View Full Version : Speed - Electric
- Battery or esc issue?
- Prop from transom distance
- genesis help
- 4074 2200kv timing
- huge scale FE race boats
- ESC timing and PWM advice please
- ESC Motor connection?
- Super Hawaii Build - Dual Outdrives
- Offshore Prop Size and Weight Distribution
- Teflon liner question
- water cooling o ring help
- Renewing a 27 year-old, 17" rc boat, need help!
- RTR Boats
- Fe boats
- FE Minimono setup
- 50" Fountain Deep Vee Powerboar P1 Setup
- FLEX DRIVE SHAFT SET 3.18-4mm Help
- Very cheap boat for a gift
- What is this hull?
- 50" deep vee twin setup
- Boats wave jumping on the creek
- 1/10 scale crackerbox scratch build
- Brushless Balaenoptera Musculus
- VS1 HELP, nearly caught on fire
- Pulling the Trigger on Motley Crew - Could use assistance with add ons plz
- possible lipo cut out?
- Yellow Bat...needs more speed ???
- Making a decision on a Father/Son electric boat purchase
- Velocity Minicat / HK Centurion questions
- Help picking motor for a 29 aeromarine cat?
- Mono Unlimited Fast RC boat?
- Miss Elam improvements
- 32
- narrowed it down to 2 choices for my xmas gift...which one
- Does anyone have experience with the Ammo 36x88/1280kv motor?
- Help please O wise and learned ones
- Castle 1410 3800kv 4 pole in a Revolt 30"???
- why the rule of Hydro1 is 5 minutes,Mono1 is 6 Minutes?
- Super Boat "Outrigger TH"
- Arowana melt down
- Distance betweeb stingers?
- Revolt 30 or impulse 31 v2?
- CAN ANYONE HELP DIAGNOSE THIS??
- GENESIS Twin Setup
- Alibaba-Buy??
- Joysway hulls
- How to make a Cat. backwards slightly???
- Miss Budweiser
- Night EDF Boat
- ProBoat Impulse 31 V2
- Help Getting this Boat Running, Yellow Bat
- Setup , which one...?
- cooling question?
- GENESIS TWIN CAT ESC HELP
- Looking for help with Yaht
- 3/16 on 5 mm thread
- Problem with brushless motor
- my first paint job ever
- Octura props - Help
- Turnigy cobra
- Who is a EE guru or electrical enthusiast I NEED SUGG.
- I need your advice about a setup
- I ran my new Minimono today!
- TRAXXAS SPARTAN - SEPARATE WATER PICKUP FOR ESC AND MOTOR
- Atlantio 059' upgrade and water cooling
- Battery issue with a VS1 using proboat outboard
- New project boat
- Bought a boat, esc puffed! :(
- need help with motor water cooling
- Aquacraft Minimono what should I be aware of?
- Proboat Mystic and Geico
- fiber glass boat repair
- Do I need a seperate harness if I have 5.5mm connectors??
- Returned newbe - SPEED ELECTRIC
- STRETCHING A HULL...IS IT POSSIBLE ??? Old Graupner Systems Cat build
- TRAXXAS SPARTAN ESC
- 2.4ghz receiver antenna question...
- Help with traxxas boat
- new guy wants boat
- X cat project
- Need help on 40c, 50c, 65+c ratings..
- Turnigy / Seaking 180Amp ESC hack
- 32
- CNC props?
- Converting IC to Electric
- LIPO Battery Swelling up
- VS1 with Proboat outboard
- Bearings instead of brass tube for flex shaft
- Traxxas Nautica ESC Specs?
- How would YOU do 8s?
- kintecracing's Zonda Cat
- Is it the EPC or the motor?
- Hunter 69"
- KOS P1 Best Up Grades
- Closed
- firbeglass repair help
- "Gas" King of Shaves brushless conversion...
- Thunder Tiger Outlaw Jr OBL RC Boat Brushless 40a ESC
- High C rating Nano's desoldering my wires.
- Who makes this outboard drive?
- Please delete
- Batteries
- To UBEC or not to UBEC? (help)
- Miss G 235$
- Miss gieco batteries?
- Lets see those boats run.
- Any Central RC Hobbies 54
- Aquacraft nitro hammer electric conversion suggestions
- OSE +++
- getting started
- How low can I run 14.8Volt 5800 Lipo's
- Converting to boatism
- New vintage acquisition and help needed
- System too hot! Whats wrong???
- Ordering lipos...
- Why is this happening to my Geico ?
- Advice on thunder tiger outlaw jr. upgrade
- Boat cuts out at just over half throttle
- The new Sterlite Cat
- What really grinds my gears.
- Choosen Offshore Warrior 2 Updates(Video Inside)
- Very Good Batteries on Ebay
- Kyosho Wave Runner
- Mystic with Prather 220+stock motor. Video
- Need Help with Electric..
- need help chosing a kit
- Couple of beginner questions
- better battery
- 3.5 K&B Outboard cowl cover
- Festival running, what boat?
- WTB MRP outboard
- UL-1 will not plane
- New tunnel hull concept
- N
- Advice to upgrade my 26 Shockwave??
- motor combo
- Made by you. Diy vs. dishing money out.
- Airbrushed Boat hulls
- Advice for lipo selection for my boat
- Flex shaft, Sleeve or no sleeve.
- OLD SCHOOL ELECTRICS
- New boat! Kyosho
- tunnel hull turning
- Proboat mystic pnp with spektrum DX7
- New life for a Venom P1 mono hull
- carbon boat hull
- Setup for Paddle Boat.
- Which boat would you get?
- Feigao 540xl ???
- Where Should My Center Of Gravity Be?
- Nubie, have lipo question
- Proboat Mystic Strutt sleeve upgrade.
- Brushless upgrade...
- A bit of testing & racing.
- bal mus
- I Will Ask Again..........Any GOOD Large Scale Electrics Out There???
- water proofing my ESC
- First run with mystic.Weird noise from drive train.
- 100+mph Delta Force Catamaran
- 600 size brushed motor for speed???
- New sleve bearing on flexshaft. Is this right ? (pic's)
- DIY brushed speed controller
- Homemade Catamaran.
- HUGE FE Radtek with custom paint
- 320a brushed esc
- Miss geico Water issue.
- What Do Ya'll Use For Rescue Boats
- for sale
- Recommended Prop size for 12v 8100rpm boat
- Atomik ARC 58" elect cat
- Pursuit 32, New personal best
- REK outboard legs
- chine walk
- Large electric outboard tunnel hulls
- Motley Crew reinforcments
- ABC 28mm jet pump(driv)e parts?
- SV27 wont stay in the water!
- nqd jet boat with abc pump seal or stuffing box seal
- Help! what to buy to redesign boat
- Help me pick out my first boat
- Apparition hull from hobbyking
- wire and connections adding to heat creation
- How many amps to charge battery?
- New Proboat Products: BlackJack 29, Impulse 31 V2 and more
- how long can you leave fully charged lipos?
- Break away rudder system for proboat mystic 29
- DPI is back!
- new prop upgrade for boat
- Probat mystic 29
- New Kyosho Wavemaster
- Plastic hulls vs fiberglass
- Joysway Super Mono X
- Any new cats out there ?
- Need info on aquacraft SV27 Brushless!
- Longer Run times with Traxxas Spartan??
- V-hull with 2 motors
- Need help please
- crystals
- new flex shaft uprade for imulse 26
- Aquacraft minimono rudder shaft issues !!!
- SPARTAN killer ????? Do share
- Whats the best motor?
- Newbie needing advice on a boat
- electric outboard for tunnel hull
- Heelllpppp......basic electrical Setup
- Proboat Mystic Digital servo
- Motley Crew Info ?
- Genesis cat questions
- Thunder Tiger Outlaw Jr. Brushless
- Rescue plane?
- Aquacraft Revolt 30
- So I've got a Rio EP...flexshaft won't fit.
- First Electric
- 41" Cat Hull Looking for Help with Beginner Setup
- 47inch deep v?
- pb impulse 26 brushless systems help
- Proboat Shockwave 26 Brushless Video
- Need Some help Regarding Cat build and the parts I received!!!
- Brand new Traxxas Spartan No throttle response???
- Finding used FE
- Hyperion EOS0606i AC/DC Charging NIMH??
- marine 550 motor getting hot
- Leopard 4082 2200kv loses power after a few seconds
- New to RC boats 48" PT109 set up help needed please
- ESC recommendation ???
- deleted
- rc boat motor
- Bay Area painter?
- 41" carbon falcon
- HK Genesis 40mm motor mounts
- Looking for the right prop .... here's what I have
- Mystic 29 pnp build
- lost build log !! please help
- 60 mph boat
- clubs in socal
- car electrics to boat?
- proboat apache 550 motor upgrade?
- Electric 1/4 Scale Racing Crackerbox plans???
- Large Scale Electric Boat RTR or ARTR?
- WTB Aquacraft pro fisherman boat
- Looking for Turnigy T600 outrunner manufacturer/supplier
- LIPO- Who makes good matched cells for good prices?
- electric conversion
- surface radio for boats
- Holes in transom of Spartan?
- New 39" Deep Vee
- Aquacraft Mini Mono Prop
- esc/receiver placement
- Spartan hatch
- AquaCraft Minimono Battery ?
