PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Questions
  2. about to take my savage and throw it off a cliff...
  3. rotostart burned up AGAIN
  4. what do you think about this engine
  5. Looking for best buy on a SH28
  6. 40 Series Cheyenne Weld Wheel
  7. Where to buy??
  8. Could you give me advice on $ value
  9. Any tips while building the SS 4.6?
  10. Is the Savage louder than average?
  11. switch location
  12. Problem with Savage???
  13. Diff oil question
  14. How do i mount a mini Video Camera ?
  15. would this work?
  16. 3Racing Fuel Tank Guard
  17. Good On-Road Tire?
  18. hpi savage ?
  19. supercharger
  20. alloy fuel tank cap
  21. brake play!!!!! HELP!!! *PICTURES*
  22. temp change with different fuels
  23. sticky pull start
  24. How do you post pics?
  25. clutch pad
  26. Tuning - Temp vs Performance
  27. How to Check Diffs?? Maybe locked up
  28. look at my savage.......(pics)
  29. Your opinions on Savage SS 4.6
  30. 3 shoe clutch assembly?
  31. Top end for bigger wheels
  32. how to install ofna linkage mod?
  33. Help! How to put in a new servo??
  34. Lunsford turnbuckles!!
  35. Central Coast California?? Anyone??
  36. Roto Start Question
  37. cheaking for air leak in fuel tank
  38. anybody try the werks clutch
  39. S25 Carb Air Leak
  40. hpi 1200mah hump pack?
  41. alluminum clutch shoes
  42. one way bearing
  43. air filter fitting?
  44. Hotbodies Shocks
  45. Savage Replacement Part Policy
  46. Savage .21 NEW?
  47. savage 4.6 cheap
  48. wheelie bar ....which one
  49. New Engine For My Savvy
  50. plastic
  51. Underhead
  52. bent shock
  53. Aluminum Gears???
  54. Which Wheelie Bar??
  55. RC Solutions roll cage-body mount
  56. Pipes?
  57. Neighbours Complaining
  58. what should i do with this $$
  59. Savage Diffs..........
  60. The build begins!! Dual brake problem #1 !!
  61. Diff Oil Thickness
  62. Dirt Jump Link
  63. hot bodies
  64. fuel tank repairs
  65. Break in?
  66. Hyper 21 8-port and Tiger Drive Start. Darn it!
  67. Savage 4.6 SS or Should I Get Something Else?
  68. 3 turns?
  69. Antenna wire question
  70. Air filter Oiling and Cleaning
  71. is this a good deal err what?
  72. New 4.6 wont start..?
  73. What new parts to buy?
  74. sh 28 blew a rod and gone. is the collari of better quility?
  75. HELP!!
  76. Savage .21 upgrade to .26?
  77. Savage Reverse Module ?????
  78. Savage break-in, PLEASE HELP
  79. Change of plan!!!!!!
  80. Back From Vacation...
  81. 4.6 engine trouble
  82. gearing
  83. Savage owner thinking about getting Revo
  84. my new sh 28 threw the rod out the side of the block
  85. my new sh 28 threw the rod out the side of the block
  86. Stuck in gear?
  87. Truckzilla Fireball Wheels & Tires for $45!
  88. Radio Box Mods Need some ideas
  89. picco .27
  90. Odonnell 30%
  91. collari or sirio .30?!?!?!
  92. genisis vs savage
  93. Pipes?
  94. Are my breaks working right?
  95. Traxxas sponsored monster truck
  96. Motor Help!!!!!!!!!!
  97. sh28 or collari comparison
  98. Another 4.6 Probelm
  99. Savage SS vs. 4.6...
  100. alloy shoes?
  101. roll bar
  102. hump pack lead connection plug...
  103. Savage almost done . . .
  104. Update on 3 speed!
  105. ribbed or polished pipe for 4.6
  106. Bodies?
  107. Savage 25 RTR
  108. 2 speed transmission problems
  109. wanted another sh28
  110. mugen mbx-5 clutch shoes
  111. broken pullstart string
  112. upside down shocks
  113. What Fuel
  114. Aluminum Wheels: Questions of strength and of tire adhesion.
  115. The absolute best tires for grass???
  116. Which Truck?
  117. Are Hot bodies and Hpi compatiable
  118. Which Radio for Savage 4.6 Kit would you get?
  119. and now a .30 Sirio
  120. What engine for the savage?
  121. 15/49 gearing sh.28 savage?
  122. savage 4.6
  123. voided warranty???
  124. 4.6 or 25
  125. what engine??
  126. 75% rear , 25% front drive !!!!
  127. Help me .46 conversion or sh28
  128. My HS-645 BLEW... I have a question....
  129. RC Boyz progressive springs
  130. PowderCoatingWorld.com is up and going !
  131. Aerial tubing
  132. what clutch to use for a Collari
  133. Avatar???
  134. I got my first complaint today
  135. Recommened % fuel for savage
  136. It broke today (kinda)
  137. need some help deciding
  138. fuerteventura
  139. metal shavings
  140. stock carb settings
  141. Savage 21, Blown Motor. Get New Engine or New Truck?
  142. RC alloys dogbones
  143. ROTO START HELP
  144. 4.6 savage roto start HELP
  145. Can't find where to buy...
  146. MY Home Made Savage Battery Box Mod .... with thanks to the MGT
  147. Steering servo saver bearings
  148. Antenna wire way too long
  149. Tranny issue
  150. SAVAGE 4.6 ROTO START
  151. Does the old .21 Savagecomes with a 2spd?
  152. savage spur gears HELP
  153. sh.28 problem
  154. 3 questions on after run oil
  155. Pulling Sled..... anyone, anyone, Bueller
  156. My $800+ Savage Doesn't Seem to Want to Respond to my Radio... EXTREME GLITCHING!
  157. new sh.28 issues
  158. Help with changing my shock oil?????
  159. custom shock towers
  160. clutches
  161. HELP PLEASE SH28 TO HOT!!!!!!
  162. Synth Receiver?
  163. Replacing Dual Disc Brake Pads
  164. I want to drive my savage!!
  165. Fake Fog Lights
  166. brand new Savage 4.6 problem
  167. Sealing Differential
  168. one-way question
  169. Age
  170. Tower Standoffs Nova- Any?
  171. haw reliable is the xtm mammoth
  172. ballooning servos
  173. xtm backplate?
  174. 4-stroke .26 from os
  175. sh28 problems
  176. how much interest in never charging batts again
  177. Where to get the SH 28
  178. Pull start
  179. sh28 owner please read
  180. Good Fuel???
  181. 75MHz vs. 25MHz radio
  182. Custom savage body, you pick it!!
  183. 24.7 in comparison with sh28
  184. Question about servos and more, PLEASE HELP!!
  185. Considering sh.28 for my savage, some questions...
  186. Savage, LST, Ofna buggy parts for sale!
  187. Is this bad?
  188. Savage SS 4.6 or Losi LST
  189. Bi-directional Sliding Flywheel/Clutch Set??
  190. sh.28 problem
  191. Dual Exhaust Guys
  192. Magic Wheel Engine Upgrade??
  193. Team Orion's new .32 Engine
  194. PLACES TO BASH IN WV?
  195. Using 6 cell, 7.2volt battery pack for stock Savage Reciever???
  196. bulletproofing a savage
  197. Where to go drive?
  198. Losi Zombie-maxx tires??
  199. Received my Savage SS 4.6 please give me your input!
  200. 3 speed tranny....today?
  201. No Response Past 1/2 Throttle
  202. savage sh.28 problem
  203. Broken again
  204. tranny shot???
  205. My Jeep
  206. Tie Rod Upgrade?
  207. What toe in do you run on the rear??
  208. bountyhunter
  209. Clutch help
  210. HS-645 Re-Assembly
  211. desperate help needed calling all sh28 owners
  212. Problem with throttle/ brake servo
  213. Titanium parts?
  214. What to do with the throttle return spring!
  215. Idling?? Normal??!!
  216. See anything differnt?
  217. Tire vibration on pavement
  218. gear tooth questions
  219. NO Budget for NEW Shell?
  220. Savage 4.6 top end breaking up!
  221. Decisions
  222. Motor Tuning Gone Bad
  223. Hitec 645 is screwed up.
  224. Break-In with Stock Pipe or Ribbed Pipe?
  225. Hump Pack charging HELP!
  226. ORANGE COUNTY, CA BASHERS ! ! !
  227. removing the flywheel
  228. gear mesh
  229. Shavings around motor?
  230. carry case
  231. SAVAGE REBUILT!!!
  232. where is the darn three speed already!
  233. Experiences with removing the shock spacers?
  234. Turbo glow plug
  235. What weight shock oil to run PLEASE help?
  236. HPI 4.6 verses the SH.28
  237. Savage Dual Disk Brake set- Any good??
  238. roto help
  239. Custom shell Thread
  240. Different in Power
  241. sh.28 tuning
  242. steel spur andclutch bell
  243. Nova tower shock spacers
  244. temporary pipe, backpressure issues.
  245. Auction ending soon, need advise NOW!!!
  246. Whats a great motor Swap with roto start??
  247. Savage+LXT Shocks Conversion Kit?
  248. Hello everyone, I'm new
  249. slipper pad question???
  250. aluminum spur gear guestion
