View Full Version : Speed - Electric
- Rio ep stock esc limits?
- throttle just stopped working?
- new Octura 435/3 prop!
- New to Rc universe!
- turnigy 180 on 4s?
- JAE 12g electric?
- FE fun in Vietnam
- Traxxas villain esc replacement or other esc's?
- Hobby City Apparition Issue
- New boat recommendations?
- Help - New to brushless
- What prop could I buy for kyosho viper?
- just picked up a new sv 27R
- New to electric!!!
- Neu problem
- Venom Miss Excite Hydroplane
- sv27R
- Aquacraft rio ep?
- Grease for Cable Lube
- new to boats, rookie questions
- mini cat mono
- NAMBA Racing "what class"?
- I have been
- Traxxas Blast Won't Idle (Sit with motor not running)
- FREYA Mk II - Help!!
- New Boat?
- fast-ish scale offshore boat
- Nitro to Electric HELP
- Traxxas Blast
- Brand new Mini Rio owner
- 25
- Lipo set-up in new Shockwave 26
- Motor, ESC and prop for slow boat
- lvc
- Basic two boats, one radio question
- Brushless motor 1500KV or 1800KV for CEN WaveShark??
- stupid question
- MRP Bud Light Tunnel rides again!
- another 25
- Just bought new Brushless Shockwave 26.. what 1st mod?
- HOR 25" MONO BUILD
- 1/16 scale Dumas boats?
- buying new boat, Shockwave 26 or widowmaker?
- help with hardware for a build
- aquacraft ep-1 outboard
- Outboarder?
- Princess from HK
- Miss Budweiser ELECTRIC
- Older Shockwave 26 Brushless Conversion Finished!, PICS
- Airplane motor underwater?
- My Unstable Mono (Tittan 33)
- what esc to buy??
- Part for Kyosho Twin Storm?
- Help with maiden Lipo Voyage
- cat and mono take 2
- Where is the Miss Budwiser thread?
- Engine ESC and other components
- villain hull
- Getting a good boat! I HOPE!
- Where does everyone find these hulls?
- FLOOD CHAMBER DIMENSIONS REQUIRED
- NEED SOME BOAT OPINIONS
- Traxxas Titan 50mph RTR
- kyosho Viper R with a mamba max 7700kv
- someone check my MATH please
- motor bearings
- ABC HOBBY FIGHTER 550
- mono and cat video
- nqd setup
- radio receiver and lipo?
- HOTR cat and mono video's
- maxamps green series life batts
- Custom Builds
- putting brushless motors in syma century
- SCALING A HULL
- sv27 way wrong
- Laser Cut wood?
- Magic Cat RTR Twin hull
- Miss Geico 29 Catamaran
- blown esc ?
- Help with wirring new motor
- 27" sk daddle motor?
- balancing props
- New Surge Crusher Brushless Twin-Hull R/C Boat (730mm) Plug-n-Drive
- 1/10th scale hydros?
- RC Catamaran Boat Kits
- low voltage cut off?
- WATER JACKET 39MM MOTOR....HELP
- Going to buy an electric boat which should I choose
- Both of my boats Custom Painted!
- Apparition-II Offshore Brushless RC Twin Hull
- delete please
- summer boating pictures
- hull braking
- my 42mm CF prop
- Anyone modify a VS-1 tunnel to electric?
- Motor question?
- How fast have you went?
- HK Genisis Cat Hull?
- how do i stop barrel roll
- My next catamaran
- what is a good starter boat?
- I had to try it!
- Painting my Supervee
- Beginner FE boat?
- SCRATCH BUILT BOAT
- What size Lipo's can I run?
- NTN-400 Brushless V-Hull R/C Boat (450mm) Plug-n-Drive
- JAE FE with SuperVee 27 or ProBoat powered?
- supervee 27 brushless new to boats......
- Sales Timing
- good ESC deal (for brushed)
- shortening a stinger drive
- quick question about lipos
- where we run
- Kyosho Making Brushless RC Boats
- Brushless F1 on ebay, I hope this is a trend.
- ricoracing mono hull
- contest Help
- Post Cancelled (Removed)
- 20C lipo's
- ProBoat Stiletto Tunnel Hull !!
- New Updated Supervee 27
- Bud Select 51" cat
- parallel
- Motor advice ??
- Battery Voltage after charging and after running
- Alligator Tours Airboat electric conversion
- Reef Racer 2 Brushless Project question
- which boat for chop?
- G FREAK F1 BOAT
- need help converting a nitro outboard to fe
- what should i do?
- torque steer problems
- 32" HOTR repair job
- Robbe Prinzess blueprint
- offshore racing
- bass boat trailer
- ELECTRIC JETSKI PROJECT...
- What should i get?
- Sunstorm 600 need help
- HK Small Bolt Hydro same as HOTR
- 32" catamaran HOTR
- HOBBYWING 120A OR 180A ESC...HELP
- lipo batt voltage problem
- Freezing a Motor
- new boat!!!
- Need help!
- Apparition-II Twin Hull w/ Twin motor (800mm)
- Prop Help
- help with prop!
- Help with Prop Size
- electric vs glow propulsion advise
- esc for 600 motor
- Just got an awesom new hull but have some questions!!
- Budweiser Select Brushless Catamaran
- replacing a Traxxas 12T 550
- HOR 25" MONO.........HELP
- lipos
- Turnigy USB linker
- brass shaft tube size?
- The Unofficial FE Rigger Thread!
- Thinking about going brushless???
- New Aquacraft Brushless Motor?
- gamma ray modification
- where to buy octura props?
- 30 inch surface drive build
- electric 8th scale hydro
- New Aquacraft Brushless Catamaran Photos
- How fast dose offshore electrics ship
- A Fast Brushed Motor
- need help with a scratch build cat
- Rudder depth on small boat
- hull questiion
- quick voltage cut question
- adding caps to esc
- HOPF twenty 9 MK2
- Brushless mini wildcat
- Need some?'s answered on Batteries/chargers
- Electric 45" mono
- how to contact moderators
- 3 blade prop question
- SuperVee 27 Brushless
- New to R/C and Boats - Have a few ?'s
- hobbyking, tracking shipping.
- Help on pick a set up for a 1377x432mm cat built
- All-new brushless Traxxas boat in June, 6S capable, 50mph!!
- Old Acomms Converted to Brushless SV27 setup Need some help!!
- 40MHz or 2.4GHz?
- GFREAKRACING
- programing esc
- looking for sv27 set up for conversion testing.
- Rigger help
- Anderson Twin Dragon servo upgrage
- 1/8 hydro with brushless?
- motor spinning at neutral position on tx
- villian brushless question
- Need A Setup For Old Boat
- Swordfish Eco-Mono
- I'm doing it - Proboat Bud to FE
- 36inch outrigger hydroplane
- Strut length VS hole shot
- LiPo newb
- ESC help!
- Is this the right motor?
- is this right?
- ProBoat Miss Elam
- Prop question
- Traxxas Villian EX. Should i buy??
- Watercooled motors
- lipo shrink flim?
- My take on Brushless Mini C Cat Racing
- Portofino Recommendations
- Building my first brushless cat....
- First VIDEO of my boat! Deep Vee 32"!
- How close do cells need to be on lipo batteries
- Storing charged lipos, are they a fire harzard
- Thunder Tiger Outlaw OBL
- connector problem
- Which Electric boat?
- Another lipo help question!
- WHITEBONE TRAILERS
- sv 27 orange paint
- why is the motor so hot?
- 32" catamaran HM Agitator
- Rio EP stabilization
- lipo size for motor?
- Supervee 27 Discontinued?
- futaba 3pjs vs sprektrum dx3s
- HELP! Can anyone Identify this Boat
- 32 inch mono advice wanted please
- which motor to choose
- Arpro probs
- motor volt/rpm Q?
- cutting down rudder?
- boat websites?
- Heres my test run with sv27
- Brushless Motor Suggestion's
- big boat brushless question
- Zippy flightmax lipos and Turnigy Lipos
- Maybe buying an electric?
- first boat with Q's
- newb question on lipo esc n motor
- Sea Twister
- what glue to use for foam and balsa
- battery question
- sv27 brushless questions
- Lubrication
- first boat
- i knew it!
