- How to straighten warped balsa.
- Applying Ultracote on top of Ultracote
- Looking for "Bendy Pipe"
- DOPE THIN
- stripped muffler bolts
- Which saw is the best saw for a modeling workshop?
- Can PU replaces DOPE?
- planking, best method
- Flattening PolyU Clearcoats?
- NEW REVIEW: Crating and Shipping Giant Scale Planes
- Ultracote Transparent White
- Patching sticky back covering
- ??? How to Paint Camo Scheme on Monocoat ???
- Mattress Pad/ARF building
- painting a gremlin
- Recovering Ultimate Bipe
- CA Techniques
- Did you use too much "Thread Locker?"
- Help w/ Clear Ultracote!
- Help! Building Surface
- SIG LT-40 PLYWOOD FUSELAGE QUESTION
- Painting an old Cowling
- Hint For Those Pesky ARF Control Horns
- What kind of paint is the most fuel proof ?
- Removing valves from 4-stroke
- Special fuel tank wanted
- Customizing a 12x6x6 foot enclosed trailer for RC planes and helis
- Covering Foam Wings
- How can I get rid of excess CA on Ultracote
- Meguiar's Plastx for canopy care
- ca pin hinges
- Goo Gone before paint?
- Baking soda and CA
- Giant Scale control horns, a cheaper way!
- A jig for Robart hinges
- Field Equipment
- 'Scale' louvres anyone?
- paint or re-cover?
- Add friction to main wheels
- HS needle valve extention?
- Soldering braided wire
- Tip - Brass Fuel Tubing
- Missles
- CA Removal from Fastners
- What is better to use-laquer or enamel for fibreglass
- Silicone sealent removal
- Looking for tips on cowl holes. lol
- Build with magnets (instead of pins)
- Thrust setting idea?
- Thrust adjustment
- Coleman fuel for cleaning
- Using contact cement to apply sheeting
- solortex covering help
- Here is how I keep my wheels from falling off my plane.
- Toothbrush technique for removing excess glue from CA hinges
- DAP "Fast n Final" lightweight spackling
- Vacuum Forming?
- how do you seal the aileron gaps?
- Foam wings
- takeoff chock
- Need idea for landing gear wire
- MOVED: ELEVATOR ON B-24
- Metric taps & dies
- Keeping it SIMPLE!
- Solorex help
- wheel collars
- tail dragger
- New Toy " Drill press"
- Painting
- New Manouvrs with Trainer
- What size for 2-56
- flames
- Smokey fuel
- Cover nose of a Duelist
- Bisson "Pitts" smoke manifold?
- Cool paint for cockpit
- Covering monokote with monokote
- Smoke oil in fuel tank
- Breakin Stand
- Establishing proper CG before covering
- Sprayguns...HVLP?
- Prymol
- Fuel proof canopy striping
- Solarfilm and clear Butyrate dope.......
- monocoat meeting a painted area?
- Engine priming with cowl attached.
- tilt wing
- Balancing techniques?
- Getting rid of CA blush on hinges instantly
- Repairing wing joiner H9 AT-6
- Do you know this flight box?
- What building surface do you use?
- Vibrating GMS
- Inserting servo grommets
- Monocoat Backing Removal Tips Anyone??
- Help! One inch of wing warp!
- RCU Video on Installing Robart Pin Hinges - CHECK IT OUT!
- Dremel Sanding Drums
- Can anyone post a picture of the Wet Pint Drops look?
- Fuel line exits
- CA Hinge vs. Robart
- monokote video
- Hardened screw holes
- Tack cloth
- Broken wing dowel
- reglue wing joint to the fueslage
- How to make perfect wing saddles
- Try this when installing landing struts
- balsa cowl for a 4*60 and godberg tiger
- covering foam aircraft
- NEED HELP LOW WING PLANE IS TIPING OVER
- aileron covering??
- TX switch covers.
- tips needed removing old Monokote.
- Making canopy 'frames'?
- fuel tubing applications
- Foam wing cores
- Best Lightweight Wheels
- need help with scale lettering
- Deans Plug Installation Help Needed
- Any info for covering on which to use and what techniques
- Easy way to cut many tailwheels
- Cheap, Lightweight Tailwheel
- Nylon hinges
- Scale Gee Bee Z question.
- Ultracoat paint
- Loctite ????
- fuel line leak fix
- Inkjet decals don't work!
- antenna length
- Care of CA Containers?????????
- Best way to install Robart hinge points
- Chart Pack tape question
- Aluminum to lite ply adhesive?
- Topflite Giant P51
- general monokote tips ?
- monokote
- covering around corners
- Covering a wing fillit.
- Help I think I just ruined 4 props trying to get ONE reamed straight!!!
- Ultracote = Oracover?
- dope help???
- Share your sheeting secrets, please
- Foam brush with latex paint
- anyone used automotive clear over tamiya?
- HANGAR HANGERS
- Field box reccomendations...
- Glassing techniques
- C of G balancing jigs
- Where can I find a Black and Decker Master Cart
- arf antenna tube
- Wing mounting opps?
- cowl shaping with melted plastic
- Looking for Designs....
- Replacing Robart hinges
- Covering fabric control surfaces... what about TE?
- Gap between surfaces using robart hinge points
- posting want ads
- is sheeting required ?
- All-Wood Landing Gear (How-To and a question)
- building techniques
- Fuel Tank stopper popped out (?)
- Glassing questions for TF corsair as an example...how to?
- Decals and Dope
- Installing Wing servos for spoilers on a Great Planes Spirit
- wing help
- sailplane tow release
- Need Automotive Clear over Duplicolor
- Monokote Trim Solvent
- Removing covering trim
- Plug for Sprayway
- Nead some tips on glassing
- Homemade Exhaust Pipe
- Removal of Threadlocker
- Swapping Servo Connectors
- Looking for a good micro retract servo
- sticky hinge
- Trick for running aileron servo wires in a covered wing
- CONVERING A FUSELAGE QUESTION..?
- Home made wire pipe mount
- Unscrewing broken screws.
- Using CA to soak fiber glass center wing
- home made decals faded away
- Help! Warped balsa sheeting
- Loc-Tite subsitute
- RADIO CASE
- Repairing water damage
- Need a Trailer, where do I start?
- Fuel soaked wood
- crock pot
- Respirator for CA allergy
- HOW TO TAKE THE WARP OF FOAM FUSE?
- Flight metal /ali question?
- clevises--dubro vs sullivan
- Bad sheeting on foam
- sheeting wing with balsa
- Hinge sealing questions ?
- I'm loosing pieces and I haven't flown yet!!!
- Washout
- Improvising
- Hair Sray vs. Balsarite
- Installing Mass for CoG
- Color Schemes
- dope on balsa???
- wing repair
- Koverall on control surface
- Tips on Tail Draggers please!
- Aluminum Spinner Painting
- Cutting out Ailerons/Flaps from a Sheeted Wing?
- Litho plate
- Trailer-Exteriors
- Oily Film Remains Even After Cleaning - What's Up With This???
- Aluminum Engine Mount Questions
- Spinner and backplate balancing....How To
- Ok Folks, I'm Totally Stumped. Any Help Is Appreciated.....
- Silk & Dope Help
- cheap homemade DC motor regulator
- Epoxy storage
- Making a non-slip straight edge / Where do I find these little round things?
- sealing decals on solartex
- wing hit rock on landing - need advice on repair
- Covering!
- Painting over Koverall
- Beating a Dead Horse - Or, a covering question
- scale panel lines & rivets
- cleaning a 4cycle engine
- How to Repair Glass sanded through to balsa~
- Clear Coat over colors
- Painting over iron on covering
- Is regular polyurethane fuel proof???
- Painting/colouring balsa models
- How to avoid hangar rash?
- How to keep pilot in seat ?
- How To Get Edges Of Vin=yl Lettering To Stay Down?
- Trailer Suspension
- Problems with LusterKote Paint
- Crankcase over flow
- MonoKote on LustreKote
- spinner
- Fuel Soaked Balsa
- bubbles in covering
- Homemade Decal Help Please
- panel line advice
- Fuel Proof Polyurethane
- Aileron servo setup question
- Muffler Brazing
- Fuel tank assembly
- Retracts in a Sig Kouger
- How do I make repairs?
- priming&flying
