- Cheep Wheely Bar And Roll Cage
- good deal?.
- More bodies (Pics)...
- stupid or cool idea
- Savage ss handling
- I broke down and bought one, but have a question.
- Where to buy pipe?
- Quick tuning question; should be easy
- tuning nightmare...
- Exhaust Cone Test
- my new savage xl
- Pics of you work areas?
- engine temp
- 3 speed trans kit for savage X rtr
- what pipe ?
- Traxxas style driveshafts on Savage?
- New pipe suggestions
- .25 factory needle specs
- noob questions
- Savage SS rx
- wasp .28 pro
- What fuel do you use?
- 25 to xl worth it
- tuned pipe for 5.9
- Still got air bubbles...
- What Should I Know When...
- Exh Gasket on Picco P3-28
- First airbrushed body and thoughts for noobs
- Noticed this
- carb tuning for xl 5.9
- Spur gear mesh always moving
- OFNA hump pack
- 3 speed instruction manual
- engine question???
- New Savage Engine
- What are YOUR n00b moments?
- Upgrades for my savage!
- HPI Problems
- Integy alloy parts are they any good
- Nitro Newbie - Replacement engine for SavX 4.1
- dum founded
- This thing is starting to annoy me...
- Just got the K5.9 today
- Lucky #7?
- E-Savage Batteries
- Savage X 4.6 needle problem
- Savage 4.6 ss or hyper st RTR??
- MT2 New engine
- Which converter is needed?
- Finally Got a Savage!
- HPI big bore shocks
- low profile for my savage xl
- What are the advantages of the XL?
- savage .25
- K4.6 help
- think my clutch springs are to light??
- savage 21 with 3 speed
- electric motors
- 4.6 troubles
- Nova RC Cooling Head On a Picco P3
- Some Questions?
- My Savages are getting neglected!
- Hitec?
- savage xl half tank lean
- old 25 engine dead - best replacement
- SH.28 engine? any good
- My Savage went for a swim !!!!!!!!!!!
- Picco P3 vs Hpi 5.9 in the XL chassis
- HPI hump pack adapter pigtail?
- Is that normal guys?
- Diff cup o-rings
- 50/50 or 70/30 throttle for Savage ??
- wich tires are better?
- Will the K5.9 Engine fit in a Savage X?
- Bubbles in fuel line?
- Picco Torque Video
- Savage RTR Vs. Kit
- Leaky front bearing? on one gallon Picco....
- Tropical Storm Fay
- Aluminum Clutch Shoe's?
- Savage XSS Pipe = Savage XL Pipe??
- savage or lst
- Savage clutch overheating melting spur gears
- Broken slide carb?
- 49 MPH Savage video !
- motor upgrade
- Exhaust gasket slightly "burnt"
- SPUR GEAR CHANGE
- BASHING PICTRUES
- What weight oil for stock shocks?
- Diff question...sort of.
- I got this loose stearing ya see...
- Wickid sweet jump=cool pics!!!
- One way bearing
- quick question?
- Hpi tough
- An old friend died today.. RIP Truckzilla..
- need a roto start to fit on picco .28
- P3 28 Teaser vid
- Question about savage bodies.
- XTM Servo
- 3 speed on savage x
- Need help!
- Shifting?
- Bodies for XL?
- rotostart 2 broke, why??
- shims for flywheel
- Long or short plug?
- Got my new used savage with upgrades!!!!!
- tuneing problem??
- Savage X RTR or the Savage XL????
- Somewhat of a powerhouse
- New Savage X vids.
- Which aluminum shoes?
- Basic maintenance/slight grease exiting drive cups
- Seems like forever
- Just Destroyed Two Clutch-bells../X SS Rebuild After Five Gallons
- Suspension adjustments
- Savage with Hellfire wing mount with base !!
- Throttle arm
- AirBrushed T-Shirt
- How Do I Remove The Axle Shaft From Driveshaft?
- awsome Savage!!!??
- Visiting shocks again...
- Picco 28 vs 5.9
- picco .28 how to take the conecting rod off the crank shaft
- Picco 27 issue
- Noobie Tuning question
- Thinking of converting my savage to race....
- For those of you who are thinking of buying bigger tires "just for fun"....
- is the mixer for the reverse still work If i use a venom smart temps
- Been awhile
- Savage 25 Overheating Solution, please!
- xl 3 speed
- Got a 3Speed , Any Sugestions?
- How do I remove the wheel hub from the driveshaft?
- Ok, we all know what they look like clean, let's see the dirty ones!
- Got my new savage X
- Vented Clutch Bell
- WHICH of these TIRES?
- Diff oil
- Hpi ribbed pipe?
- MOVED: Associated mgt 3.0
- Badlands on a Savage?
- Erratic motor behavior
- Innovative-RC Pro Mid Tank mod Kit for savage
- Upgrade the 4.6 to XL w/picco?
- Shock oil
- Stainless screw set?
- I am getting closer! Picco XL coming up!
- 2 speed or 3 speed?
- Fibre disc better or steel discs
- Savage X rtr or the Savage XSS
- SavageXL Center Skid?
- budget racer HAS ANY BODY GOT SPOILERS ON THEIR SAVVYS?
- K5.9 X Dyno results!
- would a savage xl engine fit in a savage .21
- checklist for first nitro
- savage k4.6 engine problem
- Best foams for Dirt Bonz??
- Finally after 3+ months... I installed my P3-28
- Where to get bearings for axial .28 and .32
- savy xl with a cen pipe
- Elven's Savage - WEEKEND FUN - Pics !
- Best plug in a HPI F4.1
- Extended chassis newcomer- help needed!
- New Savage owner
- Savy xl relocating the ...
- Broken tooth off steel spur gear?
- Standard Buggy Header
- Taking Picco plunge,need help please...
- Weekend Work!
- My Savage XL experiences
- Glow Plug?
- No compression, Help??
- Anti sway for FLM superduty....Anyone?
- Suspension set up?
- What ESavage Part Is This!?
- savage xl tuning question
- Sav X Upgrades
- 3 speed and tranny case changes?
- OH boy...
- Savage X SS 4.6 good investment?
- New petrol car from HPI ?
- Lst2 shock owners.. need help
- F4.6 questions
- fuel question
- p3 or 528xr...paging supertib,please.
- savage pics
- LST Shocks on FLM Shock towers and arms, Any mods???
- FLM SavageX SS
- savage x ss-3 speed transmission
- savage x 4.6
- What do you think is the best fuel?
- savage x 4.6
- Need some assitance
- What I learned today
- Savage 4.6 RTR tranny/something??
- Who has TCG TVP's???/LST shocks?
- Factory settings for K4.6
- sirio .30 header?
- need help finding parts for x roller
- runs for awhile, drives for awhile then stalls
- Savage XL 5.9 on an Ofna 086 pipe
- Savage Racer Question......
- I Need replacement Tranny Case
- XL 5.9 running cooler, revving higher, idling better...running quieter..
- Question on my savage XL
- Hot Bodes Website
- New Savage XL
- broke some stuff... good bash day
- Radio Box Ports/Holes
- Which Dual Brakes?
- Needle Problem (Pics Up)
- Pipe for Picco .28
- savage pics
- Might be getting a savage!!!
- tires?
- The XL gets a new skin!
- Here's one for you Dodge fans
- 5.9 replacement engine??
- tuning crisis?!?
- 30% fuel switch to 20% fuel:yes or no
- 30% fuel for Savage 4.6 yes or no
- Help on fuel,please.
- Does/Will the Savage XL come in kit form?
- Messed with transmisson screw still no shift?
- XL shocks
- Factory Needle settings on Savage XL
- SUV body mount
- picco .28, half tank, pull start broke
- Spur Gears Going Bad. What should i do!?!?
- KO PROPO servo horn
- Is my OWB shot?
- HPI bodies
- engine?
- how to take off the K4.6 Carb for cleaning ?
- Off set wheel ?& XL roto start shaft ?
- road rage tires gone bad
- HPI STEEL "BRAKES"
- Clutch shoes wearing out ?
- Burning through Plugs
- this clutch bell is groovy!
- have you ever had this problem?
- same story fresh start
- Savage xl or MGT 8.0
- Show off your classic, 1980 or older truck bodies
- shocks
- 4.6 Big block keeps stall
