- Hop up parts!!!
- almost there!
- My wheels keep falling off!!!!
- Turbo
- this is weird
- will savage go 50+
- Roto Start repair
- carb needles keep vibrating shut
- THROTLE NOT FULL OPEN!!!
- TF-4 vs Futaba: worth the $$$?
- Hummer H2 Body
- im confused?!?!?!?
- engine???
- Picco .26
- Bodyshell size ?
- Who's still running a .21?
- Why shouldn't I get a reverse module?
- pipe question
- NEED HELP QUICK
- Slipper Question!!!!!
- upper and lower arms
- S25 wont wheelie
- HPI Savage SS or Associated MGT
- What servo to get for steering?
- Break Pads gone
- whats the craziest conversion done on a savage
- My first step into nitro, and with a Savage
- HPI Savage SS Kit
- is it possible???
- Picco .26 carb problem
- SS radio
- Hpi Ribbed Tuened pipe
- xtm 24.7 pro back plate???
- Radio Question
- BACK PLATE ISSUE?!?
- truckzilla engine
- My savage and a Genesis pics
- clutch
- What else do I need to install the mp servo saver??
- Savage ss wheelies setting??
- mp servo saver help
- ribbed pipe
- aftermarket parts
- Front wheels pointing outwards?
- glow plugs
- Suspension arm cracked, how tp fix?
- help with spur gears
- PLEASE HELP< New SAvage
- servo savers
- tempature
- Art's Hobby CF TVP
- IT DOES NOT START!(BRAND NEW)...
- MOTOR SELECTION
- new truck?
- how to stop this
- throttle=brake, left=right
- servo saver for steering?
- Dual Disk Brake Problem
- Broken wheel thing
- Savage Info?
- FTX-Picco .26 Monster vs picco .26 P3 outlaw
- this savage is killing me
- Savage Slam on TV
- ek4 70 still the bad boy
- I broke it!!
- Battery Pack
- crackle crackle !!!!!
- tuning problem
- slipping one way bearings
- official body painting forum
- reciever?
- Not ready to run more expensive?
- How to adjust needles???
- Quiet pipe?
- Engine quits with fuel in tank
- Will this pack fit the Savage 25?
- Safe to leave fuel in tank when not in use?
- Newbie: Unable to start with roto-start
- Fuel for Savage 25
- runaway radio??
- What wrench for these screws?
- savage ss ??
- The Best Savage.
- how to tell
- Hey Help Me With Savage25
- How to tell if its shifting speeds?
- Why no generator?
- carb. problem
- Headlights and brake lights
- newbie to savage 25 have questions
- Whats the difference?
- glitching AND starting problems
- hump packs
- Exhaust re-routing
- Savage .25 shutting off without warning
- Is this an add on muffler or what?
- Ordering accessories, what else should I get?
- Safe to let run out of fuel?
- How to stop fuel/oil pouring
- savage 25 steering servo upgrades ......
- Fuel questions
- Does the Savage 25 RTR require lock tite?
- 4 spider gear cross pin mod
- ANOTHER BIG PROBLEM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Did this happen to anyone else?
- Break mecanism question
- savage ss
- cen genesis?.....
- Savage 25 no fuel filter?
- 40 Series tires for savage.
- Lost break screw, where to get?
- How to change glow plug without dirt?
- biggest baddest engine?
- What is fully closed? (about valves)
- piston?
- Low speed needle question
- Slipper clutch question
- Savage Flat Pack Question
- Engine Breakin with Big Tires
- Need help with Radio for SS kit
- Got savage - Works but with minor problems
- Back plate mod required?
- what is going on
- savage ss
- 15% !!!
- hands up if your truck drives straight
- Fail Safe & Accessories
- I know someone knows this (about transmitter battery)
- What Savage is Best?
- Used or New???
- Picco .26
- jump building
- cutting the body!!!
- E-clip failed, wrapped around all the gears
- ALL NEW PEOPLE TOO NITRO
- size of o rings
- Battery run time
- Sitting Savage
- BLUE THUNDER FUEL???????
- Savage just "stopped" starting after a gallon of fuel through it!
- 52/14 or 48/16 Why?
- SAVAGE-- BIG HEADACHE???????
- ROTO START
- No luck with the savage stock .25 engine
- heard of the a shoe clutch???
- Can the stock Savage 25 do this?
- one way bearing?
- picco question
- Running your Savage/Picco on grass?
- Receiver battery pack size?
- Reverse module
- ABS brakes?
- Savage 25 radio
- what could it be
- Wasp .28
- glow plugs
- fuel/glow plugs
- Engine stalls after starting
- roto-start on Sirio 27
- is this the picco 26 outlaw
- best pipe to get
- Radio for SS 25 kit
- Savage Not Moving
- gears=faster savage
- will this be a good radio system for the savage
- Twin Engine Convergion Kit
- savage 25 rtr clutch problem
- glow plugs?!?
- Break in questions
- Nitro Star 25 - not impressed
- 4-SPIDER DIFF MOD - HOW MUCH DOES IT COST?????
- Rotostart battery pack?
- PowerMaster fuel good?
- Bad tranny???
- making sway bars
- does savage 25 hates water???????
- does savage 25 hates water?????????
- Life Size Savage!!!
- ???ofna throttle servo mod???
- WILL THIS FIT???
- Radio and receiver battery question
- radio
- Got Savage 25, fuel bottle, wrench and glow starter, what else do I need?
- home made cold air intake
- bevel gear problem
- Rotostart worth it?
- cheapest site for picco .26
- Darn "Handle" roll bar looks like pretzel. ..
- one bracket enough for header tank?
- Aluminum - Lets Clarify
- pull start
- Fuel for Savage, 20 0r 30?
- pipe problem,needs advise
- decals or graphics
- math work-savage speed
- Upgrades
- Hook Up Help
- Savage 25 RTR, ready or not?
- Savage 25 Noise level?
- what is really need!!!
- savage really pull a wheelie
- fuel question
- Will this fit on a Savage
- h/d hpi parts
- how come !!!!!!!!!!!!!
- Monster GT pull start
- Problems to start Savage25 for first time
- Savage 25 extra gear for on road?
- Savage .25 Engine life
- What is needed for a Savage 25 RTR?
- Pull start or Roto start?
- Stupid Question Alert RE:Radio frequencies
- Building a track
- any known flaws of the savage 25 rtr?
- Tight cornering mod
- problems with brake rpm
- what do u use to seal an engine
- this is the closest shock oil they had... is this safe to use????
- HPI Savage Picture Thread
- ou what clutch to get
- what can it be
- Performance Tires???
- Big Problem1!!!!!!!!!!!
- savage slam 04
- zip ties
- whats a good temp
- temp range
- wheel question
- Temperature without a gauge
- RC Case
- who thinks they know the fastest r/c?200mph
- Team Infinity .21 engine?
- hpi 25 3 shoe VS envy 3 shoe
- .70 motor from new era pro70bx
- 3 shew clutch ?
- New savage breakin
- spur gear clutch bell combo
- dual tank problem
- avator
- painting newbie
- durability
- Where can i buy S-25 Engine Case
- wot do you think of these
- One Way bearing
- 18 tooth bell clutch in picco 26
- wasp.28???
- Filling the diffs question
- Tuned Pipe Question
- Can't get mine running
