- Running temps for Savage X??
- Fuel for torque or horsepower
- spur ?
- FOUND A SAVAGE X CHASSIS FIX!! (maybe)
- HELP
- testing the paddle tires. video.
- hellfire
- spur gears stripping every 5 minutes????
- STS .28 Rotostart Backplate
- what is the best engine for a savage
- Mugen springs and shoes.
- os 30 roto start
- a guide on how to install ofna clutch shoes please...
- broken crankshaft
- changed my mind!
- Pics of one of my best trucks!!
- QUICK HELP ON SAVAGE!!!!
- spur gears ?????
- X Chassis
- new pics of the racer and basher
- Two is Better Than One..
- Turnbuckles kep poping off
- spur gear
- savage is making a weird noise!
- Clutch help needed
- Whats it worth?
- nova ajustable mount
- Dead Engine
- what to get?
- What's your dream MT track??
- 2 speed savage question
- savage x wont wheelie
- HAVING REVERSE TROUBLES
- savage x upgrades
- what fuel do you all use and why?..
- tasmanians
- new cooling head for sav "X"??
- LCG conversion question
- X SS DATE CHANGED!
- RPM Savage & Savage X Center Skid Plates
- Ordering tuned pipe tommorrow- Last minute questions!
- compare monster trucks
- video of my savage up and running..lol
- Savvy 25 FWD only, pls help
- Upgrading my savage...Finally!
- MGT tires wheels no good
- newb spur gear question(s)
- shock spring help
- torque ?
- Starting Check List
- "X" metall exhaust making engine hotter!!..
- My plan for strong diffs, this setup good?
- stoopid question
- how good are these roll cages
- Those Nova Clutch shoes everyone is raving about.
- DUAL .46 Savage
- Rotostart issue
- tuning problems
- orion v6 clutch problem
- Play time for HPI Savage X
- submarine savage
- engine question
- is the speed transmision worth it ?
- Engine Mount broke need a replacement
- i am buying the Savage X SS
- (SAVAGE X) VS (SAVAGE SS 4.6)
- install question
- Which tuned pipe for my X
- Saveage LE Rear Wheels Won't Drive
- Orion CRF V6 clutch
- Centre Gear Box Case
- Wanted: Broken One-ways
- Diff gear help????
- diff ring/pinion upgrade.
- Did I order the right plug?
- Savage X destroying spur gears left and right
- asking for help
- Can I use this?
- Locking Diffs?
- savage ss 4.6 diff
- will These rims work on a savage?
- surefire 32, where to buy???
- X upper hinge pins pooping out FIX.
- problem with X chasis due to crash
- Tower Hobbies delivery time..???
- Your first nitro
- Post and guess vintage RC
- New Servo or/and Hump pack??
- cat walkin with my new .28 its nice..lil problelem tho
- ???HAVE U NOTICED THIS???
- Great day in our yard for MT's!!!
- smoked slipper clutch???
- Savage 25 KFX700 edition..
- is my owb bad?
- Engine Tunning Troubles...
- Post your favorite Savage video..
- Stock servo problem
- Savage Engine Question
- button mod
- beadlock wheels
- X conversion?
- 2 questions (direrent from last time)
- Ways to get your old tires off?
- LRP 28 Spec 3
- Transmission grinding\clicking noise when braking...
- tree climbing savage
- thinking about getting nova clutch shoes, what springs?
- if you are to redesign the savage x... how would it be?
- Transmitting problem.... From Radio to Truck.. Help.
- Werks One-Piece Exhaust for Savage
- fantom pipe
- Savage with GT-2
- got a new radio, need a servo recommendation
- Bashin in alaska
- troble with brakes and 4x4
- savage x
- savage x
- pics of your savages
- Mix shock oil..???????
- Removing Motor Shims
- Tuning needles
- savage 21 wont run
- do i have an air leak?
- ive got a savage X.. ha ha, at last!!..wow!
- HPI Savage Low CG Racing Chassis Set
- great deal or what
- spur gear confusion
- Are bead lock rims that great ??
- NEW PIPE
- Help Me Choose a CB-SG Combo Plz
- any thoughts about the reverse on the x
- !!!!!!!!!!!!!!Savage X Shocks Question!!!!!!!!!!!!!!!
- Roto Start2 not gripping starter shaft??
- throttle problems!!!!
- just curious???
- hpi savage performance pipes
- Aluminum&steel spur?
- Aftermarket Brake/Throttle Linkage?
- Savage X wont stay on
- Tie Rods popping off
- Transmission Binding - Need Input Please
- More savage problems.
- Savage X linkage
- HELLFIRE Questions
- Gear box question.
- HOW TO PREVENT STRIPPED RIMS
- locking savs one way tranny?
- wont run
- savage chassie
- been running topless...
- HPI Savage .25 slipper clutch problem?
- Savage X need to be re-called
- savage battery
- any aussies
- Steel Spur Gear?
- Have you ever?
- HELP!! Brand new X won't start?
- Breaking in STS .28 - Can't Start - Factory Needle Settings??
- savage ss 4.6
- brake problem..
- STS .28, will it bolt in to my LE?
- Dual disc brakes DO NOT LAST!!!!
- Thinking of selling my savage
- low end
- 20 th gear
- need help
- info on the savage ss kit
- What's wrong with my brakes?
- couple help questions with our 4.6
- wheelie bar
- the best carb to replace???!!!
- OFNA Force 32
- Ugliest Body Ever??
- Savage X receiver glitch
- Is there an easier way to change the spur gear???
- 1 more question
- 2 questions
- anyone know how to talk to os?
- very quick radio question?
- Were can i find one?
- Upcoming "Savage X SS 4.6" - build and hop-up assistance please!
- engine quits
- need help with choosing new wheels n tires
- Any one in the Vancover area
- CEN Shocks on Savage
- You Will Not Believe What Happened! (Sav X) *Pics*
- how to make a racing savage
- My track
- winter savage
- K4.6 tuning
- Question about Temps..
- Clutch Helpppp
- STS .28 Leak Issues???
- Advice on mods for my X
- Anyone Confirm That This method works? (Tuning)
- Savage X Pipe IM GETING A NEW ONE HELP ME OUT HERE!!!!!!!
- hellfire ss
- Temperature Guage
- New or Used
- savage vs. mammouth
- Idle Adjustment
- 3-speed
- Planned Purchase
- engine
- Starting issue with the SS4.6
- savage x or t-maxx 3.3
- OS 30 upgrade!
- need help with savage x
- Savage X or alternative?
- ss 4.6 discontinued?? is it.
- savage .25
- Too cool Savage X temps?
- Outside Temperature
- F 250 CC body?
- one way bearing question
- So I Got The Savvy X (help needed)
- savage brake question?
- savage x and sure fire .32 cheap
- i think something is binding in my savage.
- after run oil
- problems with savage
- Lost my Antenna
- HPI Part 76924
- Trouble Changing Spur
- Engine screams
- Engine moves while braking
- best engine for 25
- screws
- Wheels falling off
- Not happy with the stock X radio
- New to me Savage....
- decals
- Buy new Savage X or upgrade savage 25 to best engine there is?
- help buying new chassis.....??
- Fuel Ecconomy
- savage x versus hellfire
- Savage X Hump pack
- HELP Dogbone keeps coming OUT!
- one way bearing ?
- setup question
- Help needed choosing engine
- New UK Web RC Forum
- my savage x wont keep running
- Savage X Missing Chassis/Bulkhead pins
- hop ups
- HELP WITH SPUR GEAR PLEASE!!!
- Brown Spots on Exhaust Header
- converting to 17mm
- gas savage
- savage X tranny question
