PDA
View Full Version : Tips & Techniques
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Homemade fuel tanks?
  2. Painting
  3. Having a problem viewing DXF file in Tile Print
  4. gliders into rc fliers?
  5. Zurich Sunglasses
  6. Adjustable protractor to transfer angles from plans?
  7. Making corrugated siding.
  8. GP Slot Machine Jig
  9. x acto users beware
  10. Cutting Aluminum Angle
  11. What weight fiberglass cloth for wing center?
  12. What order should I buy these tools?
  13. Bright Yellow UltraCote Paint does not match covering
  14. Engine incidence
  15. The Magnetic board is done!
  16. Make Board-Edge Clamps
  17. Make Painting Boards
  18. Matching paint with covering
  19. Venus 40 tailplane
  20. Carbon fibre pushrod ends
  21. Batteries on sale
  22. Custom decal over painted covering
  23. flite metal
  24. removing decals under clear coat
  25. Gap Filler
  26. Remote ignition help. How do I do it?
  27. No heat gun with solarex?
  28. glow plugs
  29. Adding Ailerons
  30. Cheaper clear coating found
  31. Somke System How To
  32. Sig 4*60 w/retracts?
  33. Questions re channels for servo wire in foam wing
  34. how do you balance a spinner
  35. bending the pushrod for my retracts
  36. paint for styrene and solartex, suggestions?
  37. Vinyl graphics where do you get them?
  38. Painting Canopy
  39. Hiding fuel valves & power switches
  40. Side mount for standard servos?
  41. ATTENTION!! RALEIGH N.C. MODELERS
  42. CA Removal On Ultracote ?
  43. No more holes in covering!!
  44. Incidence Meter
  45. I need a dual receiver / battery 101 course…
  46. Botton hinging flaps ?
  47. Is Wright engineering still around?
  48. Dremel table saw
  49. Homemade Hot Wire Foam Cutter for $30-40!
  50. MOVED: Converting Bitmap photos to jpg
  51. DIY Shark Nose
  52. Have You Used Hot Glue in building?
  53. Ca hinges and a Butrate dope clear cote
  54. Technique for painting insignia?
  55. flight line cart
  56. os 46 engine problems
  57. Need product name and where to purchase
  58. Painting Spiral Stripes on Spinner?
  59. Help With an Airfield in Monroe, NC
  60. TF GS P-51
  61. Field Chargers
  62. improvised thread lock
  63. Panel Line Problem
  64. Glow starter in pocket
  65. Fiberglass Filler: Which One
  66. Question About Engine Mounts
  67. Help-soldering-landing gear ?
  68. How Did You Repair Cowl?
  69. Whats the best way to clean fuel soaked wood for covering?
  70. bending wire
  71. Monokote trim sheet
  72. Wing Tubes for Servo Leads
  73. How to remove decal adhesive?
  74. When cutting carbon fiber...
  75. Glue plastic to wood
  76. Looking for examples of soda bottle cowls
  77. Polycrylic over Latex
  78. Painting over Covering ???
  79. A true striaght edge?
  80. Epoxy or Gorila glue?
  81. Best way to sheet a wing without CA?
  82. help with building a wing
  83. finishing with Koverall or equivelant
  84. B.S. method
  85. Tank pressure problem? Lean run after 1/2 tank run
  86. Masking with Frisket?
  87. Need CA hinges?
  88. Cowl primer before Sig dope
  89. Making marks on covering.
  90. Making Wing Fillets
  91. Silicon Jacket Servo Wire
  92. Found a new cleaner
  93. Insanely tiny screws (self tapping)
  94. fixing styrofoam: techniques
  95. Inexpensive clear coat
  96. cleaning
  97. Using epoxy over a CA joint?
  98. Solartex How to seal?
  99. Thread on covering your airplane
  100. top flite wire wheels
  101. Monokoting over Pen or Marker on Balsawood:
  102. robart air retracts
  103. supershrink coverite and rustoleum
  104. ca alergies
  105. Benchtop magnifier
  106. Best brands/models of workshop power tools
  107. Lubricating flex cable
  108. Attaching antenna to plane
  109. monokote and acetone help
  110. Source for small (1mm-6mm or us equiv) boxend wrenches
  111. Engine break in on the plane
  112. Great Planes Giant Aeromaster and a Evolution 58GX
  113. Covering Question
  114. Giant Aeromaster/Evolution 58 GX
  115. TX AND RX ground check at ?
  116. covering help
  117. Sealing airleron hinge line
  118. Getting Started Painting my Planes
  119. Space walker II and CG problems
  120. How to cut out prop windows on spun aluminum spinner?
  121. How to Make Strong, Lightweight Shipping Crates
  122. Experienced Grit/Shot Blasters
  123. Setting up mechanical trike retracts
  124. Getting 2 actions from 1 air tank
  125. Using Standard Ca On Styrofoam
  126. Cable to use for pull-pull setup??
  127. K2R
  128. How to make your tools magnetic
  129. How to install Horns into balsa sheeted foam core rudder?
  130. Magnetic Building Board.....Cheap
  131. Radio Installation
  132. Canopy Glue clean up
  133. A new problem with Lustercoat. Please advise...
  134. smoked out canopy
  135. GP Ultimate l Strut Help
  136. How do I Fiberglass?
  137. 3/4" hole in Balsa? How?!
  138. How to build a balsa sheeted foam core wing.
  139. Repairing hangar rash on canopy
  140. Need Ideas! - Reinforcing Firewall - Funtana 90
  141. Airbrush needle
  142. Putting second battery in for landing gear help.
  143. Cheap Fiberglass etc.
  144. Threaded Hinges
  145. custom paint-job for beginners
  146. JR radio setup
  147. repairing styrofoam:
  148. Flying wires on a Stearman - Help help help!
  149. Silk and Dope finish thread? Any Interest?
  150. Using a RotoZip bit in a Dremel for shaping a stack of ribs?
  151. How to duplicate ray ban sunglasses
  152. Medicine Bottle/ Small Screw Storage
  153. Repairing MonoKote
  154. Cutting Monokote
  155. painting fiberglass fuse
  156. Cowl's
  157. modelers table saw
  158. broken hand tap
  159. Before I buy my drill press what do I Need to know?
  160. Painting over new wood
  161. ford flivver covering repair
  162. Wing to Fuse Attach Dowel HELP
  163. replacing blind nuts
  164. Ideas for homemade balloon tires?
  165. Monokote HELP!
  166. Using a Drill as a Starter
  167. Tape storage ideas
  168. Quick and cheap airplane stand
  169. Help, resurrecting old plane
  170. how to fake a scale wooden flying prop
  171. Cleaning Engine
  172. Stripping old Monokote
  173. Finishing Question
  174. park zone j-3 cub
  175. painting ultracote
  176. Whistle
  177. Where to find covering material that looks like carbonfiber?
  178. (2)10-32 rudder control arms?
  179. 40% Rudder hinge repair
  180. Monokote paint-the worst?
  181. How to replace an engine ring?
  182. afterrun oil
  183. Flip 3D .25 engine?
  184. Iron Cleaning
  185. Loss of power with exhaust extension
  186. Photos, How many airplanes can you haul in your car or wagon?
  187. Aluminum Spinners
  188. External Pylons / Tanks
  189. control rods and clevises setup
  190. Making/Finding a VERY light spring
  191. Gorilla glue for wing joining?
  192. How to reassemble a ringed engine?
  193. coverting 2 speed scroll saw to variable speed?
  194. Need to make foam inserts for 4" Robart Tires... HELP?
  195. need help transporting a plane by air
  196. balsa shavings on carpet
  197. 21st Cent Fabric - Seam Repair
  198. user beware
  199. Need Help on Bipe Struts
  200. enya 40 older model
  201. Pinpoint pull-pull cable exits
  202. Silk and Dope?
  203. Another JB Weld tip
  204. Need pull pull cable tension help
  205. Brittle landing gear?
  206. Towing a trailer
  207. Applying trim to Profilm
  208. Painting takes over my shop
  209. installing fiberglass
  210. Dave Brown Wheels
  211. Membership
  212. lumps and bumps when glassing
  213. Airborne Models ToughLon Covering.
  214. Expandable Building Foam inside Monocoat over Balsa
  215. Hot Glue?
  216. Fuel Proofing (Easier than I thought!)
  217. Sig Koverall over Fiberglass
  218. epoxy debonder
  219. Dave Brown Fiberglass Pushrods
  220. Sig koverall?
  221. 160 FX Bearing Removal
  222. throttle push rod thru firewall to servo
  223. Cheap and simple brake
  224. Ultracote Matching
  225. engine disassembly
  226. What is a good cement for the U.S Air Core 40?
  227. decals
  228. Century 21 Fabric Shrinking
  229. Eindecker 40 Aileron Servo Instalation
  230. Topflite Lustrecoat paint questions
  231. The Ultimate building table?
  232. que. about a dead flat battery
  233. paint help!!!!!!!!!!!!!!!!!!
  234. thrust angle
  235. where can i find....
  236. Broken wing dowels, help
  237. Covering edges adhesion???
  238. Trailer Question, best screws for attaching D-Rings
  239. Airbrushing books?
  240. FAI Fuels and Paint
  241. What do you guys know about Power Panels
  242. Multiple Chargers.. Multiple Planes..
  243. My rivets have dimples! help!
  244. How do I use kevlar tread on Pull Pull system
  245. Aligning Holes For Hinge Points
  246. What glue?
  247. How to Create Multi-Part Covering for a Non-Sheeted Structure
  248. Top Windower Hatch Cover J-3 CUB
  249. Syringe/Needle for glue???
  250. Clear overcoat
