- engine cut off question
- Raptor 50 Engine mount PV0107 Dimensions
- boom supports
- High altitude Raptor 50
- R 50V2 Frame Flex?
- clutch runout
- can you flip the tail rotor over on a Rap50 V2?
- Gyro question
- good (cheap) batteries
- Contemplatin my own stupidity :)
- Engine Compatibility Problem with Raptor 60
- Titan vs. 50 V2
- Titan Strange 2nd humming sound
- I hate to ask about batteries, But i must. Sorry.
- TITAN VS CALIBER 5
- raptor 30 blades
- Servo speed question
- Tail wagging
- Engine Tune inconsistent Right side up and Inverted
- picture of ur raptor
- BEST/DECENT head for raptor 50??
- carbon fins
- TT70Pro question
- Switched to 30%, Help!
- ACE HOBBY SERVICE
- I WANNA BUY A TITAN!
- raptor 50 nose dropping
- Muscle Pipe II Quiet Vrsn
- Mavrikk pipe or Macs
- R50 V2, OS Hyper 50 low speed needle adjustment
- Replaced clutch&liner
- raptor 30 on os 32sxh
- 30v2 vs 50v2
- 401 gy adjunstement
- strange pitch range
- BALL LINKS
- Strange tail jerk
- hot 36 pro
- Are these good servo's for me?
- servo help please.
- fuel dripping out of carb
- OS 37 in a Raptor 30 v1
- Auto rotation gear
- Heli shaking badly
- JR throttle curve
- R50 Main gear question
- R50 Twitching
- slow yaw turning
- second heli but still n00b
- Reccomendation for Rap 50 throttle governor?
- Raptor 30 V1
- Beginner! *Another One*!!
- Throtle Pitch curve again
- yes more questions for you to answer :):)
- Blade and bladegrip question
- About Engine Tuning (once again :))
- OS hyper problems
- wooohooo, my first Raptor in the bag!!
- Hyper Raptor 50 Titan Tail boom loosens
- servo sizing?
- To buy or not to buy, that is the question?!?!?
- Battery Setup for Titan
- Raptor 50SE Assembly help, clutch bell hitting main gear and more problems.
- Tail vibration on R60
- Skids on a 30 V2
- 4.8v or 6v???
- Throttle/Pitch curve help please
- Raptor 30 question
- Performance Devices opens RCU member buy site!
- Is the TT 70 engine any good?
- 6102 to 8103 Rap50
- Automatic glow heater?
- Landing Skid Nut ?
- Fuel Contamination question
- small paddles
- raptor paddles
- looking for Full raptor kits with radio
- Skids want to fall off!
- Coolpower 15% or 30%
- raptor 30 v2 engine upgrade
- GIANT RAPTOR PARTY!!
- Blue Carbon Fins - Who's Selling Them?
- R50 V2 Tail assembly
- Clutch question ?
- Carbon fibre is like GOLD (to me)
- RAPTOR engine head temp. OVERHEATING??
- Raptor 30 Noob
- raptor 50 fast forward flight
- Rap 50 wobble at mid stick?
- TT70PRO Tuning help needed
- Neoprene clunk line question
- RAPTOR .30 Cheep!!!!!!!!!!!!!!!!!!!
- flybar play?
- R30 V1-V2 conversion???
- Preventative maintenance? Rap 50
- raptor 50 AP gyro selection?
- tail blade sizes
- Rap 50 Heating up?
- second hand raptor. things to do!
- Excessive Head Speed!
- Tx, Rx battery cycling
- Throttle curves
- Channel/servo/gyro setup
- Governor and Field Charger
- Pls help, tail prob
- Wich engine for my Titan
- Raptor 30 Or TRex
- TRex OR Raptor 30
- wat equipment do i need to fly titan
- Suggestions on mufflers?
- Digital servo question
- Can I fly a 30 with a 6ch RX?
- Loctite 601?
- Blade Tightness?
- Looking for a Raptor 50!?!
- ZERO TENSION ANTENNA SETUP
- Some Tips On Refining My Setup Please?
- rap 50 clutch jam
- WHERE TO FINE ?
- How to do nose in
- What Is Triflo?
- R50 night blades
- dyeing canopie??
- Raptor 30 losing power inverted
- Help with Raptor 50 purchase list
- 90SE root size
- Raptor 50v2 falling out of hover.
- 30v2 with new os50
- Raptor 90 starter shaft question.
- check spindle bolt twice
- Newbie Raptor Question
- Resonants
- First Flight of the Raptor 90 PICS ADDED!!
- My Most Spectacular Crash In 17 Yrs Of Flying
- need bigger gas tank raptor 30
- Main rotor pitch housing (blade holder)
- OS .91 SZ-H Engine Tuning Help
- Wooden blades
- OS 50 Hyper in Raptor 50 Titan
- Practicing Autorotation Hyper Raptor 50
- Cosntant Tail Drive or Belt drive on R50 SE?
- TDR METAL HEAD DEFECT? to much clearance in bore?
- Whats ur crazy Raptor 50 setup?
- Velociraptor 90
- R90 Troubleshooting assistance Gear Mesh & Start Shaft Alignment
- R60 Stock wooden blades question
- how long can a raptor 60 fly?
- after run oil
- Raptor Titan help
- 30 V1 to 50 V2
- Raptor 30 v1 blade grips wobble
- got a new deal offer....help plz...
- Raptor 90 T/R setup
- Webra 50 Heli Engine in rap 50, best fuel?
- TAIL SERVO
- gohbee and a raptor
- need purchase suggestion
- raptor vs hawk pro
- what makes x cell better then raptor?
- Feels better now that someone else has looked at it...
- Max Oper temperature OS50SX-H Hyper?
- Raptor upgrade advice, please
- Raptor 50 colored exhaust deflector?
- R50 clutch not clutching.
- pinion gear and spur gear on 90
- my first flight in my Rap .30 V2
- secureing heli-max .30 training gear?
- hot starting!!!
- What is the ideal temp for TTPro50H?
- Raptor 50 Lifting power
- its 3d time! (need help)
- Loose skid bolt blues
- OS Hyper needle settings
- Anybody in Fort Worth, Tx area?
- I cant get nothing right, R30 V2 Tail and/or Gyro problem
- TTR 30
- Raptor 50 stability
- engine smoking after hover
- Poorly Finished wood blades
- What Raptor to buy?
- verry bad radio problem..need hellp!!
- Recomended servos etc Hyper Raptor 50 Titan?
- raptor v2 cluch problem
- OS 70 spool up sputter & die problem
- Hows my heli look? First Flight is closer
- over kill for raptor engines?
- raptor clutch gear - HELP!
- Head Binding in R90 STD
- Bearinng oiling/greasing Question
- Just got my Raptor 30 v2
- YS .61 ST
- what would work for me?
- Help! What did I break?
- Engine wont turn
- TT39 Engine Tuning
- Need help on Vertical setup
- wood blade covering loose
- MOVED: screaming engine plz help
- Carbon Fiber Skids how fix the rails
- Watch this FULLY AUTONOMOUS Raptor 50 Electric
- Blade balancing, how close is close
- raport 30 v1 problem
- Finally Got it all together!
- greaseing main shaft?
- Raptor 30 ?
- Can't decide?
- BK0478 Rotor Spacer for Raptor 90 Blade Grips
- Raptor 50 EVO
- raptor 50 titan problem (BIG ONE)
- 30V1 for sale
- Raptor 90 Gearing/Blade advice
- FIRST CRASH
- clutch liner for raptor 60
- ERGO 30
- Which Radio?
- Venting a OS 37
- Raptor 30 Grounded
- 90SE vs 90STD
- Ok i dont get it, 30 V2 Assembly
- Best Deal on a R 60
- who youses the carbon frame brase on the rap50
- The madness has begun....
- washout play
- Start shaft
- Help identifying an OS 91...
- arial video of my house using my raptor 30
- Best engine for 90SE
- Raptor 50 Head Speed For 3D?
- keep it cleen ***
- flying in tauranga
- Raptor 30v2 batt voltage 4.8 or 6.0
- Wow*****Chrome upgrades*****
- Rap 50 upgrades
- From a 30 to a 90 advice.
- Engine choice Raptor 60
- Does the orientation of the bearings matter
- big bubbles in fuel tank? HSN setting
- the good old debate! NiMH or Nicad?
- Raptor 90 and JR 9303 Setup/Programming
- Raptor .30 Hard to Tune?
- how long till inverted??
- tail gear box greasing
- Raptor 50 V2 bucking problem?
- R90SE full build review
- I WANNA BUY A RAPTOR TITAN 50
- Odd cyclic-type wobble..
- OS.50SX-H will this fit into a rator 50?
- Titan 50 build
- carbon frame brace?
- where to buy cheap blades
