- NiMH no fly voltage?
- sIMPROP NC MASTER PRO
- 8103 JR digtal trims NIB
- 9c expo question
- Neg Shift/positive Shift?
- FM vs PCM
- Airborne equipment,what do you use?
- heli radio selection
- airtronics rd 6000
- Jr Xf622 Faceplate Removal
- Interference question
- Welcome bpryor
- Do I need stronger servos?
- Four Channel Receivers
- Gyro on Cub?
- Mpi Servos
- "OLD" Radios
- Futaba S9150 Digitals - servo arms
- Need help with an ACE Pro 810 Receiver
- airtronics rd6000 super
- 5625 Hitecs
- JR servo numbers confusion
- jr 662 or futaba 6xas?
- gyros, gyros,gyros,
- Servo Horns for old KO / Kraft Sport servo's
- Fut 9C for sailplanes heli or acro version
- New Radio's That Have Crow Capability??
- shiftable rx
- JR to Futaba
- Legal / Illegal tx...
- Flying wires=Loop Antenna???
- Battery for Eclipse 7 / Spectra module ??
- Eclipse 7 - quick question
- Alpha Four Charger
- Servo "Pot" Cleaning ?
- Piezo Gyros
- Profi 4000 or MC24 or Other
- Jr radio w/ Futaba buddy box???
- Vibration insulated Switch mount
- Tiny Throttle servo.
- Best Servo for the money (cheap)
- Correct length for antenna (JR FM)
- FYI Using the FMA RFD1 Replacement RF Deck in units other than ACE.
- Futaba TX switch broke
- Vote: Like or don't like dedicated support forum format?
- 6x LCD almost out ???
- FP-T8UAF -tower hobbies
- servo chatter
- Futaba PA 1 assistance
- Were You At Rc Country Swap Meet?? Please Help!!
- FM or PCM Whats the diff
- Kraft or ????
- adding another plane
- 8UAFS Help in Special Prgm.
- Dream World
- What servos should i use?
- Help with Radio terms
- T6XA Flaperons with 5 channels?
- JR G-550-T + Hitech 605-BB
- Airtronics 94554 Servo Info?
- 50mhz ?
- Mike at Toledo
- Futaba PCM Receivers 138DP VS 148DP
- Contact Multiplex!?!??!?
- MPI 460MG servos glitching
- moved
- question about the 9c
- DELETE
- Futaba 9CAP
- 9Z Upgrade
- Futaba 9C and also cool tx cases
- Testing Servos ??
- What should I get
- Airtronics Buddy Cord
- Futaba Pilot Assist and JR - compatible?
- range check
- hobbico cs-71 super torqe metal gear ball bearing servos
- 9C color?
- Servo worn out?
- Easy question, I think.
- Ace Trickle Charge ?
- JR charging diode
- Futaba Super 8 VS 9CA
- 8U-E-Sailplane w/ Motor & CROW! Help.
- Futaba 12 Channel Radio
- Can you believe this NUT bought this
- JR Galaxy PCM8 Question????
- FMA Co-pilot
- Dual Rate Set Up
- 9z Transmitter Batterys
- Q. for Mike (Hitec guru). Why the Prism makes servos to buzz ?
- JR Datasafe
- Help Help !
- What kind of rx is this? Very odd.
- Hitec HS-5925 MG Failure - Attention Mike.
- Futaba FG series model FP-T4FG
- Futaba Wall Wart Charger - Airtronics Compatibility??
- Please Delete
- Waterlogged RX and servos
- Channel 11 & 60 the ends, are they no mans land???
- Eclipse 7 Transmitter with Spectra
- Narrow band to wide band
- Hitec to Futaba trainer cable, possible ?
- Rudder Pull-Pull System Pictures
- Futaba 6 channel radio
- At a crossroad, Stay with Airtronics or change to Futaba!
- Futaba 1024 PCM 3PB
- Dumb about digital trims, 9C
- Digital servos on 6 volts
- Futaba FF9 or JR 3810 ADT???
- Jr Pcm 10
- What was your first Radio?
- Crystal Swap
- Buddy-Box Compatability
- Torque ?
- reciever sing/duel conv.
- JR Crow Setup
- Using old airtronics servos with a Futaba receiver?
- Radio glitch ch41
- Hitec Digital Servos
- Servo grease? Will clear silicon work?
- Radio Failure / plane lost
- Nose wheel steering in a V-tail set-up ?
- What can I do with old Kraft servos
- Hitec / Futaba Receiver Crystals?
- Best radio for helicopters and airplanes?
- JR 622 & quad flaps ?
- JR 783 Radio
- Elevon Differential on Eclipse 7?
- Convert Airtronics to Futaba
- 9c switch switching question
- Crystal exchange service
- legal frequencies
- Futaba Radio/Servo pricing question
- 5125MG Digital Wing Servo
- Dual Conversion Crystals ????
- Futaba FP-T7UAF & 8U/9C Compatability
- Hitec w/ Futaba?
- servo confusion
- 225 metal gear vs nylon gear
- Airtronics Radiant Manual Needed
- chargers- simple question
- Jr 783
- Hitec/Futaba RX Compatability
- ServoCity???
- ServoCity???
- Hitec Flash 5 / Prism 7 ????
- opening jr 10x?
- is is better to Y-Harness the aileron's or Rudder?
- Airtronics RD6000 - may be 8 ch.?
- :) FMA interceptor 2000 rx?
- Reversing JR servo
- Airtronics Radios
- Multiplex Dealer(s) in Canada
- hitec servos and JR reciever-6.0 volts
- Who sells Futaba 9CA Transmitter only!!!
- GLITCH in my Airtronics Elev. Circuit
- crystal question
- Attn. 9C owners...how are you setting up your radio's/switches?
- Is this RX wide or narrowband?
- 9CAp slider control
- Has anyone compared Futaba & JR digitals?
- Revist 7-Servo Programming for 8UA
- Centering HiTec 85MG servos
- Which Receiver 945 or 955
- Hitec
- Very Odd Hitec Flash Problem
- Futaba's synthesized module for 9C?
- Mixing TX & RX Brands
- Still need old Futaba radio gear!
- MPI servos any good?
- Futaba S-134 large scale servos ????
- Need JR Servo Specs On These Servos
- recevier antenna
- new futaba 9c
- Help needed for Airtronic 95554 servos
- Charging leads for Ace charger?
- trim steps on the 9C
- Super8 5 Point mixing, how do you link the trim????
- please close - problem solved
- JR 10x screen problems
- Servos
- Problem with Hitec and flight sim
- Futaba digitals
- ATV below 80%
- Intermittant lockout on JR 631
- Battery Voltage
- Reversing Futaba Servo
- Expert SL500 Servo
- Where to get a potentiometer to replace one used for trim in JR 652
- Frequency Info Help Im About To Jump
- Adding 5th chanel to Futaba 4 ch. tx
- crow and eclipse
- voltage regulator
- Best price on JR Servos?
- Futaba Super 7 Tx Battery and Cycler Question
- Who Sells Aluminum Servo Arms for Hitec Servos?
- sub micro receiver
- Battery Voltage???
- I need to know
- Help - Can a Futaba 7UAP hand a V-tail
- Beginner, Futaba 6xaps? + other ?
- 8u screen for parts
- frequency interchanges - hi&lo
- volt gauge indication
- Hitec Flash 5X
- Digitals: Jr/Hitec programmer
- Discharging FUT6AS transmitter pack
- www.futabarc.com/faq Use it? helpful?
- Futaba T6FG/K *** SOLD ***
- Servo "Buzzing"
- changing frequency
- Aileron servos???
- Diff. Between R127df And R148df
- Digital Servos
- Which entry level computer radio?
- Help On Dean's Antenna
- Radio problems. Help please
- Hitec crystal
- Hitec jr rx question
- Unidentified servo
- Measuring commanded servo position, is this a no-no?
- Futaba 9CHP Color?
- ALPINA PCM RADIO (jr propo)
- 9ZAP WCII programming help
- Mix & match hitec and JR
- Servos
- Hitec 545 vs 605
- bad power indicator or battery?
- JR8103 mode2->mode1 conversion
- Radio Range
- 9z futaba vs the WC2
- Receiver convert
- Making futaba extensions
- High Torque Flight Pack w/Premium radios VS.Transmitter Only!!!
- 6 volts and servo torque
- servo's go nuts!!!!!! lot's of gitter.. Why?
- How, Dual rudder servos, Futaba 8S ?
- 9Z's,what are they worth.
- 9c buddy cord
- JR 8411SA servo, is the difference noticeable?
- Lithium batteries
- JR 421ex question
- were to buy Hitec servos
- 9CA Cosmetic flaw Awesome Radio!!!
- Throttle conversion from Air to Heli
- JR X-347 Manual
- Airtronics servos on Other brands Rec
- Where to buy Airtronics Tx only
