View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Throttle linkage ideas?
  2. PICCO P3.28 VS. LRP SPEC 3 .28
  3. How do you do a Mid tank Configuration?
  4. ever heard of "Bling" alum clutch?
  5. foam inserts???
  6. Best odd mods thread.
  7. New Savage!!!
  8. just received my axial .28!!! noticed something weird
  9. first track experience
  10. STS D30M [Short vids 1 NEW video]
  11. OFFICIAL SAVAGE X 4.6 FORUM
  12. 17mm hub conversion????
  13. Aluminum Tuned Pipe Stinger direction...
  14. Got drunk and e-bay got me......
  15. f4.6 vs k4.6
  16. HPI COMES THROUGH!!!!
  17. starting system
  18. Wheel balance?
  19. System recommendations
  20. have $500, which truck???
  21. ON ROAD SAVAGE
  22. new x 4.1 engine problems??
  23. Best tank for mid tank mod?
  24. Best Truggy Shocks???
  25. Concerns about my new Axial .28
  26. Anyone run dual exhaust?
  27. gear mesh
  28. rotostart necessary?
  29. HPI response time?
  30. bought myself an axial .28, what upgrades before i install it?
  31. cleaning sucks.. how do u clean urs??
  32. new savage 4.6 59mph ?
  33. tower terror
  34. Modded Nova n528
  35. Fuel tank without primer
  36. savage diff oil and shock oil
  37. i need some advice... savage or 1/5th?
  38. Bent wheel
  39. Anyone seen these CVD's?
  40. diff upgrade from HPI
  41. Why can't anyone drive a Savage?
  42. Starting Pin Spring
  43. savage racers?
  44. savage 21
  45. 3 speed info?
  46. Ofna .32 question?
  47. Any SUV bodies out there?
  48. Tire and rims
  49. worn engine??
  50. OS 30 TEMP - HELL
  51. calling all jumpers
  52. axial .28?
  53. blue thunder fuel
  54. 0 degrees or -2 degrees?
  55. "aftermath" of "funny video"
  56. BROKEN AXIAL .28
  57. Chronic TVP's and SomeGuy's Anodizing
  58. MY MTA4 MONSTER
  59. new savage onwer
  60. coolpower MV15 or fcp20 fuel to savage???
  61. Are piggyback shocks worth the $$$?
  62. What do you think of the Axial .32?
  63. engine / pipe question
  64. fuells ,fuells and fuells...
  65. What to buy for my savage?
  66. battery help please
  67. What part is it!!!!!
  68. axial 32
  69. thunder tiger MTA4 help please
  70. servo install
  71. Savage X 4.6 RTR just released in Japan
  72. This is Weird (Engine Issue)
  73. Started it up,need some quick help!
  74. tuning issues
  75. lst shocks
  76. Savage 25 release Date?
  77. i think the K4.6 produce more smoke than F4.1
  78. savage x hang time
  79. Diff oil
  80. rims that fit imex jumbo swamp dawg tires
  81. Just Bought A OS .12 CV-RX FOR MY SAVAGE !!!!!
  82. Picco .28 Problems??
  83. bizzaro savage .21
  84. What steering servo?
  85. need help!!!
  86. Any other way
  87. pull starter problem
  88. Couldnt Get Temps Up
  89. spur gear and clutch bell
  90. Wheels Spinning when Idling
  91. Savage X 4.6 RTR *NEW*
  92. what can i do ebay trouble
  93. Trasmisson problem savage x 4.1
  94. Bought the Savage!
  95. Savage X 4.6 vs Aftershock
  96. diff??? biggener
  97. Integy shocks sold in sets of 8 only?
  98. OFFICIAL TRACK THREAD!!!!!!!!
  99. so i went to my first jumping session today
  100. throttle spring needed?
  101. tuning sound vs temp
  102. how to seal sts 30
  103. New Bod from Proline...
  104. reverse mixer problem?????
  105. blue thunder?
  106. Common Problems with Savage
  107. engine washer?
  108. !!!Finally Got it!!!
  109. 4.6 motor help PLEASE
  110. Savage X Temperature ?
  111. savage is not starting
  112. savage 21 with 4.6 motor idling fault
  113. Diff ??
  114. which savage
  115. Germany Track
  116. IS it ok to do this...
  117. Will they fit?
  118. X RTR vs X SS
  119. Where can I get a Wheelie bar for Savage X???
  120. diff problems
  121. owb removal?
  122. break in question
  123. 2 speed adjustment
  124. Racing tires
  125. Chronic TVPs
  126. off -road track!!!!!!!!
  127. check out my close up pic
  128. Has any one order from this guy for rims
  129. Do i need a new turnbuckle?
  130. Keep Stripping out diffs....HELP!!!
  131. Savage rear tires not moving
  132. STS HELP!
  133. New X 4.6 RTR video
  134. Check out my pics
  135. Weight difference between LST2/aftershock and stock shocks.
  136. gearing
  137. what shocks ru runnin.
  138. Latest project Step by step pics (PICS)
  139. Ultimate Savage Engine??
  140. Check this out
  141. Help! NO ROLL?!
  142. A little help please.
  143. What weight shock oil r u running
  144. axles for savage help!
  145. Buying a used Savage
  146. FLY WHEEL AND CLUTCH SHOES HELP
  147. Wheelies using Tsais Dual Exhaust
  148. Shifts too early?
  149. Is Savage 4.6 RTR in stores?
  150. One last question!
  151. fuel
  152. Savage drive problem
  153. pictures
  154. Dammm have u seen this.....
  155. working on a Savage
  156. ??????????Gas tank???????????
  157. Savage X SS ?
  158. RADIO GEAR PROBLEM
  159. sts 28 troubles
  160. axial .32 comes tomorrow
  161. hpi rs4 3 evo v.s. traxxas 4 tech 3.3
  162. installed new clutch shoes and springs
  163. When do I trash the thermometer?
  164. hump pack charging
  165. camber question
  166. Savage Problem
  167. HOW DURABLE IS THE SAVAGE...REALLY
  168. axail .32
  169. Air bubbles in shocks?
  170. TSAIS Multi Position Shock Tower
  171. spur gear wobble?
  172. Savage X Vs Savage X 4.6
  173. pipes
  174. Glow Ignitor - Stupid Question
  175. X SS clutch problems
  176. neddle settings
  177. X SS Problem
  178. savage x or savage 25 or truckzilla .46
  179. axial 28
  180. Can u refubish engines????
  181. Savage
  182. Reverse and performance
  183. Axial .28 Carb question.
  184. Which is better
  185. Toyota Tacoma?
  186. will green axial .28 bolt right in savage x?
  187. I want to convert my electric monster truck to nitro!
  188. Savage Question
  189. Pipe Upgrade Question
  190. X SS worth it?
  191. New Axial body
  192. Alloy Dampers and the Savage X
  193. wich to chose
  194. manual
  195. Savage X SS questions
  196. 2 quick question?Also my shopping list!
  197. Engines for Savage X
  198. e savage motors
  199. a few questions...
  200. HPI Goliath tires
  201. New Savage X Problem: HELP!!
  202. Shreadded another tire! (PICS)
  203. does anyone have...
  204. Upgrading throttle/brake linkage
  205. e savage shells
  206. most top speed
  207. is it worth it
  208. Best suspension?
  209. Quickly please help!
  210. how many gallons of fuel you use per week?
  211. Lightning gt10 upgrade or downgrade?
  212. chassis brace???
  213. what will happen if i mix tranny fluid with nitro fuel
  214. axial .28 green or grey?
  215. no experience with savages, please help
  216. so i washed down my savage with a garden hose
  217. Savage X problem: HELP!
  218. I need to know???
  219. Savage X Diff Housing Conversion...What Parts?
  220. savage .25-x
  221. Axial 32 gearing
  222. quik questions please help
  223. rebuilding H.B. shocks
  224. reverse on a savage x
  225. What tire and rim combo?
  226. Camber and toe-in
  227. Rear Diff Locked
  228. savage axial .28
  229. Hot Bodies Lightning GT10 Videos
  230. Savage Clutch Bell bearing size??
  231. Savage X fuel mix ?
  232. Little help, please...
  233. savage ss mods
  234. dicide on t3h truckez
  235. servo
  236. Recharging receiver bat.
  237. Savage XSS questions
  238. Is it possible for a Sav to look TOO good???
  239. Savage x diff ?
  240. The reciever does not fit in reciever box!!
  241. Help me decide pls!!!
  242. Imperial LockPin?
  243. WHAT SHOULD I DO ?
  244. I'm "X"cited, Just got my chassis installed
  245. Transmission
  246. Tires return to left?
  247. SPUR GEAR HELP
  248. XTM 457 Pro Help
  249. Savage XSS Stalling issues
  250. Throttle/brake servo relocation
