- Futaba radio w/JR matchbox & JR servos
- Campac
- HiTec Eclipse radio setup...HELP
- 7.4 v servo
- Help - Futaba 2PL Tx/Rx won't turn on with brand new Ni-MH batteries!
- brand of reseivers and servos.. please help
- Hitec HS645MG..or Futaba S3305 servos, whats your experience with each?
- Futaba 9C
- Crystals
- Are Futaba 3305s safe for 1/4 scale planes and helis?
- help with picking crystals and servos
- dual elevator servos
- JR DS537 Digital Servos
- Wiggling Futaba S3004
- Trainer Box Question - Futaba
- Hitec/Futaba
- Two Way RC pair?
- Hitec HS-125MG Wing Servo
- Frequency change on T6XAS?
- Metz Mecatron - Antique Radio
- Rudder servo -- standard or high-torque?
- C19 FM35S Aerial length??
- hitec optic 6/ hobby zone super cub
- does this radio can be use for plane and heli?
- CCPM Dumb question
- Hitec Eclipse 7 Elevon Mixing endpoints
- Blue Bird Servos- Erratic!
- FUTABA S3001s and S3004s
- Futaba 3pm opinions?
- Futaba sythisized RX, TX
- 8uaps futaba set up
- Loss of signal from three feet!
- 9c acro butterfly mix
- where is futaba factory?
- Robotics Resources
- Thunder Tiger gyro help
- Throttle trim $ Futaba 7C
- Servo Geartrain Lash
- Lithium-ion voltage (8v) into JR reciever
- Cirrus servo
- on board engine starter
- Futaba T6EXA
- trainer/simulator radio
- When is 24 kg not 24 kg whenits/a HSR-5995TG
- Integy servos, anyone use them?
- Spectrum DX6 Tx spring tension
- Transmitter range with antenna collapsed ?
- Futaba 9C or Multiplex Evo 7 ?
- Futaba 9CHP Super with GWS SS = no throttle
- Futaba 9Z 10th channel hack... potential 12Z extra 2 channel hack?
- HiTec servo problem
- High band or low band?
- 4Channle with 5 sevro !!! XD ~
- Futaba 9C Knife-Edge Mix
- Airtronics nicad battery, but no charger
- fromeco charger
- Crystals in Tx Module for Optic 6
- does the gauge matter on antenas?
- Narrow Band AM Modulation
- How Does a Servo Work?
- where to get 35mhz 9chps??
- 14MZ/THIS IS A GOOD ONE!!HOW THEY FORCE US TO BUT FROM THEM!
- Split Elevators with dual servos
- futaba tx antenna question
- Futaba transmitter/receiver compatability
- centering iqque with hitec5945
- CASTLE CREATIONS
- 3pk Synthisised Reciever?
- Futaba 9Z lithium battery, how to replace?
- Which New bolt for a whip antenna.
- Parkzone Focke Wulf receiver
- would you guys say this is a futaba transmitter?
- Servo question regarding compatibility
- Using rf filter rings
- old post please delete me
- What Mini's on DPM Ultimate Ailerons?
- ? on interference while range checking
- Airtronics MX3S
- HS81 equivalent with 3D arms?
- Servo question
- Someone Help!
- Futaba Synthesized Rx Question
- futaba 7chp, skysport 6a, trainer compatability
- Thottle Fail Safe (info please)
- Beginner needs help.
- Need gyro for airplane!!
- JR radio problem, Horizon's 'help'
- 14MZ reciever compatibility with a base loaded antenne?
- JR Racing XS3, M8, etc? Please help.
- Hitec to Futaba??
- Price on Hitecs
- XtremeLink™ - 2.4GHz for Futaba, JR, and Hitec radios
- what transmitters will do this?:
- Hitec-Futaba compatability
- Anyone ever have a servo reverse itself?
- Spektrum DX2 problems?
- A short story
- Nomadio V2 any good ?????
- 6c or 7c or 9c somebody enlighten me
- FMA Co-pilot
- Compatibility of JR Sport and JR Propo
- Servo question
- Align Head Lock Gyro RCE-500X
- M8 Battery Help
- Radio TX / RX Servo compatibility
- I was shot down today.....
- JR 537's with 6volt
- Wanted ultra light weight Y-Lead
- need help jr7202 vs 9c super
- Heli or Plane
- Futaba vs. JR for my 2nd Tx
- Futaba Square Micro Plug
- New radio system
- 9CAP Elevator Problem
- JR Service- PRAISE!!!
- futaba servo
- Nomadio binding issues?
- Replacing antenna on hitec reciever, please help
- NEW 360° Proportional Servo!
- Buzzing servos
- New to 4ch r/c! Need help with my flight pack!!!
- When do I need to use a voltage regulator?
- Futaba 8U repair question
- 6EXH vs 7C (for heli)
- JR XP783 problem
- switches
- trim offset mode on JR 8103
- Frequency scanner?
- JR XP9303 field charging
- NEED futaba ESC HELP
- Strange futaba reciever
- Older Airtronics servo need specs
- Use of Flexable Transmitter Antenna
- E-flite S75 servos
- JR 125s skipping
- 9cap programing this ever happen to you?
- Can I use a Rx crystal on a Transmitter?
- transferring model information
- ailavator mixing using programmable mixes?
- servo twitch when turned on then nothing else
- mode 1 to mode 2 conversion
- What's the difference between the SPEKTRUM DX2 AND DX3???
- Hitec Fusion 9 receiver...
- GWS Receivers
- Futaba 6xea Battery?
- Swapping Rx in walkera 36
- Single servo glitch with engine running
- Transmitter Battery Question
- 14z/12z spare battery
- Life expectancy of receiver
- short rx chip or normal
- Tx and Rx compatibilty
- JR XR3i TX and RX different brands?
- JR PCM programming
- Variable Flap Positions
- Servos to use with Multiplex Radio
- GWS Nano Compatable Servo Arms
- TX Swap
- Spektrum DX6 problems
- JR 6102 question
- HELP... Need Transmitter Type (Airtronics)
- Sullivan smoke pump glitching - help
- servos twitching????/??
- micro receiver with a jr xs3?
- Charging Futaba 6EXA High Capacity Tx batteries
- Digital servos?
- low voltage in futaba flight pack?
- Futaba 9CAFS FM Super, good radio?
- New Spektrum 3PK HSR Module
- NiMh battery use
- Need M8 Help
- Servo Extensions
- ok, getting confused...which Radio??
- Buddy boxing different brands
- airtronics quantum 8p
- PCM rcvr versus FM x-ter
- futaba 5101 need spec info
- CONNECTING THE RADIO TO A PC. ANYONE HELP PLEASE!!
- Berg Micro RX + GWS Xtal -- Not a Marriage.
- Digital Servo Buzz
- heli vs. aircraft 7ch radio difference
- aitronics to airtronics Z, failed?
- Futaba FF9 Servo upgrades from S3001's
- VEX robotics controller and RC reciever?
- Trouble installing Radio on computer WInXP
- Hitec Synthesized receiver vs standard
- Problem with JR 790 PCM Receiver ??
- Synthesized Receivers available
- mid price level radio to purchase
- JR XP783 Manual
- T6XAS for heli?
- JR 9303 or Futaba 9CAPS... need some advice here!!
- JR reciever+futaba servos+speed controller
- JR9303 master 6102 Slave, Trainer Setup
- Tower Hobbies 6XM
- How to slow a servo on a 9cap super?
- Frequency Conflict Concerns
- Futaba FP-T8SSA-P antenna wire loose
- Spektrum Dx6 range
- Old Airtronics servos, need new Rx
- Li-Ion versus Li-Po on receviers and ignitions
- futaba
- Hitec module, Futaba radio, Airtronics receiver
- HELP!! need info for servo control
- *JR & Hitec Compatability*
- Universal servo plug - Best way to grip/unplug?
- 6EXAS Flaperon
- *RF Or EI Problems*
- Good starter Tx for Heli
- Synt module and hitec receiver?
- JR 8103 transmitter programming
- Spektrum cuts off at 30-40 ft
- I am shocked! Lost my 33% Edge because of the 9C receiver...
- R168DF glitch problem
- Airtronics VG6DR Vanguard
- What crystals for parkzone radios
- Scratched 12z display
- 9C Module Question - 3 hours left on
- Strange radio Interference on Giles Wildhare
- do i need a 75mhz transmitter for a 75mhz reciever?
- Multiplex help... really technical
- Changing to Futaba 9C super
- futaba 3305 servo, not with NiMH???
- Antenna Maintenance
- In what way is the Futaba S3151 better than the S3003?
- antenas
- Signal Interference
- Futaba 6XA TX antenna mount snapped off
- Spektrum
- how do i get my split elevators to move in the same direction?
- HELP! TX not responding
- Futaba Dual Conversion Crystal or not?
- 9CAPS Output
- How do you run 2 servos for elevator JR 6102?
- List of decent throttle servos?
- Some direction please?
- changing TX crystal
- t8UHF? Which Reciever?
- Receiver Channel Stops working
- Futaba 9CAP HELP
- Futaba 7CAP TX RX compatility
- JR synthesizer module, anyone using it?
- Dual Elevator servo setup
- antenna for my futaba
- JR821 servo's...anyone??
- Futaba radio frequences
- Sullivan SkyWriter smoke system set up on a 9CAPS
- Futaba FF7 or FF9?
- what does ATV do on a FOCUS4 transmitter
