PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. ?????ELECTRIC SAVAGE?????
  2. help on sh 28
  3. xtm .28
  4. SAVAGE X
  5. Best engine for savage!!!!
  6. differential and dirt (sand) help
  7. Savage X does anyone know when we can get it?
  8. parts need website
  9. shock oil
  10. Tuning and other trouble need help
  11. Jump Size
  12. some 1 help me i cant dicde yet!!!
  13. gas tank question
  14. Some Action Pics..
  15. New savage
  16. *Custom Truck*
  17. Which truck =-} Savage LE or X
  18. Good day of bashin'
  19. More new engines
  20. Broken Camber Arm
  21. Receiver
  22. frequency question
  23. Tire and Rim question
  24. roll bars
  25. what would be a good bashing monster
  26. warhead
  27. what's the longest you ran a glow plug
  28. Confused About Settings...!!
  29. hi rev 4.6..help
  30. RUST!
  31. cool head
  32. THE WIERDIST THING
  33. Carb
  34. loose carb ,but tight pinch nut..
  35. savage kit or savage x
  36. LOOKING FOR BASH BUDDIES
  37. tuning mi savage 25 le HELP
  38. novarossi 28 8 port
  39. altitude
  40. tuning question
  41. Taping the tires
  42. Air Filter Oil.. Does it have to be RC air filter oil?
  43. What do you think..Picco27 or OS30VG
  44. On two wheels?
  45. mmmm......doughnuts !
  46. OS 30VG in Savage LE
  47. first body to match my pickup
  48. is this correct?
  49. Alloy rims?
  50. This Is What I Do When it's <<COLD>>
  51. Mach .28 problems
  52. novarossi, What will it take?
  53. savage 25 gear mesh
  54. finally got my hellfire!!
  55. Another zip tie use. Body Clips.
  56. Racing in backyard track
  57. SUPER STOKED! First time letting it rip!
  58. turning problems
  59. MT SHOWDOWN!
  60. Driveshaft replacement help?
  61. BREAKS AND GEAR SHIFT
  62. cheap beadlocks
  63. premature brake failure.
  64. Brand New Savage LTD
  65. replacement for rotostart..?
  66. Surefire .32 on a Savage?
  67. any breakings on savage
  68. Anybody ever mounted a video camera on a Savage?
  69. Can't catch an LST2???
  70. Temp Gun or Probe
  71. track in ny?
  72. 1/5 scale gas powered MT has to be coming...
  73. Savage 25 or Revo ???
  74. Best Fix for Front Diff??
  75. adjusting two speed tranny
  76. quick question
  77. ?? ideling problem ??
  78. MACH 28 help please
  79. Ranger body...
  80. component material
  81. bed experinces
  82. Please Help - I'm in Spur Gear Hell...
  83. QUESTIONS ABOUT SWITCHING TO AFTERMARKET COOL HEADS
  84. pull start question/survey..
  85. buying a SAVAGE 25 LTD
  86. How/Why does switching diff oils make a difference?
  87. woh nose dive!
  88. savage 25 question
  89. Oil in diff's
  90. bsc
  91. porting.
  92. White Wall Lettering on Tires
  93. Your Opinion Pullstart vs RotoStart
  94. How do i get thru all this engine BS?
  95. engine bearings
  96. $1000 Savage
  97. Upgraded Clutch
  98. question
  99. team orion .28
  100. Damaged RAMtech rim.
  101. 3 speed settings
  102. best way to instal the servo saver on the 25
  103. Beadlock rims/ Please help !
  104. I just found these...
  105. using 20% on Lrp z.28r spec 2
  106. 2 pc metal spur gears????
  107. 4WD problem
  108. kodie
  109. savage diff oil
  110. jumping
  111. savage servos
  112. squeaking
  113. need help with clutch on ss 4.6 !!
  114. Longer steering servo horn means better turning
  115. Which motor should i get
  116. To all the newbies...
  117. team orion .28 setting
  118. what is it worth?
  119. new servo?
  120. Check out this smoking deal on 3 speeds!!
  121. HELP!
  122. engine question
  123. New reverse module for the Savage X?
  124. savage diff grease
  125. SH.28 into Savage
  126. spur gear tooth count
  127. Roto start 2?
  128. Should i get reverse?
  129. Rc track in Etown Nj??
  130. Zip ties on cooling head?
  131. Savage leak??
  132. Steering not centering
  133. Savage skid plate
  134. Hump pack and failsafe (help)
  135. savage air filter
  136. Servos Messed up
  137. Spur Gear Meltdown!
  138. hitech servo install - pleez skool me (pic)
  139. Lock-tight.
  140. ALOT of oil coming out of exhaust?????
  141. exhaust deflector
  142. Can i get a roto start for....
  143. Savages or an LST?
  144. aan improvement at least...
  145. ON Road tyres
  146. Hellfire
  147. Pull start problems
  148. when will they discontinue the ss 4.6?
  149. savage x
  150. what are brakes ...
  151. savage help please
  152. first time racing PICs
  153. Couldn't Resist the 55° weather in MI (pics)
  154. savage X link
  155. richening has leaning effects?
  156. wheelie bar design?
  157. Conclusion about Savage...?
  158. 3-speed, bigger engine, or both?
  159. exhaust position
  160. savage 25 is dicontinued?
  161. twin engine monster truck
  162. Savage X receiver box on a Savage21,25,SS,Limited?
  163. ultimate bash vehicle
  164. newbie savy owner ...
  165. the most nitro you used in a day?
  166. Clutch bell question
  167. Suggestions?
  168. Lack of Low end torque?
  169. new baja!!
  170. Venom Smart Temp Question...
  171. BEST BASHING TIRES__
  172. priices for savage X
  173. You know your a Savage freak when.....
  174. offsets or not????
  175. which engine
  176. NewComer
  177. save a post
  178. hairdryer
  179. Zombie Maxx Tire Question
  180. Servo saver
  181. hump pack help please
  182. nice crash
  183. SS 4.6 Any tips On My fierst start up ??
  184. ceramic bearings for savage
  185. new tires!
  186. savage safety shut off
  187. Compression
  188. New to HPI got a Header Problem
  189. new era fuel tank
  190. Axial Motors ??
  191. Hpi Nitro star s-25 owner's manual
  192. stock shocks
  193. carb spinning problems
  194. Did the Heat Sink Zip Tie Guard <pic>
  195. 2speed or 3 speed?
  196. Is this truck any good ?
  197. Reverse Servo Question
  198. slipper
  199. aXIAL .28 3SPD TRANNY
  200. Alliminium Shocks
  201. 4.6 SS build PLEASE HELP
  202. how does the slipper work
  203. how does the clutch work
  204. 40 series tires
  205. OS 30 VG
  206. stuff did to the savage
  207. slipper hub and plate
  208. what's a tuned pipe????
  209. Please Help, I think my tranny is fried
  210. cant popawheelie
  211. Body Painting Basics
  212. Does HPI Have a Nitro Fuel Recommendation?
  213. Back in the Game
  214. carbon fibre effect shock bodies
  215. new mach carb
  216. 2nd Tank Break In (HELP NEEDED)
  217. carb swap
  218. What flywheel is good
  219. 40 Series Rims and Tires on a Savage 25 LE
  220. bumper supports
  221. Roto start with 12mm LCG TVP's
  222. strip one way bearing...
  223. Savage X
  224. 1/8 SCALE ??
  225. which break-in method
  226. aluminuim clutch shoes
  227. When things go wrong....
  228. bringin temp down
  229. need a new body
  230. Quick Question
  231. MONSTER POWER FROM O.S. .30 VG
  232. How do you like your extended TVP,s
  233. purple heat thing at top of engine
  234. k4.6 needle settings
  235. k4.6 needle settings
  236. how easy to install steering servo?
  237. good + bad news
  238. Where are the HELLFIRES ?!?!
  239. MIP's for Savage
  240. alluminum shocks
  241. how do u keep ur spur gears
  242. HPI Engine and throttle linkage
  243. New Parts for Savage
  244. braking prob
  245. is there any way of quieting down the savage
  246. hitec hs-5645mg or hitec 645mg
  247. One Way Bearing diff from roto to pull start??
  248. show your best pics and vids
  249. Blinging this stock monster
  250. Heat Sink Guard
