PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Are the Savage Engins not good?
  2. potential
  3. Savage 25 Running problem.
  4. Rotostart for picco .28
  5. Savage 25 with diffrent motor
  6. Could this be good competition for the CEN pipe?
  7. First savage
  8. Savage for xmas
  9. 10 Mounths Ago
  10. Savage not the same since adding 3 speed!
  11. savage vs t-maxx vs mgt
  12. winter bashing
  13. engine plate
  14. Picco P3 roto start backplate?
  15. New place to bash
  16. XL F&R diff issuess
  17. what do i do to stop my rc from being a runaway rc
  18. will my 14t cb mesh properly with xl spurgear?
  19. wing mount
  20. new and need help ! Brakes not working!
  21. Couple of Questions...
  22. New motor need help
  23. Modified K5.9 pictures
  24. 2 or 3 speed?
  25. OK the Savage rocks!
  26. Wheelie Bar
  27. Savage Projects
  28. Bigger bore shocks
  29. Lst shocks(original question)
  30. new engine
  31. Different cen pipe models?
  32. engine mount question
  33. Questions about gearing.
  34. Dieing xl rims?
  35. De-Anodizing
  36. Savage Problems
  37. Carberator Idle Screws
  38. Savage Rollcages
  39. its been a long time
  40. Savage 3 speed
  41. Savage XL Wheels and tires
  42. What is your opinion on metal parts?
  43. bruchless savage help
  44. Frustrations!
  45. mgt 8.0 in a savage
  46. Anyone use Byron fuel?
  47. Does the XL 3 speed have the new transmission case?
  48. Feigao XL Brushless Motor were to buy
  49. aw man :[
  50. Crap!! I bought the wrong wheels!
  51. What is the easiest way to take out the engine?
  52. The Postman Delivered Today!!!
  53. HELP......ANYONE!?!?!
  54. THE DEFINITION OF TOO MUCH POWER
  55. Not a Savage..but some wicked high RPM Truggy runs !!!
  56. $200 engine
  57. Gotta tell the world
  58. Savage XL with Picco 28
  59. Questions about the OFNA 086
  60. Savage 5.9 XL 086 251 degrees....
  61. 4.6 running sweet
  62. Lrp Button Mod?
  63. ups and downs of trucks
  64. RDLogics Twin Exhaust Pipe
  65. Best clutch bell/ spur for K4.6 X/XL chassis?
  66. Anyone from NYC or Brooklyn?
  67. Truck goes nuts
  68. Tried The CEN pipe
  69. Can't Start
  70. savage x oneway slipping all the time??
  71. Gravediggerracing's new video
  72. Gravediggerracing?? Videos??
  73. For you LRP lovers....
  74. Is it a problem with my XL?
  75. do you have rdlogics for your XL ?
  76. Fun Halloween pictures!
  77. reciever wire
  78. How much does your Savage weigh?
  79. Revomad, bud, or any nitro expert
  80. no drive transmitted
  81. Engine experts I need your help
  82. Adjustment of gear box
  83. RX TX Prob.
  84. Servo saver
  85. Savage 5.9 XL 086 revisited...
  86. Hey Revomad
  87. My vid
  88. Swapping piston sleeve
  89. Starting a Savage with Losi Spin-start??
  90. Cheapest place for an X SS kit?
  91. Savage Xl shifting problem
  92. This you want to learn from my mistake...
  93. savage SS converson to electric
  94. which part of savage xl must be upgraded ?
  95. Savage replica
  96. my os 30 vg idle less then 5 seconds
  97. Just Bought An LRP .28
  98. Shock Suggestion
  99. Need to seal my K5.9
  100. Replace
  101. erratic behaviour
  102. Pull Start for Savage XL?
  103. Up dates to my race Savage
  104. Savage X Picco P3 28 Ofna 086 exhaust
  105. Check out my SavageCEN XL!
  106. is (#OFNC8663) good ?
  107. Dogbone grease?
  108. which pipe fit OS 30 vg ?
  109. body
  110. Savage XL 5.9 leaking fuel
  111. GPM/VENOM shocks
  112. Not happy with Savage X 4.6 RTR
  113. savage brake problem
  114. Savage X with Ofna Header and 053 pipe.. I found water!
  115. E SAVAGE people??
  116. xl with bow tie 40 series (gearing)
  117. Savage X 4.6 steering problem
  118. Clutch for F 4.6
  119. Savage X with 5.9 and 086 pipe...finally!!
  120. xl center driveaxle fit the x diffcup
  121. 4.6 brake trouble
  122. Savage X SS or XL
  123. Savage running in
  124. WOW.. you have to see this crazy Savage
  125. Savage XL for Christmas?
  126. Ready to bash again.
  127. Anyone have Dynamite 23mm hex hubs?
  128. Ordering a Savage X SS. I need help!!
  129. Steady breaking time...
  130. need help with k5.9 breakin
  131. can rx cystals break
  132. Video of my newly Acquired Savage 25 Picco 27
  133. What would be better ?
  134. The ESSENTIAL modification guide
  135. New RX/TX? Anyone use this?
  136. My newly aquired 25
  137. hpi 4.6 K or F
  138. STS.30 troubles
  139. Looking for metal suspension arm set.
  140. convert savage xl
  141. Savage x 4.6 ring gear
  142. ok guys..my Savage finally came! Need some help please!
  143. would anybody buy these???
  144. Are all piccos P3's?
  145. new savage rtr 4.6
  146. POS K4.6
  147. no luck with the savage...
  148. engine mount
  149. Wheely king hopups
  150. lrp or picco vs k5.9
  151. What are the pros and cons of using a 3 speed?
  152. Nitro star engine?
  153. 5.9 with 4.6 header and exhaust ?
  154. What tires do you run?
  155. Antenna Problems
  156. Shock Oil Weight
  157. Diff Grease VS Diff Fluid. Doesn't the fluid leak out?
  158. check out my new track and video
  159. Want to see a Picco go swimming?
  160. 17t cb and stock spur on xl ?
  161. mid engine mod/race wing for savage
  162. A BIG THANKS
  163. I Killed My STS :(
  164. x cage modded to fit my xl
  165. black rims
  166. XL Picco .28 EATING TRANNYS!!
  167. Starting point for 2 speed trans
  168. Front diff feels stiff
  169. New paint jobs coming
  170. My Savage's new 21cc powerplant
  171. savage ss cooling head
  172. throttle linkage fix.
  173. which engine for my savage x 4.6?
  174. *** BULLET PROOFING 14MM HEX'S ***
  175. B/L Savage 25
  176. Savage XL Spare parts inventory
  177. VIDEO of K5.9 + CEN pipe (NO MUSIC!)
  178. new hubs?
  179. cool video, with a bad ending!
  180. What should I do?
  181. Drive, Break, Fix, Repeat
  182. keep on loosing "screw shaft"
  183. Just bought a Savage with boxload of extras.
  184. hey BB or someguy
  185. Transmission Shift
  186. what are my wheel options?
  187. tower hobbies
  188. Another K5.9 engine + CEN GST 7.7 pipe video
  189. TIRE SWAPING
  190. Hellfire engine in Savage
  191. savage .21 out of storage
  192. Fuel line?
  193. savage x 4.6 vs t-maxx 3.3
  194. slipper clutch pad exploded
  195. Can any of the vets help me with ...
  196. New Guy - Savage 4.6 SS
  197. hope this isnt a repeat post...
  198. Remove large BB from engine
  199. 3 Speed blown bearings
  200. Savage Bashin !!!
  201. Picco burning up cluches?
  202. How to take out transmission?
  203. Picco engines
  204. frequntly needed parts
  205. Reducing the Engine Noise of Savage 25?
  206. Modding 5.9?
  207. Found this in my engine. What is it?
  208. My freshly painted shell!
  209. Engine dies at low RPM.
  210. my midtank conversion in progress....low budget.
  211. Anyone using a DX3.0?
  212. Heavy duty axles. Brake discs.
  213. Picco 27 X Picco 27 XL and Picco 28 XL
  214. Savage Race Truck?
  215. 5.9 issues
  216. Help with 3 speed tranny
  217. Any Racers running this?
  218. Roto Starter
  219. break cam/piston
  220. New Savage xl
  221. Savage X Chassis Side Plates on a ss
  222. Charger
  223. it's stuck with no reason! please help mee....
  224. My session today
  225. Now I know why it was for sale...
  226. Losted a carborater screw
  227. XL sluggish
  228. Convert Wheely king to nitro?
  229. Bud Bud or other picco experts can you help?
  230. savage ss 4.6 pipe
  231. Tell me what you guys think
  232. tough truck pics.
  233. one tough truck!!
  234. idle screw spring?
  235. Savage Xl tranny question
  236. lrp running temperatures
  237. Picco question for tib
  238. Any Picco 27 experts out there???
  239. Midget's Center Skid Plate
  240. Steering Servo saver and Servos
  241. 6v hump pack
  242. Savage home made drifting wheels
  243. please help meeee
  244. Tire question
  245. savage 4.6 vs savage 5.9
  246. wheelextensions.com?
  247. savage ss 4.6 gearing
  248. Major Wheely King bash with pictures
  249. Hey TBJ!
  250. Interesting XL run
