PDA
View Full Version : Tips & Techniques
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Restoring old iron on....
  2. Cowl Latch Suggestions
  3. how to make perfect round holes
  4. Servo load calcutator
  5. Starters and 12v batteries
  6. Refreshing epoxy
  7. Best way to remove and repaint foamies?
  8. Epoxy tip
  9. What is a "wet coat"?
  10. Pull-Pull Rudder cable geometry ???
  11. Blind nut in very rear of plane
  12. Sanding Sealer Recommendation
  13. landing gear tips needed
  14. Separating Epoxy Joints
  15. toughflon covering?
  16. Wing template
  17. Top Flite AT-6 ARF with E-Flite Retracts
  18. Widows......how to?
  19. Hanging Airplane Storage Cube/Box
  20. Dollar Tree foam board
  21. Starting screws and nuts in tight places
  22. landing lights
  23. Cubs and fabric covering details
  24. Paining lines with liquid mask
  25. Simplified Fueling Valve
  26. Flat Sanding Small Peices
  27. Bending Undercarriage Wire, the right way!
  28. Sport .46 glow engine reviews and testing
  29. Need help with home made smoke system.
  30. I need help finding an item for building.
  31. Painting... suggestions on how to fix this spot
  32. How to drill holes 90 degrees to the end ribs of horiz stab ?
  33. Sanding Tool
  34. How to make monokote stick better to OLD wood??
  35. engine mounting
  36. Decatlon hatch door
  37. Lengthen a nose gear
  38. Engine too long
  39. making decals stick
  40. Hobbistar tail repair
  41. Need Help Making Fuselage Storage Rack in Garage
  42. Vertical airplane storage
  43. How to Repair Cowl
  44. Valspar Ultra
  45. Parkzone T-28 ultra micro repair
  46. using Star Tron
  47. Fuel proofing the common spray can paint like Rustoleum
  48. What's the best paint to use over Solartex??
  49. Robostruts
  50. Quick Tip to keep your Monokote Iron off your Manhood
  51. Panel Lines: How to do Rounded Corners?
  52. How to locate mounting holes on a new cowl??
  53. Finally Achieved Zero Fades
  54. Pilot RC CF gear for 50cc Slipstream SBach 342
  55. Cheap electric glow fuel pump
  56. Wing Depron Construction Using Balsa Technics.
  57. Add Lift Spoilers to a wing?
  58. Repair Question
  59. Free fuel filler
  60. How do you remove paint over spray from MonoKote ?
  61. vac former
  62. Help with a repair
  63. lexan forming question
  64. soldering motor wires
  65. Hobby king turnygi 420 charger
  66. Warbird colors paint. What clear
  67. Spraying Latex
  68. Help with paint and tape.
  69. Heat formed plastic cowl
  70. Epoxy curing temperatures
  71. Piper cub glass
  72. Handy CG reference indicator
  73. Foam core Fiberglass wing crack
  74. Building a paint booth
  75. Painting over a painted fiberglass plane
  76. Warning to Those Using CA Over Certain Types of Foam
  77. Butyrate dope over Hobby Poxy?
  78. What is the best way to use Balsarite?
  79. Landing gear reinforcement - design, construction and assembly
  80. Easy way to create long servo extensions
  81. building board
  82. MK-82, 83 or 84; MERs & TERs (Approx 1/12 Scale)
  83. Hidden cowl mount ideas
  84. Great deal on single edged razor blades
  85. Spackling ok to fill small gaps?
  86. Wing bolts - from slot to Robertson
  87. What should I do, buy or rebuild?
  88. Painting piano wire?
  89. ESC/receiver separation distance
  90. Hobbistar 60 - Bolt-on wing conversion
  91. easy way to pull wires in plane
  92. Horner wing tip how to build.
  93. finding slow leaks in air retracts
  94. Hobbistar 60 - from one aileron servo to two
  95. Will need help from members here for this build
  96. Throttle hold for electric planes
  97. replacing bearing in a os FS 61???
  98. My new flight stand!
  99. Trim on EP plane
  100. New Mold Making & Resin Casting Book
  101. duel elevator servos
  102. Primer and Paint for Fiberglass
  103. A little help, please!
  104. Need some solartex !
  105. To Patch or not to patch
  106. Home printer grafhics...where to get the stock? What type?
  107. Slide-out Power Module
  108. Fing CG
  109. Making tools to build with
  110. Make my own mufflers?
  111. Spar Strength on a 108" C-130
  112. Homemade sealing iron socks
  113. Laytex paint is not what you think it is
  114. Need to apply epoxy precisely?
  115. Bend landing gear
  116. Help on soldering a threaded coupler
  117. Covering sequence suggestion
  118. Vinyl Graphics thikness
  119. Vinyl Markings over rib stitching
  120. Help reproducing a fiberglass cowl
  121. Removing excess glue from CA hinge
  122. Remove color from an anodized spinner?
  123. CA hinges to Robart pin hinge
  124. modified tool to make cutting foamies easier.
  125. bad lipo
  126. Awesome Pit Table Design - Plans and Instructions
  127. pull-pull rudder set-up
  128. dle 20 spark plug
  129. changing motor mounts
  130. Fiberglass cowl louvers
  131. Clear Coat: Over or Under???
  132. Airbrush
  133. Rustoleum Fuel proof paints
  134. Klass Kote thinners
  135. hatch locker
  136. ULTRACOTE
  137. PERFECT BRAND PAINT
  138. Attaching Koverall Solvent Free
  139. Sig Koverall
  140. THUNDER TIGER 90 COMPRESSION
  141. How to clean my nitro engine
  142. How to make a "copy" of a canopy?
  143. Another foam core wing sheeting technique
  144. Bind & Solder
  145. Harbor Freight P-51
  146. ASTOUNDING NEWS RE DOLLAR STORE DEPRON
  147. sticking monokote to monokote
  148. ? Clear Monokote Covering a Whole Airplane?
  149. Tape For Canopy
  150. Painting 1 - 2 -3
  151. What Parts Are Must Have for Glow/Gas Planes
  152. Write-up: Carburetor screw adjustment guides
  153. Covering With CA Glue and Silk
  154. Fuel proof spray paint a thing of the past?
  155. Painting with auto paint questions
  156. CA sticky an stopped up
  157. Smoke Oil Tank size
  158. Fue level indicator in closed cowl (RAM)
  159. Scale Switches for cock-pit detailing 1/6 scale
  160. Add Channel Switch
  161. Mix Elevator with Throttle for Scale Flight?
  162. Write-up: DLE-20 reed valve block mod
  163. Write-up: Installing a Bowman ring in a DLE-20
  164. Stix-It Question
  165. Making a CF/steel rod rudder pushrod.
  166. First impressions: Bondhus ProHold ball drivers
  167. Covering compound curves
  168. HELP - nitrate/dope 101??
  169. Ultracote Checkerboard Color
  170. Harbor Freight's Small Carry Case Ideal for Chargers
  171. Pinning the firewall - 50cc SBach
  172. Trailer pics and ideas?
  173. Covering Question
  174. Tips to make you a Better Pilot:
  175. Tips for removing covering?
  176. Cordless Air pumps for retracts
  177. That Eureka Moment..
  178. Wheel pants restoration
  179. covering wingtips
  180. Polishing an aluminum spinner
  181. Painting a glass filled composite landing gear
  182. Top coat
  183. Wood stringer storage?
  184. clearcoat decal
  185. rigging tail gear
  186. RC tools from Lee Valley
  187. Done with GP epoxy!!!
  188. 12 VDC on the bench from repurposed PC power supply
  189. Monokote keeps peeling off
  190. Tissue Covering Please Help!
  191. sources for Nelson paint
  192. First bipe
  193. Painting Coverite Fabric?
  194. Decal Application Technique
  195. Suggestion for airbrush?
  196. Air Pump recommendations needed
  197. Help: I need to remove CA from nylon tailwheel bearing
  198. Converting tricycle to tail-dragger
  199. transparant wing covering
  200. Showtime 90 with DLE20cc
  201. Transport questions
  202. RC Project Workbench
  203. hobby king code
  204. Servo horn hole too big
  205. Dawn Power Dissolver gone ?
  206. Polaris building foam
  207. Storing airplanes and keeping them clean
  208. How to loosen hinges
  209. canopies and cowls
  210. polaris foam plane
  211. balancing a sweep wing
  212. Painting Park Zone Foam War Birds
  213. Removing sticker residue - with peanut butter.
  214. Retract Question
  215. "Glazing Putty" for balsa?
  216. FMP Fox
  217. Charge transport and storage.....
  218. Prim for latex painr?
  219. Great Planes Goldberg Anniversary Cub Kit
  220. ALERT watch out be careful of this guy
  221. File for model use
  222. Check your Field Box Battery
  223. ""Locktite on Metal gear servo screws, don't skip this step""
  224. 5 mm strut pin alternative
  225. Need a Good Spray Gun
  226. Wing tote bags
  227. Sheeting done with Titebond & Heat
  228. Setting motor position
  229. Rattle Can Painting Advice
  230. Painting with rustoleum
  231. Odorless Glazing Compound
  232. Balancing trick for CG and Lateral
  233. Canopy tinting question
  234. Z-poxy Waxy coating removal
  235. Buying a vinyl cutter
  236. towing banners
  237. Mark point for drilling holes in CF reinforced plate for motor.
  238. nylon bolt extraction / removal
  239. Best way to remove & recover a small wing section?
  240. Plug-N-Play Wing's
  241. Remove paint from tires?
  242. Hinging options
  243. neat tip from an old timer
  244. New house NEW GARAGE SETUP!!!
  245. Could this be the perfect clear coat?
  246. can't give up old faithful (oil soaked wood)
  247. Which Epoxy?
  248. hold the cover?
  249. OS Max 91 fx rebuild help (Disassembly Pics Wanted)!!
  250. windshield screws at dollar store
