- Savage 2350 Shock Question
- Savage X SS Transmission Settings
- Savage 25 Bulletproof Differential Upgrade
- Am I crazy
- Savage Flux Proline Big Joe tire question
- HELP!!!!
- How to properly check the temp
- Roto start
- Problem with a battery
- SAVAGE FLUX HP XL WHEEL / TIRE OPTIONS?
- Needle falling out?
- Savage Flux 2350 Weak brakes
- batteries
- Savage X 4.6 running temp?
- Vorza/Savage BP diff How to
- A few questions about a new-to-me Savage
- Cheapest place to buy body for Savage?
- New Savage suspension on to my old savage
- Hpi Savage xs Flux Esc burned up?
- savage flux hp brakes
- Charger for two 2s 35-75c 4000mah batteries
- Savage Flux 2350 Connector issues deans vs 4mm bullet.
- Savage Flux, to XL or 5T Conversion....that is the question...
- Savage Flux toe-in/toe-out front/rear wheels?
- Hpi Savage 2350
- Getting back into Savages
- Temps Warming Up = NITRO TIME!
- Hip electric car need some help plz
- 1/5th Scale Savage Flux...
- New HPI 1/8 Gassers
- Brushless gurus help please
- Savage Flux 2350 Problem
- old new fuel. Can i still use it?
- Cool bodies for Savage Flux?
- high speed bogging
- savage shocks
- removing paint from polycarbonate/lexan body
- Savage Xl Questions
- What's the ground clearance on the Savage X 4.6 RTR?
- Is there a difference between the Bullet ST and MT (nitro)
- sensored brushless vs non-sensored
- i love craigslist
- Savage .21 hop ups...
- Snowed in, bored, YOU KNOW WHAT THAT MEANS!
- Complete Tear Down And Clean what to use?
- Savage Flux 3S batteries question
- Traxxas Stampede 4x4 vxl or HPI Savalge flux 2350?
- HPI Savage X 3.5
- sf-50 steering servo issues
- savage flux xs replacement parts
- SAVAGE X / THROTTLE STUCK
- yamada one way valve/check valve whatever u call it
- Lipo charger help
- savage flux
- savage batteries
- HPI Savage
- Installed full 8mm axles and truggy style hubs on my savage...
- Bulletproof differential questions...
- HPI Savage 25, XTM 457 swap ?? Help
- A good Replacement engine for Savage 25?
- need help with a axial .32
- Just painted my stock wheels.
- suggestions on starting 25 savage after 2 years?
- Begginer qeustion?
- Savage .25 with Savage X radio box- steering bellcrank bushings?
- remove throttle linkage for engine removal
- Whats wrong??
- savage x 4.6
- Well i got New savage x4.6 need some suggestions...
- Where do you get your Savage parts?
- smaller clutch bell= smaller diameter of the cb?
- SAVAGE X SS HELP
- looking everywhere to find the hex diameter but cant please help!
- savage xl and LRP .28 is not working out for me help!
- Any one race dirt oval with their Savage?
- savage xl, will this fit( body) need fast help!!!
- LOWER A ARM PIN BROKE FRON DIFF CASE ***!!!!
- Santa RC Upgrades
- SAVAGE XL SUSPENSION !?
- LRP .28 SPECS 3 WITH 086 PIPE??? HELP hop ups tooo
- Antenna Placement
- Thinking about taking my Savage out of retirement
- Project Blackout
- Seal new 4.6?
- cheap servos.
- Spektrum dx3s
- where to get rod ends/linkage for hub carriers?
- picco .28 p3 in a savage xl
- Body Mounts
- In need of a new radio set up
- New savage x 4.6 vs new xl
- dump truck with radio controll dump
- picco glow plugs
- battery charger
- Is this a good deal on a HPI Savage 25?
- Savage suspension kit?
- savage Xs owners
- Hpi mt2 keeps breaking center shaft HELP!!!
- Approximate value of a used e-savage
- Trash-talking-free Engine Question(I hope..)
- SAVAGE XL WITH OFNA PICO .28 OR HPI F 4.6?? and hop ups!
- K 5.9 really that bad
- LRP .32!!
- Savage xl new body
- LOSI XXL VS SAVAGE XL 4.6 ENGINE
- bumpy rear suspinsion on xl
- buying-savage-xl worth buying? one way bearing
- Cheap servos
- new to the rc world
- savage prob help
- savage 4.6 diff rtr
- Where can i get the best price on Savage Flux Hp?
- rims
- XL center rear dogbone
- Savage Flux Roll Cage
- Hpi customer service
- savage x chassis
- Its been a while RCU.. Help me rebuild my truck
- Savage throttle spring question
- savage 4.7mm thick tvp
- Thinking about making a change
- Savage hex hub kit questions...
- big bore shock covers?
- Charging reciever batt.
- IMEX Jumbo Maxx Tires
- 3 speed settings
- Controlling the Savage Flux HP
- werks fuel
- shimmed diffs??????
- xs specs
- Badass Savage project...pretty much done, pics page 3.
- Pinion gear coming loose on Savage Flux
- Flux split diff gear, Is there any options?
- Lrp.30+ stck xlpipe
- Going brushless Xss savage
- Savage Set Up for Racing? Reducing Body Roll?
- HELP required !! SAVAGE 25 SPUR Gear replacement
- Strongest Shocktowers???
- New set up which do you like best?
- servo
- Any one seen these on a savage before?
- Spur gear /pinion mesh problem
- Fuel tank options
- White Baja Desparados
- Identifying the savage !
- savage xs battery size?
- Purchasing first Savage XL Nitro - With upgrades
- Lipo cells completely unbalanced after each run
- Savage X4.6 diffs
- Savage XL, problems with Pullstart Shaft Holder and Cover Plate
- biggest tires I can get
- Picco 069 header pipe?
- xl exhaust mod
- Are these specs correct?
- Savage XL, engine temperature problems
- leaking carb
- Spektrum Receiver Set Up
- getting smaller backplate for mach .26
- savage flux aluminum parts
- Spektrum Radios with HPI
- Program card for savage xs
- FLUX 5T teaser
- Fuel?
- sparky! sparky!
- Hobby Shop New England
- bullet now available in usa!
- HPI TF-20U
- Svage Stall at Half Tank
- hpi bullet
- flm lcg extended chassis and midtank mod parts list
- picco .28 dead spots while full throttle
- 25 tooth pinion+savage flux/me= nightmare
- Best slipper for FLUX?
- need a replacement savage flux esc
- Savage flux 2350 ESC issue
- updating roll bar and body question for new tvp
- HUGE tires for my Savage Flux
- my upcoming flux project
- What will the next Savage Flux be?
- savage flux dog bones cheap
- Flux tranny into x?
- Savage road tires?
- Savage XS Flux manual?
- Problem with New Savage Throttle! No Response...
- Very interesting
- broken connecting rod
- losi ht pipe on a picco .28 ?
- HPI AM TX vs 2.4ghz TX
- How do you .....
- Flux 2350 or hp 2200
- Wheels and tires
- My roll cage finished
- Which Savage is this?
- Delrin Gears? Need experienced users!
- hpi 2.4
- Cen diffs gearing?
- roto start for picco
- Wieght distribution, extended tvps on flux??
- Upper a arms
- savage flux xl steering problem
- Tire wobble
- used savage
- I think I killed the esc
- my new bronco body
- new savage question
- Big Bore Shocks
- Its been a while
- tekin vs mamba monster?
- Lrp 28 vs picco 28
- RX/TX advice.
- Help rebuilding a Savage 25
- Few more picco questions lol
- My savage 25 bogs down when try to go full throttle?
- How can i start my Savage 25 the easiest way?
- Screamin picco
- Xss Diff
- Xss tranny
- tuned pipe
- New truck
- Just Got A New Savage X SS Kit
- Flux is locked up?
- Well guys....
- Have you moved your Savage to a better Tx?
- New savage X 2.4
- Engine Break In
- clicking noise
- Will Savage XL differentials fit on the Savage .25?
- Wheely king custom questions
- 5.9 locking up while running
- servo advice.
- Whats wrong w/ my Flux?
- Savage x gears not aligned
- Just my luck
- Just ordered a Savage X SS!
- dynamite 086 on savage x with 5.9
- would this air filter fit???
- is it worth converting my savage x?
- Savage Flux part question
- How is the new Savage x 4.6 VS the last one?
- the flux is back to insane!
- A Picco powered Savage did this not a Flux
- Building a Buggy Eating Savage
- Help
- My day...
- Savage Flux HP vs Savage X 2.4ghz
- Deciding between Savage flux 2350 and Flux HP and Savage X4.6 2011
- Anyone got a milling machine ?
- bearing size?
- New engine break-in/tuning questions
- NEW PICCO IS IN, but............
