- QUICK WHICH ENGINE AND WHY for my SAVAGE!!!
- roll cage material
- Super Savage vs Novice Truggy Race Video
- Savage with roll cage action pics.
- What Differential shims to use?
- 5.9 engine
- Any body have one
- My home made Savage roll cage
- I need tire help!
- Anybody try this yet?
- Savage X Picco 28 installation
- Which one of these rims will work with Badlands?
- Happy Bday to me!
- rating and score
- Extended LCG chassis options?
- savage x ss brakes?
- savage X
- purchasing savage atv kfx700
- Silly Vid
- Need Help Tuning W/Vid
- May be a bashing day!!
- Savage on the way
- byrons 30%
- Toe Gain
- noisy savage XL
- Suspension setup/Shocks
- Nitro fuel for my Savage
- Savage XL
- Advice for a noob please?
- Slipping OWB? Try this!!!
- F4.6 Front Bearing Leak
- Tires and Wheels?
- The Good Karma Bus Arrived!
- Picco .26 Plug....?
- That's a new one!
- Lipo damage?
- steering servos?
- savage XL engine
- Need some help choosing bodies: Can any1 confirm 100% if Slash/Slayer will fit extended Savage .21?
- savage XL
- Just missed a steal on Craigslist...
- Only driven by front wheels???
- Fathers day
- Planning to jump something large.....
- XL 5T
- Clocked Picco has a new temp. home
- mach 427 .26
- Savage Action Shots..............................
- lrp 30 running out of fuel in fuel line
- been a while
- Wow I'm Stupid!!
- GRP Engines are gone !!!
- In love...
- Just Bought a slightly used Picco .26 for my XL...what should I expect from this?
- BudBud read this HELP
- I think I FRIED something... HELP!!!
- Savage clutch shoes flywheel and CB on picco .26...?
- I got a savage x 4.6 today
- Is the RD-Logics exhaust good or bad
- Just got a savage x
- Side-by-side Picture Request: T/E-Maxx & Savage XL
- Savage XL: Problems & Recommendations
- tie rod ends
- springs for clutch shoes
- roto start unit for LRP ZR30
- Holy Crap!
- Just got my LRP .28 Spec 3
- Anybody need a LRP 28 button?
- Where to buy an LRP spec 3 .28
- Two New BBBVs
- Tuneing The lrp 30
- integy product
- got any blue rpm upper arms?
- Picco 28 with an Hpi pullstarter
- Flux + 30' of air + dbl back flip + concrete = NOT GOOD *PICS*
- LRP30 or OS30
- OFNA 053
- What exhaust to run on an Axial .28
- Death to my rear pinion... my fault though..
- What radio gear do you run ?
- Single Speed Savage Gearbox ?????
- Killed a differential
- BudBud i need your opinion
- picco .26 pull start question
- Savage Flux 6s beatings (video)
- Any new motors you reccomend?
- Baja Flux enjoying the Beach
- new 3rd gear?????
- Carburetors! Christmas in June!
- Savage X at the Jumpin' Joe's Hill
- How bad are the diff problems on the savage??
- HPI aluminum clutch?
- Savage 4.6 needle settings?
- Tuned Pipe Question
- Lrp 30 pull start tight fit on savage xl
- pipe options
- Crank Shafts PS vs Non PS???
- Another BBBV in grass Picco 28 issues?? Another Picco on an 053 pipe!
- BUTTON HEAD 4 MY SAVAGE 4.6
- savage 25 carb???
- savage xl help please
- Savge xl pipe on lrp 30
- bought an Axial .28
- Lipo charging question
- Savage xl shifting
- Savage .21/Flux parts.
- Do all Savage parts fit all Savage variants?
- what are the axle thread directions?
- Picco on 053.... video-warning... all grass
- Speedo/ radar gun
- Picco .28 JLR RED DOT
- Where to find Savage .21 pre-painted bodies in the $50 range?
- another reason to figure out how to bump start a savage!!!
- button head ?
- Need buying advice for Kershaw brushless conversion
- LRP 30's are something else!
- e savage problem
- E SAVAGE QUESTIONS HELP!!!!!!
- Savage X with RB Mods LRP Spec 3
- How long can you leave your throttle
- LRP 28 Carb Issue Solved !
- Hmm, I may switch to Traxxas connectors
- Aluminum or Carbon Fiber????
- Savage Engine Settings
- Brand New Savage X Owner
- Best engine under $250
- engine bearing
- HPI Aluminum Threaded Shock Set
- servo issues- seeking advice
- Strongest Shocks for HPI Savage
- nitro star 25
- mecanic problem help me pls
- Uh oh, did I ruin my SMC Lipos?
- Savage Flux - Roll Cage?
- Savage 25 tuning Method?
- Decent stick packs for flux
- Engine question for Budbud
- 2speed or 3speed
- Just got off the phone with HPI in regards to Savage Flux Lipo's, gearing, NIMH and diffs
- fuel filter
- PICS of the AWESOME FLUX XL Black TVPS installed!
- IF you are about to buy a new FLUX... come inside...
- Hpi Modified Savage Race Videos
- New Savage Flux - Using Less than 25c lipo???
- Brushless XL Build!
- wheelies
- New savage servo released
- value battery setup for flux
- no brakes with brushless
- Do I buy HPI Hellfire????
- frustrating
- LRP .28 Carb Issue
- Buying Savage parts on EBay - WARNING
- Savage 4,1 trouble
- Picco at Jumping Joe's
- Covered in um, stuff...
- Diffs = annoyance...
- Bigger tank without Mid Tank Conv?
- Clickin Noise
- antenna mod?
- Ran the savage a little and got some video...
- exhaust hanger wire
- K4.6 leaking bearing
- So, Your engine guy does an engine and then says you do not run it hard enough....
- my savage project is 99% complete
- Converting Original savages to FLUX
- 40 series?
- XL or MT2 cant decide!
- Exhaust for Savage with Picco .28
- Personal Rc Track
- Savage Flux pins
- Lrp .28 roto start back plate
- Any baja 5T/B owners out there who own savages?
- Savage XL LRP ZR.30 vs Mugen MBX5T Clocked Picco~Hillclimbing video!
- show your maximizer wheel /tire setups
- Best upgrades for a savage
- savage xl body
- How can I put a tiger drive on a savage with an ofna force .26?
- Savage X
- Mach .26 in savage xl 5.9?
- Finally have my truck rock solid.
- Lrp.30
- Which brand of bearing?
- BUTTON HEAD ?
- My Savage Flux takes to the sky! Then breaks.... *vid*
- SAVAGE XL CONVERSION FINISHED
- For the E-Savage crowd: cheap CVDs
- Savage Flux owners / soon to be owners ... the XL is commith!
- Axial 28 supercharged or turbo?
- HPI Savage 25 Tear Down and Rebuild Thread
- 2 new parts from HPI: HD Top Gear & Flux Motor Plate
- Monster Trucks
- New and Improved Super Heavy duity Ring and Pinion
- Finally got it all right........and then
- clutchbell and pipe question
- new engine over revs
- Glow plug for savage xl
- Savage 21 drop in engine
- HPI Savage XL Conversion Questions
- Is my engine Fried?
- picco and 3 speed box?
- Weird Steering Problem
- I thought I finally had my Savage running well but. . .
- Keep Breaking Diff With LRP28 X
- X Conversion to XL
- savage 4.6 motor backplate starting pin
- another picco prob
- Picco vs LRP 30 - Memorial Day fun!
- Savage x tunning problem
- Hot Clutch?
- Strange Day with the Savvy
- share your 1st experience with a nitro truck
- secrets on lrp z.28 spec 3 with pullstart?
- Carbon Fiber Savage Race Video
- better with 2 3S or 2 5S batteries?
- savage with wing
- HPI SAVAGE 5T!!!
- My Savage Broke... but my Mugen ran! video!
- jump bash and locked out....
- 4.6 running hot
- Budbud was right on.....
- thread jacked to drag racing sory earl
- short jump clip
- Steering Servo plastic arm XL, 25 ??
- inside the xl tranny?
- SH .28 VS STS 28 VS Hobao Mach 28
- steering servo saver
- Need Help with Steering Linkage on Savage 25
- reciever antenna
- Problems with my Savage X SS
- 17MM Hub Conversion with XL's (Narrow / standard width) HD Axles
- anyone from uk
- picco issues
- Savage Flux - Jumping & Backflips
- servo's glitching on my savage!
- Nova Rossi N528XR vs Picco 28 sleeve photos
- LRP 30/ Picco 28, what a week!
- Making the switch to the Flux
- Who has a Savage that looks like their 1:1 truck, SUV or car?
- Hpi 86972
- wobbley tire FOAM BLOWN
- Savage owners, lets see your tires!
- Aftermarket Radio Box?
- repair and upgrades...
- Savage Flux high speed runs and jumps! (vid)
- My Savage X SS
- sliping aluminum clutch shoes?
- Savage X Project (Finished!)
- savage xl pull start
- savage x axel question
