Problems - Crosspost
- recovering blades
- Governor basics
- Raptor 30
- Which one is better between Raptor 30 V2 and Raptor 50 V2?
- Anyone here in MA close to Boston
- Raptor 50 v2 Positioning Of Stabilizer Fin
- Raptor 50 V2-Tail Assembly Question
- Best begginers Heli?
- Where to buy a tt 30 V2 ARF and the best price
- Wiggling Raptor
- What to buy R30 or R50 for beginner ?
- Head Broke Of Clutch Bolt !!
- Why a flybar lock ?
- Gluing main frame?
- i'm looking for raptor problems
- 30V2 vs. 50V2 performance
- Raptor 60 v2 upgrades
- Fma=co-pilot??????????
- My Raptor
- 30/50 confusion
- Raptor V1/V2 Clutch
- Raptor 60 v2 advice please
- Are the main blades in my kit ready to fly?
- What shall I do?
- 50 V2 Engine assembly..... assembly.
- Lets See Ur "Naked" Raptors
- os 50 low speed needle
- Raptor 30 V2 kit questions
- Raptor electronic suggestions please. Servo's, Gyro etc.
- TT 39 tuning
- Model Difference
- Webra 52 installation in a Raptor 50
- Fut 401 w/non-digi servo (30 V2)
- Raptor 50 V2 engine fan assembly
- Now where did that retaining ring go
- rator 30 with os 46
- 30 or 50 v2?
- Carbon Arrow Shaft Pushrod
- R60V1 to V2 upgrade
- NEW Raptor 50 V2 COMING !
