PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Heads up for people with aluminum servo saver
  2. stripping screws into plastic
  3. The Savvys
  4. First race tonight!!!!! Batesville Indiana!!!!!
  5. supercharger
  6. 25 to x
  7. Melting your spur gear.
  8. CINCINNATI BASH! Speak up here
  9. 3 Speed for the X
  10. Savage Exhaust with LRP Z.28R Spec 3
  11. Wow what a pain ( Clutch Shoes / Springs )
  12. Rebuild Savage 25
  13. Is anyone running a Fioroni sliding clutch?
  14. Tires for the Savage... ofcourse :D
  15. diff oil
  16. Break in Future Problems..
  17. best savage clutch
  18. FLM rear bulk/diff case
  19. rotostart 2 battery....
  20. Favorite/best upgades for savage ss
  21. Just Bought The Savage XL Pics Inside
  22. Savage Clutch/Flywheel and Brakes
  23. LRP .28 Backplate Trouble
  24. SPAZ STIX CHROME
  25. Whats the difference?
  26. fuels
  27. LRP Break-In
  28. Terra Pins on dishes?
  29. New Engines Arrived
  30. High temps.....fuel??
  31. Not tracking straight?
  32. engine bogging
  33. Savage SS pushes hard and flips under hard braking?
  34. new savage xl video
  35. High revs after letting of gas.
  36. the barnfloor?
  37. new pipe for savage xl
  38. No second gear anymore!
  39. Best motor for savage
  40. Cliff Jumping?
  41. Savage TVP Question
  42. Where to purchase Savage
  43. HPI E-Savage vs. Traxxas E-Maxx
  44. Engine question.
  45. tanks per gallon?
  46. what breaks the most
  47. Ingegy spur gear does not work with savage
  48. hpi hellfire differentials
  49. Savage X SS engine upgrade
  50. having trouble starting axial .28
  51. Kevlar pull starter cord
  52. front end not spinning...
  53. LST Shocks on X-arm?
  54. Body and shoucks for savage
  55. Savage x ss + picco P3 .28 stage 2 = a force none to be reckon with!
  56. I Need Brakes Any Advice?
  57. Cleaning the Savage
  58. charts
  59. innovate rc shocks
  60. whats the best moter for my savage x
  61. From Traxxas To HPI That's what I'm doing
  62. Mmm.... 2 new engines!!!
  63. Savage exhaust
  64. 14.8v lipo E-Savage???
  65. Savage K5.9?
  66. hpi 4.6 in a Revo 3.3?
  67. high pitched whine on deceleration
  68. Throttle linkage on STS d30M broken?
  69. Would the 5.9xL motor drop straight into the old savagex4.6 model
  70. Header??
  71. Hot Bodies Lightning Stadium Pro
  72. receiver batteries?
  73. Starting in 2nd ?
  74. the new t-maxx 3.3 or savage 4.6?
  75. Problem with Savage X 4.6 Start Up...
  76. Savage racer
  77. Savage with Cen GST shocks
  78. LST2 shock upgrade and other stuff *pics*
  79. Savage - Engines for it.
  80. Spektrum low voltage cut off?
  81. Mamba Monster Max released
  82. Another STS 30 video featuring a Savage 25!
  83. Axial engine?
  84. Best Savage Upgrade Engine
  85. Savage Motors
  86. STS .30 vs Picco .28
  87. Monster Hhybrid Build!
  88. EZ Fit ( Cheap too ) Upper Arm
  89. What do i need? besides HELP?
  90. Savage X Motor Upgrade
  91. Savage 25 doing a short wheelie
  92. Cracked engine plate: vibration issues?
  93. XL Chassis Conversion
  94. HPI Fans, Stand Up & Represent
  95. First Savage XL Review!
  96. Got the LRP in.
  97. savy not getting to second gear at all!
  98. 3rd gear shift adjustment
  99. Hi torque servos on a budget??
  100. don't know what i did.
  101. savage xl finally arrived!
  102. LSN and Idle tunning
  103. Just ordered Savage XL Chassis Conversion. Anyone want Chronic TVPs?
  104. savvy 3 speed.
  105. Is this Orion V6 clutch fitted correctly, looks odd
  106. Nothing like............
  107. Transmission upgrade savage x
  108. Servo help
  109. should i wait
  110. Picco P3 what fuel 20% or 30%
  111. lightning gt10 questions
  112. f4.6 - k4.6
  113. Special Glow Plug for Picco P3-28??
  114. I think my brakes were shot!
  115. Savage 25 next engine
  116. What fuel for F4.6 break in
  117. Any Hot bodies GT10 Sport owners??
  118. 25 shock towers on x diffs?
  119. Piston Sleeve Pincher ??
  120. Savage Hump pack....?
  121. just bought a picco
  122. Toronto Savage Bash
  123. Got Wheelies?
  124. whats up guys
  125. Savage x shock placement?
  126. Savage 25 LE - New engine maby?
  127. Stronger or better bodies...?
  128. savage XL is OUT!!!!!!!!!!!!!
  129. Tuning question
  130. Brakes problem
  131. savage xl on the way !
  132. Stock x 4.6 Breaks keep fading....Need help getting a new one
  133. weired diff problem
  134. sts28 help!!!
  135. Super Brain 977
  136. Cen Genesis big bores on Savage
  137. hhhhhmmmmmmm
  138. This is why you don't buy all that aluminum junk!
  139. airfilter covers
  140. Comparing high torque servos.
  141. Losi huge shocks mod
  142. K4.6 Break-in
  143. Painted a new body
  144. eliminate the starting pin
  145. tunning
  146. starting pin / pressure spring install
  147. Savage OFNA tank mod?
  148. Rotostart 2 ?
  149. Your spur and bell recomendations
  150. one way bearing???
  151. just bought a savagex!
  152. Tuned pipes
  153. E-Savage or E-maxx
  154. Yet Another Savage Fuel Tank Mod ...
  155. What to do next
  156. Which radio
  157. 'Must have' upgrade for Savage
  158. Aluminum Clutch shoes & Vented/Hardened Clutch Bell
  159. 1 way bearing, again...
  160. Shock shaft material???
  161. Savage drive shafts.
  162. starting problem
  163. porting a savage 25 engine
  164. ACE outlaw pipe?
  165. What glow plug for F4.6 ?
  166. Finally sold it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  167. heavy duty rod for traxxax 2.5/3.3
  168. savage 3speed
  169. Dogbones?
  170. bead lock ???
  171. three speed transmission savage x
  172. Strange Request
  173. Custom TVP Time
  174. Hot Bodies brake install
  175. My custom Rx hump pack
  176. chrome rims
  177. dumb hump pack ?
  178. Got an Ofna .32 for my savage but...
  179. Savage kit vs RTR
  180. Savage tires. What does everyone use?
  181. mid-tank lean question...
  182. can i use these springs?
  183. My dad gave me a good deal
  184. X4.6 RTR Stock ( Just me or anyone too )
  185. Is it the fuel causing the savvy to hardly move?
  186. New Ramp....A little playing, and a couple vids
  187. wheel extensions
  188. New to Savages and have some ?
  189. Flat spots on driveshaft pin?
  190. Going to purchase LRP .28 engine
  191. sh 28 on my savage 25
  192. Just got a new Radio/Tranmitter =)
  193. Just sold the savy x?
  194. s-25 nitro star clutch
  195. Antenna probs
  196. savage lowering??
  197. Help with throttle servo!!
  198. X4.1 Engine Issue
  199. k4.6 HO
  200. AWESOME
  201. savage hop ups?
  202. rcx expo
  203. TVP's? Which ones?
  204. E-Hellfire?...and a question about normal Hellfire
  205. Orion CRF V6 clutch??
  206. dual brake???
  207. new parts!
  208. Half Tank Lean Problem
  209. Brake disc on Savage X 4.6...
  210. engine swap
  211. savage x?
  212. X SS Clutch Setup
  213. kitchener area racers
  214. Quick Question
  215. savvys
  216. Servo brand help please
  217. rotostart causing engine prob?
  218. Which shock towers to buy?
  219. X SS Radio Box Access
  220. Savage SS diff Re & Re
  221. Mugen Hex Hubs on Savage X SS
  222. engine temps way up
  223. Savage X for sale?
  224. uploading pics?
  225. hellfire vs savage
  226. savage xl?
  227. Building X SS brakes problem..
  228. To much power for the Spur?
  229. Pull Start in the Savage
  230. Crack Fuel Tank
  231. need help selecting dogbones
  232. engine keeps cutting out..
  233. steering servo
  234. Run times....
  235. Good Online Site or No
  236. Shocks Oils ?
  237. Savage clutch and Shoe shim questions
  238. Savage X and X SS dog bones
  239. OFFICIAL HPI SAVAGE XL 5.9 THREAD!
  240. gettin a savage x 4.6
  241. ??? about shock towers???
  242. savage x speed
  243. Metal Spur gear for savage..how many teeth
  244. After 2 hrs of bashing in the Desert ( was shootings some guns )
  245. Shock Idea (Coilover with Bypass)
  246. Savage wheelies And 3 speed Question.
  247. I had a wreck yesterday!
  248. new axial .28 question
  249. Ofna .32 in savage crankshaft too long!!
  250. How many of you would use a Savage based IRC chat?
