PDA
View Full Version : Speed - Electric
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. charger not recognising lipos properly
  2. MISS VEGAS BRUSHLESS CONVERSION?
  3. Harbor Freight Speedboat
  4. Proboat Shockwave 26 Brushless Conversion
  5. 31" MONO BRUSHLESS BUILD
  6. twin outboard cat please help
  7. Problems Getting My Brushless Setup To Work HELP!!!
  8. urgent help needed
  9. 33" Brushlees Build help wanted
  10. Laser Cutting
  11. Self-Righting Hull
  12. soldering wires on batteries
  13. What charger to buy for Li-Po NiCd and NiMh
  14. Looking to get a boat
  15. New videos of my Oldschool Boat Check it out.
  16. Alternative Motors
  17. Batteries for Zig Zag
  18. any one got any plans for a small boat
  19. Brushless Elam 1/12 Coming soon!!!!!
  20. SV27 HULK (VIDEO by Genettico)
  21. What kind of boat to get
  22. what esc for a renagade rigger
  23. I want to build a 24-27" jet drive boat.....
  24. Cleaning an ABS Hull ???
  25. Electric Miss Vegas Video Update!
  26. My SV27!
  27. Twin Motor Gearbox
  28. New to Boats!!
  29. Hammer EP Battery Problem
  30. 1210 I 8s lipo charge
  31. ESC recomdations
  32. Looking for recomendations for a electric RC boat
  33. Finally!!! A Brushless RTR Hydro...but
  34. alternative cooling for KB45XL?
  35. DANVO Boats
  36. Just an Idea
  37. Formula Fastech Brushless
  38. Motors Needed
  39. SETUP PHOTOS PLEASE
  40. WOF Hydromite
  41. Blizzard Outrigger turnfin mounting??
  42. charging lipos
  43. Source for small Speed Controller ?
  44. Nitro to electric
  45. SV Beeps 4 times on arming???
  46. Hammer prop and graphics
  47. Two hydro turn fins?
  48. Hydromite CG
  49. SV27 SHAFT PIPE&MOTOR TOTALLY OFFLINE!
  50. what 5000MAH lipos are the best?
  51. OSE Upgraded SV27 Drive shaft
  52. 32" offshore cat apparition
  53. Leaky water jacket!!
  54. 2008 World's Fastest SV 27 Competition (educated guesses needed)
  55. Speed controller issues
  56. Surface drive?New Scratch build
  57. advice on brushless setup
  58. Aquacraft SV speedo not arming
  59. What to run Lipo
  60. Miss Elam
  61. Charging 2 Lipo packs @ once
  62. Villian Ex problem
  63. SV on 7 cells?
  64. ORION LIPO
  65. Mean Machine Build??
  66. need ESC & motor
  67. Faast Boat - Cutoff Help Please
  68. Motor of Choice
  69. NEED THE ELECTRIC GURU
  70. hydro strut surface drive and at sponson line?
  71. RARE FUTABA BOAT!!!!!!HELP
  72. Liquid Tape To Seal Receiver Box
  73. first scratch build
  74. New charger??
  75. PROBOAT APACHE 24
  76. Questions about going electric
  77. Problem with SV ESC and Futaba 3PM 2.4 FASST
  78. Proboat Shockwave 26 Gallery and Tip Center
  79. Spektrum & Speed Controls
  80. what would I have to do to convert a mini-v to lipo?
  81. Mini-c help!
  82. Brushless Shadow Sport 40 project
  83. Boat Recommendation
  84. Here's a VERYGOOD Infrared Temp Gun
  85. Medusa Brushless motors
  86. Cooling?
  87. Maxamps New 2s 8000 packs with 25c discharge rate!
  88. gecko help
  89. 700sc powered villain(video)
  90. Mini-c new-b help me?
  91. can i use ener G 4600 battery packs in a traxxas villain ex
  92. battery time estimation/calculations
  93. SV27 receiver pack
  94. what's a good paint to use?
  95. gecko
  96. supervee goes nuts
  97. feigao 12s w/a pro boats 45a esc
  98. SuperVee Prop Nirvana......
  99. Pro Boat Mini-C RTR
  100. how to no when lipos going bad
  101. SuperVee Battery Packs......
  102. BBY Oval master 21
  103. help with setup for 25" mono
  104. sv27 brussless?
  105. newbie needs help with speed controller
  106. Electronics set up for 15inch (39cms) small boat?
  107. fe tunne Q's
  108. AquaCraft Mini Rio Offshore RTR EP Boat
  109. Chips in SV27 hull!
  110. SV27 RTR two Beeps instead of one?
  111. Need help with imperial
  112. need help w/setup stuff(building time is soon)
  113. Miss Vegas Electric Project
  114. Which brushless motor in my 28" hydro?
  115. SV27 Help!!! Best way to remove paint
  116. is this a good idea
  117. Traxas Villain U-joints?
  118. Stinger drive
  119. charging integy 8.4v 3600s
  120. Brushless Acomms back again With videos
  121. Anyone run 14.4V on a Traxxas 7.2V ESC?
  122. not real happy with the rigger
  123. position for twin drives for cat?
  124. Will stock sv27 take 5S power or burn up? opinions?
  125. Traxxas Villain EX conversion
  126. outrunner motor for boat?
  127. MHZ mini shovelnose or Tenshock Carbon fibre Mini Bat?
  128. outboards
  129. minibat
  130. Trim Tab Setting (pictures)
  131. Acomms Oldschool Boat Motor question
  132. Reciever Pack??
  133. Tell me your experience with "generic" BL motors
  134. lipo worth it???
  135. GrimRacer 40x52 Prop in SV27?
  136. Running Gear for racing 1/72 PT boats?
  137. Supervee 27 FE Mono Port Turn Fin
  138. Parts needed...
  139. what boat to buy
  140. Balance Point of Super Vee 27
  141. my 1st boat?
  142. whats a good brushless rtr?
  143. new pro boat formula brushless
  144. CoG
  145. CEN Aquajet?
  146. prop for shockwave 26
  147. Tape your hatches!!
  148. Good Stable 50 mph boat!!!!
  149. Outboard Opinion???
  150. quick sv27 question
  151. Picked up a Blackjack
  152. Boat accepting a 700BB?
  153. A123 systems
  154. SV27 Lipo Battery Mounting Options
  155. NEU 1515 1Y or 1512 1Y...Which one?
  156. Wild Thing question
  157. Death of a mini Rio
  158. smc li-po 5000mah
  159. change in plans, need help
  160. Brushless boat: options?
  161. kyosho viper
  162. Supervee 7L and Hydra 120 on 4s 4000 Mah
  163. Twisted Liquid Racing - BUYER BEWARE
  164. replacement motor for sv 27
  165. Proboat PT-109 Feedback?
  166. SV27 4slipo vs 14nimh weight vs voltage which is faster setup? opinions please
  167. Blackjack 26 flex shaft question
  168. direct drive vs. gear reduction
  169. Brushless MRP Miss. Budweiser
  170. lipo cutoff
  171. graupner hydrospeed flexdrive w/ 700 motor
  172. .
  173. Thought I would post a video of Doby's Electric V24
  174. My FE Sport 21 Whiplash
  175. best 7 cell battery charger
  176. Update: N2 micro rigger RTR
  177. 4MM Graupner U-joints/Villain?
  178. What do you guys think about this little ARR on Ebay?
  179. what prop moves more water
  180. anyplace sell M-1 supercat hulls?
  181. 15% discounts on Lipos and chargers Tax Time discounts!!!
  182. Dumas Hotshot 3.5 to electric?
  183. fun on the water
  184. Aftermath of todays run
  185. jollymotor offshore
  186. Q about thrust ball bearing
  187. CEN aquajet motor + ESC
  188. Traxxas VXL brushless in a boat?
  189. brushless
  190. Blackjack cutting out at full throttle
  191. Blackjack cutting out at full throttle
  192. Rollover cowl for the SV27,,Whats your thoughts on this?
  193. Propeller basics?
  194. ANTENNA MOUNT
  195. Hydromite steering...
  196. Cen aquajet motor
  197. Any Villain EX owners?
  198. Leaky supervee?
  199. Supervee Defective - Tower/Aquacraft.
  200. GPS onboard to tell speed?
  201. SV27 - Ammo motor or ESC problem?
  202. KB45 XL for 1/8?
  203. Flex drive cable ?
  204. Oldschool Acomms Fast Electric
  205. sv27 adjustable?
  206. IB4200 issue
  207. Hydro vs Blackjack 26
  208. My new build need info on batterys
  209. SV27 flex shaft removal question/Problem :(
  210. converting budwieser to brushless
  211. LiPo Break-in Procedure
  212. kyosho mini-z catamaran total mod
  213. My Supervee maiden experience
  214. Burning up 540 motors
  215. Micro-iceberg dual-drive setup
  216. Can someone school me on battery charging/discharging?
  217. Need a motor to push my shockwave 36 (converting to brushless)
  218. 1st RC Boat I just bought
  219. Props
  220. Super vee 27 brushless? iquivalent?
  221. sv27 6 cell
  222. New Boat on the water
  223. Talk about your crashes!
  224. cavitation!!!!
  225. Truoble with an Anderson Sintra 700
  226. SUPER V 27 with 5s LIPO
  227. Boat turn over, top came off and sank!
  228. 7L Motor Esc?
  229. Maxamps 3S 4000 pack revieuw
  230. 3 cell LiPO boats
  231. Anyone use these batteries?
  232. Which motor to buy?
  233. Any place sell parts for older boats?
  234. Saltwater maintence?
  235. Brushless RTR Hydro or conversion?
  236. Anyone use the new Airthunder packs
  237. Lipo Problem
  238. Elite Li-po's
  239. Saltwater Electrics?
  240. 7L, Hydra 120, 2-3 cell lipo
  241. lipo size and amp draw grid, good news for new people, or new to lipos
  242. h&m no step 4
  243. sv27 question
  244. RC motor ?
  245. first rc build
  246. reccomend a good starter eleccy (preferably brushless)
  247. Hull Design Drawings
  248. Hull Design Drawings
  249. Electro Vee Mod
  250. Pro boat Formula fastech brushless??
