PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Antenna Wire length
  2. Firestorm or GT2?
  3. Air Filter
  4. Chassis supports
  5. savy steering?
  6. Savage with sh.28 not idleing please help!
  7. Looking for new
  8. Reverse
  9. 4.6 bearings
  10. savage center skid plate
  11. well done video
  12. Savage tough as HELL
  13. after run oil
  14. RECALL ON 3rd GEAR??????
  15. Battery Charge Question - HPI saddle pack and Ofna charger
  16. what causes this sound?
  17. savege ss brakes
  18. Fuel Switch & OWB Please Advise
  19. diff + hot glue=locked
  20. WOULD'NT YOU LOVE TO HAVE ONE!
  21. axial .32 break in.
  22. axial .28 or 32 or force .32
  23. servo ?
  24. e savage
  25. new savage on the way
  26. Problems with savage x 4.6 rtr
  27. E-Savage 8XL Motor Mount
  28. Like new SS 4.6 or X 4.6?
  29. Savage x 4.6 steering????
  30. Best performance pipe for my savage x
  31. whats the factory settings ?
  32. Selling F4.1, need an answer to potential buyer's question...
  33. My Lil project...((was check these))
  34. Savage x 4.6 HELP PLEASE
  35. axial .28
  36. Toe in cast and camber
  37. Aluminium shocks for Savage
  38. Just need a one quick answer:What roto backplate fits on the lrp z.28r spec 3?
  39. Savage extended A-Arms
  40. TVPs?????
  41. Help with Savage 4.6
  42. New Nitro User - suggestions
  43. wheelies?
  44. CLUTCH BELL DESTRUCTION
  45. Slipper clutch and pad problem!!!!!
  46. linkage problems
  47. New here
  48. Ab Mods Picco 28
  49. Team Orion Marathon Connector
  50. Custom-made swaybars
  51. Stock HPI polished pipe vs JP-3
  52. first steel spur on X
  53. stock clutchbell on a 4.6 RTR
  54. Get in line girls!
  55. A-Team body??
  56. rotostart conversion
  57. Shock conversion
  58. careful with your new rc
  59. Which of those 2 slide carbs...?
  60. my HPI Savage SS
  61. Integy Beadlock pics... (update: moabs on)
  62. Lrp break in,leaned hsn and lsn stil stalling!Videos!New break in video
  63. is my fuel still good?
  64. LRP Spec 3 PullStart vs Truggy.
  65. Upgrade motor?
  66. Tuning shocks!!!!!!!!
  67. 2 spd Tranny # set screw turns
  68. Roto Start
  69. Gettin a JR RS310 receiver, what radio is good with that?
  70. Post Break-In LRP Problems...
  71. Looking for a new engine
  72. batteries
  73. Air Filter Cleaning?
  74. Replacing the .25, suggestions?
  75. FLM MODS
  76. Broken Pull Start
  77. Can anyone tell me whats wrong with my savage x
  78. NEW SAVAGE FROM HPI
  79. carb
  80. upgrade for the 43t bevel gear and the 13t bevel gear???
  81. 3 gear setup
  82. well, here it is
  83. savage spur gear replacement
  84. how much fuel do u have to use befor break in before u can use 30%
  85. e-savage parts from a nitro savage?
  86. slipper clutch spring removal????
  87. throttle linkage?
  88. savege 17 mm hex adapter
  89. savage help
  90. First RC Truck
  91. help with GH spur gear for savage!!
  92. Where to buy?
  93. DuraTrax-WARHEAD
  94. Roto Start HPI Savage (HELP!)
  95. Asbestos brake pad warning.
  96. Triple Rate Springs
  97. RDLogics HPI Savage Twin Exhaust Pipe
  98. who has installed the 427???
  99. Can't tight down the carb
  100. Can anyone help with this linkage?
  101. Picco Conversion to Roto Start
  102. E-Savage Baja Body on Savy X?
  103. Savage x 4.6 hump pack
  104. hpi alum shocks
  105. broken... again
  106. new truck
  107. Wheelie Bar
  108. Grease in the diffs and no fluid? Good or bad?
  109. IS IT POSSIBLE TO DOUBLE UP THE STOCK TVP CHASSIS PLATES?
  110. Did a Linkage Mod
  111. Trade for radio box accessories and tie rod eliminators
  112. Anyone runnin RPM center skidplates?
  113. bored of my savy!
  114. How tight???
  115. Rear axle holder
  116. Gearing issues
  117. New STS break-in
  118. wat to do
  119. up dated high speed 3rd gear
  120. Atomic steering pieces (questions)
  121. What is the newest savage
  122. Dif oils for Hellfire
  123. What starter box would be best for my Ofna Pro Comp and Hellfire?
  124. What are these?
  125. Hitec HS-645MG install
  126. Savage Transmission Idea....
  127. savege or savege 25
  128. tuning troubles
  129. Lots Of Savage X Racing Questions!
  130. Hitec HS-5955 nto enough power to center?
  131. Pull Start Help
  132. MOVED: Savage X SS Vs Buddies ATV
  133. FLM questions...
  134. Savage Skatepark Video
  135. Alternative to rear tie rods
  136. servo short
  137. Break in problems with lrp!
  138. weather!
  139. frame damage
  140. New TVPs from FLM
  141. e savage
  142. holding tune
  143. Videos from last weekend (X SS Axial .28)
  144. HPI Polished pipe
  145. duratrax 360 backplate HELP
  146. Bash day in Sugar Land.. pics galoure
  147. LST conversion afterthought! If you want to do the mod, read this.
  148. I got the savage 4.6 any thing i should do before break in
  149. Savage 4.6 Junk???
  150. Throttle linkage?
  151. Savage 21 RTR...help needed???
  152. Noisy tranny under braking
  153. SERVO VIDEOS of MG 995 power
  154. no rear wheel drive
  155. Putting a truck together
  156. Putting a truck together
  157. Different Sized Wheels & Tyres
  158. Saavge truck stand
  159. shift point suggestions for axial .28
  160. SAVAGE radio problems
  161. Hot Bodies Truckzilla
  162. NewB Spure gear?
  163. bad shifting on my 4.6
  164. Painting the tire lettering
  165. INCREASING ONE WAY BEARING LIFE
  166. hex set
  167. Starting issues
  168. Hitec 645mg guys...
  169. servos and Radio..
  170. Tires For My X?
  171. savege wing
  172. hump pack
  173. OWB slip due to oil in fuel...?
  174. Torn antenna
  175. engine boggs???
  176. Hellfire worth the price??
  177. HELP-hard starting, weird noise 4.6
  178. Savage with a 2.5
  179. Skidplate screw help
  180. Clutch bell
  181. One-Way Bearing
  182. PICCO P3 .28 stock venturi size
  183. Can't hear truck shifting at all..
  184. Savage
  185. hpi roto starter.....help
  186. parts compatability
  187. savage xss k4.6 engine
  188. engine starting problem
  189. Wont start need help
  190. what did you guys do??
  191. ordered some Integy parts... Jury is out
  192. Slipper clutch adjustment
  193. Phaltline Tire/Blast Wheel Chrome
  194. 3-Speed Tranny?
  195. xtm 24.7????
  196. Cheap bodies/Tracks near me?
  197. high speed gear set
  198. Ssvage x Roll cages
  199. savege 4.6 ss
  200. weird problem (savage 3.5)
  201. Diff/Dogbone Quick Questions
  202. savy instructions
  203. savage or revo 3.3
  204. best motor 4 savage x
  205. Need help selecting clutch
  206. new tank for the savage
  207. Savage dual brakes hitting clutchbell..HELP!!
  208. Associated Engine fit?
  209. Glow plug question
  210. What brand/weight shock oil are you running in your stock shocks?
  211. oil weight for LST/AFT shocks?
  212. savage x mods
  213. Engine won't stay running
  214. Whats the diff??
  215. New Savage X SS 4.6
  216. XTM 24.7 Motor Questions
  217. mods for savages
  218. Need help with savage differential!!!!!!
  219. Grr more problems!Screw stuck cant get out)!
  220. savage x drifter
  221. Four shock setup
  222. savage x 4.6 rtr
  223. Almost disaster, savage run away!!!
  224. savage x lowering
  225. newbie need a little help
  226. savage+eardrums=pain
  227. Switch to Savage
  228. steering servo???
  229. Finally!
  230. offset rims
  231. bad ?
  232. to rich or not
  233. backlash on spur gear!!!
  234. Savage 5.9 true?
  235. which servos?
  236. Clutch shoes
  237. Shifting problems
  238. savage won't move HELP!!!
  239. RC Cars racing in north wales uk
  240. Lrp z.28r spec 3 clutch pictures/need clutch help!
  241. MT2 18SS Eating through spur gears
  242. sealing the carb
  243. thanks!!
  244. Savage X Speed Club
  245. taking old tires off
  246. Savage x 4.6 Tranny
  247. Savage shock shaft trouble Help needed!!
  248. Pull start
  249. making a track
  250. where to buy a phantom pipe
