- HS 5625MG - What do I have?
- JR Servos compatible with Futaba Receiver/Transmitter?
- Fm Receiver & Pcm Receiver Crystals
- 9Z / 9C / 8U how to clean?
- Adjustable Detent / Stop on Non-Centering Sticks or Knobs
- Glitch solution on long servo leads
- Radio Frequencies
- Hitec Digital H.S. 5625 mg servo
- Looking for servo suggestions
- Narrow or Wide Band?
- Need Advice
- Glitches when servos are under load?
- hitec flash system X
- Wideband Explanation?
- Reversed the battery
- Need opinion
- How? Flaps with a JR 8103 HELP!
- R610m Jr
- Futaba 8 UAP up in smoke
- dots on crystal
- Help: hi band and low band
- Jr servos in futaba rec.
- vision radio upgrade
- Using Hitec transmitters on Flight Sims
- Throttle servo
- Extending battery leads
- new futaba 9c--ham band rec. ?
- Coding Info for Wiring Compatibility
- What grease to use in servos
- changing a JR Tx from mode 1 to mode 2
- Anybody using Hitec 625/645 servos?
- futaba 9C screen contrast adjustment
- receiver battery connection?
- servo ratings
- humming servos
- jitter
- TQ radio for traxxas nitro 4 tec
- Airtronics Servo Buzzing at idle
- Radio recommendations??
- Graupner MC24
- Delete
- receiver antenna
- Futaba Receivers
- JR 610M receivers any good?
- hitec servos
- servo arms((((help))))
- Best place to buy Airtronics?
- Discharging without cycler
- Rx battery size????
- Pulse width reader
- Lithium Ion for Tx
- Single Stick
- Mode1 vs. Mode2
- Futaba 6XAS - Airbrake
- Reversing servos
- Futaba trainer switch
- Futaba/Hitec/Aritronics
- Jr X-347 PCM C or Z
- Futaba Tx Module crystal changable?
- Need help with Airtronics Radio
- fitting Futuba servos to JR receiver
- Hitec HS-81 failure rates???
- Making Futuba servos fit JR receiver
- JR 652 Transmitter A weird Issue
- Old Hitec radio problem
- crystal exchange web site
- Are you guys happy with your Hitec Digital servos?
- Single Rate and Dual Conversion receiver and crystals???
- Jr Xf622
- JR Crystal Questions
- Futaba vs. JR vs. Hitec vs. Multiplex Which do you use?
- Delete
- FUTUBA 9ZCan someone telll me c
- Mini Servo's On Throttle?
- Futaba's new lineup...
- Info on old Futaba radio wanted....
- Please Help! I am so *&^%# mad!
- Futaba 8UAP glitch
- slowing servo speed for retracts
- Futaba 9C any thoughts
- System report - Good or Bad?
- Hitec, JR, Futaba Radio
- JR Rx question
- Problem with Hitec 5625
- Futaba 8uaf 8uafs difference
- What did I do wrong?!?!?
- JR 10 SX Fuse
- Futaba 8 super dual-rates question
- FMA receivers
- JR or Fut comp radio
- Transmitter Stand?
- gws receiver
- using digital servos
- Hitec 5125 servo. - When ??
- Hitec Spectra and the Futaba rx
- Futaba 8u/9z module question
- Eclipse-7 vs. Futaba-8S input please !!!
- slow down servo
- I have problem
- Futaba TX Modules
- JR 10x module?
- futaba FP-s24L IC SERVO
- 9zwc2 mixing question
- JR Digitals----GONE
- can futaba 7 pcm tx can be used with fm receiver??
- need manual or info on old Galaxy computer 8 pcm
- Old Futaba Servos
- Are HES servos any good?
- futaba 9CA Questions
- Hitec Servos
- Mp8000
- Futaba 9Z and CamPac
- Which servos to use???
- I miss my MicroPro
- rx battery size?
- Airtronics Z and old compatibility
- New to computer radios (expo?)
- 72mhz to 50 or 53mhz
- new radio
- How to use Expo
- Airtronics Radiant
- Airtronics Vs The Others
- Reversing Digital Servos
- which radio
- ever heard of 'Dads' type/brand of reciever?
- Can I change from Low to High Band
- closed
- Hobbico servo's any good?
- Glitching
- Hitec radio systems, inexpensive and good quality?
- Airtronics Infinity D/R switch broke HELP!!
- JR precision servo
- JR Max battery charging
- airtronics servo question
- "Y" Harness with amplifier
- Mixing rudder,front gear and retract
- Tower Dropping the 6XAS
- Wanted: Futaba PCM interface/editor
- Jr 10s?
- Using Hitec RX with Futaba and JR TX
- JR R600 Rx
- What's My 10SX Worth
- Syth. Module for JR
- A.M. Radios
- Futaba 7UA vs. 7UG???
- Fiber optic ext.
- Precision Gyros
- What radio to buy...and where
- retract servo suggestion needed
- 9ZAP Radio programming
- AM Cross question: How to hook up Realflight to 9C???
- Aileron Extensions, Maxx Products, anyone used them?
- Twin engine throtle control
- Futaba 8U PMIX Switch
- Cirrus 900 XLC
- futaba
- Hitec Prism 7 mixing help needed
- Lithium battery change
- Servo Oscillation
- Servo Checker for setting up your plane
- What servos for 1/4 scale?
- What Battery do i need ?
- Hitec Servo Reversing??
- Futaba S-48 servo
- Vtail mixing And nose wheel steering
- Hitec HS-77BB servos - advice needed
- New Futaba 9 ch radio question
- antenna replacement
- hitec 5645MG servos
- futaba
- Graupner/JR MC24
- Futaba repairs
- Removing Rx from it's case?
- Futaba Radio ???
- jr servos vibration
- Rx Batt Voltage
- Need Help
- Pcm crystal for pcm rx?
- Homemade glo = interference?
- TX trays
- transmitter mode conversion
- Quad Flaps and Airtronics Super 6000
- Futaba FP-7UAP PCM 1024
- Servo extension DIY
- changing xtals
- Flaperons Don't Work
- Who makes tower servos?
- 27mhz radios
- Futaba servos - JR Radio
- Futaba crystals
- Dual Con. Xtals
- Antenna question...
- Futaba 6XAS
- Multiplex Radio Systems
- Hitec HS-645 High Torque Servo
- jr 950s recievers like new 265.00
- New plane flaperon setup & humming servos, min voltage for safe flight
- OH BOY Big problem, please advise...
- New JR X-378 radio
- JR Radio Repair
- Coreless Servos
- 9CHP on Channel 50? Where oh where are they?
- Futaba 9304 or 9001?
- Hitec Metal Servo Arm?
- Changing servo connectors
- What does "Mode" mean when refering to RC radios?
- FF9 Question -
- Hitec servo metal arms in various length?
- 9CAP or 8103
- JR 378 radio
- Radio JR XF421EX for park fliers/gliders
- jr servos
- Your thoughts on Expert servos needed
- Futaba Experts Needed!
- co-pilot systems?
- Intermittent jitter
- Defective Expert Servo Reverser
- T6Xas Dual Elvators?
- JR783-H9 Ultra Stick, Can't Get Crow-Help
- JR Radio Range
- 9ZAP question
- Control surface servo/load
- Completing old Futaba items collection -- please help!!
- Multiplex servo programmer
- Why use Hitec 525 when 225 appear to have better stats
- Dual Receivers.......?
- 9C question/ split elevators?
- Whip Antennas ???
- throttle servo location on gas A/C
- S148 or S3004
- FMA Direct service?
- Futaba 8U Modul
- Anybody using FMA Direct Servos?
- difference between futaba 8uap VS 8uaps
- PPM vs. PCM vs. FM?
- Two jumper blocks on my PCM receiver?
- Futaba FG series battery pack
- Single Stick Radio
- JR S-PCM Versus Z-PCM Receivers
- How do you wire servos for H9 Ultra Stick to Hitec RCD3800 w/JR Radio?
- desperate for a single stick Futaba
- futaba gya350/351 at 6V
- Are Futaba and Hitec servo arms the same ?
- Radical RC Servos
- Futaba 9C, flap positions
- receiver position
- Futaba Servo's
- Hitec 3500 and 3800 receiver ?
- HS-5625MG Hitec Servos
- Futaba 127DF or Hitec Superslim?
