- WrenMW44i Manual
- Gas solenoid source
- Wren 54 AutoStart problem?
- Wren mw54 eco r Fadec pump not working.
- Wren Supersport problem
- Wren44G Data display unit.
- Wren Super Sport Kero Programming
- Wren 44 ECU paramters
- Wren 44 startup issue
- Wren 80DCI
- Wren 44 Gold bearing change
- WREN MW54 Manual Start - Manual request
- Wren 44 Heli V 50i heli engine diferences
- Wren 44 heli turbine
- Wren 44 ECU
- Gas start Wren 100 bearing size
- Help with Wren MW54
- Help with a Wren 44 Gold
- Wren turbine oil
- Prop for Wren 44 Turbo prop.
- Wren 44i Starter Motor Bracket
- Wren starter overload message
- Wren USA Turbine Forum Converted to Member Supported Forum
- How is Wren doing in 2017
- Starter slipping 100dci
- Wren SS/ Xicoy ECU
- Question about Wren 160
- Wren 54 parts
- how to start a gas start turbine (autostart) without solenoid valves
- Wren 44 priming of fuel lines
- Wren UK service
- Wren 54 mk4 flame outs
- Need a Wren turbinewheel and NGV.
- Wren going out of business (Bankrupcy)
- Wren 54MK3 Help please
- acceleration error
- Wren MK3 ECU upgrade
- Need SS manual
- New (used) Wren 54 MkIII Owner
- Wrens Awesome Service!!
- start up not good
- What batteries??
- Solenoid test
- So in this forum nobody uses Wren?
- wren 44 silver case LONG LAG TIME
- "W44G" powered foamy
- Wren 160 failures
- wren xl200 just short on full rpm
- blown xicoy ,help
- How to visually tell the difference from the Wren 54s from the Super sport
- Wren turbines usa have a new website
- mw54 mk3 start time
- Modernizing a Wren 54 Mk2?
- Wren 44 Gold hot start
- WREN 44 gold Kero FADEC replacement
- Diesel Fuel
- supersport spool-up problem
- Wren 75 videos ( now jubilee )
- Older Wren 54 kit turbine still runs GREAT
- Wren Turbines starter motor service and replacement
- Wren Tutorial Videos
- Wren USA Open House
- Wren 44 10th anniversary
- Please delete.. Double post... Sorry :)
- Wren 44 gold on diesel.
- Xicoy ECU and DX10 setup problems
- WREN JUBILEE
- Mw 44 unburnt fuel
- 44 fuel pump change.
- Wren 44 Man Start
- Xicoy ECU on Wren 44 which PC Software ?
- WREN 54 3D Modelling
- Wren Jubilee now available!!
- Wren SS / 100 PIPE
- Super sport No hand over of control
- Super Sport does not start
- S/Sport
- Wren 44 gold
- looking for a wern 44 for a 90mm Jet
- Which way up???
- Wren 54mkII
- Looking for help in building a Wren 54 MK II
- upgrade/replace
- Is something new coming from Wren
- 54 Mark II stopping abruptly
- Wren MW54 refurbishment & balancing
- xicoy ecu
- Wren 54 mk3 bad start
- Correct solenoid connection for Xicoy ECU
- ProJet ECU setup using JR 12X
- MTH pumps (modell technik hauls)
- Kero start question
- Proper Pro Jet solenoid connection for KeroStart
- Wren USA attending Kentucky Jets 2012
- Mounting the 44 gold
- Starter installation on Wren motors
- Proper solenoid plug location for Xicoy ECU
- Test menu?
- Wren 44 gold ECU settings.
- Spring 2012 Wren Open Day
- Early Wren 44 EGT
- Wren 44 gold dies on idle after I fly
- NEW EMAIL FOR WREN USA
- search for a used wren 44
- WREN USA OPEN DAY 2011
- Wren 44 Gold Adj Flow Control Setting
- W44 Flightworks 100-c pump?
- Wren 100 malfunctioning
- Wren SS starting issues please help!!!
- 44 Problem???
- Need SuperSport parameters
- early 44 Gold can thrust increase to 10 lbs?
- 54 FADEC Q
- Wren 100
- 44 gold start problem
- Turbine powered foamy
- wanted Wren 44
- Kero start now available on all Wren motors
- Diesel Usage
- Wren44 question
- Wren 44
- Airframe optins for a Wren 44 gold?
- WANTED Wren44
- parameters for a wren mkII
- 54 markII erratic rpm reading
- Wren 44 Gold
- wren 54 ECU
- New Wren website now online
- wren 54 idle help
- wren 54 ecu meanungs
- Wren 75 info/news
- WREN 54 SS HELP
- Wren 160, Projet ECU and 3S A123 battery
- Bench Testing Controller
- Speed Low error message
- Contact info...website update
- Ron....
- PROJET ECU CODES
- ecopy of Super Sport manual
- Wren 160PRO Shutoff Solenoid
- 44 green plug setting?
- Saber 100 AMSoil
- 44 wont start
- Wren 44 gold will not ignite
- Wren 160 K Pro
- Flame outs on Wren 54 mk3
- Gaspar ECU failsafe
- First runs on 160
- Wren 44Gold idle problems
- High EGT Wren 54
- Wren 44 acceleration problem.
- Wren Power!!
- SS tempature sensor position?
- Wren 54 catastrophic failure
- A123 w FADEC
- Wren 54 Mk2 idle problem
- Wren 200 XL
- looking for cheap replacment bearings
- Running a MW-54 after storage
- Wren 54 Mk4 - throwing flames
- New Power PLug
- shaft movement
- Wren44 Turboprop Bearing Failure
- Wren Super Sport oil to use??
- fuel types
- wren 54 fadec parameters
- Supersport and MOBIL DTE Light ?
- Wren Manual Start Settup on DX7
- Supersport fuel pump
- replacement fuel mainfold
- Exhaust pipe orientation
- MW54 ?
- Pump Start Point Wren 44
- which oil ?
- wren shakeup
- Wren 44 TP Exhaust
- Wren 44 Autostart
- Wren 54 Mk2 problem
- 160 FADEC Hook-up
- Wren 160 PRO fuel consumption
- early 44 gold flame out
- WREN54 MANUAL START HELP
- Wren 44 Manual Start
- Recommended Oil Types
- Turbine oil question
- Wren 44 Fuel Pump Not Engaging
- Wren 44 blocked fuel jets
- Problem with priming
- Wren 120 kit?
- Congrats to Wren!
- Kero start
- Welcome Wren Turbines USA
