PDA
View Full Version : Tips & Techniques
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23
  1. Phaeton II Balsa USA
  2. balsa filler
  3. Painting - I feel dizzy
  4. Iron-on Film over epoxy
  5. Balsarite
  6. Paragon Canopy
  7. Engine mounting
  8. Spare prop storage
  9. Painting a Spinner
  10. Is car paint fuel proof.
  11. Warped ABS Hull
  12. dual aileron &rudder servo install
  13. Wing Fillets
  14. Field box 3
  15. Field box 2
  16. Field box +
  17. Adding an LED to Rx channel?
  18. Fiberglass parts for GP Ultimate Bipe. Where?
  19. 4*40 Balance
  20. metal strip hinge installation
  21. What Type of Air Brush?
  22. Nylon Ball Link Removal
  23. How do I get glow feul off of my wood floors?
  24. How do I fit a pinned flat hinge neatly?
  25. really nice wheel wells
  26. Hog Bipe
  27. Mounting servos in foam wings
  28. Got Starter ???
  29. Monokote Question - Advance Covering -
  30. CA hinges and probond
  31. Cutting CA Hinges & Re-Installing Elevator
  32. Advise on silk span covering
  33. Any tips
  34. Using Aqua Net before covering?
  35. Backup Rx battery?
  36. what is Heat-Tac Carbon Tape?
  37. Air-craft stand
  38. Micromarks $329 "Microlux Tilt Arbor Table Saw"???
  39. Skiis off grass?
  40. New release of software Profili!
  41. Building from a kit & ran out of balsa
  42. Monocoat circle cutter
  43. Shock absorbing Landing gear
  44. A very handy Tool
  45. Covering techniques? Help!
  46. How to install phenolic sockets in built up wing
  47. How to bend 3/4 Al thinwalled pipe?
  48. Spray Adhesive
  49. Old midwest (Pitts Special) Kit
  50. How do they do that?
  51. Winter Flying
  52. Best Planer?
  53. Post flight glow cleaning tips?
  54. Sheeting Wing Cores, Cutting Control Surfaces, & Putting Leading Edges.
  55. Sealing Hinges
  56. Ca glue
  57. bipe help please
  58. buliding light/4 star
  59. Home made downdraft table
  60. Whats the purpose of balancing a low wing aircraft upside down?
  61. Servo mounting
  62. tube wing spar
  63. PPG K36 Primer online source?
  64. 1/3 scale Pitts - Incidence figures ?
  65. Threadlocker for plastic motor mounts
  66. Bomb bay doors ???? Mechanism
  67. SUPER Small battery pack? SURE!!
  68. Does size REALLY matter?
  69. Fuel tanks with molded nipples
  70. Storing a plane
  71. Windscreen Scratches
  72. Hinge pockets
  73. Using Sig Koveral?
  74. Hangar 9 Alpha Trainer - Reinforcing the Tail
  75. building on glass surface?
  76. Model Tech P-51 .60
  77. Help with sheeting foam core wing
  78. :confused: fuel proofing H-9 p-51 ARF cowl
  79. Dazzler .40
  80. Copying Plans
  81. Painting trim on fabric... Need some help.
  82. Laterial Balancing!
  83. Wing bracing wires
  84. Static Buildup- Explosion Hazards?
  85. Old Timers out there: Which Silk best for Dope??
  86. Retracts and CG
  87. Tracer
  88. Stay Brite works!!!!
  89. Covering an SE Fuse
  90. What is the Fan-Fold Foam??
  91. oil base poly finished fiberglass question
  92. 3W Extra 330 Colours
  93. plastic covering
  94. weathering
  95. Shrike 40
  96. Luster Coat on ABS plastic
  97. Silkspan and Monokote together
  98. Sig Hinges
  99. Website about making you own tailwheel
  100. Rounding the trailing edges, is it essential?
  101. Soldering wire gear
  102. Cowl mounting - drilling holes
  103. I want to cover like this.....
  104. retracts for Lanier P47
  105. book on r/c working with fiberglass ?
  106. CA glue and humidity
  107. Best way to install pinned hinges ?
  108. clear coat problem: any ideas???
  109. Pipe bending
  110. Bending Balsa Sheeting
  111. Coverite over Coverite
  112. Will Windex method work on clear packing tape ?
  113. CG problem
  114. Scale Panel Lines
  115. Adding Weight... How?
  116. How to make flames from monokote ?
  117. Building board??
  118. Need a canopy HELP!!!!!
  119. Easy, Consistent Rivets
  120. Silkspan and Nitrate
  121. Which one? Monokote or 21st century fabric???
  122. Aluminum Ski's
  123. How do you embed an aluminum c-channel spar into a foam wing?
  124. SOLARTEX - how to ?
  125. tariler
  126. Drop down wing rack
  127. New trailer layout
  128. getting any rubber objects to slide into anything
  129. Ultracote & Oracover
  130. K&B Paint thinner What is compatible?
  131. washout
  132. Hardest waterbased Polyurethane.
  133. Drilling through ABS
  134. How to apply trim over monokote
  135. where to buy #1 & smaller screws
  136. how to build a low cost automatic foam cutter
  137. Laying out foamwing cut outs
  138. #11 blades from Tower Hobbies any good?
  139. WIng joining problem
  140. Racks for planes/wings
  141. Stab installation mistake
  142. Mounting Receiver
  143. Making wood propellers
  144. Removing CA from Covering ?
  145. Coverite
  146. Building On Glass
  147. Determining CG for a tapered wing
  148. Foam Expert out there?
  149. Thin odorless?
  150. Downthrust
  151. Covering undercambered wings?
  152. Epoxy vs. CA Glue
  153. What kind of wood?
  154. what is silkspan and dope process?
  155. tissue and dope ?
  156. Field Stand
  157. FW190 sliding canopy
  158. Filler/Putty
  159. Sig Koverall
  160. Zen 90 Rudder Control Horn Pull-Pull issue
  161. Substitue Rubbing Alcohol
  162. Sheeting a Foam Core Wing
  163. 4*40 Fuel Tank
  164. D-tube gluing process
  165. How to repair canopy
  166. Thinning CA
  167. Wing hold down ideas?
  168. Replace servo with electronic on/off switch
  169. Does Carden make a 1.20 sized Edge?
  170. Warping
  171. easy touch sander
  172. How do you get monokote off your balsa wing?
  173. Sealing Hinge Line onUS60
  174. Paint To Match Monocote Pearls
  175. How do I Repair "Spider" cracks in Fiberglass?
  176. Refinishing a cowl
  177. Has anyone tried this fiberglassing techinque?
  178. How Do I Get Smoke?
  179. Coverite
  180. Heli Glassfibra blades
  181. Ultra Sport 1000 wing sheeting
  182. how to make great home-made decals!!
  183. Source of CUSHIONING Foam for transmitter
  184. G.P. AT-6 Texan Best Retracts ????
  185. PFM Glue...Where can I find...
  186. Help with warped ARF panels
  187. Another fiberglassing question
  188. Making nice CFK finish... forgot the plastic.
  189. Building tips and kit reviews at Hangar 37
  190. Patching and covering with Ultracote
  191. Plane Balancing Idea???
  192. No more leaky after run oil!
  193. Cub help wanted
  194. Dual servo aileron...
  195. Mixing proportions for millitary colors
  196. Trim Scheme Poster
  197. fuel proofing model masters paint
  198. Love to build, hate to cover.....help?
  199. Throttle linkage for 4s
  200. Does anyone have a TX cleaner?
  201. Z-Bends vs. Quick Connects
  202. Holding stick-built frames down
  203. Balsa Sheeting / silkspan control surfaces FW190
  204. A Question for painters....
  205. Quality Prop Reaming Tools
  206. Fuslage twist? Now how'd that happen.....?
  207. 8' Solid Worksurface?
  208. 1/4 Music Wire- Bending
  209. Taping wing joint with fiberglass and epoxy
  210. Covering over Filler
  211. Bending / Shaping Balsa
  212. Gap seals
  213. Where to spray paint??
  214. tip on monocote cleaning
  215. a not so perfect wing ... and flying??
  216. Stencils from shelf paper?
  217. canopy question
  218. Chart tape Panel Lines
  219. Fuel proofing exterior latex paint
  220. Ultracote repair
  221. MonoKote/Ultracote Iron Sock Idea!
  222. Custom Decals for RC Aircraft
  223. Covering for the Novice
  224. Another handy Tool Idea
  225. Hinges and the order they should be installed in.
  226. Engine Mounting
  227. I got my new trailer to haul planes with!~!
  228. Hobby Lobby Oracover
  229. Nose heavy? Have Solution!
  230. Removing wing-warps
  231. O.K. Let's Build.....
  232. How much Z-Poxy Resin?
  233. HELP! Epoxy not setting up!
  234. "Window Tint" Spray Paint
  235. retracts
  236. What type of glue for Klett or Dubro Hinges
  237. European name for 6061 Aluminium!!
  238. Nitrate Vs. Butylate
  239. Onion Skin Paper for Homemade Decals
  240. Spray gun?...
  241. Hinge slotting for dummies...
  242. How to make a good FLAME with monokote
  243. Fiberglass canopy?
  244. will this work?
  245. Best way to tap engine mount holes on firewall ?
  246. Let's Talk SMOKE!
  247. Applying monokote with out heat
  248. Gel-Coat Repair / Refinish
  249. Foam cutter variac
  250. seagulls making a mess
