- Looking for Soaring Competition Leagues
- Finally flew my BoT
- Stolen OLY II
- Hot Lining
- gental lady
- TOONS
- Big Bird XL Construction Pic's Anyone?
- World Models Big Wing
- Is the House Of Balsa 2x6 Worth Building?
- a Bubble Dancer coming this way
- AR 500 receiver
- Multiplex Blizzard. Tail failure
- Craft Air Leo
- CULARIS - Powered Glider / BIG FUN!
- Hello from Phoenix AZ!
- Big Bird Wing Sheer webbing
- SF East Bay Slope for Northies
- 9m ASG29 Glider initial fligth
- Glider brushless suggestions
- Cutting in Flaps ~ Any tips?
- Obechi veneer
- Hobbico Upstar Q
- epp V tail Jart ?
- Info on HobbyLab SR-71
- 3.1Meter FVK Model Graphite
- spirit 100 arf 2500mm
- toughest covering for foam?
- Suggestion for light lift slope glider
- How to make a wing with hotwire
- robbe flying wing
- Freudenthaler folding props
- Slope Soaring in San Francisco
- Bird of Time Tail Feathers
- glider plan
- Slope soaring in the Netherlands
- Please, help to find Hotliner with not solid wing.
- Radian - a new e-glider from Parkzone
- ***** Big Contest - Oct 4&5 near Reading PA
- Omega II 1.8 e interference problem. HELP!
- Foka
- Sky Bench Aerotech Lil Bird 2
- slope soar off your nose
- Hiking or biking to flying sites?
- Which wing configuration to build?
- I need some help selecting a brushless outrunner
- foam glider manufacturers?
- SZD 55 SIAPLANE BY JISPRO
- setting up crow in a cularis
- melody 1500 with twin edfs
- Listen To Podcast with World Soaring Champ David Hobby
- Help! - Thermic PROWLER, buildinginstructions, photos?
- Any Southwest Mo. gliders giders???
- Colorado pilots?
- Anybody Converted a CMP Discus to Electric powered??
- Need Help!
- propeller not folding?
- Flap settings?
- Sig Riser 100
- 133" V-tail glider.. Need ID
- Visit The Glide Fast Journal Blog
- E HAWK 1500 OBL29/09-07A Brushless motor timing and frequency problem
- Intermmediate airfoil, help needed
- CAN COMPETITION BE USED AS A TRAINGING TOOL?
- Micro Spirit, check it out
- WHO MAKES THIS
- plane set up help
- Hey crew, new to gliders - need some help.
- Anyone know name of this sailplane?
- Airworld 4m Fox
- Spirit 100 kit discontinued?
- Leaving for Egypt with Easy Pro Glider
- MOTOR GOES HOT -HELP PLEASE
- Can any one identify this SailPlane?
- Help ID 2 meter glider.
- Pusher type electric sailplans-suggestions
- A Eagle..
- Alcyone 121- motor mount placement?to electrify
- Fuz for - Protech Ultimate
- A little too windy tonight..
- Bridle Harness
- "Bird" type sailplane designs?
- I need some basic termal glider measurments for use in a new design.
- Have some fun - 9/20 and 21 - Long Island NY
- nesail or espritmodels
- Landing 3.5M Long Fox Pinnochio
- 100" Carbon fiber plug-in, help needed
- Hobby Lobby DG-1000
- Bird of Time tailfeathers
- Graupner Cumulus XXL
- Best tape for taped hinge?
- Mistral
- Ailerons or not??
- RJ 5 sailplane
- Apache DLG
- SETTING UP EP GLIDER TO USE UP-START
- Multiplex Easy Glider Electric
- Oly II instruction booklet
- E-flite Ascent 450 Brushless
- 9 CAP radio setup
- Robbe Geier flying wing glider
- World Champion Thermaling Seminar
- Open class sailplane V-tail servos / Hybrid
- JR 12X for a Supra setup
- how much flight time of a discus launch
- aero bird wings and a cardboard tube
- Fixing and AVA elevator mount
- id help rhonadler-ka
- Battery overheats and RC motor stop working
- ANYBODY FLYING A DYNAFLITE BUTTERFLY ANYMORE?
- ARF
- Anyone need foam cores cut?
- WACO Beta
- Graupner Maxie Sport 3200mm motorglider
- Thermal Sailor or Vista EP
- Multiplex 480/4g motor mount
- Bungee Launching Video!
- Sailplane Wing Balance
- Need Receiver Suggestions for JR XF421EX Radio
- Determining altitude
- Landing skid for glider
- Bruckmann Modellbau Gliders????
- SL Models Salto H101
- Can you name which giant Fox glider
- Schweizer SGS 1-26 4500mm 14.5kg
- Finished Ferox!
- Fuse reinforcement: best material
- Hangar 9 Aspire power plant
- Combat Wing Tape
- show us your gliders
- Hobie Hawk fuselage painting.
- Hitec Eclipse 7 (synth) or Futaba 7C 2.4?
- Triple Slope!
- NEED IDEAS FOR DROPPING GLIDER FROM AIRPLANE????
- CAUGHT MY FIRST THERMAL!!!
- > BUYER BEWARE <
- ASH 26 6m in action
- Lost on Temple Hill
- My new 18HP wacko-winch
- Secrets of Thermal Soaring
- Old School Gliding: No motor just a camera that so far still works!
- R/C Solar Powered World Altitude Record!
- Aero-Towing
- Electra power
- lost glider
- Hobbico MSG 12 Metal Gear High Speed Micro Sailplane Servos
- Lynx-e Build help
- ASW-22 BL 2.8M
- CMPro Ventus- 2HX 2600mm
- Felix
- how do you put an image on posts
- What would be a good first glider?
- Can someone explain thermals???
- E-Sprit Manta-E sailplane
- Balancing folding props ????
- FROG Diana
- Free plans thread
- New Fleet (needing repairs) UPDATE W/PICS
- TMRC-sailplanes, how to contact.
- Spectrum dsp75 digital servo?
- what flying do you prefer
- Hitec Eclipse 7 Program for RES
- peak hobbies' "Sights EP"
- Ace Quasoar Manual?
- Good electric setup for kit built Bird Of Time..info here!
- Sagitta 900 glass fuse?
- what brushless for 2m sig riser?
- Can I plug a 7.4 lipo directly into a receiver?
- Multiplex Blizzard hotliner
- Reconsidering The Monterey
- looking for a really big glider kit?
- Electric tugs
- New HLG Contest Video Clips.
- Sailplane towing - cradle
- Pulsar 2008 or Hyper 2.3m
- Easyglider Tow Plane?
- Tug plane tow release
- Towing gliders to altitude, risky?
- 78" sig riser aileron conversion
- Advanced Sailplane
- Glider/Sailplane Flying in North Carolina
- re-covering modified wing question
- 2.4ghz radios with sailplanes bad or good?
- Glider suggestion
- Slopes in Peru (In response to Evan-RCU)
- 4 meter foam wing structure???
- New guy, old plane, new question
- 1/2A Pull a Gentle Lady?
- Ez glider pro
- Vista EP trim problem
- competition rc model
- Choosing the right one for a beginner
- New Standalone Altimeter and Airspeed Sensors starting at $37.99
- Recomended slope planes to fly Eagle, Kiona in WA
- F3B, F5J F3-WHAT?
- Anyone built a Big Bird w/Flaps & Ailerons???
- electric power for 160in glider
- New to RCU
- Full House setup for Spektrum 7
- Flap/Spoiler Rigging
- CF Tail Booms
- rogallo wing glider plans
- Kyosho Soarus Power System Recommendations
- Sailplane - Spoiler or Flaps?? Or Both??
- Question
- bird of time to eletric : which motor size, prop, esc and battery
- Lipo batteries - What voltage?
- EP Setup for sailplane w/AXI 2820-10???
- Bird of tme as a begginer sailplane?
- Aerofever ASW 28
- Multiplex Easy Glider suggested battery?
- fling dl
- Super Dimona
- Resurecting a Lovesong
- Guppy spoiler/flap setup
- Kill Devil Hills - outer banks NC = slope flying??
- Jeti 40 amp controller - Need some info!
- putting together a electric power pod for 1oo inch glider ?
- Newly Tested Elliptical Zagi... Any comments?
- Servos For Big Bird - Suggestions
- Which covering to use?
- Aquila CG?
- windstar glider
- EVO 12
- e-dynaflite talion?
- pulling Segeta sailplane out of mothballs
- Model Rack
- Wing covering for Sailplanes
- Wing building tools - jigs
- paint
- Bird 3000 (Electric BOT) aileron trouble
- 2 meter X models Whisper
- Help Raise Funds For US F3J Team
- cularis and thermaling
- Wiring Wing servos?
- Macchi Glider
- A not-so-newbie returning with questions...
- ST Model Easy Fly
- Multiplex EasyGlider Elecric
- Got Rudder?
- Big Bird - Any Opinions?
- EP Sailplane 100"/Motors - Any Opinions
- Best way to hold down the hatch/canopy?
- Gental Lady/Sophisticated Lady - Any Opinions?
- Airtronics Olympic II - Any Opinions?
- Icare Jantar Sailplane - Any opinions?
- finally found a gentle lady!
- CMPro Discus 2.6m or Multiplex Cularis Sailplane
- Is an Eflite 450 enough power to launch a sailplane?
- Step up glider
