View Full Version : Tips & Techniques
- Securing batteries/receivers in flight...
- Chrome trim tape application... HELP!!!
- Dubro pull-pull system
- Screwed up some blind nuts
- 4 strokes engine vibration
- Windex Method Bubble Problem
- What is an EZ way to make a glow starter
- Metalworker Needs Help
- Decals Under Fiberglass
- Modifying GP Easy Sport ARF
- How fast?
- xacto blade and soldering iron
- Rubber Bands Rock!
- Website for calculating cg
- Home-made muffler
- Tack cloth
- Working shock absorbers?
- Elevator repair on H9 Edge
- OS AX .46 EXHUST LEAKS
- Super Magnets
- Oracover trim letters.
- Re-covering tail surfaces
- Cheap,light pushrods
- Another Solatex Technique Question/Advise
- Scarf Joint
- solartex painting
- Engine holding with threaded screws
- Does Anybody Know Where I Can Get Blades For This?
- test stand with out the cost of an arm or leg
- How to Make a Good Fillet Sander
- Oily, greasy, grimey, fuel soaked fuse repair.
- Cleaning Ultracote
- HELP --Taking out the ARF "shine"
- Workshop Power Tools
- Outfitting my box trailer.
- the pantyhose technique (?)
- Drill clean holes in balsa - make a Razor Hole Saw
- Decals
- sanding and painting
- Masking film-how much?
- Charging 12V 7amp field battery
- Wing Repair to One Side--Rebalance?
- Prepare wood surface for Glassing
- Engine Cleaners?
- Eopxy Resin techniques
- seen the trailer pic how about car, truck, van setups
- Waxed paper to get smooth filler finish
- engine cleaning
- Vacum forming
- Servo mounting procedures: tips
- Panty Hose & Epoxy Cowls
- Lead Routing Warning
- hatch attachment
- Pull on your clunk to make sure it doesn't come off
- How to prepare raw wood for painting?
- Best Way To Patch A Covering Hole?
- Quick & easy way to balance props?
- How to repair PAINTED solartex?
- ys engine
- Help repairing Plywood Fuse GP Cap 232
- WORKING WITH STYROFOAM!
- OS Performance Upgrades?
- Broken Rib Repair Method
- Improve your ARF: make a wing saddle
- Airplane painting practice
- Installing Canopies
- Prop hole drilled off-center - now what?
- How to paint on WW1 Roundels?
- Smoke System Woes
- GS Landing Gear Plates
- I have a loose muffler on my Saito
- Need help - Warping Checkerboard
- Cypress for sticks?
- fuse jig
- Panel line pen
- need help RE covering PLEASE
- Duplicate Fiberglass Cowl - How ?? Help??
- Socket head servo screws for landing gear straps
- Need help soldering music wire
- Home Made Tools
- 126 building tips
- Where is cg on biplane?????
- Any suggestions lanier 33% EXTRA
- My starter battery caught fire!!
- How to clean Futaba 9C radio face clean?
- How to keep oil off the plane?
- Landing gear installation in foam core wings
- MOVED: Model set up
- A glue tip
- How to make retracts air vessel?
- simple plane hold down?
- CA Hinge Installation
- How to make fglass wheelpants last
- Bending balse - amonia concentration?
- Coloring Epoxy
- attaching fuel line
- starter battery holder
- Covering\Painting Foam Planes
- KOverall finishing
- 2 Ailerons w/ 1 Servo? Is it possible?
- Curing CA the cheep way
- CG How to?
- New Work Bench for $35 Bucks!
- PVC pipe holder for planes - screw them together
- Covering Large Wing Panels
- Tachometers
- Wing twisted? How to check...
- Permanent Field Support Stand for Club
- Dubro servo arms color coded?
- Balancing Machines.
- NACA air inlet
- Trailer venting?
- How to Sand out Orange Peeled Paint
- Retract Guide Please??
- Drilling Fiberglass Cowls, etc.
- Epoxy fillers
- Strait edge
- Foam Wings
- Joining Split ailerons?
- fuel cleanup?
- Harbor Freight nitrile gloves . . .
- Skinned Hinge, torque rod binding
- C G Cap 232
- Reusable Epoxy tool
- brushing dope - what kind of brush?
- Painting fiberglass parts
- COving/Finish on a Kit Build
- Carbon/graphite arrow shafts for push rods
- Posting a Pic
- A good paint to spray on fiberglassed area ?
- Servo Cover
- CG with a cradle or pendulum
- covering schemes
- Help- First Time Moutning an Engine
- Help Balancing My Plane
- What happened to my wing??
- How to lock up Springair retracts when transporting?
- Sealing CA Hinges
- flater finish & panel lines
- Clothes pin Clamps
- Casting rubber tires
- Yo Campy.. Thanks!
- TRU-TURN SPINNER
- Slippage: spinner backplate to thrust washer?
- glueing plans down to building surface
- Short nose plane ? Need nose weight ?
- Accurate flats spots in landing gear
- Aileron horn offset
- MODEL DR.
- Tiedowns for your airplane trailer
- Making pneumatic rams
- The Ultimate Wing Skids?
- Replacing a piston ring?
- cheap field stand
- glueing large areas
- Pica 1/6 Mustang D canopy
- Makeing Linkage with Central Hobbies CF rods and ends
- Installing CA Hinges
- Covering Help
- Ultracoat over ultracoat
- 2 Rudder servo hookup
- Measuring Thrust
- Tip for vintage planes
- Protecting Plans from building damage
- Good method for truing up root ends of 2 pc wing
- Painting Checkerboard
- Transporting Planes
- Drilling for Engine Mounts on Firewall
- pull-pull system setup
- Fuel filler in a cowl
- good TiP ...just cant remember the name
- Looking for a FLAT clearcoat
- Fuel proof thin felt pen
- tip on using gorilla glue for wing joining
- Best "Aliphatic" glues brands??
- Soaking an older engine.
- Fiberglas and polyurethane covering
- Show me your best Latex vs Urethane
- Making Tapered Wing Ribs - Oldie, but goodie
- PROCTOR NIEUPORT 28
- How to find the CENTER LINE on a newly built firewall?
- Try it You will LIKE IT
- Clearcoat over Worldtex
- bandsaw blades for balsa?
- Help with painting polystyrene
- 1/8th Nitro Buggy Break In, Tuning, and Cleaning
- new to fiberglassing, please help
- need help finding
- Cutting precise stripe ends etc.
- Proxxon Micro Band Saw
- Coloring Epoxy
- Cutting spinner prop slots
- horizontal stabilizer not parallel to wing
- How do you remove Monocote trim?
- New Workshop Under Construction NEED HELP
- Ove Glove as an Covering Iron rest
- OK, just tested some HINGE GLUE
- NEW FIX ON THE GEAR,,,HANGER-9 CORSAIR.."IT WORKS"
- just repaired wing
- spilled ca glue
- Need Help.. How to add rivets and panel lines
- DRILLING HOLES IN FIBERGLASS??
- Plastic Gas Tank Repair Tip
- Canopy and other plastic Parts
- Attaching canopies
- WHATS THE BEST WAY TO GLUE IN DU-BRO HINGES??
- How to iron 2nd layer of monocoque w/o bubbles
- Windex for sticky back decals?
- Painting with Latex
- Fuel Tank
- Home made CA Accelerator ?????
- Aer. servo cover
- Du-bro inflatable tire thingy?
- Night fly with luminous paint
- light and sturdy
- Buyer beware !
- Drilling wheel hubs out?
- DIY stick ends paint job !
- I need a vacuform expert...help
- Help installing Dubro skiis!
- new painting
- chisel
- Loctite differences??
- OS 61fx piston install question
- Warped wing
- good lay out for panel lines ??
- Sig Koverall
- safe pack for RX
- Bending music wire?
- RADIO HELP
- Epoxy over Latex
- 5x10 landscaping trailer converstion
- Evolution power system tuning
- Curing CA with Smoke
- MOVED: Servo centering question
- removing monocote
- looking for an up-to-date informative RC plane flight tip/techniques book
- Foam Cutting problems
- Flaps for ARF'S?
- My Turbocharged MDS .68
- Krylon paint
- Bad Dog cutting tool
- fabric/paint removal Pica Waco
- Question air comp and tool oilers and paint
- Muffler extension caused loss of power
- Light weight STRONG struts
- BT Spifire: Sanding Filler
- GWS Tiger Moth (camera on board)
- jet tronic brake valve setting and mixing
- Looking for LED lights for you airplane?
