- JR 652 mode change
- Futaba 8UHFS does it work with 127df
- T6XA with Crow possible?
- Trade a 9Z for a 9C
- Sanwa rd6000 manual wanted
- Multiple aircraft Radio
- JR 10 xxxx progression....
- How to mix flaps and elevator
- Multiplex Evo 9 /12 specs. to print out
- gyro problems
- 8UAPS-tower-annmarie-cross
- 9204 Gears
- JR652 aileron set-up
- 9 chan RX, FUtaba, Multiplex, others?
- Cost to check a rx and replace its case
- RD 6000 Super Programming Question
- Check this out!
- Hitec spectra module and futaba 8UAFS
- single /dual/ what is it?
- servo arm centering
- kopro po module
- JR10SX2 Problem
- Where can I get Jr Transmitter Parts??
- Buddy Box problem??
- Zap Mixing issue.
- Max Jr Radio
- Changing Radios, need some info. plz...
- DSC cord for Futaba 9VAP
- FMA direct recievers- Any good???
- Futaba S3501 servo
- Where to buy Multiplex in USA
- Manual for JR radio
- Rudder to Elevator Mixing
- Tight fitting connector on receiver
- great hobbies
- Reciever question?
- Hitec 605 MG
- Can I change Fut Tx Xtal from ch 48 to 21 ?
- Adjusting EPA on mixed channel, JR 10
- Futaba 9CAF Best price??
- jr and futaba trainer cord
- Futaba Radio, Airtronics Receiver?
- programming delta mix in a JR 652
- How close can I mount the RX to a servo?
- Eclipse7 or JR's new X378 ?
- JR 950s receiver
- Atmospheric effects?
- Futaba tx/ JR servos, need help !!!!
- WOW! Major servos...
- Buddy Box'ng
- RX schematic
- What's the deal with?
- Futaba 9C radio
- Futaba FP-T8SGA-P
- Jr X3810 ??
- 8103??
- JR 8103 Mixing Dual Elevator Servos
- Futaba 8U or 9C TX with a Hitec PCM RX
- Tranmitter or TRANFORMER TOY !
- More throw on Flaps with mixed with a switch
- Anyone Running Dual Recievers??
- Don't trust servo specs
- EXPO
- would you trust this crystal??
- JR 10x module help please
- 9C w/ Ultimate Biplane
- changing from a 4 cell to 5 cell pack
- Metal servo arm and metal clevis GOOD OR BAD
- Tx Module Question
- I did not intend to crash that plane.
- Thought on the 309 dp
- 8U Pinout
- 9C Pinout
- Hi-Tec Reciever w/JR crystal?
- Futaba 3003 Schematic
- JR gyro with Futaba radio. Need URGENT HELP!
- Jr Ds 811 Servos ?
- Hitec 605BB servos are not suitable for the H9 1/4 scale Cap!
- Lost signal question
- PWM information for digital servos
- Antenna routing
- My thoughts on Hitec
- Sending for Service, Futaba USA
- pot cleaning
- JR Xstals with "RED" cover ???
- Hitec 5925 MG
- Hitec servo flutter
- engine induced rx interference
- 10x mode 1 to 2
- Digital servos
- FMA CoPilot Troubleshooting
- 8103
- Gy401 W/servo $200nib
- 10x datasafe??
- Handheld radio scanner Fm channel check??
- Hi/Low Receiver
- Results of Interference Poll
- Linear Servo
- Futaba 8UAF diode question
- Synthesized Recivers
- JR 631 Flaperon Adjustment Question
- Need Spec's on JR 501, and 2001 Servo's
- HELP! 9Z radio question....
- Broken Spectra
- Buzzing servos
- JR 10SX flaperon question
- I fried something in my 8UHPS. Help?
- I did a bad bad thing :(
- How tight are your servo linkages?
- Futaba 6XAS Problem
- Unknown Servo
- 9zWC2 programing (heli throtle)
- old futaba connections
- Crystal
- Hitec servo arms
- Gold Sticker
- FMA Direct Co-Pilot (WOW!)
- Running servo extensions next to each other?
- replacement receiver
- rx cover missing
- Lynx 3d, JR XR3 or Futaba 3 memory
- Help!!!! Flaperon mixing
- Electronic Switch
- voltmeter
- Possible range problem
- Wondering how the 9C (9CHP) looks inside?
- Pegas Engineering Transmitter Tray
- JR Match Box is it compatiable with Futaba
- JR 652 Program Mix Help!!!
- Hitec Servo Horns
- Single vs Dual Conversion RXs
- Futaba to JR
- 6 volt voltmeter Can I use
- Will the Futaba 9CAP accept the old 5U and 7U series frequency modules?
- servo twitching
- JR 10X_How Long Has It Been Out
- Jr X-378 English Version Manual
- Really weird interference
- My new Futaba 9c pcm------mem mod
- long servo extension problem
- Need help from radio guys
- Fut 148 RX problem
- Is there a Buddy Box for Airtronics RD6000?
- srvo reversing
- Erratic servo behavior with extensions
- servo torque??
- Servo Reversing
- Mixing Servo Manufacturers
- radio help
- Another Receiver Qestion
- 9Z and JR gear
- Jr R700 Rx
- y choke
- Suggested uses for wide band radios
- Reciever question
- changing frequency ?
- Operating Speed HS-55
- 6 meter conversions
- Is the 8103 worth the extra $
- JR 8103 Tx Battery Connector
- JR TX keeps paging through without stopping
- Indoor range check
- program smoke on T6XAs
- Getting radio's repaired
- Hitech servos
- Trainer system
- Fp-t8sga-p
- Ace 4-1.20 bi plane
- Question on charging JR XP783 tx.
- Jr Radio
- If you could design your own transmitter--what would you add?
- Hitec Servo Problems?
- Best way ensure slowest battery discharge rate?
- help gws servos
- Manufacturer Support
- CAMPac and 9C
- JR XF622hI GUYS
- transmitter repair
- Anyone Sell the Futaba 9C tx only?
- Flt Pack
- Hidden menu for FUT 9Z
- What Kind of Receiver is this?
- OT: heli contest software beta testers needed
- H9 edge receiver
- New Generation Servo?
- Multiple modes/conditions in fixed wing
- How do I increase Visual Range - a Reason!
- Ham 6 meter
- Old Hitec receiver and Servos
- Futaba Servos
- Help with JR 8103...Trim Offset
- Where do you route your antenna
- ALSO.... HOW much is this worth?????
- HOW Much is a Telebee GR703 NIB........
- Old Cirrus RX
- Checking Receiver Battery
- Can a T6XA be set-up for Heli's
- How do I increase TX/RX range?
- Can you identify a JR Rx #NER 327X ???
- Mounting Hardware for micro servo
- Buddybox sending RF signal?? It happened!!...
- How to change Lithium battery in JR Tx
- Superbatterypacks.com???
- Airplane rudder gyro
- buddy box function not working
- Busted antenna on a futaba pcm receiver
- Max radio range and GPS
- Old Radios
- rx antenna
- TX crystals
- Servos-Are you spending too much?
- servo hook up questions, im lost...
- 9c dial and a grain of sand
- Question about Hitec servo arms.
- Galaxy Computer 8 PCM JR Radio
- Jr 631
- servos twitter w/o tx...whats up?
- 94102's!!!
- 94102's!!!
- Lithium Battery for 9CAF
- buying my first rc radio
- Programming the 8103
- Futaba S3304 servos good or bad?
- Aluminum TX Carrying Case
- Hitech Flash 5 X
- P-Mix
- Changing from mode 1 to mode 2 on Futaba radio
- JR buddy box and training methodology; please explain......
- Futaba Super 8 Dual Rate Switch Source
- Programing the JR XP8103
- Receiver
- DELET THIS - IGNORE THIS - DON'T READ THIS
- Good Multi Digital Charger
- Strange Radio Problem
- 9c And The Campak
- Tower servos: TS 71MG ?????
- FMA servo source
- strange radio problem !!!
- JR 8103 Mixing/Trim for slave channel
- Battery for Giant Scale
- 9C LCD so dim
- darn birds!
- Antenna installation
- Does rain disturb radio signals?
- Look Ma, no thumbs...!
- Futaba Attack AM
- Hitec servo Arms
- Cirrus radio question
- Airtronics compatible RX?
