- Kerosene Start. Great!
- Fuel Solenoid Interface
- P-60 compressor
- Onboard propane tank orientation
- Propane selenoid?
- P60 Kero Start Battery Question
- which jetcat for first timer
- Some jet-tronic software questions
- p70 max thrust
- P-120 Kero/Start
- Blade marks??
- JetCat P120 Ver 5 ecu Upgrade
- P-80 RPM ECU 5.0T?
- 5.0X Upgrade
- RPM Jetcat 120
- P60 A Few Questions...
- ECU battery
- p70 failing to ignite.
- Starter housing, P120
- i HAVE JUST PURCHASED A 120
- p-60 popping on start up around "stabilize" mode...
- Winamac Aero Modelers
- ECU firmware upgrade
- Futaba 8UAPS Switch Setup
- JetCat P-180
- Basic Ques. abt AUX mode operation
- jet cat fuel/propane valve ques
- while runing ......
- JC 70 not starting
- P-60 fire
- manual mode p70
- GSU programming
- pics
- P80 fast idle
- P70 rpm variation
- Search small turbine
- RC OFF! ?????
- Jet tronics ECUS glossary of terms help
- P-60 start failure
- V5 ECU and Lipo
- P160 Mounting Strap
- New mini JetCat fuel valves
- JC P120 MANUAL MODE
- P-120 Blade Damage?
- P70 startup again
- P 80 Shutdown
- Fixed my P180 starting problem, now have another.....
- smoke system pressurized or pump?
- My first flameout.
- P70, shutting down on startup.
- Switching to JetCat
- PROBLEMS WITH ECU V 5.0
- ecu version
- P70 mount and fuel pump
- Version 5.0X ECU
- First time JetCat user
- P-120 Propane Mixture for Start Up?
- Doh
- turbine setup do's and dont's ???
- ver 5 ECU
- Dificult to Start P60
- P120 lifespan
- P-180 Problem
- JetCat Engine Mounts
- Started P180 w/kero start for the first time... a few questions....
- jet cat p 80
- Leaking jetcat fuel filter....
- Kero-Start
- p60 question
- I/O Board
- Kero Start?????
- P-60 kero start mounting question
- Normal fuel consumption?
- Data terminal.... P-80 needed
- kero start with Li-ion battery
- moved
- Need help with ducted fan/turbine for build project
- Guidelines on Fuel System Design
- moved no luck here
- p-80 current ecu??
- Jetcat P120 Max rpm with V5.0ECU
- P-80 and the Inconel liner (Help Mr. Matt)
- P-70 vs. P-120 and questions
- Here is the O-ring
- Jet Cat Questions
- Turbine / tailpipe alignment
- P60 Power
- ECU Settings?
- Newbie - Use P-80 or other?
- mixing different tubine oils
- P60 - Acceleration low - won't start
- P70 speed fluctuations.
- JetCat USA and Florida Jets 2006
- Ecu and RS232 help needed
- Range problems
- Missing parts
- JetCat Airspeed Sensor pics?
- TCW3 Oil
- p-70
- Winter Ops ?
- P120 Flame out
- JetCat RS232 Windows Software
- P 70 surging in power
- 4 mm tubing all the way to the clunk?
- Jet Cat P80 lubrication
- P-160 to Titan?
- O Ring replacement RCU that
- PHT3 belts
- Deleted
- Default Glow Plug voltage
- Smoke pump instructions.
- single channel setup
- Smoking Fuel Pump During Startup
- Kerosene start
- Final stage wheel indentations P120
- Southern California Fires!
- P-80 Hot Spot
- Delayed start on a P-160
- P-60 Screws loose
- Announcement
- UAT tips
- Flameouts
- P 120 Temp. at room temp.
- trouble range with radio
- kerosene start on p160
- Fuelfail - What does this mean?
- P60 sputtering in flight
- Rebalancing after very first run
- Low RPM shut down on the p120
- Delivery Dates?
- P-70 Surging
- ECU 5.0 Fuel Monitor
- pump voltage on p-120
- P-80 Mount Question
- P-60 Fuel used Number on GSU
- p160 start temp
- Blue flames from P-120
- Hi there
- P60 acceleration
- Info on the P60 and if its the same size of a Wrenn 44
- P 60 PIPE
- fuel mix
- JETCAT P80
- Oil Recommedations
- Smoker ECU valve for low fuel/batt/failsafe
- Drain gas Tank on Failsafe
- Loose mounting clamp on Titan
- Other P60 trouble
- P-60 popping
- P120 CHirp on start
- P60 DECELERATION
- P-60 sluggish throttle response
- P120 Temperature ?
- P-60 trouble
- P60 Starter O ring worn out?
- Useful Life of Jet-A/Aeroshell Mixture
- P-60 starting confusion
- P-70 Pops on first start
- P-60 Starting Quirk
- can a jetcat propane valve be used with another engine system?
- P-70
- Filter Question
- P-60 problem
- P80 over rpm shutdown
- Setting for "High Altitude"
- JetCat P60 factory FOD screens?
- jetcat software
- Intake Cover Screw Size?
- Glow plug washer
- Attention JetCat Owners
- p-80 not achieving max rpm (need help)
- P120 problems
- Smoke in the Turbine duct P-80
- p-120 promblems
- Care and feeding of gas solenoid
- Gears 7mm
- P-120 engine weight
- Mixed up ECU leads
- P80 rpm
- What is wrong with....
- stats menu
- P-120 RPM Problems
- Titan
- Propane Valve Problem ??
- P-80 shuts off at start and quits while Taxiing downwind at idle!
- 25 hours in USA and 50 hours in GDR?
- P70 Issue
- P-120 eating temp probes
- Turbine oil other than Aeroshell 500?
- New Titan........is this a problem?
- CASTROL TURBINE OIL
- P60 Mounting strap?
- P 80 Slow Acceleration
- P60 FOD screen?
- 160 in flight stops
- Projet & Jetcat
- FOD screen (P120 and P80)
- P120- Failed starts due to slow acceleration
- p-120 mount
- P200 FOD Screen
- P200 Plumbing?
- Jetcopter fuel line replacement
- Jetcopter manual
- P-120 missed starts
- JetCat GPS Unit Mounting
- ecu up grades
- P120 ECU receiver leads
- 2-cycle oil
- p80 shutting down at full thrt
- JET CAT P80
- Smaller Jetcat?
- P80 Static Mounting
- Titan vs P-160
- zero RPM
- P-70 COLD WEATHER SHUT-DOWNS
- P120 Rx connections
- Turbine Mount Strap Material?
- Trade in's on new Titan
- Fuel connection diagram
- P-160 Too Hot Maybe?
- speed sensor
- John R, Issue with my P120
- P80 problem
- P120 Problem
- Winter storage
- GSU Question
- Jet cat P60
- Test smoke valve
- Air BP 2389 use with Jetcat?
- Fuel pump/ECU
- P-160 "Slow Acc"
- electrical noise reduction
- p-60's ?
- P-120 inverted start overheat ..
- P-120 shutting down again????
- P80 funny sound
- P120 start problem
- Kero Spool Problem
- D@mn fast shipping - thanks John!
- Set up and install for twin
- Charging ECU Battery - Harness
- P-120 ECU and ECU Battery
- P-120 & Pipe/bypass separation
- P120 Shutdown Problem
- P80 Acc. Slow
- P-120 intermittent start failure
- P-80 trouble
- 160 blinking red light
- Questions About Fail Safe Set Up
- Mk2
