PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Mid tank mod
  2. New 7 minute video
  3. Is it possible ( Savage x 4.6 Antena )
  4. New shoes for the savage....
  5. exhaust diflector
  6. MOTOR UPGRADE QUESTION
  7. HPI: Mt2 question, popping wheelies and making it faster
  8. Electric Setup
  9. cb removal..
  10. Question about truckzilla clutch bell..
  11. Question about clutch bell..
  12. Roto start for my LRP .28 spec 3
  13. Spur Gear
  14. Savage Jumping Compilation
  15. NEW XL
  16. Manifold
  17. clutch/flywheel for savage
  18. Watch this, its got a savvy in it!
  19. Trani case?
  20. Glow Plug??
  21. My SUGGY!!!
  22. I hate to admit it but...
  23. Savage 25 UPGRADES!!! Need Help
  24. Engine sleeve and piston removal???
  25. Vintage Royal Crusher 4x4 question
  26. Savage most common engine used.
  27. 14mm Hex stripping..
  28. Atomic R/C rear hub carrier
  29. Switching glow plugs
  30. X chassis question
  31. Im so Savvy
  32. spektrum question
  33. Needle Question
  34. Savage X SS Suggestions
  35. After run oil in your fuel
  36. Savage X f4.6 idle problems.
  37. Pics from a HOT Collari .32
  38. Something is wrong and i can't figure it out
  39. diff spool
  40. MGT 8.0 engine
  41. savage problems?tanks breaking?
  42. I love home made parts!!!
  43. need help with clutch bell assembly on new axial rr mill
  44. Easy fix for piston stuck at TDC
  45. savage x keeps eating spur gears
  46. Lst shock pics
  47. savage ss / 4.6 run problems please advise
  48. SH.28 or K4.6?
  49. Savage Body Template - for paint designs..
  50. fuel tank horrors, ideas PLEASE
  51. The Engine Fit
  52. all of a sudden glow plugs keep dying... help
  53. savage rear diff
  54. Savage Owner w/ Full Roll Cage
  55. Friend Thinking of Getting a x 4.6 SS
  56. Who was it????
  57. Dog bone problems
  58. Getting Hot
  59. screw ?
  60. new shocks
  61. Fuel Tank Run-out?
  62. Savage X rtr or Savage ss
  63. Cracked fuel tank
  64. cracked engine case.now what
  65. Easy Mods
  66. What to do!?
  67. Need help w/ my x4.6
  68. lrp /picco play time
  69. 2 week old savage clutch trashed
  70. Chassis bolt keeps breaking.....why?
  71. Flaming out? Not sure why.
  72. Good Hobby Web Sites!!
  73. BUKU owner's please help me...
  74. svage x 4.6 rtr "Dog Bone"
  75. savage x losinng power
  76. exhaust question
  77. witch glue is best
  78. all you s25 diff housing
  79. 49 tooth spur gear
  80. dual disc brake install, i have a quick question.
  81. tuning questions.
  82. Transmitter,and receiver upgrade.
  83. lst shocks?
  84. What Part is this Quick!
  85. savage ss or savage x ss??
  86. Savage upgrade questions
  87. x arms vs 21 arms
  88. 17mm hex
  89. Proud new Owner of a X4.6 ... I have ? too
  90. HPI Graphite TVPs?
  91. quick question
  92. hop ups which to do what not to?
  93. RBMods SureFire 32R break-in
  94. engine for savvy!
  95. first savage bash
  96. Savage 25 RTR differential question.
  97. tacoma / hilux body
  98. Savage Owner !!! What Glowplug
  99. E-Savage GT Escape Charger question?
  100. Bashing- Pictures inside
  101. Savage XL???
  102. equivalent gear ratios with different clutch and spur combinations
  103. Question about Savage 21
  104. Mt2 Electric conversion
  105. spur gear
  106. savage 4.6 with LRP 28 spec 3!!!
  107. savage XL to buy or not to buy
  108. Difference in tuned pipes?
  109. Did this also happened to your K 4.6? Pics inside
  110. Differential confusion
  111. skeptic ->(converted now)
  112. El Cheapo Wheel Repair
  113. Savagex brakes
  114. Washers for the Savage X SS steering post
  115. Has anyone seen this VID.. Sick air!
  116. RB modded STS 30 VS stock Picco P3 VOTE!!!!!!!!!!!!!!!!
  117. new glowplug... WOW big difference.
  118. cordless drill instead of roto start??
  119. Big Tires
  120. Very unusual problem.
  121. CV vs Dog-Bone Question
  122. Brakes
  123. why the savage?
  124. reading xrc cars may 08
  125. metal spur gear?
  126. Quick help with 2nd -3rd gear adjustments
  127. NEED HELPS!
  128. Need help with engine, please.
  129. Brake upgrade...suggestions wanted
  130. Dented RD pipe with LRP 28
  131. exhaust protection plate?
  132. new savage
  133. 17mm conversion
  134. F4.6 bearings.
  135. Mid tank Mod
  136. Can 7cell fit in E-Savage?
  137. ? about LST SHOCK SETUP
  138. Little Night Time Bashing /w Video
  139. Liquid Wrench Dry Lubricant
  140. SavageX RTR f4.6 smokes SavageX Ss K4.6?
  141. Savage Vs Quad
  142. jacked up Savage problem
  143. Rainy days with nothing to do...
  144. Bad exaust seal problems!!!!!!!
  145. Savage Flywheel....
  146. addicted to nitro?
  147. Savage XL TVPs on E-Savage?
  148. Lets see your favorite action shots...
  149. OS Max 30VG in a Savage (Questions)
  150. throttle return spring
  151. Having trouble a little help please
  152. Anybody have any of the smf videos?
  153. torque start roto start for dynamite 427?
  154. Play day pics and video to follow...
  155. Low Profile Towers W/Truggy Shocks (Update 4/26/08)
  156. Help me
  157. HPI Big Bore Shocks
  158. Lcg tvp's
  159. Time for a new motor.
  160. Gasser engine in a savvage possible?
  161. Clutch bells??
  162. Has any used the FLM Hybrid Bulkhead
  163. Savage 25 Glow Plug.. Can I use this one?
  164. wheel/tire suggestions
  165. Savage X SS spare parts
  166. New toy WOOHOO!
  167. Savage 25 to X!!!
  168. new 3 speed worth it?
  169. dusTy savage cleaning
  170. clutch spring help..
  171. savage xl
  172. shock setup?
  173. Comparing prices...
  174. Need some input
  175. HB tuned pipe
  176. savage xl or savage ss
  177. Silicone Exaust coupler replacement?
  178. difference between these spur gears??
  179. Who Won
  180. Tower Hobby codes? NEW CODES AS OF 4-1-08
  181. My new lid harley davidson F650
  182. Sleve Resizing?
  183. 2wd savage X?? remove fronts
  184. LST Shock ?
  185. GIVE CONGRATS
  186. Radio-servo issue
  187. Diffs
  188. reyalp's Savage X SS build thread - too many pictures...
  189. need wheely king info.
  190. Nitro noob can't get truck to run
  191. RPM Parts
  192. Savage XL available for 589.99
  193. Smack the Hobby Shop Guy
  194. K4.6 adn F4.6
  195. OS 30VG temps
  196. Air filters
  197. Diesel
  198. Suped up HPI MT
  199. Need Help
  200. TAKE A LOOK AT THIS!!!!! (BUMMER)
  201. help with slipper clutch
  202. Questions for the pro's
  203. HOT BODIES
  204. another one way bearing
  205. engine problems
  206. truck runs away
  207. CINCINNATI BASH TODAY!
  208. Can this make a engine easy to start?
  209. How reliable is the pullstart on a LRP .28?
  210. sputtering t 3/4 and whinning after release of WOT
  211. Jumpin
  212. radio "miscommunication"
  213. savage break in problem?
  214. CHECK THESE OUT FROM OUR PLAYDAY!!!
  215. firestorm
  216. My Savage /w Homemade Ligts
  217. savage clutch
  218. stainless screw set - no screws for plastic parts?
  219. Locked diffs
  220. Buying a Savage X SS
  221. Savage Suspension Conversion Set and new servo
  222. HELP! I am in a bit of a sticky wicket...
  223. upgrades for my savage x
  224. OKC PLAYDAY!!! who wants to be on are weekly video!!!
  225. savage ss 25 price estimate help..
  226. E-savage
  227. savage x rtr stalling
  228. Lowering the savage
  229. I need some advice about My savage
  230. RIPPIN STS D.30m SPASHDOWN!
  231. Surefire .32
  232. random back differential problems
  233. About to order my Hump Pack, got a quick ?
  234. Picco P3 turbo head
  235. Oh No She didnt lol
  236. Diff Locker
  237. Trouble dialing in the LSN
  238. Eng in Hellfire SS
  239. Sav25 to SavX Diff Case Swap Troubles....
  240. rotostart2 help
  241. Is reverse worth it?
  242. Truckzilla Wheelie Bar
  243. just bought a hpi mt2 18ss, started once but wount start again!
  244. PROUD new Savvy owner
  245. WOT on stand - could that hurt?
  246. compression+fuel+fire=run?
  247. tips on tuning savage 4.1
  248. Diff locking
  249. servo parts
  250. lil Confused
