PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Savage X Diffs on Savage 25
  2. Some help please?
  3. sirio 30 comments
  4. NEW TRUCK SUGGESTIONS!!
  5. new savage ss 4.6 problem
  6. BRAKES
  7. low cg chassis and nubz conversion?
  8. savage x
  9. I am at a loss !!
  10. Building a track
  11. idle problem
  12. First Run!!
  13. savage good wheeling engine
  14. which one?
  15. what a clean savage looks like
  16. rx/tx not working
  17. backplate screw is stuck
  18. What clutch do you like best?
  19. Engine problem
  20. throtle
  21. have a fast question!!!!!!!!!!!!
  22. savage engine
  23. savage engine
  24. Savage "on-road" tires and RDLogics twin exhaust w/ dual stinger pipe question
  25. shock oil replacement
  26. failsafe location
  27. i need a new antenna for my hpi tf-3
  28. i need help
  29. roto start
  30. .25 carb settings
  31. small block clutch fit big block
  32. Really frustrated with spur gear on X
  33. Any one running the RC Pro Series with their Savage?
  34. At what point does spit sizzle?..
  35. WHAT DO YOU THINK
  36. how do you flush an engine?
  37. where to get a steel spur??
  38. GLOW PLUG!!!
  39. What are the Best Savage Shocks?
  40. Savage X SS
  41. Carbon fiber chassis
  42. more newb questions
  43. Pull Start Vs Roto Start for Savage X
  44. half-tank lean problem!!!
  45. savage
  46. got used savage do they have dual disk brakes?
  47. who would win this race?
  48. identify these parts
  49. DISCODAN- WE NEED A FULL REVIEW ON THE PICCO .28
  50. Rod end links
  51. New Savage X Owner...Now what ?
  52. Once hot, real pain to start
  53. Moderator material?
  54. brake kit
  55. Ever throw your Savage on a dirt Oval? *video*
  56. why so loud????????????
  57. has anyone ever seen these?
  58. BIG BLOCK FOR TRUGGY?
  59. ez start on savage?
  60. savage x first tank break in
  61. Loving the os 30 vg
  62. Sav X, Hellfire, LST Vid
  63. Questions for LHS owners
  64. Digital Servo's in a Spektrum
  65. So much room
  66. Don't buy Pull starter version of STS .28
  67. Spur Gear stripped on new X
  68. savage x
  69. what is the best chassis upgrade for the savage x. suggestions? thanks
  70. One speed?
  71. Antenna broke
  72. rip off!
  73. sirio 30 progress
  74. sirio 30 progress
  75. Savage X question
  76. stripped hex fix
  77. converting my sav to electric
  78. whats wrong with my truck?
  79. Finally( help needed please)
  80. sirio 30 savage questions
  81. 2 important questions.
  82. which pipe will be the best?
  83. POPPING GLOW PLUGS
  84. motor making weird noise
  85. All 4 wheels not moving
  86. newb wondering about nitro
  87. Throttle Servo Help?
  88. GF is Hooked
  89. Savage .25 shifting killing engine HELP!!!
  90. Savage X break problems
  91. help with 2speed (savage)
  92. my cb and main gear on sav x do not line up
  93. ribbed hpi pipe on my x
  94. Anyone broke their Roto start 2???
  95. carb
  96. busted!
  97. STEERING HELP
  98. Axial 32 for savage truck
  99. How far does it reach?
  100. can these gears be too low
  101. Funny Fact About Roto Start
  102. savage tank puntured
  103. another stupid question(s)
  104. charger question
  105. did i get a bad deal a decent deal or a good one?
  106. what's the point of...
  107. Hellfire SS kit?
  108. Tweaked Chassis
  109. 3 speed trans for savage x?
  110. HRH got them in
  111. Hot Bodies and HPI pipes same???
  112. Savage SS Pro-line 40 series wheels bent??
  113. RPM HPI Savage and Savage X A-Arms
  114. Question about Savage Dogbones...
  115. tuneability of the savage .25
  116. Hex hub?
  117. tuning help
  118. HPI hellfire?
  119. What spur gears will fit on X?
  120. any word on?
  121. fuel tank mod
  122. Has anyone orderd from here?
  123. Anyone know the torque on a stock Savage X steering servo?
  124. Spur gear/Clutch bell setup..?? assist pls..
  125. Post your Truck Pics here
  126. batts for transmitter
  127. I need help with jumping
  128. Savage X owners...Has anyone used the spare CB 18?
  129. help shifting to 3rd
  130. 3 speed tranny and slipper ?
  131. dual brake help
  132. hpi rush and rush evo
  133. Hi-Tensile Screw Kit from Je Spares
  134. ring gears are going to fast
  135. Throttle/brake servo problem on X
  136. just got my savageand its great but it doesn't wheelie
  137. Wobbly Wonky..... wheels
  138. Just installed STS .28, 3 Speed trans, Disc Brakes on X
  139. Tuned pipe for th Savage X
  140. how long too charge
  141. QUICK N STILL TUNNIG
  142. K4.6 K4.6HO
  143. Could I Make This Work
  144. savage deal
  145. SAVAGE X ss 4.6 wearabouts
  146. collari carb swap?
  147. Tell me about Savage x 4.1
  148. No shift
  149. Savage .25 deal I got
  150. Where to mount fuel filter on a Sav X?
  151. lowering savage x ?
  152. brakes dont go back
  153. A Good Tool Set???
  154. savage x with 3 speed and dual disc worth while conversions
  155. piggybacks
  156. cb and spur to tight
  157. savage 25 trany
  158. exhaust help!
  159. Savvy X Transmission Gear Stripping - WHY???
  160. Savage SS 4.6 BigBlock
  161. SAVAGE X .32
  162. SAVAGE X
  163. Savage X Trans. 3 speed
  164. STS owners please read
  165. sharing the joy...
  166. K4.6 problem
  167. What hop up parts should i put on my savage 25?
  168. Buggy or Monster truck.
  169. rc predator nitro
  170. stainless brake setup, acting a fool?
  171. Engine back plate issue
  172. best fuel for rb tm 728
  173. Could this be the one?
  174. Which .32 & pipe for Savage X
  175. Hellfire body
  176. experience required?
  177. How much better is the STS .28 vs Stock 4.1 X???
  178. does any1 have any spare....
  179. Savage Heat Problem
  180. Test how fast your trucks top speed is.
  181. ribbed pipe
  182. Radio Glitching
  183. Anyone have the new NITRO GT-2 TRUCK BODY?
  184. Help Needed From Fellow K.4.6 Owners
  185. diff binding?
  186. can't get wheels to stop spinning.
  187. CVEC pipes
  188. which engine for savage .25
  189. rc solutions roll cage
  190. I'm buying a Savage X
  191. any one ever use a os 03 in a savy?
  192. Overheating S25-HELP!
  193. Whats it gonna hurt (what should i do)?
  194. spur gear melting???
  195. Lots of frustration here, please help.
  196. air filter oil substitutes
  197. Switching fuel %
  198. break in question, once again
  199. zombies
  200. screw broke in shaft please help
  201. Carburetor
  202. diffs in rear dont work at all!
  203. new radio system, are any of these good?
  204. Savage LE servos
  205. is it just me??
  206. help needed
  207. diff problem help
  208. Grease In The Transmission?
  209. Savage 25, or revo 2.5
  210. 1/4 turn on 46 low speed needle
  211. nitro fuel & savage
  212. pipes savy
  213. air leaks
  214. idel out of control!!!
  215. savage backflips
  216. How much extra stuff do you have? (PICS)
  217. Engine removal help
  218. How long have your diffs lasted?
  219. Base needle settings for Picco 28 non-turbo
  220. another h.b .46 q's
  221. hot engine
  222. SickHobbies.com
  223. exhaust deflector
  224. Savage running temp question related to tuning
  225. Trinity Spyder Tank on a Savage
  226. Question about X parts
  227. spur gear tightening
  228. Torque pipe for racing
  229. my engine needs help!!!
  230. worst crash stories
  231. Aerial Antenna
  232. servo problem
  233. i keep burning plugs out.
  234. please tell if this will damage batteries..???
  235. Anyone Tried a JPL Tune Pipe?
  236. time for something new
  237. Bogging engine
  238. Diffrence between lsn and hsn
  239. How do i mount these ahhhhh please help
  240. reverse
  241. X idle problem
  242. HPI Hellfire, how is it on bashing?
  243. Oily Sh*t around the flywheel ?
  244. battery and engine troubles...
  245. savage clutch changing
  246. Is this possible? Battery Question..
  247. Anyone use FLM Bulkess
  248. Anybody seen a Baja in action?.. Cool vids..
  249. a question related to tuning after fuel brand change
  250. removing tyres
