PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Hpi nitro mt
  2. 6S, was it a mistake !!! Diff destruction !
  3. good tire for grass?
  4. slipper nut to tight??
  5. Flux HP Pinon / Spur, what now?!?!?!
  6. picco schumacher
  7. Need Some Help With A Stripped Problem.
  8. Two Questions....Need some input from the veterans
  9. Flux XL conversion
  10. Savage brushless conversion
  11. Bad glow plug?
  12. savage body
  13. roto start for picco
  14. Up to you members!!!
  15. Wheel size
  16. Diff Ugrade Question
  17. Steering servo linkage question
  18. What is needed to convert XL to Flux?
  19. Picco .28 - Pool of Fuel
  20. A closer look at the HPI Savage Alloy Big Bore Shock Set...
  21. sf-50?? servo question.
  22. General Lee Body ??
  23. My XL - Whats next?
  24. savage flux hp trans question HELP
  25. Help!
  26. As fast as firestorm but worth buying??
  27. Steering Servo
  28. Im shocked!!
  29. reciever
  30. savavage flux slow!!!
  31. os .30vg
  32. MOVED: short course selection
  33. 100wt oil?
  34. savage x engine?
  35. Robinson Racing Slipper/Spur for Flux
  36. Savage Flux XS?
  37. Easiest to maintain???
  38. Savage Flux - SC tires/rims/suspension - advice sought
  39. XL w/ Baja Wheel and OFNA mid tank mod
  40. Savage Flux - alternative to Deans?
  41. Making a switch
  42. ANyone know of any good deals on the flux right at the moment?
  43. Savage xss into xl
  44. Before i buy my new truck
  45. GPM daul exhaust
  46. Flux hp cleaning q's/conversion kit q's
  47. problem with front diffs
  48. Looking for a Good Fail Safe
  49. Good link for bullet proofing your savage
  50. binding problem..
  51. What to do?????
  52. Tcs 5mm chassis
  53. Bushings to bearings in steering??
  54. Hitec or Savox TG servo???
  55. How do I tell....
  56. cool little vid
  57. how do i slow my savage down???
  58. Ballon Shock Cover for Plastic Big Bores
  59. christmas came early!
  60. Using Duratrax Correctly???
  61. Futaba radio help
  62. Savage .25 difficulties
  63. Where to buy FLM stuff????
  64. Flux HP vs 2350
  65. Extreme Bashing Carnage
  66. So it has to be a flux...
  67. Help with shock towers
  68. Savage X SS - build question
  69. Whats the best steering servo saver?
  70. So called 80 mph savage????
  71. Savage X SS - pull starter won't pull?
  72. Totally lost
  73. Clocked Nova 28-7 RT on ERCM pipe
  74. What can i use for extra stability?
  75. Temp Gun Best bang for buck??
  76. 7.4v powered servo?
  77. Kustom Roll Bar for XL
  78. Custom touches
  79. Making a flux ready for sand
  80. Savage X bodies?
  81. Strange 3speed gearing?
  82. VINTAGE ROSSI GLOW PLUGS FROM 1986 (VIDEO)
  83. Wheely King
  84. Savage X F4.6 Engine Tune Video (OPINIONS...Please) With Stock Gearing
  85. Another savage vs mgt
  86. Racing chassis?
  87. wheelie w/ savage 25?
  88. new 4.6 SS owner
  89. Say What!!!!!
  90. pics of my savage
  91. My mid tank savage
  92. another problem
  93. Slow mo Savage Flux flights, landings & crashes vid!
  94. stock settings
  95. affraid of a new spektrum
  96. goin to 2.4ghz help need
  97. Flux pinion gear set screw backing out help.
  98. Mid tank conversion
  99. Savage Flux 2350 - wheel nut problems
  100. savage flux lower alloy arms
  101. storing a nitro truck?
  102. savage flux
  103. savage flux vs. 2350
  104. tuning question
  105. SICK savage CAGE designs!!
  106. Picco weekend Project
  107. Savage clutch in MGT 8.0
  108. schumacher x28 turbo in savage build
  109. New to forum and nitro
  110. Flux XS
  111. I hope someone can help with this
  112. Bashing Pics
  113. Flux pinon gear?
  114. Novarossi N528XSP
  115. Will these batteries fit in a Flux?
  116. Transmitter settings
  117. Savage flux common break parts
  118. No Brakes while bashing
  119. Money no object Savage tuning
  120. Problem with my Flux....
  121. My flux Xl Build is nearly complete
  122. hi, can anyone explain this?
  123. HPI MT looking for a new motor
  124. 3spd mixed with 2spd parts
  125. F 650 body what colour should i paint?
  126. savage 21 starting pin and starting shaft
  127. Replacement tires for a Savage Flux?
  128. help with my mt2 please
  129. PLANS FOR A NEW HPI SAVAGE X SS
  130. paddle tires for savage?
  131. Replacing Connecting Rod???
  132. another wormy newb question please help!!!!!
  133. exhaust gaskets for the picco?
  134. Savage tuning advice
  135. alternative to nitro cleaner
  136. savage x gearing question
  137. Bigger Engine; What would happen?
  138. NOT A GOOD DEAL
  139. Savage XL pinion Question
  140. Dynamite Big Red Monster .28 on my Savage XL 5.9
  141. Differential oil question
  142. OWB problem? i think?
  143. Help: Savage Flux 2350
  144. EPIC HD XL 6s Savage Flux Vid w/ Slo-Mo MUST SEE!!!
  145. ouch..,.
  146. spur gear issues, please help
  147. savage x hydraulic brakes?
  148. Wheely King for a 7 year old?
  149. HELP I have fking had it with this engine
  150. Engine mount upgrades
  151. Anyone in Melbourne Australia?
  152. any bulletproof upgrades for these tranny gears?
  153. HPI Savage 3.5 Missing Parts?
  154. Flux Steering Servo
  155. Tighnten up the steering on Savage X
  156. Clocked Racing Modified Picco P3 in my XL
  157. Ported Axial .28
  158. Good steering servo?
  159. engine upgrade for savage xl
  160. New servo wont fit
  161. Recommend engine/exhaust for Savage 5.9 XL
  162. New LIPO for my Airtronicss MX-Sport....Amen!
  163. Savage Flux stock radio
  164. Corrosion inside crankcase
  165. savage suspension conversion kit
  166. HD 6s Flux vid -Big air, flips, wheelies, and breakage!!!!!!
  167. another lrp .30 question
  168. savage flux bash vid
  169. proline body question
  170. Xl flux chassis plates question?
  171. HPI EMAIL HELP
  172. Mid tank savage pics
  173. Active Powersports
  174. Think it'll hold
  175. need help with diffs
  176. Savage Flux - how many sets of batteries?
  177. Traxxas wheelie bar upgrade
  178. hpi savage ICE CREAM truck...
  179. castor oil in my fuel question
  180. my plan for my 5.9
  181. LRP .30 or .28
  182. Tires
  183. shocks
  184. CLUTCH BELL QUESTION
  185. LRP 2.8 questions
  186. Melted my Plastic Spur gear.....Question??
  187. fuel question?
  188. Picco 28 vs pull starter
  189. 2011 savage x 4.6
  190. Best cleaner?
  191. wd-40 cleaning quary
  192. Clocked Nova 28-7 RT Teaser vid
  193. opinions?
  194. LST Shocks on an XL shock tower question
  195. which shocks are these?
  196. Buying Used: What to look for?
  197. Pics of my flux's broken bulkhead. (For those who wanted to see it)
  198. Nizn Rechargable Batteries 1.6vlts
  199. Flux owners advice?
  200. Thinking of going brushless on Savage
  201. glow plug question
  202. savage XL hump pack charge time
  203. savage went crazy today
  204. Help a newbie fix this tune (video included)
  205. clocked picco in xl
  206. Rubber Shock Boots (Covers) Good or Bad Option??
  207. massive crashe
  208. xl tranny issues
  209. Differences between these bevel gear sets
  210. mamba monster
  211. Just asking
  212. New flux is silly!...but
  213. quick release body retainer question.
  214. lower esc mounting plate (flux xl)
  215. newb ridding wheelies!!!!!!!!!!!
  216. ERCM pipe on a Modded Picco
  217. 27mm hex 40series rims?
  218. differences between the x, xl, flux. i cant tell!!!!
  219. parts shop?
  220. the worlds best truck turns out to be worst
  221. Sup gear
  222. looking for a stock savage xl body
  223. Why are my brakes so weak??!
  224. need to put new engine in HPI savave 4.6 X
  225. savage xl pistin jammed
  226. possible problems with trans not shifting
  227. newby
  228. Savage flux HP discontinued??
  229. back in the game
  230. Savage X Kicked my Butt
  231. Charger
  232. Flux diff or gst diff?
  233. HO-LEE CRAP!!! I love my Flux!!!
  234. wheelie bar suggestions?
  235. New custom XL 4.5mm TVP's
  236. More construction site running video
  237. PART NAME?
  238. not running right
  239. HPI Savage XS Flux!!
  240. Where can I get a CEN DIFF?
  241. Could my tow be out?
  242. new-used savage
  243. Whats the difference?
  244. Ofna .32 roto back plate
  245. got a poblem
  246. What k diff out do I run?
  247. Better body post 'stubs?'
  248. removing one way bearing?
  249. Savage X difference
  250. First run of the year !!!
