- Steam
- what do i need to...
- tvp/engine compare
- which gear for more low end
- Free NOVA RC Cooling head! (PICS)
- x or LE
- setup help on brake?
- E-Hellfire
- Need a HUGE favor...
- Savage X SS
- Clutch bell question.
- Engine stalling
- Center skid plate for Savage X
- Q about air filter
- 3 speed help plz
- HI, Serious Question about ribbed pipes
- tires
- Need link for steal spur????
- Savage SS 4.6 Questions
- 3 speed problem
- Savage X break in help
- Rain...
- Collari .32 witch will fit TM728 or TM928
- gear mesh ???
- savage 3 speed conversion ?'s
- Clutch Bell Temp Please HELP!!!
- pipe and filter
- Clutch in Savage 21
- Dumb wiring question for servo box
- My Self Charging Car
- does this fitt?
- Collari 32 or SureFire 32
- some1 please ANSWER MY QUIESTION
- servo problem
- Selling the Savage X for a Revo 3.3
- What engine will drop right in for Savage X???
- 2 Questions: Engine-sealing and Diff-shimming
- problem shifting
- rattles and bounces
- A+ shout to Hot Bodies and HPI
- first backflip/question
- Carb Air leak help
- I can't decide on a savage anymore!!
- Savage 4.6 break-in
- How much dif oil?
- 1/6 savage model HUGE
- savage 25 speed with 3 speed tranny
- savage 25 wheelies
- engine upgrades
- What do others think about this concept?
- melted spur gear
- New Sav X video
- I Lost MY TRUCK!!!!!!
- Diffs in Savage X
- Battery Gauge
- How to keep your fuel from foaming
- Team Orion CRF V6 Adjustable Clutch???
- yet ANOTHER q about sts 28
- O’Donnell Fuel
- savage 25 reverse and 3speed
- t-maxx 3.3 or savage 25
- Savage X video!!!
- RD Logics Twin Exhaust Pipe w/Dual Stingers for Savage
- SAVAGE-X SPEED?
- Clutch bell, clutch shoes, and clutch springs?
- how do you properly mesh the gears when the spur is wobbly?
- no compression whats the prob?
- savageX shock upgrade
- what temp.
- can use a drill?
- Engine question for the pros!
- Q about recoiling pullstart
- I need some break in advise and answers...Help please
- idle to high
- Sav X Video
- reverse gear
- Is This a Three Speed?
- pipe
- Sidewinder Pro-Race Blend (20% Nitro 10% oil)
- Prep work before running my new X
- Diff oil in x???
- savage ss 4.6
- bashing vids
- Radio controls and servos for HPI savage ss 4.6
- can't get any fuel through the lines
- HELP PLEASE
- ive got 2 questions
- Anyone try a Hot-Racing steel spur gear yet?
- savage too loud
- New Trick - Somebody's gotta' try it..
- What method to keep on leaning your truck?
- Savage X positve camber
- clutch bell
- 7" Hotbodies tires feedback
- batteries failling
- should I get a savage, if so what kind.
- Replacing brakes on Savage x easier???
- HPI K4.6 vs HPI K4.6 High Output for savage x
- pic question ples help!!!
- Bash-Crash Videos
- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- sh 28
- hpi SAVAGE SS 4.6
- Transmission problem?
- Sav X 4.1 pullstart ?
- Lowering Savage
- Anyone own a Hellfire??
- my header
- what's your opinion of these shoes?
- what a crash......what a great truck!!!!!!!
- What reciever Battery pack??? HELP!
- rotostart snuffed it......
- Hot bodies LSP?
- READ THIS before you even THINK about starting your RTR Savage!
- Squeaking sound when accelerating... what could be???
- nitro fuel change
- should i get the x?
- HOW MAny Teeth CB????
- wheelie
- racing question..
- sts 28 tuned pipe??
- New Savage X SS K4.6 Kit!
- BLOOD HELL !!!
- Problem - finally need help with my Savage 25..(diffs, I think..)
- transmiter batteries, use rechargeable?
- underhead question
- whats wrong?
- Best aftermarket Screws
- Delrin Spur Gear?
- Interesting info regarding Savage X issues..
- what is better the pull start or the roto start for savage x
- broken crankshaft
- Collari .32 + Tiger Drive final (PICS)
- Sand
- mammoth
- My savage starting
- Hpi says 2.9Hp but Dyno shows 1.28 Hp
- MOVED: blackheath meet
- savage x carb sweats....
- Jumping problem
- savage carb question
- Tires fell off from the wheels.
- lrp 28 vs picco 28 vs novarossi 28 8 port
- jumping problems
- My Savage X has no breaks!! Help please
- savage SPUR
- shock oil
- Savage Servo
- metal clutch vs plastic...worth it?
- MOVED: Any bashers in the 909? (so Cal)
- required mods.
- common misconceptions
- Noob, needs some help.
- robinson racing clutch and spur .........
- k4.6 vs. picco .28
- Anyone tried Dds Gold Spur gear ????
- Savage X transmission
- What do you guys think my 4.6 is worth? PICS
- Savage ext, lcg and rollcage
- Shock Oil and Carb ?
- Best roll cage for my savage
- hard time tuning my x
- what engine for savage 25????
- so im lookin to race my savage.......
- Engine temperature/Radio Range
- roto crapped out, what's it's rpm?
- What wheels are these?
- Flywheel question
- LOWER C OF G
- Replacement antenna for X
- Locked Front Diff????
- New Rubicon LID and Warmer Weather
- Need your opinion
- O'donnell 20% racing fuel
- Fuel tank
- Savage Racers
- how to tune?
- Is This A Good Pipe
- Revo 3.3 or Savage x
- 14mm 40 series big joe, stripped wheel, buy again ?
- wt wheels do i buy 4 my savage 4 more grip on tarmac
- shcock questionnn
- STRIPPED BOLT!!
- Rear Diff...Again
- Bullettproof Shells!! TIP
- HPI K46 Engine Woes
- savage vid
- real cooling head?
- GOT PARTS?!?
- gear and torque trouble
- CRF V6 Clutch
- SavageX spur gear melted - what are my options?
- Where does this X part go??
- Savage 25 Vs Savage X
- replacement carb
- RTV sealent
- Savage X with Wheelie Bar
- what else could i do?
- will a mach 427 engine power a savage good?
- X ONE WAY BEARING!! anyone else have this prob?
- haveing trouble with starting up
- ATTENTION: Collari owners
- Body advice
- Break in question
- wheels for imex jumbomaxx tires
- Half-tank lean prob.. how to fix?
- What Upgrades?
- Os has some of the best support!
- STS 28
- need ideas quick please help!!!
- Reverse problem please help
- charging 12V lead acid batteries
- Suspension Clips........
- Receiver pack question
- WOOT my first savage! help me plz
- Savage 25 upgrades
- savage up grade pics
- check this out!
- BAM !!! Upgrades baby !! PICS !
- (POLL) ALL PLZ ANSWER How often do you change the spur gear?
- Any Shock Preferences For jumping Bashing..
- Locktite Question
- day out
- how good of a racer is the savage x
- STEEL SPUR GEAR ?????
- Carb problem.
- fuel filter, specific way?
- ****WHICH MOSTER TRUCK PLEASE HELP!!!!!!!!!!!!!!!!!!!****
- Spektrum rechargeable batteries
- gas gas gas
- anyone ever used this w/ a savage
- Savage X SS 4.6 vs TMaxx 3.3
- (PIC) ADJ Nova RC aluminum shoes results
- New Savage X running very slow and sluggish
- E SAVAGE
- What springs with OFNA aluminum shoes
- Moving from TMaxx 2.5
- FLM Teaser
- Hellfire and 3 speed tranny?
- tower pro mg995 or hitech 645
- LST shocks mounting kit
- Savage twin.
- Digital Servo Help
- axial 32
- Pulled out pull cord
- Breaking in the OFNA Force .32
- My Savage 25 does not perform wheelie!
- O.S. 30 or PICCO .28 ??
- Anyone know of a Paint template program or website ?
