- lst thrust bearing problems!!!!!!!!!!!!!!!!!!!!!!!
- How loose are your spur gears?
- In Off The Post.....
- How do I host a vid?
- SEIZED MACH?
- Rc solution roll cage
- ROUTINE CLEANING
- New Era Shock Tower BENT...
- Where do you take your's?
- 40 SERIES BOWTIES
- LST PICS!!!! NEW BODY AND SHOES
- Looks like I have to buy a new LST
- Steering servos?
- Got Shoes?
- Tape it up!!!
- Picking a replacement engine: Questions
- LST PICS
- Is the LST a good truck?
- wMach .26 running HOT!
- need help posting pics
- Fuel Consumption
- LST Racer Body--Does it have an overspray film on it??
- My New cp2 Body
- Painter Snob....
- 4-Wheel Steering Mod
- is this all what i need???
- Transmission grease
- Please Help...Broken screw - how to get out?
- Shimming the pinions after the clutch bell?
- Collari Carb
- FUEL
- Stock brakes just seem to have lost their power.
- Does anyone have...
- Dynamite exhuast swop
- brake noise
- front bearing
- First Video!!!
- Removing con rod from crank in MACH .26
- how clutch for me ? ?
- Can I use regular 'Engine Degrease' for car to cleanup my LST after run?
- Pro_line 23mm Hex's and Wheels
- lst servo saver
- project azteklst done!!!!!!!
- IMEX Jumbo Swamp Dogs???
- Custom Skid Plate
- Toe in help. This too much? pic.
- Skid Plate Screws
- glow plug and fuel
- High/Low gear
- Tires for LST
- need help about glow plug ignitor
- LST ROLL CAGE
- Mc59
- Direct Fit Clutch Shoes?
- NEW LST
- ok...batteries ??help out an old guy
- Basic Tuning Guide
- Drive problem
- bent pipe
- Cvd s
- SCREWS???
- My new CP2.0 by pyrographix
- Anyone with a CEN Genesis ???
- Airtronics 94358's with Kimbrough's
- Smaller Tires
- Catching inbetween
- New Tranny Case - l Left out a shim. Is this okay?
- T-Maxx vs. LST
- Spaztix paint
- Engine Tuning
- LST, yes or no
- Need Help "Washer"
- LST stock spring lb rating?
- it happened!!
- Tsais pipe for lst
- Need help about bleeding the shocks?
- Gears are not lining up looks like. Help would ya
- Driveline binding
- A tale of a Werks clutch and an SH.28
- Looking at my glow plug........
- Help with clutch springs
- Breakin in my SH 28
- New Lst owner..
- new backplate - now i'm stumped..
- What happened to the forum!!!
- where did all the forums go????????
- Finally got pics
- best way to the flywheel
- Stripped Screw in Cooling Head...
- slipper adjustment...help!!
- wats wrong??????????
- RD LOGICS PIPE FOR THE LST
- LST purchase
- Does anyone know....
- Titanium Nitride (TiNi) Pinions and Spurs on.
- LST project now Complete!!!!
- Here's a few pics
- LST Roller FS
- 2speed bushings - only a small problem :)
- Team Losi Super King Pin Tires INFO!
- BRT1's and Wheel Wobble
- Reciever Batteries
- Blocked screw hex holes.
- RamSavageLST
- Time to break away from the stock body..
- WHAT IS "2/3 alignment problem"
- could you use this for an e-lst?
- CNR Hexes
- which should i get....
- Lil help here plz
- antena wire gone
- Need some troubleshooting help PLEASE
- Carbon Fiber parts thread......
- Forward only tranny
- wheres ''jefx''???
- LST Alloy Diff Cups
- One way bearing slipping? HELP!!!
- integy aluminum shoes on a lst
- My Mach exploded
- Stock losi tires
- LST VIDS!!!!! ALOT!
- Idle seems to hang a little
- Will a HPI S25 Head Button fit the Mach 26?
- LSN Setting
- Steering Servos/rx Battery
- New LST Number 11697
- Lowest truck # w/no washer ??
- Tunne up - Turn Needle
- Diff noise, with new alum diffs
- servo problem
- output shaft in the tranny
- Sportwerks Carb ???'s
- metal gear for roto start drill
- what size of the backplact philipe screw
- Anyone buy the .26 werks motor??
- Extra long body posts - support brace too wide?
- leak problem
- I made my own!!!
- mmm don't put too much after run oil
- INFO ON RECEIVER PACKS
- Aluminum aftermarket arms.
- Is there a perfect lst yet...
- need help
- slipper setting
- What's up with my mach?
- temp problems
- Removing Axle Stub
- What charger are you using to charge your packs?
- LST finally gets a new body.
- HELP!!!!
- Need a quick favor
- Titanium Axles
- ALUMINUM A ARM PROJECT !!!!!!!
- LST not unbreakable
- whats you"re favorite lst body?
- 2 Speed gears????????
- Did you change the shift point when going to proline 40's?
- Rear toe link alternatives
- Just quit moving
- Hot Racing Arms broken nut
- Arrived my SH .28 engine! (pics!)
- so does my engine have that washer..new LST pics..thx
- LST not getting fuel..
- What Springs and Oil to Use
- Pipe striper
- RACE RULES after reading the drake thread
- electric LST
- 590 servo on Throttle
- Stripping 63 & 70 Tooth spur gears
- Custom machined CVD axle
- Truck bag big enough for LST
- Optional mounting for sec gear cover?
- mach problems
- They're Here.......
- Fluids!?!?!?!
- Problems Starting Flywheel
- Stupid Mistake...Don't Laugh
- CUSTOM TEAM LOSI STAND
- Dying wheels
- New Era Wheel Hexes
- BRT 1's on SALE
- ok whos selling there lst...
- Best way to remove chrome?
- What a weekend!!!
- mach break in ?
- How much should I ask for?
- Just a few LST questions
- selling revo
- Regreasing my diffs
- Can't wait! Just ordered the BRT1's/Pentos!
- What do you guys use for assembly grease?
- Thank-You Horizon Hobby!!
- Help needed. Starter slips...
- TRINTY MONSTER FUEL comparo BLUE CHUNDER RACE FUEL
- .46 CONVERSION
- Anyone know if there are longer drive axels?
- where to buy
- Losi Hexes ?
- LST Parts List- Need a part or upgrade look Here!
- My upgraded steering mods for the LST...pics
- Alright! finished my first video!
- Trying to choose a radio
- Motor Plate & Chassis Brace
- Are quality parts getting cheaper?????
- Airtronices 94358 servos/ one servo steering?
- broken drive shaft
- Question about "limited slip"
- M8 aitronics radio batteries???
- You know your dedicated to your hobby when...
- Proline HD
- AFTERMARKET DIFF CASES
- battery plugs
- Top Five Mods for My LST
- Racer bod.....
- LST W/ O.S. Max .21(P) -X ???
- Compression Question???
- SAVAGE / Losi DUEL tomorrow!
- Damn Chrome Pentos- LOOK
- lst at the track today
- i got this cool work stand....
- Ring gear screws
- Replacment Hex driver bits!
- How to test if the fail is working or not?
- Jammin JP-1 = Amazing
- Radio Distance?
- engines
- I think I killed my Mach .26...
- All with SH .28'S -- please report!
- Has anyone ordered a SH .28 at rcmodel.com.hk
- Too Much Money Vid w/ LST
- Notchy feeling going in reverse
- Velos....29.99!!!!
- Just a few more pics so I can post in Banned Rc
- Pic's of my LST
- TI NI full gear set conversion in the UK at last.
- first attempt for making a video
- Racer Body?
- Collari .30
- The U.S. Monster Truck Championships Sept 24-25
- Diff question - extra shims?
- HELP WITH SH PULL START
- Need suggestions / recommendations for speed.
- removing the screws!!!! Red threadlock
- Clicking on reverse/forward shifter
- No washer in schematic.
- Frequency question
- power shift?
- UPGRADE PIPE
- JR Race Tq vs Tq servo???
- Pull Start Options
