- HPI SAVAGE X CONVERSION 87250
- savage x or revo or warhead
- diff help
- superchargers on RC nitro, vid included
- used savage 21 with lots of extra parts?
- k4.6 clutch help
- Savage X Nightmare!!
- 1st Post - my Savage LE in Action
- suspension lift?
- Savage Half Tank Lean - HPI Says: No such thing!
- O.S. 30 temp
- one tire needed
- Spur gear problem/ question?
- Need to buy a clutch.Which 1?
- CHEAPEST NICEST ENGINE??
- How often do you pull your trucks down?
- Please help with Tires choice for Savage! (Mashers / Big joe.. whatr is good??)
- savage over mgt
- I need help which engine?? please
- Newbie here Kinda
- Tuned Pipe ??
- Nitro Star 2-25 Carb
- Savage / LST suspension Conversion
- Removing Superglue and Glueing Tires
- Jb weld???
- witch one???
- Engine pricing question
- On-line Shops
- Suspension arms on Sav X
- Steering play??
- Maximizer X-75 Problems.
- Maybe you can help
- best hd dog bones/cups set up?
- what did you spend to get your savage running?
- Reverse on Savage X4.1
- Roto Start Question?
- Twin .21 engine Savage SS
- Brushless Savage?
- Kawasaki quad body on Savage LE
- Savage X Prob - Brake and Throt horn slipping
- truck not starting!!!
- i know it's been asked a million times...
- How often do you change a glow plug?
- savaje x transmision woeks on savaje le?
- best savage for a nitro noob
- **WHICH ENGINE FOR A SAVAGE 25?**
- ******MACH 427?******
- Hellfire nose down in jumps
- How do you adjust the steering alignment?
- want to buy a savvy x are they really good?
- **Replacement Engine for savage?!**
- Vids from the net
- tunning Problems Savage 25
- I keep stripping the motor mount bolt holes
- **Savage X Question**
- Front wheel"s spin back dont...
- adjusting suspension
- what pullstart fits xtm 24.7
- Too lean?
- one way bearing
- First time poster, Savage X brakes? Their is none?
- too cold?
- Slipper clutch slips too much!
- Wheels Keep falling off!...?HELP?
- Hey, my new truck
- Why all the traxxas @#&% on this board??
- new engine in savage
- stock cb/shoes
- IF your to get a new truck...
- *Savage Exhaust????!!!!*
- Break in Help *This is bad*
- What Injuries has your savvy caused to you or others
- Need recommendations on a tuned pipe !
- *****Which Monster Truck????????*****
- ok .... whats happening here?
- new x?
- is this ok???
- Rush Evo RTR or SAVAGE
- Alum clutch???
- I'm out
- Newbi
- savage tranny help
- noob needs help !!!
- Best Transmitter
- What did you DO?
- What did you DO?
- GPM BI DIRECTIONAL POWER UP CLUTCH flywheel diameter
- answer me this will you please!!!
- no gear change on savage 25
- My Brother Asked Me A Good Question
- Started building my own mini track in the backyard *VIDEO*
- owb
- savage x or t-max 3.3???
- HPI 4.1 engine rebuild
- Hellfire
- how do i tune my transamittion?
- would you consider a FG Bigfoot 1/6 26cc?
- PICS! Titanium CVD's + brake hub?
- Noob Looking for some help I'm lost!
- pipe cone
- SAVAGE X or T-maxx 3.3?
- Need More Power Captain.
- Custom tvp's
- what shocks
- Savage X Brakes!!!
- New Savage X
- 21 and 25??
- glow plug
- Any magazines dedicated to MT's
- i need a new engine
- ??? for savage X guys
- O.S. .30 or Collari .32?
- crush into a car!! need new carb
- engine placement
- Savage X ?
- having trouble starting
- Thunder Tiger 28 Pro MGT 4.60 Engine Monster GT Savage
- PICS! Plastic diff stripped gears=1 reason
- SlapMaFro On line Store
- Collari .32 Instructions ??
- Ran my 4.6 for the first time
- Won't Stay Running
- plastic kit
- Pulling a scam to get new parts
- Bad crash leaves it not so smooth
- What is your temp failsafe set to on your F4.1 ?
- Whats the deal with the F4.1 stock exhast cone ? helps or hurts ?
- SAVAGE X front differential
- Bye guys
- savage pics
- Why is my 25 dieing??
- Savage25 drivetrain slipping?
- Slight engine bog
- White Lightening?
- is a roto start alot of money?
- Collari .32.....
- STS .28 or LRP .28 Vspec
- Venom Smart Temp Fail safe probs, have YOU?
- Do you guy know anything about these??
- 3RACING SHOCK OR HB PURPLE ALU. FOR EZILLA
- Look what i got
- tire glue or rubber cement?
- x gearbox
- Gearing for the surefire 32??
- cluch
- Send all videos of savage x!!
- 3 speed
- Rear Diff question
- Attn: People with the New Era tank mod.
- Which servo saver do you use?
- Installing 3 shoe clutch
- Is the savage x better then revo 3.3?
- 300 deg Celsius
- Savage X tires
- Nemesis Shocks on Savage?
- wich servo
- Holy crap, it's a NINJA TURTLE!
- hi how is the savage x truck like?
- air filter
- Broken pins F diff
- Going to Hong Kong....
- Stripped diffs?
- Savage x and 3speed change over help
- Which servo arm
- Some 3 sp. vs. 2 sp drag race input
- Savage X or SS 4.6?
- surefire .32
- No Movement W/ Throttle
- Stripping spur gears? Here's why!
- 125cc tank Need link plz
- RACE BETWEEN SAVAGE W? COLLARI 32 VS REVO 3.3???
- cluthc bell assembly
- just got hpi savage .25 <-- i think
- steel spur gear
- low-end
- What tyres do you run?
- is this a carb?*pic* have to clean the dirt how do i do it?
- Broken 49t spur NEED HELLP!!
- exhaust cone
- my gearing setting!
- 3 speed 2nd gear mod?
- better power plant
- 3 speed Tranny Questions
- Easy to make home-made wheelie bar
- Diff oil weight for bashing
- what should I do (Picco .28)
- Lowering CG
- Savage LE Shock Springs
- WE NEED STICKIES!
- Waterproofing???
- where to buy 25?
- How do you Clean your dirty Savvy?
- How do you start your savage?
- wider + longer
- 32 angine and 3 speed tranny
- Quick question
- Fuel Options
- chassis gremlins
- savage cvd's
- Looking for a monster truck
- help Im lost
- POST YOUR SAVAGE PICS!!!
- Price check on a savage 2.5
- SAVAGE X body pins
- repositioning componets
- SH.28 Pull Start prob. Please Help
- truckzilla runs fine when i first start
- savage x with surefire .32
- Sure fire starter plate
- break in pains
- What Geaing should I use on me SS
- HELP US HELP YOU!
- quik SPUR question.
- TT EB-4 to Truggy conversion
- Cracked!
- 110km Savage BONE STOCK
- which is your favorite savage modded or not
- how do you have your brake set up?
- help.....
- Reverse Module gear shaft breaking???
- servos
- HELP WITH SAVAGE!!!!!!
- cooling head
- 2 speed tranny problem
- SavageX F4.1 engine shims
- Pinch test
- Glow plug ???
- Diff shimming
- Savage X vs Losi LST2
- MOVED: Just a comment
- do u use the manual
- diff question
- Not the standard ofna throttle mod Question
- Turning Radius Savage X
- Whoo hooo
- MT2 18ss glow plugs
- wheelies??????
- Ribbed pipe or not ribbed?
- savage X engine poll
- Tuned Ribbed Pipe question
- cold air intake
- new motor for savage x??????
- howmany gallons
- Savage X 4.1 ??????
- whats a good engine
- What is the fastest savage?
- BONE DRY!
- HPI's Monster customer service!
- Who owns a regular Savage AND a Savage X??
- Aftermarket Options
