PDA
View Full Version : Tips & Techniques
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. paint or monokote?
  2. Applying Ultracote on Ultracote
  3. repair of Hatori header
  4. Foam Rubber
  5. Keeping your CA
  6. old J3 with fabric restoration
  7. Color match the filler of ABS cowl/pants
  8. Rough field wheel pants
  9. Removing stuck piston ring
  10. How do you protect your servo & batt wires, foam, cable clamps or what????
  11. Building with magnets
  12. header extension
  13. Interior trailer lights
  14. Practice techniques for rudder
  15. Robart styrofoam stand as wing holder
  16. wings that use rubber bands whating to turn them into bolt on
  17. OS 120S-E PROBLEM
  18. canopy?
  19. covering over fuel soaked balsa
  20. Inverted Fuel Flow set up
  21. A HATCH LATCH IN KEEPING WITH THE "KISS" PRINCIPLE
  22. Removing dried CA from monokote?
  23. Painting with Rustoleum...
  24. Need info on building...
  25. Is this resin any good??
  26. building functional shocks for your cub
  27. How to make your own CF pushrod?
  28. Easiest /best way to remove aged covering?--in-->
  29. setting cg
  30. A Boat Builder's Resin Coating Concept
  31. Some questions about an old plane...
  32. Great Planes SS landing gear
  33. How to properly set up ultra stick lite 1.20 for gas
  34. HOW DO YOU SET UP A 3 WAY GAS TANK LINE
  35. Aileron glitch
  36. Building a muffler
  37. Installing balsa sheeting
  38. gap repair
  39. ignition noise (glitch)
  40. canopy setup
  41. working with acetate
  42. Rust-Oleum?
  43. HELP! Monokote Peeling Off
  44. 25.0mm Wing Tubes!
  45. dope over latex polyurethane
  46. Painting over monokote
  47. New Workshop Questions, Ideas...
  48. Recievr Channel Usage
  49. balsa usa magic primer
  50. transporting my planes
  51. bending a four stroke manifold
  52. Masking tape residue
  53. Replacement for canopy glue and filler
  54. Spinner Painting 101 help
  55. Anyone have plans for a building table?
  56. Clear Coat Question
  57. building board material
  58. Installing blind nuts--question
  59. Weightwatchers' Guide to airplane skin
  60. Wire bending
  61. How do y'all control balsa dust?
  62. Show us your airplane storage meathod-Need ideas
  63. ? about building bomb releases
  64. Re-decorating an ARF. Can anyone do it for me?
  65. PLEASE HELP WITH MY NEW WORKSHOP
  66. Check Valves and Inline Fuel Filters
  67. I want to use Coverall bst way?
  68. The VERY BEST Tip I ever got...
  69. decathlon test flight
  70. TWISTED AILERON
  71. Throttlr Set-up Proceedure
  72. Supplies from hardware stores
  73. Can you make small control horns?
  74. monokote overe monokote
  75. twisting 1/4" balsa
  76. Here's a ? for the fume sniffers
  77. difficult to locate engine mounting holes
  78. Programming flaps
  79. Straighten a twisted Easy Touch Bar Sander
  80. Strut attachment
  81. UltraSkik 120/gas powered
  82. Can I drill holes in servo arms?
  83. Bi-plane rigging
  84. Prop Flying off NO MORE
  85. LOOK AT MY GREAT NEW PLANE HAULER
  86. Glassing / Which is Stronger?
  87. Need help: How to mount 90-degree bell crank
  88. How to Hot-Wire a tapered wing, Low-Tech
  89. electric motor mounting
  90. Battery Mounting
  91. Painting prop tips?
  92. panel line questions
  93. Great Planes PT 17 Stearman - engine question
  94. Making SFG's for my 35% Extra
  95. Wet Epoxy Clean-up?
  96. BF 109G-6 split flaps
  97. monocote cleaning reciepe
  98. soldering , brazing or welding?
  99. Muffler
  100. du-bro snow skis
  101. Sig 4*120 Question
  102. Using foam for fillet
  103. How to cover fuel soaked wood?
  104. How do I Prep & Paint a Painted Cowl ?
  105. Another Profili question, sorry.....
  106. can u paint ultracote.
  107. Making a canopy
  108. Rx antennas: can I do this?
  109. Low cost 12V Power Supplies?
  110. Hanging Planes, How-to Hooks
  111. Glue for hinges
  112. Hinge Pins for Smaller Aircraft
  113. Nitro Models Kangaroo Modified
  114. Top flite 63" P-47 Scale Hinging?
  115. New Monokote Technique
  116. Latex,Acrylic and Polyurethane question
  117. TopFlite Monokote Smartstripe Tool
  118. Painting My TF P 51.
  119. How to strip paint from fabric?
  120. panel lines how to
  121. Carving airfoil on depron
  122. Good source for formica??
  123. Oh No! The clearcoat didn’t kick!
  124. Shear web question
  125. Center of Gravity "CG" Computations
  126. How can I Fuelproof Contact Paper?
  127. Cutting G10
  128. New RC media portal for uploading your video, photo, audio and documents
  129. Magnetic building system
  130. Working with Solartex
  131. Need help: Using Servo channel to activate FlyCamOne
  132. Hardening screw holes
  133. How to make valve cover gaskets?
  134. 1" or 4" belt/disc sander?
  135. Home Made CA Kicker
  136. Createx of Faskolor
  137. How to make 4 stroke valve gasket cover?
  138. Sanding Table
  139. Any tips cleaning dirt from fabric covering
  140. On/off vol. switch DX7
  141. dimentions of main spars
  142. 1st spray paint gun?
  143. For .6 ohms application foam cutter
  144. What glue for EPS foam?
  145. radio antenae question
  146. New Power Sander
  147. Covering Question.
  148. Aileron servo positioning, swept wings ???
  149. Make a Good Dremel Router Table and Fence
  150. Tony Hallo, or others quick question about Tony's work
  151. Film Glue
  152. What guage nichrom wire is preferable
  153. Olive Drab Paint In PPG
  154. Need help, how to build a Carbon Fiber pushrod
  155. A better linkage than the plastic
  156. Cutting curves with UltraCote
  157. Aluminium spinner how to cut?
  158. how to cycle batteries
  159. how do you paint a checkerboard?
  160. Removing Decals
  161. fuel?
  162. How to bend wire landing gear...
  163. Wing tube for servo wire
  164. carb and white grease
  165. No shucks
  166. Problem with Cub Yellow Lustercote spray paint matching Monokote film
  167. How do you straighten warped stock?
  168. Iron-On Album Art
  169. How to make a leading edge???
  170. Plans for Hot wire Foam Cutter?
  171. Fiber Glass Repairs
  172. Pop Up Trailer Conversion
  173. OS Drive washers
  174. WING TUBE INTO FOAM WING
  175. Mask For CA Fumes
  176. Onboard glowswitch
  177. Super Coverite
  178. Getting a deal at the LHS
  179. Gorilla Glue for CA Hinges
  180. CA Hinge Off Centerline
  181. Needle Valve Extension
  182. Free Kevlar
  183. Straws for wiring tubes? Oh yeah!
  184. Magnets for Hatches
  185. canopy cut edge
  186. Covering question
  187. Checkerboard Covering
  188. Free Marvel Mystery Oil (After-run)
  189. Solder connections on push rods
  190. Painting Pilot Figures
  191. Joining balsa sheet....
  192. Tips On Painting an ARF Please....
  193. Making a Better Pushrod
  194. Lazy mans large, Portable,building table Finished w/ PICS
  195. Work Bench building
  196. Bobcat Tank Setup....???
  197. How do you get rivot lines?
  198. Help with PPG paints!
  199. Glassing questions
  200. Painting vs. Monokoting??
  201. How do you keep plastic film attached
  202. Engine Mounting?
  203. anyway to keep old decals down?
  204. Latex Paint Spray Tip Size
  205. Need tips on sheeting I suck
  206. Pull-Pull Rudder Setup Help
  207. Winter storage for RC planes
  208. Evolution 1.00 w/ Bisson Style Pitts muffler
  209. Tin Foil on Radio True or False?
  210. windows and fuel filter valves
  211. Ribbons???
  212. Solartex clear coating
  213. Devilbiss Touch Up Gun for Latex
  214. Reinforcement taildragger
  215. Byron Pit Pal tool holders
  216. Mounting a servo on its side.
  217. Help with cowl cutting
  218. painting wood
  219. Is there any way to shrink balsa sheet?
  220. One gallon paint can for fuel tank in field box
  221. Cleaning covering after flight
  222. must have at the helicopter field for clean ups
  223. Tips for buying R/C stuff at wal mart, home depot ect ect
  224. wheel collar air restrictor for retracts
  225. Fabricating Gear Doors
  226. How to Choose a Power Setup
  227. Speed 400 motor
  228. Dupont Centauri Replacement
  229. clear coating ?
  230. Preflight-PreflightPostflight?
  231. Glue for green floral foam?
  232. How to solder connectors?
  233. Super Tigre fix for any size
  234. Problem with Lustrecoat paint
  235. spraying plane with polyurethane
  236. 2 Stroke Glow Engine questions
  237. Painting an ARC Cessna 177 (ABS) ? ?
  238. Metal push pins
  239. custom markings using film
  240. Cutting plywood parts without all the fancy saws
  241. *Good Solid Work Table*
  242. Paint question
  243. What is the best way for making decals?
  244. Scotch blue painter's tape, handy thing
  245. 2C Garage to Ultimate R/C Shop Renovation
  246. flying wire kit
  247. Relocate NiCD Pack to Shift CG
  248. cheap reciever, fuel tank battery e.t.c protection
  249. Paint over Monocoat?
  250. Plane stand
