View Full Version : Tips & Techniques
- Super-Easy Durable Coating for Foamies
- how to correct twist in sheeted/glassed stab?
- covering with fabric where to start?
- Pre-Finishing with Epoxy on Plywood
- Prevent Exhaust Deflector from falling off
- Removing glow engine cylinders
- STEP DOWN IN ONE SERVO
- Sand paper review
- Newbie covering project????
- Storing Glow Engines (2 & 4 stroke)
- New addition to my flight box, cool huhh
- Homemade COG machine
- adding 2 servoes fro elevator
- HOW TO RECOVER FROM AN UNINTENTIONAL SPIN?
- How do you store your covering in your shop?
- Propeller storage and carrier?
- COCKPIT COAMING MATERIAL
- Bench running
- Fiberglass Cowl, How to repair, make whole
- Digital Servos with an ESC?
- Balancing Question
- Tip on hardening holes, NEATLY
- WHAT TO DO AFTER THE PLANE IS PAINTED?
- HOW TO ACHIEVE STRAIGHT LINES OVER THE EDGE?
- A VERY GOOD TIP YOU CAN USE !!!
- Smoke in Jet
- Here's a simple tip!
- CARL GOLDBERG TIGER 60 PLANS
- HEAT GUN - DO OR DIE?
- Translucent/ Chromed canopy
- REFINISHING A BALSA SURFACE -AFTER REMOVING THE FILM COVERING
- NEED DAVE BROWN SOUTHERN SORGHUM
- Covering, Double layer trim? Should I?
- WHAT TO DO IF YOU LOSE ORIENTATION IN FLIGHT
- So you want a shiny plane for that special airshow?
- HOW TO APPLY VINYL GRAPHICS
- Save Your Cowl!
- reversed servo
- Stryofoam repair
- Free clamps
- Retracts (mechanical)
- selecting balsa
- advice: which mini table saw to buy?
- Goal Post Engine Stand
- Foam Wing Panel, get the warp out ?
- Heat gun doing more harm than good. Need help/suggestions.
- Made me a plane stand today!
- Rolls of covering ,Unrolls
- Spray Painting - Order of Colors Applied
- Rust-Oleum Painters Touch - Fuel Proof
- Silicone Fuel Line Rotting !!
- Engine cowl (Cutting to fit)
- Help Cover a Sterling Models Cirrus Wing
- Balsa Clean up
- Changing PVA into a contact glue
- Prep for paint
- Oil can makes engine cowl
- Solar Battry Chargers
- Ziroli Stearman 87"
- Retract Strut Length Too Short, Options?
- Clear Silicon Sealant Wing Saddle Seal
- DIY Nav Lights & strobe
- Macs Tuned pipe for OS 46 AX
- NOSE GEAR STRUT REQUIRED
- field box
- Paint finish to foamies
- covering wing tips
- satio 72 4c high & low settings now off
- Broken 4 Star Spars
- Did a dumb thing today
- remote glow ?
- Z-Poxy finishing resin ..?
- What to paint with???
- Respirator
- Is thin CA Necessary?
- Vacuum form a canopy
- Koas 40
- Cleaning covering iron
- Checkerboard iron on covering
- To put Lipo in my glow airplane.
- How do you clip a J3Cub ARF wing?
- Klass Kote Paint question
- Rustoleum Universal Paint
- Covering Plastic Model
- Where to buy sheets of vinyl to make graphics
- switchs
- First time with Dope
- applying fiberglass (or koverall) with contact cement
- Paint compatibility
- Securing large wings in a trailer
- Fiberglassing center wing section...
- Y harness question
- bent shaft from hobby city!!!!!!!!!!!!!!!!!!!
- TIP-TOWER HOBBY HAS A COOL GLO IGNITER
- LEARN ALL YOU EVER WANTED TO KNOW ABOUT ANY RC SUBJECT -right here
- Will my compressor work w/ Paasche airbrush?
- Quick Release pins for H9 Cub?
- Decal removal for CMP Corsair 120
- What size compressor for Sata Minijet 4 HVLP
- Painting a fiberglassed plane, best paints to use.
- arf convering
- Off road trailer questions
- Paint Match for Ultracote Cub yellow
- Barn door drop hatch
- Homemade Strip, Square and Triangle Stock
- RETRACTS
- NEEDLE VALVE basics 101
- Repair Antenna
- esc and motor......
- Correcting bad servo mounting surface
- Attaching and finishing canopies
- OS AX 46
- Exhaust pipe for OS 120 surpass
- Soldering flex throttle cable end links
- Heat resistant fuel tubing?
- HELP! How do I mount these servos!
- Cowl, engine locator!
- Digital Protractors at Bunnings for $24.95!
- Best way to make a replacement canopy?
- What paint to use
- Need help, how to drill small holes, deep within fuselage
- engine isolator?? for vibration
- Balsarite thinner
- DINGED CANOPY
- EXPERIENCED RC PILOT FLYING -TIPS
- Wife bothered by epoxy glue. Alternate solution?
- quick and easy engine alignment/mounting
- Flying one-handed
- JR 9303
- power scource
- What you like the least in this hobby?
- metallic paint for fiberglass fuselage?
- my trailer
- Separation in blue Loctite after long storage, so shake it.
- Torqmaster LC 12V battery.....problem
- Questions on using Solartex
- a great weather resource
- Electrical connections for removable wings
- Gyro on aileron servo in an airplane
- Balancing Jig?
- Tap and Drill set?
- Smallest Gas Engine made for R/C?
- Enlarging Prop Holes
- Canopy glue fuel-proof?
- For What It's Worth
- Home made truck bed slider
- SIG WONDER STARTING STAND/HOLDER
- Sloppy Servo Horn Clevis Fit
- WHO'S GOT THE BEST WING RACK?
- Cutting ribs for tapered wings
- Monokote pre covering
- Simulating upholstry stitching for model airplane interiors.
- custom exhaust
- BUILDING JIGS
- Truck Rack
- engine cleaner
- Removing stuck-on pigment from surface of MonoKote
- Assembly propeller
- Balsa Storage Bins?
- How to make a engine header
- how to remove ca glue
- ABS cowl reinforcement
- Fabric Covering Sticker and graphics removal
- Hanger Storage Options
- Field table finish
- Help bending smaller dia. music wire!!!
- making a cowl
- How to for tinting canopy?
- Sealing Monocote
- What is the Best Airplane Cleaner
- Dirty Birdy
- Thin Wall Steel Tubing
- Need help with a tight fuel tank stopper
- How do you designate servo connections?
- how to do no bubble monocote on sheeting?
- Wire Landing Gear
- Technique to repair a sheared off wing
- I need help making wings...
- Plug in foam wings.
- bomb release for 4 bombs
- Radial Engine Hobbs Meter
- best/cheapest place to get 4-40 hardware
- balancing spinners and props
- How is the best way to stain Coverite?
- HOW TO UNGLUE JB WELD?
- Foam wings - need DIY equipment
- need to measure the torque
- isolate from fuel
- Homemade Servo Extensions
- cowl louvers ....how?
- Nose Art Help
- Fiberglassing - help
- Crisp edges on hatches?
- POLYESTER CLOTH
- Camo colors
- showtime 50 cg balancing
- Fuel proof clear coat over Krylon
- Servo Speed Control
- Cutting Aluminum spinner?
- Tatone pitts muffler for .60
- Red Oracover Paint Match
- CA fogging windshield
- PPG/Omni Paint Help
- My New Workbench. Thanks to your suggestions.
- Virtual Cockpit Website
- O.S. "F" plug for 2 cycle engines.
- what type of solder to use
- A 123 battery problem
- MonoKote on painted cowl??
- rc 56 glue is drying up?
- New to painting
- Clearcoating Epoxy Resin
- Spraypaint on aluminum?
- Casting your own tires?
- Smoke with a small 2 stroke
- JR XP-7202 mode1 to mode 2 conversion
- Fiberglass reinforcement of firewall of ARF warbird?
- Rattle can hint
- READ THIS THESE, COMPANIES ARE GREAT
- Best method to trim cowl
- Install Standard Dubro Nylon Hinge
- Keeping your pilot in place.
- Split Flaps
- removal of decals
- OS 200 FOUR STROKE
- Propeller tube
- Cheap plane transport trolley
- Priming solartex?
- Finishing Klass Kote
- Sullivan dynatron starter
- iwata airbrush
- Monokote and a clean oven mitt=no wrinkles at all!
- GP Cap 580 Splat removal
- lt) a few planes with pretty nice results, but there is one area I Stiff Ailerons
- glassing the wing center section
- roll on primer instead of spray?
- My new totally over-kill work bench
- joining spilt cowling
- Paint over MonoKote
- RED NECK Foam wing cutter power supply
- x heli
- Using Ultracoat over oil soaked balsa
- Making a the solder aid (Helping hands) help even more..
- NEED HELP WITH FIBERGLASS COVERING
- Vac forming Beaver cockpit kit
- Foam to Balsa
- throttle linkage
- Dope and thinner mixing
- Skinny Dip
- Can I apply Monokote or Ultracote to plastic ?
