PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. my savage shakes alot
  2. truckzilla wheels remove tires???
  3. Help Savage SS Transmission Adjustment
  4. anyone tested there 25 le's top speed
  5. will this work??
  6. Nitro Star 25 carb fix
  7. Stumble, where to set HSN
  8. Resetting Control, RC wont respond
  9. How much resistance when Pull Starting
  10. body lean
  11. Axial .28 on my savage.
  12. Savage Dual Steering?.
  13. help with carb needle o-rings
  14. screw stripped, how do i remove it?
  15. pro-line moab on a savage
  16. new radio box cover
  17. too loud!!
  18. Savage Limited Edition RTR
  19. new fuel problem
  20. 3 speed gear box anyone help
  21. picco 27 help tunning
  22. probe vs temp gun discussion
  23. DEAD LINK plz dont post
  24. savage & revo bashing and 100ft drops
  25. rebuilding clutch HELP!
  26. Replacement carb
  27. I can't WIN!!!???
  28. whats hard core racing's web site
  29. what temperature
  30. Slider clutch
  31. Engine Help
  32. Just broke my Pull Start! (am I that strong)
  33. carb came out...but no sleeve
  34. Is 8% oil ok?
  35. Your crash and burn stories
  36. snow questions(i know there is alot of threads)
  37. Busted shock
  38. ok tuners...diagnose this one
  39. Remember years ago when engines were simple?
  40. CB Rubbing Spur?
  41. new tires
  42. good or bad
  43. The savage radio box...
  44. Just Broke in SH.28, a couple questions
  45. Can't Get the carb out!?!?!?!?!?
  46. motor off?
  47. cant start on idle?
  48. starting my savage
  49. Upgrading the S25 to F4.1 Engine
  50. Ofna Hyper .21
  51. Servo Problems, cant get it to run when servo is on
  52. jr high torq servo
  53. xtm .28 pro
  54. put in GPM aluminum diff case, now........
  55. What is a stoppie??
  56. Savage X
  57. time for a new car
  58. Lockers?
  59. Spektrum Telemetry in Savage
  60. Tire Glue?
  61. centre skid plate
  62. Changing nitro %
  63. New Savage X info
  64. Need Help with decision on Engine
  65. Going bashing tomm questions....
  66. i need parts
  67. loose carb
  68. Good deal....or not?
  69. Hump Pack doesnt fit?
  70. New savage 21 owner
  71. using a temperature probe
  72. venom hump pack??
  73. Did I get a hosing or a deal?
  74. picco26 ,cant spin motor over??
  75. New Axial .28
  76. Help please!/Clutch bell problems...
  77. best mods list
  78. metel spur
  79. front dogbone prob
  80. Engine suggestions?
  81. How long should it take to start ?
  82. Venom Temp Monitor (pic)
  83. need gearing info 4,6 3 speed
  84. Help Cleaning Tires
  85. Gearing for those who don't know
  86. Hot bodies jumbo tires on a Savage?
  87. HPI Rumors? Whats next for us?
  88. Braking Adjustments
  89. Hi questions about servos!!
  90. 3 speed?
  91. Anybody have the Hitec HS-635HB servo?
  92. I had a dream !
  93. what would be the best clutch replacement for savage 25?
  94. Removing carburetor from 4.6?
  95. what engine upgrade for a .21?
  96. what u did that was stupid that broke a part
  97. atomik 2 temp gun
  98. help w/ 4.6 tunin
  99. dual disk brake problem
  100. MY SAVAGE SUCKS
  101. What do you think?
  102. clutch
  103. Savage 25 LE tuning problems
  104. just got a ss!!
  105. New Savage 25 Engine Tuning
  106. I May Be Buying A Savage - Questions Please...
  107. I need a Break from Break in (SH.28)
  108. savage 25 temperature question
  109. HPI ATV QUAD
  110. rossi 28 3 port vs sh.28
  111. K4.6 Rear Bearing = Baked Alaskan
  112. wheelie question w/ 4.6
  113. help on 4.6 engine
  114. Ramp Making ...Where Plans?
  115. Another question ( EDITED )
  116. Im gonna go aluminum!!
  117. Savage 46
  118. servo
  119. Savage stalling!!!
  120. new Savage 25 will not start or turn!
  121. Spur Gear and other problems
  122. Sure Fire .32
  123. About to trade for a savage
  124. tmaxx rims ?
  125. Quick question?
  126. handeing help 4.6
  127. Fuel Tank Mod?
  128. BEST WAY TO BREAKIN-IN YOUR ENGINE!!
  129. What can make the electronics freak out?
  130. spur gear installation
  131. Mach.28 or Sure Fire .32 ??
  132. Savage25......loose carb......Help
  133. Lifting a R/C Chassis
  134. glo plug heat range?
  135. savage 25 spur gear
  136. Antenna
  137. basic battery/charger biz....
  138. Ofna Micro Failsafe
  139. temperature
  140. hellfire body for savage?
  141. STRONGER SHOCK SHAFT???
  142. Hot Bodies Shocks
  143. New SRV tribute body
  144. HPI Customer Service....Thumbs Up!!!
  145. Savage 4,6 & Revo vs 127ft jumps video
  146. How can I tell if my clutch-bell is shot?
  147. Clicking?
  148. getting into nitro cars
  149. Cold Fusion Solder iron
  150. Clutch bell?
  151. Rear differential problems.
  152. O.S. .30 Questions
  153. Can't Get SH.28 Started
  154. ...spare a minute?
  155. running in my savage
  156. HPI .25 in a Revo.
  157. Break-in Issues (Idling)
  158. Workstand Dimensions?
  159. Just Got SH.28, Please help with break in
  160. Are you wheeling your stock Savage 25?
  161. tranny
  162. Nitro Star 25 Carb Question
  163. To Beadlock or not to Beadlock?
  164. TAKEING A POLL!!
  165. new engine
  166. closed
  167. HELLFIRE OUT ON THE 15th!!!
  168. Need your help guys !
  169. nitro %
  170. werks racing clutch
  171. Tank 5 ..went drifting on a baseball diamond
  172. custom fabrication (off topic)
  173. just wondering
  174. I need a definition of BASHING
  175. Stupid Question...
  176. roto start
  177. IS THIS GOOD ?
  178. Hot Bodies Fireball tire for Savage?
  179. Triple rate springs?
  180. Shock Mod
  181. Failsafe
  182. Clutch problem
  183. How does the Savage handle stock?
  184. OS .30
  185. If I Only Could Do 1 Mod or 1 Upgrade thread
  186. What breaks of the Savage???
  187. THE BEAST LIVES.......
  188. boreing
  189. Savage motor swap??
  190. 30 000 wt diff oil
  191. Gpm Stering upgrade
  192. HOLE IN DIFF CAP
  193. shifting problems!!!!!!
  194. savage clutch install
  195. Kyosho Landmax body???
  196. hpi savage steering
  197. buying a savage
  198. wasp 26 needs sealing and what glowplug
  199. Service
  200. using TMAXX shocks on the savage
  201. NITRO STAR K4.6 HO ENGINE
  202. Confused?
  203. NEW Savage 25 Limited edition
  204. piston skirt
  205. hellfire vs thunder tiger st1
  206. Shock servicing?
  207. servos going NUTSSS
  208. AM vs. FM
  209. supercharger
  210. ~SAvAGE25~SS~OR 4.6??~
  211. noice when engine cuts out
  212. clutch?
  213. Found the weak spot ...
  214. How can I get SH .28?
  215. XTM
  216. Which radio is more suited to Savage?
  217. FINALLY I BROKE SOMETHING!!!
  218. QUESTION FOR A SAVAGE ENGINE EXPERT
  219. savage or evo3?
  220. Savage 4.6 SS or Savage LE
  221. 4.6 3 speed gearing
  222. A simple mod for you pull start guys with pics
  223. 4.6 Engine Box
  224. Plugs
  225. Revo & Savage 4.6 Snow Bashing
  226. Need tips for starting with radio/reciever ON
  227. BASHERS
  228. BEADLOCKS
  229. servos and radios
  230. Working Stand.. Any recommendations?
  231. Will this be a good set up?
  232. Are the Alu or Alloy parts worth the $$$
  233. savage 4.6
  234. Best shocks for savage?
  235. Headlights ?
  236. Problem I can't figure out. Calling all experts!
  237. New tires
  238. T-Maxx Boddies for Savage 4.6 Fitament?
  239. Noob Here, need guidamce on upgrades!!!!
  240. Cage extentions !
  241. crazy 2nd tank break in question
  242. ***????!?!?
  243. N00b Question for Parts from T-Maxx
  244. First kill
  245. What does it mean wgen the rotostart shaft locks?
  246. hpi savage videos
  247. servo
  248. I have a problem... i think
  249. I have a problem... i think
  250. Please help a noob out!
